  4. Probleme mit Updates
29 Beiträge 5 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • S Steinmetz_4
    @mickym sagte in Probleme mit Updates:
    @steinmetz_4 Ich hab Dir mein Vorgehen noch verlinkt. Mach halt ein Backup deines systems vorher.
    pi@iobroker-pi:~ $ iob stop
    pi@iobroker-pi:~ $ cd /opt/iobroker
    pi@iobroker-pi:/opt/iobroker $ sudo rm -rf node_modules
    pi@iobroker-pi:/opt/iobroker $ sudo rm package-lock.json
    pi@iobroker-pi:/opt/iobroker $ npm cache clean --force
    npm WARN using --force Recommended protections disabled.
    pi@iobroker-pi:/opt/iobroker $ npm install
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    added 2246 packages in 6m
    194 packages are looking for funding
      run `npm fund` for details
    pi@iobroker-pi:/opt/iobroker $ npm list
    iobroker.inst@3.0.0 /opt/iobroker
    ├── @types/caseless@0.12.2 extraneous
    ├── @types/request@2.48.8 extraneous
    ├── @types/tough-cookie@4.0.2 extraneous
    ├── coffeescript@1.12.7 extraneous
    ├── iobroker.admin@6.2.23
    ├── iobroker.alexa2@3.19.9
    ├── iobroker.backitup@2.4.12
    ├── iobroker.chromecast@2.3.1
    ├── iobroker.cloud@4.2.2
    ├── iobroker.coronavirus-statistics@0.8.7
    ├── iobroker.daswetter@3.1.3
    ├── iobroker.discovery@3.1.0
    ├── iobroker.ds18b20@1.6.0
    ├── iobroker.dwd@2.8.3
    ├── iobroker.epson_ecotank_et_2750@0.0.12
    ├── iobroker.feiertage@1.1.0
    ├── iobroker.flot@1.11.0
    ├── iobroker.fritzdect@2.2.3
    ├── iobroker.history@2.2.0
    ├── iobroker.homeconnect@1.1.0
    ├── iobroker.hs100@2.1.2
    ├── iobroker.ical@1.13.1
    ├── iobroker.icons-addictive-flavour-png@0.1.0
    ├── iobroker.icons-material-png@0.1.0
    ├── iobroker.icons-material-svg@0.1.0
    ├── iobroker.icons-mfd-png@1.1.0
    ├── iobroker.icons-mfd-svg@1.1.0
    ├── iobroker.icons-open-icon-library-png@0.1.2
    ├── iobroker.icons-ultimate-png@1.0.1
    ├── iobroker.influxdb@3.1.8
    ├── iobroker.info@1.9.19
    ├── iobroker.iot@1.11.9
    ├── iobroker.jarvis@3.0.15
    ├── iobroker.javascript@6.0.3
    ├── iobroker.js-controller@4.0.23
    ├── iobroker.knx@2.0.13
    ├── iobroker.lgtv@1.1.10
    ├── iobroker.meross@1.14.0
    ├── iobroker.mihome-vacuum@3.4.2
    ├── iobroker.net-tools@0.2.0
    ├── iobroker.node-red@3.3.1
    ├── iobroker.ping@1.5.3
    ├── iobroker.pollenflug@1.0.6
    ├── iobroker.rpi2@1.3.2
    ├── iobroker.scenes@2.3.9
    ├── iobroker.shelly@6.0.0
    ├── iobroker.simple-api@2.7.0
    ├── iobroker.sonnen@1.11.0
    ├── iobroker.sonoff@2.5.1
    ├── iobroker.sourceanalytix@0.4.12-1
    ├── iobroker.sql@2.1.8
    ├── iobroker.tankerkoenig@2.1.1
    ├── iobroker.telegram@1.14.1
    ├── iobroker.tr-064@4.2.16
    ├── iobroker.trashschedule@2.0.3
    ├── iobroker.vis-google-fonts@1.0.3
    ├── iobroker.vis-hqwidgets@1.3.0
    ├── iobroker.vis-icontwo@0.89.0
    ├── iobroker.vis-inventwo@3.3.3
    ├── iobroker.vis-jqui-mfd@1.0.12
    ├── iobroker.vis-justgage@1.0.2
    ├── iobroker.vis-materialdesign@0.5.9
    ├── iobroker.vis-plumb@1.0.2
    ├── iobroker.vis-timeandweather@1.2.2
    ├── iobroker.vis@1.4.15
    ├── iobroker.weatherunderground@3.4.2
    ├── iobroker.web@4.3.0
    ├── iobroker.whatsapp-cmb@0.2.2
    ├── iobroker.worx@1.7.0
    ├── iobroker.zwave2@3.0.3
    ├── node-inspect@2.0.0 extraneous
    ├── suncalc2@1.8.1 extraneous
    ├── typescript@4.7.4 extraneous
    ├── virtual-tsc@0.6.2 extraneous
    └── wake_on_lan@1.0.0 extraneous
    Hab ich gemacht. 'Soll ich npm prune auch machen?
