  4. [solved] iobroker upgrade - weiterhin Adapter updateable?
    5.7k
adapter update probleme
21 Beiträge 3 Kommentatoren 846 Aufrufe 2 Beobachtet
    @reutli
    nodejs Version?
    iobroker upgrade admin --debug
    reutli
    @thomas-braun sagte in iobroker upgrade - trotzdem weiterhin Adapter updateable?:
    @reutli
    nodejs Version?
    admin@ubuntu-server:~$ iobroker upgrade admin --debug
    This upgrade of "admin" will at least introduce the following changes:
    -> 6.2.22:
    Corrected admin4 adapter settings
    -> 6.2.21:
    Corrected small JSON config issue
    -> 6.2.20:
    Corrected GUI issues
    -> 6.2.19:
    Corrected some issues
    -> 6.2.18:
    Corrected GUI bugs on custom settings
    -> 6.2.17:
    Corrected GUI bug on intro tab
    -> 6.2.16:
    Corrected many GUI issues
    Added `stable` flag for repositories
    Added reset button for repositories
    Improved `writeFile` function for socket communication
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @5.3.4 to @6.2.22 now? [(y)es, (n)o]: y
    Update admin from @5.3.4 to @6.2.22
    host.ubuntu-server Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.17
    Installing iobroker.admin@6.2.22... (System call)
    npm ERR! code EISGIT
    npm ERR! path /opt/iobroker/node_modules/iobroker.husqvarna_mowers
    npm ERR! git /opt/iobroker/node_modules/iobroker.husqvarna_mowers: Appears to be a git repo or submodule.
    npm ERR! git Refusing to remove it. Update manually,
    npm ERR! git or move it out of the way first.
    npm ERR!     /home/iobroker/.npm/_logs/2022-10-18T09_30_24_200Z-debug.log
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    host.ubuntu-server Adapter "system.adapter.admin.0" is started
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
      @reutli
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      reutli
      @reutli
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.20.1
      v14.20.1
      6.14.17
      4.0.21
      admin
      admin iobroker
      /home/admin
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://deb.nodesource.com/node_14.x focal InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists... Done
      All packages are up to date.
      nodejs:
        Installed: 14.20.1-deb-1nodesource1
        Candidate: 14.20.1-deb-1nodesource1
        Version table:
       *** 14.20.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      ich seh schon .... nodejs version 😧
      • R reutli
        @reutli
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.20.1
        v14.20.1
        6.14.17
        4.0.21
        admin
        admin iobroker
        /home/admin
        nodejs:
          Version table:
        @reutli sagte in iobroker upgrade - trotzdem weiterhin Adapter updateable?:
        ja, aber nicht zwingend Ursache für dein Problem.
        @homoran sagte in iobroker upgrade - trotzdem weiterhin Adapter updateable?:
        Das was @Thomas-Braun angefordert hat.
        das fehlt noch, da muss mehr kommen
        • R reutli
          @reutli
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.20.1
          v14.20.1
          6.14.17
          4.0.21
          admin
          admin iobroker
          /home/admin
          nodejs:
            Version table:
          Jein, eher nodesource.list
          Die muss auf jammy umgestellt werden. Im Zuge dessen würde ich auch auf node16 schwenken.
          R 1 Antwort Letzte Antwort
            reutli
            Gibst Du mir schnell hint oder soll ich suchen (Thema ist ja hinreichend bekannt...sorry)
            • R reutli
              @reutli
              Wegen der großen Nachfrage steht das sogar in meiner Signatur.
              Dir spukt aber der
              in die Upgrade-Suppe.
              cd /opt/iobroker
              npm uninstall iobroker.husqvarna_mowers
              R 3 Antworten Letzte Antwort
                @reutli
                Dir spukt aber der
                cd /opt/iobroker
                reutli
                Dir spukt aber der
                schon weg ;o)
                  @reutli
                  Dir spukt aber der
                  cd /opt/iobroker
                  reutli
                  jupp, melde mich wenn 'done'
                    @reutli
                    Dir spukt aber der
                    cd /opt/iobroker
                    reutli
                    hmm will nicht ganz so:
                    admin@ubuntu-server:/etc$ sudo cat /etc/apt/sources.list.d/nodesource.list
                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x jammy main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x jammy main
                    admin@ubuntu-server:/etc$ sudo apt update
                    Get:3 https://deb.nodesource.com/node_16.x jammy InRelease [4583 B]
                    Get:6 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages [772 B]
                    Fetched 5355 B in 2s (3416 B/s)
                    1 package can be upgraded. Run 'apt list --upgradable' to see it.
                    admin@ubuntu-server:/etc$ sudo apt full-upgrade
                    E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
                    • R reutli
                      Da hast du mal einen dpkg-Prozess während der lief gekillt.
                        reutli
                        die sehr lange Ausgabe (die noch läuft) brauchst Du nicht, oder?
                        Wenn durch würde ich neu booten und nochmal
                        fahren.
                        • R reutli
                          fahren.
                          @reutli
                          Lass das diesmal durchlaufen...
                          Dann das übliche
                          sudo apt update
                            @reutli
                            Dann das übliche
                            sudo apt update
                            reutli
                            schrieb am zuletzt editiert von reutli
                            Denke das habe ich bei 22.04 Update verbrochen (SSH session ist abgekachelt und ich dachte ist durch, dann reboot).
                            So, jetzt sollte es aber passen:
                            [sudo] password for admin:
                            ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.17.1
                            v16.17.1
                            8.15.0
                            4.0.21
                            admin
                            admin iobroker
                            /home/admin
                            Hit:3 https://deb.nodesource.com/node_16.x jammy InRelease
                            nodejs:
                              Installed: 16.17.1-deb-1nodesource1
                              Candidate: 16.17.1-deb-1nodesource1
                              Version table:
                             *** 16.17.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                            Updates sind ordnungsgemäss durchgelaufen:
                            admin@ubuntu-server:~$ iob update -i
                            Used repository: stable
                            Adapter    "admin"        : 6.2.22   , installed 6.2.22
                            Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                            Controller "js-controller": 4.0.23   , installed 4.0.23
                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                            Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                            noch was testen, oder passt es aus Deiner Sicht?
                            • R reutli
                              x86_64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.1
                              v16.17.1
                              8.15.0
                              4.0.21
                              admin
                              admin iobroker
                              /home/admin
                              nodejs:
                                Version table:
                              @reutli
                              Passt.
                                @reutli
                                Passt.
                                reutli
                                Danke für die Hilfe!
