  3. Einsteigerfragen
  4. Problem: "Error: libnode.so.72" mit Folgen
    5.6k
28 Beiträge 2 Kommentatoren 2.9k Aufrufe 2 Beobachtet
    @benemuc
    Was sagt
    sudo apt update
    sudo apt full-upgrade
    Und warum stehst du überhaupt in / herum? Hat dein pi kein zuhause?
    cd ~
    BeneMUC
    schrieb am zuletzt editiert von BeneMUC
    @thomas-braun said in Problem: "Error: libnode.so.72" mit Folgen:
    Was sagt
    sudo apt update sudo apt full-upgrade
    pi@raspberrypi:/ $ sudo apt update
    Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:1 http://security.debian.org/debian-security bullseye-security InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
    Err:2 http://deb.debian.org/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
    Hit:6 https://deb.nodesource.com/node_10.x bullseye InRelease
    Err:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:4 http://deb.debian.org/debian bullseye-backports InRelease
    Reading package lists... Done
    W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
    E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
    E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
    W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
    E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
    W: GPG error: http://deb.debian.org/debian bullseye-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
    E: The repository 'http://deb.debian.org/debian bullseye-backports InRelease' is not signed.
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      gyp libc-ares2 libfuse2 libjs-highlight.js libjs-inherits libjs-is-typedarray
      libjs-psl libjs-typedarray-to-buffer libssl-dev libuv1-dev node-chownr
      node-color-name node-err-code node-extsprintf node-fast-deep-equal node-indent-string
      node-ini node-is-typedarray node-json-parse-better-errors node-json-schema
      node-json-schema-traverse node-qs node-resolve-from node-through
      node-typedarray-to-buffer node-uuid
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Werde die fehlenden Keys dann mal in den apt key manager einfügen.
    da bin ich jetzt überfragt^^ was ist denn hier das Stichwort mit dem ich dazu googeln kann? #noop
    • B BeneMUC
      Was sagt
      @benemuc sagte in Problem: "Error: libnode.so.72" mit Folgen:
      node-
      Neben den fehlenden keys...
      (Wie hast du die Kiste von wo aus upgegraded???)
      sudo apt remove node-*
      sudo apt update
      sudo apt autoremove
        node-
        sudo apt update
        sudo apt autoremove
        BeneMUC
        Nach dem Fixen der Keys lasse ich jetzt sudo apt update und sudo apt full-upgrade durchlaufen. Schaut soweit gut aus aber dauert natürlich ein Weilchen.
        Kann ich dir leider nicht genau sagen. Hab die Kiste vor ca. 1,5 Jahren nach irgendeiner Anleitung aufgesetzt und mich seither nicht um System-Updates gekümmert. Gestern dann eben entsprechend deinem Werkzeugkasten versucht alles auf den neuesten Stand zu bringen.
          BeneMUC
          aktueller Stand sieht jetzt so aus:
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && o $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
          armv7l
          Kein Docker
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.0
          v16.18.0
          8.19.2
          4.0.21
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
          Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
          All packages are up to date.
          nodejs:
            Installed: 16.18.0-deb-1nodesource1
            Candidate: 16.18.0-deb-1nodesource1
            Version table:
           *** 16.18.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
               12.22.12~dfsg-1~deb11u1 500
                  500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main armhf Packages
               10.24.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_10.x bullseye/main armhf Packages
          Um node- muss ich mich morgen kümmern - langsam fehlt die Konzentrtion ;) Vielen Dank aber schonmal für Deine Hilfe bis hierher! :)
          • B BeneMUC
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.18.0
            v16.18.0
            8.19.2
            4.0.21
            pi
            tty
            /home/pi
            nodejs:
              Version table:
            @benemuc
            Ja, das schaut doch schon wesentlich anders aus. :-)
              BeneMUC
              Eine Woche später...
              Da ich den libnode.so.72 Fehler trotz aller Maßnahmen nicht beseitigt bekommen habe, hab ich zwischenzeitlich den Raspberry komplett neu aufgesetzt (raspbian, nodejs, iobroker + Backup eingespielt).
