  4. ERROR: Process exited with code 1 / keine Updates mehr
    5.7k
errorkein updateprocess exited with code 1
24 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • DJMarc75D DJMarc75
    @symsen zeig mal bitte
    iob list adapters
    symsen
    @djmarc75 sagte in ERROR: Process exited with code 1 / keine Updates mehr:
    iob list adapters
    maik@iobroker:~$ iob list adapters
    /opt/iobroker/node_modules/ansi-styles/index.js:162
            get: assembleS4yles
    ReferenceError: assembleS4yles is not defined
        at Object.<anonymous> (/opt/iobroker/node_modules/ansi-styles/index.js:162:7)
        at Module._compile (internal/modules/cjs/loader.js:1085:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        at Module.load (internal/modules/cjs/loader.js:950:32)
        at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        at Module.require (internal/modules/cjs/loader.js:974:19)
        at require (internal/modules/cjs/helpers.js:101:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/wrap-ansi/index.js:4:20)
    maik@iobroker:~$
    • S symsen
      iob list adapters
              get: assembleS4yles
      maik@iobroker:~$
      @symsen sagte in ERROR: Process exited with code 1 / keine Updates mehr:
      ansi-styles
      Das ist eigentlich kein core Modul.
      cd /opt/iobroker
      npm ls ansi-styles
      HomoranH S 2 Antworten Letzte Antwort
        ansi-styles
        cd /opt/iobroker
        npm ls ansi-styles
        @thomas-braun filesystem schrott?
          Schwer zu sagen.
          @symsen
          dmesg -T | grep -i ext4
          sagt?
            ansi-styles
            cd /opt/iobroker
            npm ls ansi-styles
            symsen
            @thomas-braun sagte in ERROR: Process exited with code 1 / keine Updates mehr:
            ansi-styles
            cd /opt/iobroker
            npm ls ansi-styles
            Last login: Tue Nov  1 17:54:43 2022 from 192.168.178.159
            maik@iobroker:~$ cd '/home/maik'
            maik@iobroker:~$ cd /opt/iobroker
            maik@iobroker:/opt/iobroker$ npm ls ansi-styles
            [sudo] Passwort für maik:
            iobroker.inst@3.0.0 /opt/iobroker
            ├─┬ iobroker.js-controller@4.0.23
            │ └─┬ yargs@17.4.1
            │   └─┬ cliui@7.0.4
            │     └─┬ wrap-ansi@7.0.0
            │       └── ansi-styles@4.3.0  deduped
            ├─┬ iobroker.tuya@3.6.15
            │ └─┬ qrcode@1.5.0
            │   └─┬ yargs@15.4.1
            │     └─┬ cliui@6.0.0
            │       └─┬ wrap-ansi@6.2.0
            ├─┬ iobroker.vis-icontwo@0.89.0
            │ └─┬ np@7.5.0
            │   ├─┬ chalk@4.1.2
            │   │ └── ansi-styles@4.3.0
            │   ├─┬ cosmiconfig@7.0.1
            │   │ └─┬ parse-json@5.2.0
            │   │   └─┬ @babel/code-frame@7.15.8
            │   │     └─┬ @babel/highlight@7.14.5
            │   │       └─┬ chalk@2.4.2
            │   │         └── ansi-styles@3.2.1
            │   ├─┬ listr@0.14.3
            │   │ ├─┬ listr-update-renderer@0.5.0
            │   │ │ └─┬ chalk@1.1.3
            │   │ │   └── ansi-styles@2.2.1
            │   │ └─┬ listr-verbose-renderer@0.5.0
            │   │   └─┬ chalk@2.4.2
            │   └─┬ listr-input@0.2.1
            │     └─┬ inquirer-autosubmit-prompt@0.2.0
            │       └─┬ chalk@2.4.2
            └─┬ iobroker.web-speedy@0.2.0 (github:iobroker-community-adapters/ioBroker.web-speedy#d2485e1ba9bdc21d89802a4329bc1caeb9baa456)
              └─┬ speedtest-net@1.6.2
                └─┬ chalk@2.4.2
              Schwer zu sagen.
              @symsen
              sagt?
              symsen
              Schwer zu sagen.
              @symsen
              sagt?
              Last login: Tue Nov  1 17:56:45 2022 from 192.168.178.159
              cd '/home/maik'
              maik@iobroker:~$ dmesg -T | grep -i ext4
              dmesg: read kernel buffer failed: Die Operation ist nicht erlaubt
              maik@iobroker:~$
              • S symsen
                Schwer zu sagen.
