  4. EspHome: fatal error: ESPAsyncWebServer.h
    5.7k
31 Beiträge 6 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • draexlerD draexler
    @draexler Hab den Adapter jetzt mal deinstalliert und jetzt krieg ich den nicht mehr installiert....
    $ iobroker add esphome --host SmartHomePi
    NPM version: 8.19.2Installing iobroker.esphome@0.2.4... (System call)
    host.SmartHomePi Cannot install iobroker.esphome@0.2.4: 126
    ERROR: Process exited with code 25
    Das habe ich jetzt schon ausgeführt in " /opt/iobroker/node_modules" Aber keine Verbesserung.
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    Was mache ich jetzt?
    @draexler sagte in EspHome: fatal error: ESPAsyncWebServer.h:
    Mit --debug-Option installieren:
    iobroker add esphome --host SmartHomePi --debug
    • draexlerD Offline
      draexlerD Offline
      draexler
      @thomas-braun sagte in EspHome: fatal error: ESPAsyncWebServer.h:
      pi@SmartHomePi:~ $ iobroker add esphome --host SmartHomePi --debug
      NPM version: 8.19.2
      npm ERR! code 126
      npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
      npm ERR! command failed
      npm ERR! command sh -c -- npip install
      npm ERR! sh: 1: npip: Permission denied
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-19T21_35_48_951Z-debug-0.log
      Und im Log:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@8.19.2
      2 info using node@v16.18.0
      3 timing npm:load:whichnode Completed in 1ms
      4 timing config:load:defaults Completed in 10ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 3ms
      7 timing config:load:cli Completed in 6ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
      10 timing config:load:project Completed in 5ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 2ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 0ms
      16 timing config:load:credentials Completed in 3ms
      17 timing config:load:setEnvs Completed in 3ms
      18 timing config:load Completed in 36ms
      19 timing npm:load:configload Completed in 37ms
      20 timing npm:load:mkdirpcache Completed in 2ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install iobroker.esphome@0.2.4
      23 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
      24 timing npm:load:setTitle Completed in 4ms
      25 timing config:load:flatten Completed in 9ms
      26 timing npm:load:display Completed in 11ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-10-19T21_35_48_951Z-debug-0.log
      29 timing npm:load:logFile Completed in 15ms
      30 timing npm:load:timers Completed in 1ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 73ms
      33 timing arborist:ctor Completed in 2ms
      34 silly logfile start cleaning logs, removing 2 files
      35 silly logfile done cleaning log files
      36 timing idealTree:init Completed in 3429ms
      37 timing idealTree:userRequests Completed in 37ms
      38 silly idealTree buildDeps
      39 silly fetch manifest iobroker.esphome@0.2.4
      40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 4029ms (cache revalidated)
      42 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
      43 silly fetch manifest @sentry/node@^5.30.0
      44 silly fetch manifest esphome-native-api@^1.0.9
      45 silly fetch manifest nopy@^0.2.7
      46 silly fetch manifest tree-kill@^1.2.2
      47 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 157ms (cache revalidated)
      48 http fetch GET 200 https://registry.npmjs.org/tree-kill 272ms (cache revalidated)
      49 http fetch GET 200 https://registry.npmjs.org/nopy 334ms (cache revalidated)
      50 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 889ms (cache revalidated)
      51 timing idealTree:#root Completed in 4969ms
      52 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
      53 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
      54 silly placeDep ROOT nopy@0.2.8 OK for: iobroker.esphome@0.2.4 want: ^0.2.7
      55 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
      56 silly fetch manifest @sentry/core@5.30.0
      57 silly fetch manifest @sentry/hub@5.30.0
      58 silly fetch manifest @sentry/tracing@5.30.0
      59 silly fetch manifest @sentry/types@5.30.0
      60 silly fetch manifest @sentry/utils@5.30.0
      61 silly fetch manifest cookie@^0.4.1
      62 silly fetch manifest eslint@^7.13.0
      63 silly fetch manifest events@^3.2.0
      64 silly fetch manifest google-protobuf@^3.14.0
      65 silly fetch manifest net@^1.0.2
      66 http fetch GET 200 https://registry.npmjs.org/google-protobuf 120ms (cache revalidated)
      67 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 167ms (cache revalidated)
      68 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 188ms (cache revalidated)
      69 http fetch GET 200 https://registry.npmjs.org/events 229ms (cache revalidated)
      70 http fetch GET 200 https://registry.npmjs.org/cookie 238ms (cache revalidated)
      71 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftracing 253ms (cache revalidated)
      72 http fetch GET 200 https://registry.npmjs.org/net 269ms (cache revalidated)
      73 http fetch GET 200 https://registry.npmjs.org/eslint 285ms (cache revalidated)
      74 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 361ms (cache revalidated)
      75 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 428ms (cache revalidated)
      76 timing idealTree:node_modules/iobroker.esphome Completed in 493ms
      77 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
      78 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
      79 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
      80 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
      81 silly fetch manifest @babel/code-frame@7.12.11
      82 silly fetch manifest @eslint/eslintrc@^0.4.3
      83 silly fetch manifest @humanwhocodes/config-array@^0.5.0
      84 silly fetch manifest debug@^4.0.1
      85 silly fetch manifest doctrine@^3.0.0
      86 silly fetch manifest enquirer@^2.3.5
      87 silly fetch manifest eslint-scope@^5.1.1
      88 silly fetch manifest eslint-utils@^2.1.0
      89 silly fetch manifest eslint-visitor-keys@^2.0.0
      90 silly fetch manifest espree@^7.3.1
      91 silly fetch manifest esquery@^1.4.0
      92 silly fetch manifest file-entry-cache@^6.0.1
      93 silly fetch manifest functional-red-black-tree@^1.0.1
      94 silly fetch manifest globals@^13.6.0
      95 silly fetch manifest ignore@^4.0.6
      96 silly fetch manifest import-fresh@^3.0.0
      97 silly fetch manifest imurmurhash@^0.1.4
      98 silly fetch manifest js-yaml@^3.13.1
      99 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
      100 silly fetch manifest levn@^0.4.1
      101 silly fetch manifest lodash.merge@^4.6.2
      102 silly fetch manifest natural-compare@^1.4.0
      103 silly fetch manifest optionator@^0.9.1
      104 silly fetch manifest progress@^2.0.0
      105 silly fetch manifest regexpp@^3.1.0
      106 silly fetch manifest strip-ansi@^6.0.0
      107 silly fetch manifest strip-json-comments@^3.1.0
      108 silly fetch manifest table@^6.0.9
      109 silly fetch manifest text-table@^0.2.0
      110 silly fetch manifest v8-compile-cache@^2.0.3
      111 http fetch GET 200 https://registry.npmjs.org/enquirer 445ms (cache revalidated)
      112 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 456ms (cache revalidated)
      113 http fetch GET 200 https://registry.npmjs.org/doctrine 455ms (cache revalidated)
      114 http fetch GET 200 https://registry.npmjs.org/eslint-scope 453ms (cache revalidated)
      115 http fetch GET 200 https://registry.npmjs.org/eslint-utils 453ms (cache revalidated)
      116 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 444ms (cache revalidated)
      117 http fetch GET 200 https://registry.npmjs.org/debug 468ms (cache revalidated)
      118 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 459ms (cache revalidated)
      119 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 493ms (cache revalidated)
      120 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 513ms (cache revalidated)
      121 http fetch GET 200 https://registry.npmjs.org/ignore 502ms (cache revalidated)
