  4. YAHKA Adapter lässt sich nicht updaten
    5.7k
26 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
    @guitardoc
    Zeig mal die Ausgaben vom nodejs-Check.
    Vermutlich reicht ein
    sudo apt install --reinstall nodejs
    aus. Korrekte Pfade vorausgesetzt.
    guitardoc
    pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.1
    v16.17.1
    8.19.2
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth gpio i2c spi iobroker
    /opt/iobroker
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:5 https://repo.homebridge.io stable InRelease
    Get:6 https://pkgs.tailscale.com/stable/debian bullseye InRelease
    Fetched 5,545 B in 3s (2,209 B/s)
    Reading package lists... Done
    All packages are up to date.
    nodejs:
      Installed: 16.17.1-deb-1nodesource1
      Candidate: 16.17.1-deb-1nodesource1
      Version table:
     *** 16.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    pi@raspberrypi:/opt/iobroker $ sudo apt install --reinstall nodejs
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 0 B/24.1 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 91627 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.17.1-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (16.17.1-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
    Setting up nodejs (16.17.1-deb-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypi:/opt/iobroker $ nodejs -v
    v16.17.1
    pi@raspberrypi:/opt/iobroker $ npm -v
    8.15.0
    • G guitardoc
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.19.2
      4.0.23
      pi
      /opt/iobroker
      nodejs:
        Version table:
      v16.17.1
      8.15.0
      @guitardoc
      Ja, jetzt ist es richtig.
      Lass künftig die Finger von händischen Upgrades von npm.
      G 1 Antwort Letzte Antwort
        @guitardoc
        guitardoc
        schrieb am zuletzt editiert von guitardoc
        @thomas-braun Hmm, bin mir gar nicht bewusst, dass ich händisch etwas geupdated habe... Seltsam.
        Aber der Adapter lässt sich immer noch nicht updaten. Hab zwischenzeitlich den Raspi neu gestartet, ändert aber nichts:
        pi@raspberrypi:~ $ iobroker update
        Used repository: Latest
        Adapter    "admin"        : 6.2.23   , installed 6.2.23
        Adapter    "backitup"     : 2.4.16   , installed 2.4.16
        Adapter    "cloud"        : 4.2.3    , installed 4.2.3
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "email"        : 1.1.4    , installed 1.1.4
        Adapter    "eusec"        : 0.9.4    , installed 0.9.4
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "info"         : 1.9.21   , installed 1.9.21
        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
        Adapter    "shelly"       : 6.2.2    , installed 6.2.2
        Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
        Adapter    "socketio"     : 6.1.10   , installed 6.1.10
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.52   , installed 0.0.52
        Adapter    "web"          : 5.2.10   , installed 5.2.10
        Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
        Adapter    "ws"           : 2.1.5    , installed 2.1.5
        Adapter    "yahka"        : 0.16.0   , installed 0.15.0 [Updatable]
        pi@raspberrypi:~ $ iobroker upgrade
        Would you like to upgrade yahka from @0.15.0 to @0.16.0 now? [(y)es, (n)o]: y
        Update yahka from @0.15.0 to @0.16.0
        NPM version: 8.15.0
        Installing iobroker.yahka@0.16.0... (System call)
        up to date in 12s
        95 packages are looking for funding
          run `npm fund` for details
        upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
        upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
        upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
        upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
        upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
        upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
        upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
        upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
        upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
        upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
        upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
        upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
        upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
        upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
        upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
        upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
        upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
        upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
        upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
        upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
        pi@raspberrypi:~ $
        • G guitardoc
          NPM version: 8.15.0
          up to date in 12s
          pi@raspberrypi:~ $
          @guitardoc sagte in YAHKA Adapter lässt sich nicht updaten:
          yahka
          Mach es mit --debug-Option im Terminal:
          iobroker upgrade yahka --debug
            yahka
            guitardoc
            @thomas-braun said in YAHKA Adapter lässt sich nicht updaten:
            pi@raspberrypi:~ $ iobroker upgrade yahka --debug
            NPM version: 8.15.0
            up to date in 17s
            pi@raspberrypi:~ $
            • G guitardoc
              NPM version: 8.15.0
              up to date in 17s
              pi@raspberrypi:~ $
              @guitardoc
              iob stop
              iob fix
              iob start
              Und dann nochmal versuchen.
                @guitardoc
                iob stop
                iob fix
                iob start
                guitardoc
                Funktioniert leider nicht...
                • G guitardoc
                  @guitardoc
                  Ist ganz frisch im Beta-Zweig:
                  github:	0.14.0
                  latest:	0.16.0 for 0 days
                  stable:	0.13.1 for 21 months
                  vielleicht nicht richtig im Repo eingecheckt. Mach mal ein Issue auf. Ich vermute da muss der Maintainer nochmal schauen.
                  [Edit:] Gibt es sogar schon:
                  https://github.com/jensweigele/ioBroker.yahka/issues/363
                  G haus-automatisierungH 2 Antworten Letzte Antwort
                    @guitardoc
                    github:	0.14.0
                    guitardoc
                    @thomas-braun Ahhh... Na schau mal an, ich bin nicht der einzige mit dem Problem... Aber etwas Gutes hatte es doch - meine npm-Installation wurde gefixt... :-) Aber mir ist wirklich unklar wie diese seltsame Version da drauf gekommen ist. Hmm.
                    Danke für die schnelle und ausführliche Hilfe!!!
                      @guitardoc
                      github:	0.14.0
                      haus-automatisierungH Offline
                      @thomas-braun sagte in YAHKA Adapter lässt sich nicht updaten:
                      Ich würde darauf tippen, dass in der io-package.json die Version nicht aktualisiert wurde und nicht zu der Version in der package.json gepasst hat. Deswegen gibt es seit einer Stunde wohl auch die 0.17.0
                      Deswegen nutzt man als Entwickler auch eigentlich das Release-Script
                        marlan99
                        ach guck an :-)
                        https://forum.iobroker.net/topic/59061/yahka-adapter-lässt-sich-nicht-updaten/6?_=1665999650703#:~:text=marlan99-,about an hour ago,-Bei mir ähnlich
                        • M marlan99
                          ach guck an :-)
                          @marlan99
                          Dein nodejs kannst du aber unabhängig davon auf Stand bringen.
                            @marlan99
                            marlan99
                            @thomas-braun danke für den Tipp. Habs nach deiner Bemerkung auch gleich gemacht 👍
