  4. Alexa Update nicht möglich.
    5.7k
46 Beiträge 4 Kommentatoren 4.5k Aufrufe 3 Beobachtet
    @ostseereiter
    Versuch das Ding mal zu löschen:
    rm -rf /opt/iobroker/node_modules/iobroker.amazon-dash/
    ostseereiterO Offline
    ostseereiter
    @thomas-braun sagte in Alexa Update nicht möglich.:
    und weg ist er das ging fix und nun nochmal update versuchen?
    Gruß OSR
    Plattform
    • ostseereiterO ostseereiter
      @ostseereiter
      iobroker update
      iobroker upgrade
      versuchen.
      ostseereiterO 1 Antwort Letzte Antwort
        @ostseereiter
        iobroker update
        iobroker upgrade
        versuchen.
        ostseereiter
        schrieb am zuletzt editiert von ostseereiter
        immer noch nicht
        andy@debian:/opt/iobroker$ iobroker upgrade
        This upgrade of "alexa2" will introduce the following changes:
        -> 3.20.1:
        make sure caching works correctly with multiple instances of the adapter
        -> 3.20.0:
        Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
        Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
        -> 3.19.10:
        Fix issue in retry handling when rate limit exceeded is returned by Amazon
        Do not clean up Smart Home Device objects for now - delete manually if you remove a device
        Would you like to upgrade alexa2 from @3.19.9 to @3.20.1 now? [(y)es, (n)o]: y
        Update alexa2 from @3.19.9 to @3.20.1
        NPM version: 8.19.2
        Installing iobroker.alexa2@3.20.1... (System call)
        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
        This upgrade of "admin" will introduce the following changes:
        -> 6.2.23:
        Prepare for future js-controller versions
        Corrected deletion of objects
        Would you like to upgrade admin from @6.2.22 to @6.2.23 now? [(y)es, (n)o]: y
        Update admin from @6.2.22 to @6.2.23
        host.debian Adapter "system.adapter.admin.2" is stopped.
        NPM version: 8.19.2
        Installing iobroker.admin@6.2.23... (System call)
        upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.debian Adapter "system.adapter.admin.2" is started
        andy@debian:/opt/iobroker$ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
        Adapter    "alarm"        : 3.1.1    , installed 3.1.1
        Adapter    "alexa2"       : 3.20.1   , installed 3.19.9 [Updatable]
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backit
        Gruß OSR
        Plattform
          immer noch nicht
          -> 3.20.1:
          -> 3.20.0:
          -> 3.19.10:
          NPM version: 8.19.2
          -> 6.2.23:
          NPM version: 8.19.2
          Adapter    "backit
          @ostseereiter
          iobroker upgrade admin --debug
            @ostseereiter
            ostseereiter
            andy@debian:~$ iobroker upgrade admin --debug
            -> 6.2.23:
            NPM version: 8.19.2
            npm WARN old lockfile
            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
            npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm WARN tarball tarball data for iobroker.amazon-dash@https://github.com/PArns/ioBroker.amazon-dash/tarball/master (sha512-H9kEjSW6LgD7eFO/ELMc8KmX155JdpsxQ9TDIuiFjnT3yficwUp7pXOnWpls7z6Q4aVFVibymBbk4n/OoSetbg==) seems to be corrupted. Trying again.
            npm ERR! code EINTEGRITY
            npm ERR! sha512-H9kEjSW6LgD7eFO/ELMc8KmX155JdpsxQ9TDIuiFjnT3yficwUp7pXOnWpls7z6Q4aVFVibymBbk4n/OoSetbg== integrity checksum failed when using sha512: wanted sha512-H9kEjSW6LgD7eFO/ELMc8KmX155JdpsxQ9TDIuiFjnT3yficwUp7pXOnWpls7z6Q4aVFVibymBbk4n/OoSetbg== but got sha512-JLpCxPcPnRtjVqY1Hpf88o+ioXG771H8i3IPLyaTaNRY2zD1QTUVE/dHFdbZRye9pLG28wAMXlsGtV2glj3DGg==. (73039 bytes)
            npm ERR!     /home/iobroker/.npm/_logs/2022-11-02T17_19_06_266Z-debug-0.log
            Gruß OSR
            Plattform
              -> 6.2.23:
              NPM version: 8.19.2
              @ostseereiter
              Keine Ahnung warum
              a) package-lock.json nicht angepasst wird und
              b) der amazon-dash-Kram mit der falschen Prüfsumme nicht aus dem Cache geht.
                @ostseereiter
                Keine Ahnung warum
                ostseereiter
                schitt, dann bleibt wohl nur noch ne Neuinstallation das muss ich dann wenn ich wieder mehr Luft habe mal ransetzten so bringt es ja nix
                Danke.
                Gruß OSR
                Plattform
                • ostseereiterO Offline
                  ostseereiter
                  Ich habe ja noch den baugleichen Client als Ersatz zu liegen dort kann ich doch erst mal Debian und Iobroker installieren und dann die Festplatte in den Client der jetzt läuft einbauen wegen der IP Das müsste doch klappen? Dann Backup einspielen und gut ist es dann.
                  Gruß OSR
                  Gruß OSR
                  Plattform
                    @ostseereiter sagte in Alexa Update nicht möglich.:
                    iobroker.amazon-dash liegt da noch quer.
                    Installier den mal neu.
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    kannst eigentlich löschen - funktioniert nicht mehr, es sei denn, du hast noch dash laufen - bei mir sind alle batterien leer und damit unbrauchbar
                      Gruß OSR
                      @ostseereiter
                      Wenn die MAC-Adressen die IP vom DHCP-Server bestimmt dann ja.
                      Wenn da mit 'statischen IP' herumhantiert wurde dann nicht (so ohne weiteres).
                        @ostseereiter
                        ostseereiter
                        Ja werden von der Fritzbox vergeben. bei der MAC-Adresse das ist doch Hardware spezifisch. Das könnte ein Problem werden.
                        Gruß OSR
                        Plattform
                          @ostseereiter
                          Dann kannst du das einfach hin- und her tragen.