      122 http fetch GET 200 https://registry.npmjs.org/lodash.merge 504ms (cache revalidated)
      123 http fetch GET 200 https://registry.npmjs.org/imurmurhash 519ms (cache revalidated)
      124 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 516ms (cache revalidated)
      125 http fetch GET 200 https://registry.npmjs.org/levn 514ms (cache revalidated)
      126 http fetch GET 200 https://registry.npmjs.org/natural-compare 529ms (cache revalidated)
      127 http fetch GET 200 https://registry.npmjs.org/optionator 528ms (cache revalidated)
      128 http fetch GET 200 https://registry.npmjs.org/regexpp 526ms (cache revalidated)
      129 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 525ms (cache revalidated)
      130 http fetch GET 200 https://registry.npmjs.org/strip-ansi 534ms (cache revalidated)
      131 http fetch GET 200 https://registry.npmjs.org/progress 564ms (cache revalidated)
      132 http fetch GET 200 https://registry.npmjs.org/table 557ms (cache revalidated)
      133 http fetch GET 200 https://registry.npmjs.org/text-table 561ms (cache revalidated)
      134 http fetch GET 200 https://registry.npmjs.org/espree 636ms (cache revalidated)
      135 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 571ms (cache revalidated)
      136 http fetch GET 200 https://registry.npmjs.org/js-yaml 604ms (cache revalidated)
      137 http fetch GET 200 https://registry.npmjs.org/esquery 649ms (cache revalidated)
      138 http fetch GET 200 https://registry.npmjs.org/globals 643ms (cache revalidated)
      139 http fetch GET 200 https://registry.npmjs.org/import-fresh 640ms (cache revalidated)
      140 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 651ms (cache revalidated)
      141 timing idealTree:node_modules/esphome-native-api Completed in 718ms
      142 silly placeDep ROOT @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
      143 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
      144 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
      145 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
      146 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
      147 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
      148 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
      149 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
      150 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
      151 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
      152 silly placeDep ROOT esquery@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
      153 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
      154 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
      155 silly placeDep ROOT globals@13.17.0 OK for: eslint@7.32.0 want: ^13.6.0
      156 silly placeDep ROOT ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
      157 silly placeDep ROOT import-fresh@3.3.0 OK for: eslint@7.32.0 want: ^3.0.0
      158 silly placeDep ROOT imurmurhash@0.1.4 OK for: eslint@7.32.0 want: ^0.1.4
      159 silly placeDep node_modules/eslint js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
      160 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
      161 silly placeDep node_modules/eslint levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
      162 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
      163 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
      164 silly placeDep node_modules/eslint optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
      165 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
      166 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
      167 silly placeDep node_modules/eslint strip-ansi@6.0.1 OK for: eslint@7.32.0 want: ^6.0.0
      168 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
      169 silly placeDep ROOT table@6.8.0 OK for: eslint@7.32.0 want: ^6.0.9
      170 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
      171 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
      172 silly fetch manifest @babel/highlight@^7.10.4
      173 silly fetch manifest debug@^4.1.1
      174 silly fetch manifest strip-json-comments@^3.1.1
      175 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
      176 silly fetch manifest ms@2.1.2
      177 silly fetch manifest esrecurse@^4.3.0
      178 silly fetch manifest estraverse@^4.1.1
      179 silly fetch manifest eslint-visitor-keys@^1.1.0
      180 silly fetch manifest acorn@^7.4.0
      181 silly fetch manifest acorn-jsx@^5.3.1
      182 silly fetch manifest eslint-visitor-keys@^1.3.0
      183 silly fetch manifest flat-cache@^3.0.4
      184 silly fetch manifest type-fest@^0.20.2
      185 silly fetch manifest parent-module@^1.0.0
      186 silly fetch manifest resolve-from@^4.0.0
      187 silly fetch manifest argparse@^1.0.7
      188 silly fetch manifest prelude-ls@^1.2.1
      189 silly fetch manifest type-check@~0.4.0
      190 silly fetch manifest type-check@^0.4.0
      191 silly fetch manifest ansi-regex@^5.0.1
      192 silly fetch manifest ajv@^8.0.1
      193 silly fetch manifest lodash.truncate@^4.4.2
      194 silly fetch manifest slice-ansi@^4.0.0
      195 silly fetch manifest string-width@^4.2.3
      196 silly fetch manifest strip-ansi@^6.0.1
      197 http fetch GET 200 https://registry.npmjs.org/ms 256ms (cache revalidated)
      198 http fetch GET 200 https://registry.npmjs.org/esrecurse 255ms (cache revalidated)
      199 http fetch GET 200 https://registry.npmjs.org/estraverse 262ms (cache revalidated)
      200 http fetch GET 200 https://registry.npmjs.org/argparse 243ms (cache revalidated)
      201 http fetch GET 200 https://registry.npmjs.org/type-check 241ms (cache revalidated)
      202 http fetch GET 200 https://registry.npmjs.org/type-check 240ms (cache revalidated)
      203 http fetch GET 200 https://registry.npmjs.org/prelude-ls 246ms (cache revalidated)
      204 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 280ms (cache revalidated)
      205 http fetch GET 200 https://registry.npmjs.org/ansi-regex 244ms (cache revalidated)
      206 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 272ms (cache revalidated)
      207 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 244ms (cache revalidated)
      208 http fetch GET 200 https://registry.npmjs.org/slice-ansi 244ms (cache revalidated)
      209 http fetch GET 200 https://registry.npmjs.org/string-width 255ms (cache revalidated)
      210 http fetch GET 200 https://registry.npmjs.org/ajv 276ms (cache revalidated)
      211 http fetch GET 200 https://registry.npmjs.org/parent-module 324ms (cache revalidated)
      212 http fetch GET 200 https://registry.npmjs.org/type-fest 332ms (cache revalidated)
      213 http fetch GET 200 https://registry.npmjs.org/acorn 351ms (cache revalidated)
      214 http fetch GET 200 https://registry.npmjs.org/resolve-from 343ms (cache revalidated)
      215 http fetch GET 200 https://registry.npmjs.org/@babel%2fhighlight 376ms (cache revalidated)
      216 http fetch GET 200 https://registry.npmjs.org/flat-cache 825ms (cache revalidated)
      217 timing idealTree:node_modules/eslint Completed in 1030ms
      218 silly placeDep ROOT @babel/highlight@7.18.6 OK for: @babel/code-frame@7.12.11 want: ^7.10.4
      219 silly fetch manifest @babel/helper-validator-identifier@^7.18.6
      220 silly fetch manifest chalk@^2.0.0
      221 silly fetch manifest js-tokens@^4.0.0
      222 http fetch GET 200 https://registry.npmjs.org/chalk 76ms (cache revalidated)
      223 http fetch GET 200 https://registry.npmjs.org/js-tokens 83ms (cache revalidated)
      224 http fetch GET 200 https://registry.npmjs.org/@babel%2fhelper-validator-identifier 99ms (cache revalidated)
      225 timing idealTree:node_modules/@babel/code-frame Completed in 115ms
      226 silly placeDep ROOT @babel/helper-validator-identifier@7.19.1 OK for: @babel/highlight@7.18.6 want: ^7.18.6
      227 silly placeDep node_modules/@babel/highlight chalk@2.4.2 OK for: @babel/highlight@7.18.6 want: ^2.0.0
      228 silly placeDep ROOT js-tokens@4.0.0 OK for: @babel/highlight@7.18.6 want: ^4.0.0
      229 silly fetch manifest ansi-styles@^3.2.1