    HomoranH Offline
    HomoranH Offline
    @steinmetz_4 mixst du gerade beide Anleitungen?
    die verfolgen unterschiedliche Ansätze!
    entweder - oder! nicht beides!
      @steinmetz_4
      iobroker upgrade admin --debug
      Steinmetz_4
      pi@iobroker-pi:~ $ iobroker upgrade jarvis --debug
      Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      Would you like to upgrade jarvis from @3.0.14 to @3.0.15 now? [(y)es, (n)o]: y
      Update jarvis from @3.0.14 to @3.0.15
      NPM version: 8.19.2
      Installing iobroker.jarvis@3.0.15... (System call)
      added 56 packages, removed 16 packages, and changed 74 packages in 22s
      188 packages are looking for funding
      upload [153] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon-120x120.png apple-touch-icon-120x120.png image/png
      upload [150] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon-iphone-retina.png.png apple-touch-icon-iphone-retina.png.png image/png
      upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/favicon.ico icons/favicon.ico image/vnd.microsoft.icon
      upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-20~ipad.png icons/ios/AppIcon-20~ipad.png image/png
      upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-60@2x~car.png icons/ios/AppIcon-60@2x~car.png image/png
      upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/web/favicon.ico icons/web/favicon.ico image/vnd.microsoft.icon
      upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_12.436b3798.png img/moon_12.436b3798.png image/png
      upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_21.f3b5ba0a.png img/moon_21.f3b5ba0a.png image/png
      upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_4.61c6ba58.png img/moon_4.61c6ba58.png image/png
      upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_13.a630a54d.png img/weather_set5_13.a630a54d.png image/png
      upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_5.5334b7ac.png img/weather_set5_5.5334b7ac.png image/png
      upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_6.1435f645.png img/weather_set5_6.1435f645.png image/png
      upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_7.439d10db.png img/weather_set5_7.439d10db.png image/png
      upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_8.9011b110.png img/weather_set5_8.9011b110.png image/png
      upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_9.9dc0f52e.png img/weather_set5_9.9dc0f52e.png image/png
      upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/index.html index.html text/html
      upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/1.e516e81e.js js/1.e516e81e.js application/javascript
      upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/10.de09a5cd.js js/10.de09a5cd.js application/javascript
      upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/11.b003d093.js js/11.b003d093.js application/javascript
      upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/3.4a8ae51d.js js/3.4a8ae51d.js application/javascript
      upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/4.9a563abe.js js/4.9a563abe.js application/javascript
      upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/5.9ba66b59.js js/5.9ba66b59.js application/javascript
      upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/6.020de47f.js js/6.020de47f.js application/javascript
      upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/7.89eaea6c.js js/7.89eaea6c.js application/javascript
      upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/8.cb657ea9.js js/8.cb657ea9.js application/javascript
      upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/9.e9a6eb5e.js js/9.e9a6eb5e.js application/javascript
      upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.5d534061.js js/app.5d534061.js application/javascript
      upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.hash.json js/app.hash.json application/json
      upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.licences.json js/app.licences.json application/json
      upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/vendor.3ed67ef3.js js/vendor.3ed67ef3.js application/javascript
      upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/socket.io-2.3.1.slim.js socket.io-2.3.1.slim.js application/javascript
      upload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.css admin.css text/css
      upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.js admin.js application/javascript
      upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index_m.html index_m.html text/html
      upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
      upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
      upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/zefau.jpg zefau.jpg image/jpeg
      Raspi 4 mit aktuellem IoBroker Master (The Brain)
      Raspi 4 mit aktuellem IoBroker Slave und DS18b20 für Warmwasser und Pufferspeicher
      Raspi 4 mit aktuellem Motioneye
      3 x Heizstab zur PV-Eigenverbrauchsoptimierung
      ETS 5 Professionel - 5.7.5
      Samsung Tab 2 - 10.1
      Buskomponenten von MDT
      • S Steinmetz_4
        NPM version: 8.19.2
        HomoranH Offline
        HomoranH Offline
        @steinmetz_4 da ist kein error25
        und ACHTUNG!!