              Ergebnis ist, dass der libnode.so.72 Fehler zwar weg ist aber der Zigbee Adapter immer noch nicht wieder startet.
              admin@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
              uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
              aarch64
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.1
              v16.18.1
              8.19.2
              4.0.23
              admin
              admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              tty
              /home/admin
              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
              Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
              nodejs:
                Installed: 16.18.1-deb-1nodesource1
                Candidate: 16.18.1-deb-1nodesource1
                Version table:
               *** 16.18.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              Fehlerlog:
              2022-11-08 18:19:44.554  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2022-11-08 18:19:44.724  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12720
              2022-11-08 18:19:49.143  - info: zigbee.0 (12720) starting. Version 1.7.6 (non-npm: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
              2022-11-08 18:19:49.271  - info: zigbee.0 (12720) delete old Backup files. keep only last 10
              2022-11-08 18:19:49.274  - info: zigbee.0 (12720) Starting Zigbee  npm ...
              2022-11-08 18:19:49.960  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
              2022-11-08 18:20:03.854  - error: javascript.0 (10979) Error in callback: TypeError: Cannot read properties of undefined (reading 'pmap_id')
              2022-11-08 18:20:03.854  - error: javascript.0 (10979)     at aktualisiere_datenpunkte (script.js.common.iRobot-Control:184:105)
              2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.<anonymous> (script.js.common.iRobot-Control:45:13)
              2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
              2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
              2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
              2022-11-08 18:20:03.857  - error: javascript.0 (10979)     at processImmediate (node:internal/timers:466:21)
              2022-11-08 18:20:10.091  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              2022-11-08 18:20:10.129  - error: zigbee.0 (12720) Failed to start Zigbee
              2022-11-08 18:20:10.130  - error: zigbee.0 (12720) Error herdsman start
              2022-11-08 18:20:20.136  - info: zigbee.0 (12720) Try to reconnect. 1 attempts left
              2022-11-08 18:20:20.138  - info: zigbee.0 (12720) Starting Zigbee  npm ...
              2022-11-08 18:20:20.171  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
              2022-11-08 18:20:20.469  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2022-11-08 18:20:20.470  - error: zigbee.0 (12720) Failed to start Zigbee
              2022-11-08 18:20:20.471  - error: zigbee.0 (12720) Error herdsman start
              Leider fange ich mit den Fehler nicht viel an - sieht für mich sehr generisch aus.
              • B BeneMUC
                aarch64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.18.1
                v16.18.1
                8.19.2
                4.0.23
                admin
                tty
                /home/admin
                nodejs:
                  Version table:
                Fehlerlog:
                @benemuc
                Warum eine Version aus dem github?
                  @benemuc
                  BeneMUC
                  Ehrlich gesagt keine Ahnung - ich hab einfach mit
                  curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                  sudo apt install nodejs
                  installiert.
                  Woran siehst du, dass eine github Version installiert ist?
                  • B BeneMUC
                    installiert.
                    @benemuc
                    Ich meinte den zigbee-Adapter:
                    Die Meldung
                    hat im übrigen oftmals mit der Firmware des Sticks zu tun. Was ist da installiert?
                      @benemuc
                      Die Meldung
                      BeneMUC
                      Ach so, ich hatte den Adapter zunächst ganz normal über den iobroker installiert. Das selbe Problem bestand damit aber auch und ich hab auf der Suche nach einer Lösung irgendwo im Forum gelesen, dass man versuchen kann, den Adapter über die Katze aus git hub zu installieren. Am Fehlerbild hat das aber nichts geändert.
                      Hab den Stick auf die Conbee Version von hier vom 15 Mai 2022 aktualisiert. Geholfen hat es nicht.
                      Dann habe ich einen neuen Conbee II Stick gekauft und angesteckt (Pfad im Adapter natürlich geändert) - hat am Fehler aber leider auch nichts geändert.
                      • B BeneMUC
                        @benemuc
                        Wie sehen die Einstellungen im zigbee-Adapter aus?
                        • B BeneMUC
                          Ich hätte ehrlich gesagt andere Hardware gekauft.
                            @benemuc
                            BeneMUC
                            • B BeneMUC
                              @benemuc
                              Den Typ musst du auf 'Deconz/Conbee' einstellen.
                                @benemuc
                                BeneMUC
                                jaa mega, die Einstellung hat noch gefehlt - hab ich nach der Neuinstallation scheinbar nicht mehr angepasst. Jetzt funktioniert der Adapter endlich wieder :)
                                Herzlichen Dank dir! ^^