      230 silly fetch manifest escape-string-regexp@^1.0.5
      231 silly fetch manifest supports-color@^5.3.0
      232 http fetch GET 200 https://registry.npmjs.org/supports-color 74ms (cache revalidated)
      233 http fetch GET 200 https://registry.npmjs.org/escape-string-regexp 87ms (cache revalidated)
      234 http fetch GET 200 https://registry.npmjs.org/ansi-styles 96ms (cache revalidated)
      235 timing idealTree:node_modules/@babel/highlight Completed in 121ms
      236 timing idealTree:node_modules/@babel/helper-validator-identifier Completed in 0ms
      237 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
      238 silly placeDep node_modules/@eslint/eslintrc js-yaml@3.14.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.13.1
      239 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
      240 timing idealTree:node_modules/@eslint/eslintrc Completed in 10ms
      241 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
      242 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
      243 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 8ms
      244 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
      245 timing idealTree:node_modules/doctrine Completed in 0ms
      246 timing idealTree:node_modules/enquirer Completed in 0ms
      247 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
      248 silly placeDep node_modules/eslint-scope estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
      249 timing idealTree:node_modules/eslint-scope Completed in 7ms
      250 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
      251 timing idealTree:node_modules/eslint-utils Completed in 3ms
      252 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
      253 silly placeDep node_modules/espree acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
      254 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
      255 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
      256 timing idealTree:node_modules/espree Completed in 22ms
      257 timing idealTree:node_modules/acorn-jsx Completed in 0ms
      258 timing idealTree:node_modules/esquery Completed in 0ms
      259 timing idealTree:node_modules/esrecurse Completed in 0ms
      260 timing idealTree:node_modules/events Completed in 0ms
      261 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
      262 silly fetch manifest flatted@^3.1.0
      263 http fetch GET 200 https://registry.npmjs.org/flatted 79ms (cache revalidated)
      264 timing idealTree:node_modules/file-entry-cache Completed in 90ms
      265 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
      266 timing idealTree:node_modules/flat-cache Completed in 12ms
      267 timing idealTree:node_modules/flatted Completed in 0ms
      268 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
      269 silly placeDep ROOT type-fest@0.20.2 OK for: globals@13.17.0 want: ^0.20.2
      270 timing idealTree:node_modules/globals Completed in 8ms
      271 timing idealTree:node_modules/google-protobuf Completed in 0ms
      272 timing idealTree:node_modules/ignore Completed in 0ms
      273 silly placeDep ROOT parent-module@1.0.1 OK for: import-fresh@3.3.0 want: ^1.0.0
      274 silly placeDep ROOT resolve-from@4.0.0 OK for: import-fresh@3.3.0 want: ^4.0.0
      275 silly fetch manifest callsites@^3.0.0
      276 http fetch GET 200 https://registry.npmjs.org/callsites 54ms (cache revalidated)
      277 timing idealTree:node_modules/import-fresh Completed in 69ms
      278 timing idealTree:node_modules/imurmurhash Completed in 0ms
      279 timing idealTree:node_modules/js-tokens Completed in 1ms
      280 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
      281 timing idealTree:node_modules/lodash.merge Completed in 0ms
      282 timing idealTree:node_modules/natural-compare Completed in 0ms
      283 timing idealTree:node_modules/net Completed in 0ms
      284 timing idealTree:node_modules/nopy Completed in 0ms
      285 silly placeDep ROOT callsites@3.1.0 OK for: parent-module@1.0.1 want: ^3.0.0
      286 timing idealTree:node_modules/parent-module Completed in 5ms
      287 timing idealTree:node_modules/callsites Completed in 0ms
      288 timing idealTree:node_modules/progress Completed in 0ms
      289 timing idealTree:node_modules/regexpp Completed in 0ms
      290 timing idealTree:node_modules/resolve-from Completed in 0ms
      291 silly placeDep node_modules/table ajv@8.11.0 OK for: table@6.8.0 want: ^8.0.1
      292 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.0 want: ^4.4.2
      293 silly placeDep ROOT slice-ansi@4.0.0 OK for: table@6.8.0 want: ^4.0.0
      294 silly placeDep node_modules/table string-width@4.2.3 OK for: table@6.8.0 want: ^4.2.3
      295 silly placeDep node_modules/table strip-ansi@6.0.1 OK for: table@6.8.0 want: ^6.0.1
      296 silly fetch manifest json-schema-traverse@^1.0.0
      297 silly fetch manifest require-from-string@^2.0.2
      298 silly fetch manifest astral-regex@^2.0.0
      299 silly fetch manifest is-fullwidth-code-point@^3.0.0
      300 http fetch GET 200 https://registry.npmjs.org/astral-regex 61ms (cache revalidated)
      301 http fetch GET 200 https://registry.npmjs.org/require-from-string 81ms (cache revalidated)
      302 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 85ms (cache revalidated)
      303 http fetch GET 200 https://registry.npmjs.org/is-fullwidth-code-point 79ms (cache revalidated)
      304 timing idealTree:node_modules/table Completed in 119ms
      305 timing idealTree:node_modules/lodash.truncate Completed in 0ms
      306 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
      307 silly placeDep node_modules/slice-ansi is-fullwidth-code-point@3.0.0 OK for: slice-ansi@4.0.0 want: ^3.0.0
      308 timing idealTree:node_modules/slice-ansi Completed in 8ms
      309 timing idealTree:node_modules/astral-regex Completed in 0ms
      310 timing idealTree:node_modules/text-table Completed in 0ms
      311 timing idealTree:node_modules/tree-kill Completed in 0ms
      312 timing idealTree:node_modules/type-fest Completed in 0ms
      313 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
      314 silly placeDep node_modules/@babel/highlight ansi-styles@3.2.1 OK for: chalk@2.4.2 want: ^3.2.1
      315 silly placeDep node_modules/@babel/highlight escape-string-regexp@1.0.5 OK for: chalk@2.4.2 want: ^1.0.5
      316 silly placeDep node_modules/@babel/highlight supports-color@5.5.0 OK for: chalk@2.4.2 want: ^5.3.0
      317 silly fetch manifest has-flag@^3.0.0
      318 http fetch GET 200 https://registry.npmjs.org/has-flag 51ms (cache revalidated)
      319 timing idealTree:node_modules/@babel/highlight/node_modules/chalk Completed in 62ms
      320 timing idealTree:node_modules/@babel/highlight/node_modules/ansi-styles Completed in 0ms
      321 timing idealTree:node_modules/@babel/highlight/node_modules/escape-string-regexp Completed in 0ms
      322 silly placeDep node_modules/@babel/highlight has-flag@3.0.0 OK for: supports-color@5.5.0 want: ^3.0.0
      323 timing idealTree:node_modules/@babel/highlight/node_modules/supports-color Completed in 5ms
      324 timing idealTree:node_modules/@babel/highlight/node_modules/has-flag Completed in 0ms
      325 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      326 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 5ms
      327 silly placeDep node_modules/@eslint/eslintrc argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
      328 silly fetch manifest sprintf-js@~1.0.2
      329 http fetch GET 200 https://registry.npmjs.org/sprintf-js 54ms (cache revalidated)
      330 timing idealTree:node_modules/@eslint/eslintrc/node_modules/js-yaml Completed in 60ms
      331 silly placeDep node_modules/@eslint/eslintrc sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
      332 timing idealTree:node_modules/@eslint/eslintrc/node_modules/argparse Completed in 3ms
      333 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
      334 timing idealTree:node_modules/@eslint/eslintrc/node_modules/sprintf-js Completed in 0ms
      335 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
      336 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      337 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 3ms