        @homoran sagte in Probleme mit Updates:
          Steinmetz_4
          Nein! Ich mische nichts durcheinander.
          • S Steinmetz_4
            @steinmetz_4
            Von
            war aber nicht die Rede. Jedenfalls nicht von mir.
              @steinmetz_4
              Von
              HomoranH Offline
              HomoranH Offline
              @thomas-braun sagte in Probleme mit Updates:
              das war der alternative Vorschlag von @mickym, den @Steinmetz_4 leider hier untergemischt hat
                Steinmetz_4
                Ja, ich kann mich düster erinnern, dass das ganze begann mit einem Update von Nodered. Darum habe ich den Vorschlag von Mickym ausprobiert.
                Ich habe nun den Worx Adapter über die Adminoberfläche upgedatet und es hat funktioniert.
                Ich Danke euch für eure Hilfe!!! Ohne eure Tips, wäre das nie wieder was geworden.
                Tolles Forum, tolle Leute...
                Mfg
                Tom
                • S Steinmetz_4
                  Mfg
                  Tom
                  HomoranH Offline
                  HomoranH Offline
                  @steinmetz_4 aber du hast jetzt immer noch diese mir absolut unbekannte Meldung zu dem Updateintervall drin, und wahrscheinlich jetzt einen ziemlich undefinierten Zustand durch die Vermengung der beiden Anleitungen.
                    Steinmetz_4
                    schrieb am zuletzt editiert von Steinmetz_4
                    Ich habe glaube ich nichts vermengt.
                    Ich habe wie Thomas schrieb, nur einen Adapter mit --debug upgegraded.
                    Was kann ich tun, um sicher zu gehen dass alles wieder passt?
                    pi@iobroker-pi:/opt/iobroker $  which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.1
                    v16.17.1
                    8.19.2
                    nodejs:
                      Installed: 16.17.1-deb-1nodesource1
                      Candidate: 16.18.0-deb-1nodesource1
                      Version table:
                         16.18.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                     *** 16.17.1-deb-1nodesource1 100
                         12.22.12~dfsg-1~deb11u1 500
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                         12.22.5~dfsg-2~11u1 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    Ist das in Zeile 9 und 10 so in ordnung?
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      Ich seh da auch kein Problem. Da das komplette node_modules neu aufgebaut wurde, sollten eigentlich sowieso die aktuellsten Version drin sein und ist auch kein Mischmasch - da ja gar nichts altes mehr vorhanden war.
                      • S Steinmetz_4
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.1
                        v16.17.1
                        8.19.2
                        nodejs:
                          Version table:
                        @steinmetz_4
                        Nein. Updates sind dazu da installiert zu werden.
                        iob stop
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                        Und lass künftig die Finger von manuellen Updates von npm.
                          @steinmetz_4
                          iob stop
                          sudo apt update
                          sudo reboot
                          Steinmetz_4
                          Wird umgehend erledigt...
                          Mir ist noch das aufgefallen, könnte da ein Fehler sein?
                          pi@iobroker-pi:~ $ npm list
                          /home/pi
                          ├── @iobroker/adapter-core@2.6.0 extraneous
                          ├── @types/iobroker@4.0.2 extraneous
                          ├── @types/node@17.0.26 extraneous
                          └── iobroker.simple-api@2.6.5 extraneous
                          • S Steinmetz_4
                            /home/pi
                            @steinmetz_4 sagte in Probleme mit Updates:
                            Ja, im /home/pi hat das nix zu suchen. Da haste mal direkt irgendwas per npm installiert und 'daneben geworfen'.
                              Steinmetz_4
                              kann ich das los werden, oder soll ich es ignorieren?
                              • S Steinmetz_4
                                mickymM Offline
                                mickymM Offline
                                mickym
                                lösch halt das node_modules Verzeichnis im home Verzeichnis des pi - und gut ist.
                                • mickymM mickym
                                  Steinmetz_4
                                  @mickym 👍
