  4. Alexa2 Adapter kann nicht mehr installiert werden
36 Beiträge 7 Kommentatoren 3.5k Aufrufe 7 Beobachtet
  • C Offline
    ChrisBGL
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4b
    js-controller: 4.0.23
    Nodejs-Version: 16.18.0
    NPM-Version: 8.19.2
    ich habe den Alexa2 Adapter deinstalliert und wollte ihn nun wieder reinstallieren.
    Dabei erhalte ich folgende Fehler:
    $ iobroker add alexa2 auto --host raspberrypi --debug
    NPM version: 8.19.2
    Installing iobroker.alexa2@3.19.10... (System call)
    npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient...npm WARN old lockfile
    npm ERR! code ETARGET
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-10-27T13_41_08_110Z-debug-0.log
    host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 1
    ERROR: Process exited with code 25
    Die relevante Stelle im Log ist wohl die hier:
    2134 timing command:install Completed in 59527ms
    2135 verbose type version
    2136 verbose stack @sentry/utils: No matching version found for @sentry/utils@7.17.0.
    2136 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:209:23)
    2136 verbose stack     at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:125:22)
    2137 verbose cwd /opt/iobroker
    2138 verbose Linux 5.10.103-v7l+
    2139 verbose node v16.18.0
    2140 verbose npm  v8.19.2
    2141 error code ETARGET
    2142 error notarget No matching version found for @sentry/utils@7.17.0.
    2143 error notarget In most cases you or one of your dependencies are requesting
    2143 error notarget a package version that doesn't exist.
    2144 verbose exit 1
    2145 timing npm Completed in 59863ms
    2146 verbose unfinished npm timer reify 1666878068440
    2147 verbose unfinished npm timer reify:loadTrees 1666878068480
    2148 verbose code 1
    2149 error A complete log of this run can be found in:
    2149 error     /home/iobroker/.npm/_logs/2022-10-27T13_41_08_110Z-debug-0.log
    Kann mir bitte jemand helfen das Problem zu lösen?
    ? 2 Antworten Letzte Antwort
    • C ChrisBGL
      NPM-Version: 8.19.2
      NPM version: 8.19.2
      2144 verbose exit 1
      2148 verbose code 1
      @chrisbgl da bist du nicht der einzigste, ist hier und bei anderen auch so. Warten, bis ein update fuers Update kommt, liegt wohl an einer fehlerhaften depency for Sentry, wenn ich das Fehlerlog richtig verstehe...
        HomoranH Offline
        HomoranH Offline
        https://forum.iobroker.net/post/880621
        • C ChrisBGL
          NPM-Version: 8.19.2
          NPM version: 8.19.2
          2144 verbose exit 1
          2148 verbose code 1
          @chrisbgl jetzt gehts, der Bug bei Sentry ist gefixt. Also nochmal probieren.. hier liefs jetzt durch
          C 1 Antwort Letzte Antwort
            ChrisBGL
            schrieb am zuletzt editiert von ChrisBGL
            @ilovegym Prima, bei mir auch. Danke für den Hinweis. War dann wohl schlechtes Timing von mir.
            Muss ich hierzu irgendwas machen?
            Hatte in meiner Verzweiflung auf Nodejs 16 geupdated.
            ? Thomas BraunT 2 Antworten Letzte Antwort
            • C ChrisBGL
              @chrisbgl
              Dann schau mal, ob du Node richtig geupdated hast, hier wird dir geholfen:
              https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
              • C ChrisBGL
                @chrisbgl sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                Die Meldung dürfte mit dem Switch auf npm@8 (kommt mit nodejs@16 daher) zusammenhängen. Schau mal ob das Ganze 'senkrecht' installiert ist:
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  @chrisbgl
                  ChrisBGL
                  @ilovegym Ja, nach dieser Anleitung hatte ich es gemacht.
                  MyzerATM 1 Antwort Letzte Antwort
                  • C ChrisBGL
                    MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    woher kommt das update, katze, aber was npm oder github ?
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                    • MyzerATM MyzerAT
                      @myzerat
                      Die 3.19.10 kommt ganz regulär aus deinem Repo, nix 'Katze'.
                        @myzerat
                        MyzerATM Offline
                        MyzerATM Offline
                        MyzerAT
                        @thomas-braun sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                        @myzerat
                        also als update angezeigt, wenn es sowiet ist und freigegeben , thx
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • MyzerATM MyzerAT
                          @myzerat
                          @myzerat sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                          iobroker update
                          iobroker upgrade
                            iobroker update
                            iobroker upgrade
                            MyzerATM Offline
                            MyzerATM Offline
                            MyzerAT
                            iobroker update
                            iobroker upgrade
                            ist das nicht wo man vorher "iobroker stop" machen muss ?
                            lg Rudi
                            Node 22.23.0
                            Nodejs 22.23.0
                            npm 10.9.8
                            js-controller 7.2.2
                            • Thomas BraunT Online
                              @myzerat
                              Nein.
                                @myzerat
                                Nein.
                                MyzerATM Offline
                                MyzerATM Offline
                                MyzerAT
                                ok, ich warte aber bis es offiziell verkündet wird, von @apollon77 das alles wieder passt!
                                lg Rudi
                                Node 22.23.0
                                Nodejs 22.23.0
                                npm 10.9.8
                                js-controller 7.2.2
                                • MyzerATM MyzerAT
                                  @myzerat
                                  https://forum.iobroker.net/topic/59390/alexa-2-nutzer-der-3-19-x-bitte-auf-3-19-10-updaten
                                  • apollon77A Offline
                                    Laut User-berichten geht es wieder ...
                                    • apollon77A apollon77
                                      MyzerATM Offline
                                      MyzerATM Offline
                                      MyzerAT
                                      @apollon77
                                      für die dummen unter uns, gibt eine anleitung, bitte , danke
                                      lg Rudi
                                      Node 22.23.0
                                      Nodejs 22.23.0
                                      npm 10.9.8
                                      js-controller 7.2.2
                                      • MyzerATM MyzerAT
                                        @apollon77
                                        @myzerat Wie meinen? Einfach Update auf die 3.19.10 nochmal versuchen wenn es vorher heute nicht geklappt hat. Wer die 3.19.10 drauf hat sollte alles passen
                                          MyzerATM Offline
                                          MyzerATM Offline
                                          MyzerAT
                                          @apollon77
                                          genau das ist ja mein problem, über die katze ? npm oder github
                                          lg Rudi
                                          Node 22.23.0
                                          Nodejs 22.23.0
                                          npm 10.9.8
                                          js-controller 7.2.2
                                          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