      338 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
      339 timing idealTree:node_modules/eslint-scope/node_modules/estraverse Completed in 0ms
      340 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 0ms
      341 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      342 timing idealTree:node_modules/eslint/node_modules/debug Completed in 3ms
      343 silly placeDep node_modules/eslint argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
      344 timing idealTree:node_modules/eslint/node_modules/js-yaml Completed in 3ms
      345 silly placeDep node_modules/eslint sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
      346 timing idealTree:node_modules/eslint/node_modules/argparse Completed in 3ms
      347 silly placeDep node_modules/eslint prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
      348 silly placeDep node_modules/eslint type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
      349 timing idealTree:node_modules/eslint/node_modules/levn Completed in 7ms
      350 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
      351 timing idealTree:node_modules/eslint/node_modules/optionator Completed in 0ms
      352 timing idealTree:node_modules/eslint/node_modules/prelude-ls Completed in 0ms
      353 timing idealTree:node_modules/eslint/node_modules/sprintf-js Completed in 0ms
      354 silly placeDep node_modules/eslint ansi-regex@5.0.1 OK for: strip-ansi@6.0.1 want: ^5.0.1
      355 timing idealTree:node_modules/eslint/node_modules/strip-ansi Completed in 3ms
      356 timing idealTree:node_modules/eslint/node_modules/ansi-regex Completed in 0ms
      357 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
      358 timing idealTree:node_modules/eslint/node_modules/type-check Completed in 0ms
      359 timing idealTree:node_modules/espree/node_modules/acorn Completed in 0ms
      360 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
      361 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
      362 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
      363 silly placeDep ROOT @sentry/tracing@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
      364 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
      365 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
      366 silly placeDep node_modules/iobroker.esphome cookie@0.4.2 OK for: @sentry/node@5.30.0 want: ^0.4.1
      367 silly fetch manifest @sentry/minimal@5.30.0
      368 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 124ms (cache revalidated)
      369 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 173ms
      370 silly placeDep node_modules/@sentry/tracing @sentry/hub@5.30.0 OK for: @sentry/tracing@5.30.0 want: 5.30.0
      371 silly placeDep node_modules/@sentry/tracing @sentry/minimal@5.30.0 OK for: @sentry/tracing@5.30.0 want: 5.30.0
      372 silly placeDep node_modules/@sentry/tracing @sentry/types@5.30.0 OK for: @sentry/tracing@5.30.0 want: 5.30.0
      373 silly placeDep node_modules/@sentry/tracing @sentry/utils@5.30.0 OK for: @sentry/tracing@5.30.0 want: 5.30.0
      374 timing idealTree:node_modules/@sentry/tracing Completed in 36ms
      375 timing idealTree:node_modules/@sentry/tracing/node_modules/@sentry/hub Completed in 0ms
      376 timing idealTree:node_modules/@sentry/tracing/node_modules/@sentry/minimal Completed in 0ms
      377 timing idealTree:node_modules/@sentry/tracing/node_modules/@sentry/types Completed in 0ms
      378 timing idealTree:node_modules/@sentry/tracing/node_modules/@sentry/utils Completed in 0ms
      379 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
      380 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 5ms
      381 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
      382 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
      383 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
      384 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
      385 timing idealTree:node_modules/iobroker.esphome/node_modules/cookie Completed in 1ms
      386 timing idealTree:node_modules/slice-ansi/node_modules/is-fullwidth-code-point Completed in 0ms
      387 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.11.0 want: ^1.0.0
      388 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.11.0 want: ^2.0.2
      389 timing idealTree:node_modules/table/node_modules/ajv Completed in 9ms
      390 timing idealTree:node_modules/require-from-string Completed in 0ms
      391 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
      392 silly placeDep node_modules/table is-fullwidth-code-point@3.0.0 OK for: string-width@4.2.3 want: ^3.0.0
      393 timing idealTree:node_modules/table/node_modules/string-width Completed in 4ms
      394 timing idealTree:node_modules/table/node_modules/is-fullwidth-code-point Completed in 0ms
      395 silly placeDep node_modules/table ansi-regex@5.0.1 OK for: strip-ansi@6.0.1 want: ^5.0.1
      396 timing idealTree:node_modules/table/node_modules/strip-ansi Completed in 3ms
      397 timing idealTree:node_modules/table/node_modules/ansi-regex Completed in 0ms
      398 timing idealTree:buildDeps Completed in 8237ms
      399 timing idealTree:fixDepFlags Completed in 43ms
      400 timing idealTree Completed in 11780ms
      401 timing reify:loadTrees Completed in 11783ms
      402 timing reify:diffTrees Completed in 112ms
      403 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/agent-base' ]
      404 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/ansi-styles' ]
      405 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/async-lock' ]
      406 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/asynckit' ]
      407 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/axios' ]
      408 silly reify mark retired [
      408 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/axios-cookiejar-support'
      408 silly reify ]
      409 silly reify mark retired [
      409 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/basic-auth-parser'
      409 silly reify ]
      410 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/big.js' ]
      411 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/buffer-from' ]
      412 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/buffer-shims' ]
      413 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/chalk' ]
      414 silly reify mark retired [
      414 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/color-convert'
      414 silly reify ]
      415 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/color-name' ]
      416 silly reify mark retired [
      416 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/combined-stream'
      416 silly reify ]
      417 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/debug' ]
      418 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/decimal.js' ]
      419 silly reify mark retired [
      419 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/delayed-stream'
      419 silly reify ]
      420 silly reify mark retired [
      420 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/eventemitter3'
      420 silly reify ]
      421 silly reify mark retired [
      421 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/follow-redirects'
      421 silly reify ]
      422 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/form-data' ]
      423 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/fs-extra' ]
      424 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/futoin-hkdf' ]
      425 silly reify mark retired [
      425 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/get-caller-file'
      425 silly reify ]
      426 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/graceful-fs' ]
      427 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/has-flag' ]
      428 silly reify mark retired [
      428 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-levoit-air-purifier'
      428 silly reify ]
      429 silly reify mark retired [
      429 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-midea-air'
      429 silly reify ]
      430 silly reify mark retired [
      430 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper'