                @symsen
                sagt?
                cd '/home/maik'
                maik@iobroker:~$
                @symsen
                Okay, dann mit sudo
                sudo dmesg -T | grep -i ext4
                Oder ist das wieder so'n Container-Gesumsel?
                  @symsen
                  Okay, dann mit sudo
                  symsen
                  schrieb am zuletzt editiert von symsen
                  @symsen
                  Okay, dann mit sudo
                  Last login: Tue Nov  1 18:00:14 2022 from 192.168.178.159
                  cd '/home/maik'
                  maik@iobroker:~$ sudo dmesg -T | grep -i ext4
                  [Mo Okt 31 10:13:31 2022] EXT4-fs (sda1): mounted filesystem with ordered datamode. Opts: (null)
                  [Mo Okt 31 10:13:32 2022] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                  maik@iobroker:~$
                  Der ioBroker läuft auf einer VM.
                  • S symsen
                    @symsen
                    Okay, dann mit sudo
                    cd '/home/maik'
                    maik@iobroker:~$
                    @symsen
                    iob stop
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iob start
                      @symsen
                      iob stop
                      cd /opt/iobroker
                      iob start
                      symsen
                      @symsen
                      iob stop
                      cd /opt/iobroker
                      iob start
                      Last login: Tue Nov  1 18:17:40 2022 from 192.168.178.159
                      cd '/home/maik'
                      maik@iobroker:~$ iob stop
                      maik@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                      Das hat nicht funktioniert, bitte nochmal probieren.
                      > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                      > node lib/preinstallCheck.js
                      NPM version: 6.14.17
                      > unix-dgram@2.0.6 install /opt/iobroker/node_modules/unix-dgram
                      > node-gyp rebuild
                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                      In file included from ../node_modules/nan/nan.h:60,
                                       from ../src/unix_dgram.cc:5:
                      /home/iobroker/.cache/node-gyp/14.20.1/include/node/node.h:793:7: warning: cast between incompatible functiontypes from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                        793 |       (node::addon_register_func) (regfunc),                          \
                      /home/iobroker/.cache/node-gyp/14.20.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                        404 | NODE_MODULE(unix_dgram, Initialize)
                        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                        COPY Release/unix_dgram.node
                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                      > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
                      > node iobroker.js setup first
                              get: assembleS4yles
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      npm WARN http-cookie-agent@1.0.6 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
                      npm ERR!     /home/iobroker/.npm/_logs/2022-11-01T17_18_56_246Z-debug.log
                      maik@iobroker:/opt/iobroker$ iob start
                      Jetzt kann ich den ioBroker nicht mehr über die Webseite erreichen.
                      • S symsen
                        @symsen
                        iob stop
                        cd /opt/iobroker
                        iob start
                        cd '/home/maik'
                        > node-gyp rebuild
                                get: assembleS4yles
                        npm ERR! errno 1
                        npm ERR!
                        @symsen
                        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        iobroker list instances
                          @symsen
                          symsen
                          @symsen
                          Last login: Tue Nov  1 18:30:31 2022 from 192.168.178.159
                          cd '/home/maik'
                          maik@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                          maik@iobroker:~$
                          maik@iobroker:~$ iobroker list instances
                          internal/modules/cjs/loader.js:905
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                              at internal/main/run_main_module.js:17:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          maik@iobroker:~$
                          • S symsen
                            @symsen
                            cd '/home/maik'
                            maik@iobroker:~$
                              throw err;
                              requireStack: []
                            maik@iobroker:~$
                            @symsen
                            Den Rest auch noch.
                            • S symsen
                              @symsen
                              cd '/home/maik'
                              maik@iobroker:~$
                                throw err;
                                requireStack: []
                              maik@iobroker:~$
                              Das interssanteste fehlt:
                                symsen
                                Last login: Tue Nov  1 18:40:17 2022 from 192.168.178.159
                                cd '/home/maik'
                                maik@iobroker:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker&& echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm&& nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                x86_64
                                Kein Docker
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.20.1
                                v14.20.1
                                6.14.17
                                  throw err;
                                  requireStack: []
                                maik@iobroker:~$
                                  symsen
                                  So, ich habe nun neu installiert und das Backup eingespielt, es funktioniert wieder.