      430 silly reify ]
      431 silly reify mark retired [
      431 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/http-cookie-agent'
      431 silly reify ]
      432 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/ip' ]
      433 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/jsonfile' ]
      434 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/lru-cache' ]
      435 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/mime-db' ]
      436 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/mime-types' ]
      437 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/minimist' ]
      438 silly reify mark retired [
      438 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/mkdirp',
      438 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/mkdirp'
      438 silly reify ]
      439 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require' ]
      440 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/ms' ]
      441 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-persist' ]
      442 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-tunnel' ]
      443 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/psl' ]
      444 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/punycode' ]
      445 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/q' ]
      446 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/querystring' ]
      447 silly reify mark retired [
      447 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/querystringify'
      447 silly reify ]
      448 silly reify mark retired [
      448 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/remove-trailing-separator'
      448 silly reify ]
      449 silly reify mark retired [
      449 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/requires-port'
      449 silly reify ]
      450 silly reify mark retired [
      450 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/semver',
      450 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/semver'
      450 silly reify ]
      451 silly reify mark retired [
      451 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/source-map-support'
      451 silly reify ]
      452 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/strftime' ]
      453 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/string-argv' ]
      454 silly reify mark retired [
      454 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/supports-color'
      454 silly reify ]
      455 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/tough-cookie' ]
      456 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/traverse' ]
      457 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/tslib' ]
      458 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/tunnel' ]
      459 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/universalify' ]
      460 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/url-parse' ]
      461 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/yallist' ]
      462 silly reify mark retired [
      462 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/iobroker'
      462 silly reify ]
      463 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/node' ]
      464 silly reify moves {
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/agent-base': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.agent-base-XZSbD2Mv',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/ansi-styles': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.ansi-styles-WEBLKjJI',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/async-lock': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.async-lock-BsyRKXU9',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.asynckit-Meiy0eQv',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/axios': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.axios-0doD2cKL',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/axios-cookiejar-support': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.axios-cookiejar-support-1mocmZ0o',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/basic-auth-parser': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.basic-auth-parser-F9CdRglF',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/big.js': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.big.js-tUpQSp4M',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/buffer-from': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.buffer-from-eNOZXrub',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/buffer-shims': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.buffer-shims-eLl6f5uo',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/chalk': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.chalk-qOlaLiBs',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/color-convert': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.color-convert-tSBBFCzU',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/color-name': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.color-name-IbGcckp9',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.combined-stream-2hoXEQyQ',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/debug': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.debug-RaGjE3R1',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/decimal.js': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.decimal.js-OWtOpJ19',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.delayed-stream-AHmHwJoa',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/eventemitter3': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.eventemitter3-00eNk4Po',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/follow-redirects': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.follow-redirects-mbUhz97t',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.form-data-UOsrzKiW',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/fs-extra': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.fs-extra-j0xX6LxT',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/futoin-hkdf': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.futoin-hkdf-iIDa0Pbb',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/get-caller-file': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.get-caller-file-MitBu9u5',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.graceful-fs-ymo4N14m',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/has-flag': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.has-flag-srGt5rRm',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-levoit-air-purifier': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.homebridge-levoit-air-purifier-m8yZh2Yf',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-midea-air': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.homebridge-midea-air-dt178IwB',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.homebridge-plugin-wrapper-OjZ33uAg',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/http-cookie-agent': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.http-cookie-agent-U1mXkvuy',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/ip': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.ip-JQwSM2kT',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/jsonfile': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.jsonfile-brnwCVlh',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.lru-cache-vLJA48iL',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.mime-db-RfHmywyQ',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.mime-types-W57lHa5q',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.minimist-GeruU8jT',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/mkdirp': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.mkdirp-gPAkyRBK',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/.mkdirp-A2rzNB6c',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.mock-require-zLGI33hW',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/ms': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.ms-249YRT8r',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-persist': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.node-persist-GIyZGlcY',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-tunnel': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.node-tunnel-9LZQAPNC',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/psl': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.psl-yhADlgUq',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.punycode-3mUuRAwt',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/q': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.q-7VMiJ1YP',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/querystring': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.querystring-XiZjIazd',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/querystringify': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.querystringify-7MGt5Tnq',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/remove-trailing-separator': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.remove-trailing-separator-LOSbmapr',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/requires-port': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.requires-port-3HJcEzOb',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/semver': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.semver-FBqhjXWD',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.bin/.semver-33llE1bs',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/source-map-support': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.source-map-support-KIcrtnrA',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/strftime': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.strftime-tICv71WA',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/string-argv': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.string-argv-H9Jv73gq',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/supports-color': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.supports-color-G3TBVleQ',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.tough-cookie-WyRj00Yz',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/traverse': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.traverse-FlCJVBmO',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/tslib': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.tslib-NdONBogv',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/tunnel': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.tunnel-KMQe42oQ',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/universalify': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.universalify-ZPxh99T3',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/url-parse': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.url-parse-4aiXfoj6',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.ham/node_modules/.yallist-hb5tDB68',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/.iobroker-7gALfJy6',
      464 silly reify   '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.ham/node_modules/@types/.node-crq3UI1V'
      464 silly reify }
      465 timing reify:retireShallow Completed in 61ms
      466 timing reify:createSparse Completed in 45ms
      467 timing reify:loadBundles Completed in 0ms
      468 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
      469 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      470 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
      471 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
      472 timing reifyNode:node_modules/osx-temperature-sensor Completed in 41ms
      473 timing reifyNode:node_modules/fsevents Completed in 41ms
      474 timing reifyNode:node_modules/natural-compare Completed in 1683ms
      475 timing reifyNode:node_modules/require-from-string Completed in 1717ms
      476 timing reifyNode:node_modules/slice-ansi Completed in 1717ms
      477 timing reifyNode:node_modules/resolve-from Completed in 1717ms
      478 timing reifyNode:node_modules/parent-module Completed in 1716ms
      479 timing reifyNode:node_modules/imurmurhash Completed in 1721ms
      480 timing reifyNode:node_modules/@babel/highlight/node_modules/has-flag Completed in 1734ms
      481 timing reifyNode:node_modules/@babel/highlight/node_modules/escape-string-regexp Completed in 1735ms
      482 timing reifyNode:node_modules/@babel/highlight/node_modules/ansi-styles Completed in 1735ms
      483 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1733ms
      484 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1736ms
      485 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1740ms
      486 timing reifyNode:node_modules/astral-regex Completed in 1756ms
      487 timing reifyNode:node_modules/lodash.truncate Completed in 1756ms
      488 timing reifyNode:node_modules/callsites Completed in 1756ms
      489 timing reifyNode:node_modules/@babel/highlight Completed in 1757ms
      490 timing reifyNode:node_modules/import-fresh Completed in 1758ms
      491 timing reifyNode:node_modules/@babel/code-frame Completed in 1759ms
      492 timing reifyNode:node_modules/net Completed in 1760ms
      493 timing reifyNode:node_modules/slice-ansi/node_modules/is-fullwidth-code-point Completed in 1778ms
      494 timing reifyNode:node_modules/@babel/highlight/node_modules/supports-color Completed in 1777ms
      495 timing reifyNode:node_modules/table/node_modules/ansi-regex Completed in 1778ms
      496 timing reifyNode:node_modules/table/node_modules/is-fullwidth-code-point Completed in 1779ms
      497 timing reifyNode:node_modules/table/node_modules/strip-ansi Completed in 1781ms
      498 timing reifyNode:node_modules/table/node_modules/string-width Completed in 1781ms
      499 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1783ms
      500 timing reifyNode:node_modules/eslint/node_modules/ansi-regex Completed in 1783ms
      501 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1785ms
      502 timing reifyNode:node_modules/eslint/node_modules/strip-ansi Completed in 1786ms
      503 timing reifyNode:node_modules/esrecurse Completed in 1802ms
      504 timing reifyNode:node_modules/js-tokens Completed in 1801ms
      505 timing reifyNode:node_modules/tree-kill Completed in 1804ms
      506 timing reifyNode:node_modules/iobroker.esphome/node_modules/cookie Completed in 1817ms
      507 timing reifyNode:node_modules/v8-compile-cache Completed in 1830ms
      508 timing reifyNode:node_modules/file-entry-cache Completed in 1832ms
      509 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1834ms
      510 timing reifyNode:node_modules/acorn-jsx Completed in 1853ms
      511 timing reifyNode:node_modules/lodash.merge Completed in 1853ms
      512 timing reifyNode:node_modules/eslint/node_modules/type-check Completed in 1860ms
      513 timing reifyNode:node_modules/progress Completed in 1873ms
      514 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1877ms
      515 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1886ms
      516 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1886ms
      517 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1885ms
      518 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1887ms
      519 timing reifyNode:node_modules/eslint/node_modules/levn Completed in 1889ms
      520 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1889ms
      521 timing reifyNode:node_modules/globals Completed in 1903ms
      522 timing reifyNode:node_modules/@babel/highlight/node_modules/chalk Completed in 1914ms
      523 timing reifyNode:node_modules/eslint-scope/node_modules/estraverse Completed in 1912ms
      524 timing reifyNode:node_modules/flat-cache Completed in 1926ms
      525 timing reifyNode:node_modules/ignore Completed in 1926ms
      526 timing reifyNode:node_modules/functional-red-black-tree Completed in 1926ms
      527 timing reifyNode:node_modules/eslint/node_modules/optionator Completed in 1934ms
      528 timing reifyNode:node_modules/eslint/node_modules/prelude-ls Completed in 2017ms
      529 timing reifyNode:node_modules/@babel/helper-validator-identifier Completed in 2030ms
      530 timing reifyNode:node_modules/text-table Completed in 2074ms
      531 timing reifyNode:node_modules/espree Completed in 2076ms
      532 timing reifyNode:node_modules/doctrine Completed in 2077ms
      533 timing reifyNode:node_modules/flatted Completed in 2100ms
      534 timing reifyNode:node_modules/@sentry/tracing/node_modules/@sentry/minimal Completed in 2111ms
      535 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 2109ms
      536 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 2121ms
      537 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 2130ms
      538 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 2155ms
      539 timing reifyNode:node_modules/eslint-scope Completed in 2161ms
      540 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/sprintf-js Completed in 2172ms
      541 timing reifyNode:node_modules/eslint/node_modules/sprintf-js Completed in 2171ms
      542 timing reifyNode:node_modules/regexpp Completed in 2190ms
      543 timing reifyNode:node_modules/eslint-utils Completed in 2240ms
      544 timing reifyNode:node_modules/events Completed in 2384ms
      545 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/argparse Completed in 2426ms
      546 timing reifyNode:node_modules/eslint/node_modules/argparse Completed in 2425ms
      547 timing reifyNode:node_modules/@eslint/eslintrc Completed in 2437ms
      548 timing reifyNode:node_modules/iobroker.esphome Completed in 2481ms
      549 timing reifyNode:node_modules/type-fest Completed in 2511ms
      550 timing reifyNode:node_modules/@sentry/tracing/node_modules/@sentry/hub Completed in 2608ms
      551 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 2601ms
      552 timing reifyNode:node_modules/esphome-native-api Completed in 2604ms
      553 timing reifyNode:node_modules/enquirer Completed in 2626ms
      554 timing reifyNode:node_modules/google-protobuf Completed in 2673ms
      555 timing reifyNode:node_modules/esquery Completed in 2688ms
      556 timing reifyNode:node_modules/eslint/node_modules/js-yaml Completed in 2686ms
      557 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/js-yaml Completed in 2688ms
      558 timing reifyNode:node_modules/espree/node_modules/acorn Completed in 2739ms
      559 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2909ms
      560 timing reifyNode:node_modules/table Completed in 2997ms
      561 timing reifyNode:node_modules/nopy Completed in 3131ms
      562 timing reifyNode:node_modules/@sentry/tracing/node_modules/@sentry/utils Completed in 3213ms
      563 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 3201ms
      564 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 3238ms
      565 timing reifyNode:node_modules/@sentry/tracing/node_modules/@sentry/types Completed in 3418ms
      566 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 3407ms
      567 timing reifyNode:node_modules/@sentry/tracing Completed in 3738ms
      568 timing reifyNode:node_modules/table/node_modules/ajv Completed in 4024ms
      569 timing reifyNode:node_modules/eslint Completed in 4060ms
      570 timing reify:unpack Completed in 4071ms
      571 timing reify:unretire Completed in 2ms
      572 timing build:queue Completed in 17ms
      573 timing build:link:node_modules/eslint Completed in 8ms
      574 timing build:link:node_modules/nopy Completed in 6ms
      575 timing build:link:node_modules/tree-kill Completed in 5ms
      576 timing build:link:node_modules/@eslint/eslintrc/node_modules/js-yaml Completed in 9ms
      577 timing build:link:node_modules/eslint/node_modules/js-yaml Completed in 10ms
      578 timing build:link:node_modules/espree/node_modules/acorn Completed in 10ms
      579 timing build:link Completed in 14ms
      580 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
      581 info run iobroker.esphome@0.2.4 install { code: 126, signal: null }
      582 timing reify:rollback:createSparse Completed in 1019ms
      583 timing reify:rollback:retireShallow Completed in 70ms
      584 timing command:install Completed in 17315ms
      585 verbose stack Error: command failed
      585 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
      585 verbose stack     at ChildProcess.emit (node:events:513:28)
      585 verbose stack     at maybeClose (node:internal/child_process:1100:16)
      585 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
      586 verbose pkgid iobroker.esphome@0.2.4
      587 verbose cwd /opt/iobroker
      588 verbose Linux 5.10.103-v7l+
      589 verbose node v16.18.0
      590 verbose npm  v8.19.2
      591 error code 126
      592 error path /opt/iobroker/node_modules/iobroker.esphome
      593 error command failed
      594 error command sh -c -- npip install
      595 error sh: 1: npip: Permission denied
      596 verbose exit 126
      597 timing npm Completed in 17697ms
      598 verbose unfinished npm timer reify 1666215349309
      599 verbose unfinished npm timer reify:build 1666215365429
      600 verbose unfinished npm timer build 1666215365433
      601 verbose unfinished npm timer build:deps 1666215365434
      602 verbose unfinished npm timer build:run:install 1666215365466
      603 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1666215365467
      604 verbose code 126
      605 error A complete log of this run can be found in:
      605 error     /home/iobroker/.npm/_logs/2022-10-19T21_35_48_951Z-debug-0.log
      • Thomas BraunT Online
        @draexler
        uname -m
        Könnte mit 32bit/64bit zusammenhängen:
        https://forum.iobroker.net/post/838479
        draexlerD 1 Antwort Letzte Antwort
          @draexler
          uname -m
          draexlerD Offline
          draexlerD Offline
          draexler
          @thomas-braun Habe ich auch gerade gefunden.
          Vielleicht mal der Anstoß auf 64 zu wechseln und Gleichzeitig von Buster auf Bullseye hochzuziehen.
          Gibt es irgendwas zu beachten mit 64 Bit und ioBroker? Gleiche Installationroutine?
          Werden eigentlich alle Adapter mit den Versionständen nachinstalliert wie sie waren? Ich laufe normalerweise auf Stabel habe aber ein zwei Adapter (z.B. espHome) die es nur im Beta gibt/ gab.
            Alles gleich.
            Ja.
              Alles gleich.
              Ja.
              draexlerD Offline
              draexlerD Offline
              draexler
              @thomas-braun Hab's gemacht. Bullseye mit 64 Bit. Läuft wunderbar.
              Stolpersteine waren:
              • VIS (also erst mal auf eine niedrigere Version und dann rauf)
              • zwei Adapter wurden nicht installiert, da diese über GIT installiert wurden.
              • Yahka musste das Backup manuell nachgeschoben werden
              • Historie musste das Backup manuell nachgeschoben werden (aber eventuell ist das ja so gwollt)
              Aber sonst lief es sauber durch. Merken tut man wie erwartet nichts an Performance etc.
              Gesamtzeitaufwand ca. 3 Stunden
              Hoffe das ich jetzt wieder ein paar Jahre Pause habe mit einem "so großen Versionshub"
                paar Jahre Pause
                Bis ca. August 2024.
                  paar Jahre Pause
                  marsmännchen
                  @WolfgangFB
                  @SBorg
                  Nachdem ich es geschafft habe von NPM die aktuellste Version zu installieren, ohne Fehler 25 oder ähnliches, besteht das Problem vom "fatal error" immer noch.
                  Was könnten wir noch tun?
                  MfG
                  Patrick
                  Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
                  Wago PFC200 mit Dali Lichtsteuerung.
                  • M marsmännchen
                    @WolfgangFB
                    @SBorg
                    MfG
                    Patrick
                    @marsmännchen sagte in EspHome: fatal error: ESPAsyncWebServer.h:
                    Wie genau? Npm selber packt man nicht an, das kommt per nodejs daher.
                      marsmännchen
                      iobroker url DrozmotiX/ioBroker.esphome --host meinhost
                      und dann:
                      iobroker add esphome --host meinhost
                      Hat soweit geklappt, das ich den Adapter im Admin sehe, eine Instanz sehe welche grün ist, und ich das Dashboard benutzen kann.
                      Aber eben den Fehler bekomme beim verbinden mit einem Olimex-ESP:
                      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/olim1.yaml...
                      INFO Generating C++ source...
                      INFO Compiling app...
                      Processing olim1 (board: esp32-poe-iso; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
                      HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
                      LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
                      Library Manager: Installing esphome/AsyncTCP-esphome @ 1.2.2
                      Warning! Please upgrade to the PlatformIO Core 6
                      Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
                      Dependency Graph
                      |-- <WiFi> 1.0
                      |-- <FS> 1.0
                      |-- <Update> 1.0
                      |-- <DNSServer> 1.1.0
                      |-- <ESPmDNS> 1.0
                      Compiling .pioenvs/olim1/src/esphome/components/captive_portal/captive_portal.cpp.o
                      Compiling .pioenvs/olim1/src/esphome/components/esp32/gpio_idf.cpp.o
                      Compiling .pioenvs/olim1/src/esphome/components/esp32/preferences.cpp.o
                      Compiling .pioenvs/olim1/src/esphome/components/logger/logger.cpp.o
                      Compiling .pioenvs/olim1/src/esphome/components/md5/md5.cpp.o
                      In file included from src/esphome/components/captive_portal/captive_portal.h:10:0,
                                       from src/esphome/components/captive_portal/captive_portal.cpp:3:
                      src/esphome/components/web_server_base/web_server_base.h:9:31: fatal error: ESPAsyncWebServer.h: No such file or directory
                      * Looking for ESPAsyncWebServer.h dependency? Check our library registry!
                      * CLI  > platformio lib search "header:ESPAsyncWebServer.h"
                      * Web  > https://registry.platformio.org/search?q=header:ESPAsyncWebServer.h
                      compilation terminated.
                      *** [.pioenvs/olim1/src/esphome/components/captive_portal/captive_portal.cpp.o] Error 1
                      ========================== [FAILED] Took 7.04 seconds ==========================
                      • M marsmännchen
                        und dann:
                        Dependency Graph
                        |-- <WiFi> 1.0
                        |-- <FS> 1.0
                        |-- <Update> 1.0
                        |-- <ESPmDNS> 1.0
                        @marsmännchen
                        Sorry, hatte dich missverstanden.
                          @marsmännchen
                          marsmännchen
                          kein Problem.
                          Ich glaub das ist wohl eher so eine Github issue sache.
                          Egal mit welchem Bauteil/Modul (ESP32,...) man arbeiten will fehlt immer die oben genannte Headerdatei.
                          • M marsmännchen
                            kein Problem.
                            @marsmännchen
                            https://community.platformio.org/t/including-libs-file-not-found/29943
                              @marsmännchen
                              marsmännchen
                              okay, danke...
                              lib_deps eintragen...
                              Bin gespannt
                              • M marsmännchen
                                okay, danke...
                                Bin gespannt
                                marsmännchen
                                @Thomas-Braun
                                Vielleicht noch eine letzte idee wo ich das einfügen muss?
                                esphome:
                                esp32:
                                  framework:
                                    type: arduino
                                    lib_deps:
                                      ayushsharma82/AsyncElegantOTA@^2.2.7
                                      ottowinter/ESPAsyncWebServer-esphome@^3.0.0
                                      links2004/WebSockets@^2.3.7
                                # Enable logging
                                logger:
                                # Enable Home Assistant API
                                api:
                                ota:
                                  password: "b93b5acd7b0bb6f4306931842f157caa"
                                Da kommt dann immer:
                                Failed config
                                esp32: None
                                  framework:  None
                                    type: arduino
                                    [lib_deps] is an invalid option for [framework]. Please check the indentation.
                                    lib_deps: |-
                                      ayushsharma82/AsyncElegantOTA@^2.2.7 ottowinter/ESPAsyncWebServer-esphome@^3.0.0 links2004/WebSockets@^2.3.7 None
                                • M marsmännchen
                                  @Thomas-Braun
                                  esphome:
                                  esp32:
                                    framework:
                                      type: arduino
                                      lib_deps:
                                  # Enable logging
                                  logger:
                                  api:
                                  ota:
                                  Failed config
                                  esp32: None
                                    framework:  None
                                      type: arduino
                                      lib_deps: |-
                                  @marsmännchen
                                  Nein, keine Ahnung. Hab ich mich noch nie mit beschäftigt.
                                    @marsmännchen
                                    marsmännchen
                                    Sollte noch jemand anderer daran arbeiten:
                                    die einzige Möglichkeit die ich rausgefunden habe das er nicht über den Syntax meckert ist über die "platformio_options"
                                    Was er jedoch beim kompilieren gekonnt ignoriert (und der ursprüngliche Fehler bleibt)
                                    esphome:
                                      platformio_options:
                                        lib_deps: ayushsharma82/AsyncElegantOTA@^2.2.7
                                    esp32:
                                      framework:
                                        type: arduino
                                    # Enable logging
                                    logger:
                                    api:
                                    ota:
                                    • M marsmännchen
                                      esphome:
                                        platformio_options:
                                      esp32:
                                        framework:
                                          type: arduino
                                      # Enable logging
                                      logger:
                                      api:
                                      ota:
                                      M Online
                                      M Online
                                      mrjeschke
                                      @marsmännchen
                                      Sollten die Einträge nicht in die platform.io?
                                      /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/platformio.ini
                                        marsmännchen
                                        Also ich kann folgenden Erfolg verbuchen:
                                        Da ich nämlich ein Olimex esp32-POE benutzen will brauche ich auch eine andere Yaml welche natürlich die LAN Parameter übergibt.
                                        Und die WiFi Parameter habe ich entfernt.
                                        Sieht bei mir dann so aus:
                                        esphome:
                                        esp32:
                                          framework:
                                            type: arduino
                                        ethernet:
                                          type: LAN8720
                                          mdc_pin: GPIO23
                                          mdio_pin: GPIO18
                                          clk_mode: GPIO17_OUT
                                          phy_addr: 0
                                          power_pin: GPIO12
                                          # Optional manual IP
                                          manual_ip:
                                            static_ip: 123.123.1.2
                                            gateway: 123.123.1.2
                                            subnet: 255.255.255.0
                                        # Enable logging
                                        logger:
                                        api:
                                        Ob sich ein ESP32 mit WiFi einrichten lässt kann ich natürlich noch nicht sagen.
                                        MfG
                                        Patrick
                                        • M mrjeschke
                                          @marsmännchen
                                          marsmännchen
                                          @mrjeschke
                                          Ohh auch interessant!
                                          Ja das kenn ich noch nicht.
                                          Werd ich mir auch später ansehen.
                                          Tochter schreit schon nach Aufmerksamkeit.😭
