  4. [Gelöst] Error: Cannot find module 'node:os'
    5.8k
20 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • J Jannis 0
    pi@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.1
    v16.17.1
    8.15.0
    pi
    /home/pi
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://repos.influxdata.com/debian buster InRelease
    OK:4 https://deb.nodesource.com/node_16.x buster InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           16.17.1-deb-1nodesource1
      Installationskandidat: 16.17.1-deb-1nodesource1
      Versionstabelle:
     *** 16.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    Zum Bluetooth ble:
    pi@iobroker:~ $ sudo iob rebuild ble
    Rebuilding native module "ble" ...
    rebuilt dependencies successfully
    Rebuilding native modules done
    trotzdem bleibt das im log?
    ble.0 2022-09-29 19:16:26.883	error	Terminating because A dependency requires a rebuild.
    ble.0 2022-09-29 19:16:25.291	info	starting scanner process...
    ble.0 2022-09-29 19:16:25.247	info	monitoring all services
    ble.0 2022-09-29 19:16:25.245	info	enabled plugins: Xiaomi, mi-flora, _default
    ble.0 2022-09-29 19:16:25.243	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0 2022-09-29 19:16:25.123	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.17.1, js-controller: 4.0.23
    Und zum iob -Update:
    pi@iobroker:~ $ sudo iob update
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "nut"          : 1.5.1    , installed 1.5.1
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tado"         : 0.4.0    , installed 0.4.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    Da ist doch (fast) alles aktuell? Was mir gerade aufgefallen ist: Iobroker lässt mich keinen Adapter mehr entfernen, weder über Web noch über Konsole?
    pi@iobroker:~ $ sudo iob del vw-connect
    Delete adapter "vw-connect"
    host.iobroker Counted 1 meta of vw-connect
    host.iobroker Counted 1 adapter for vw-connect
    host.iobroker Counted 1 states (system.adapter.vw-connect.*) from states
    host.iobroker file vw-connect.admin deleted
    host.iobroker object vw-connect deleted
    host.iobroker object vw-connect.admin deleted
    host.iobroker Deleting 2 object(s).
    host.iobroker Deleting 1 state(s).
    Error deleting adapter vw-connect from disk: host.iobroker: Cannot uninstall iobroker.vw-connect: 217
    You might have to delete it yourself!
    Das Log:
    host.iobroker 2022-09-29 19:19:58.058	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker 2022-09-29 19:19:58.058	error	Caught by controller[0]: }
    host.iobroker 2022-09-29 19:19:58.058	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.iobroker 2022-09-29 19:19:58.058	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.iobroker 2022-09-29 19:19:58.057	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker 2022-09-29 19:19:58.057	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) {
    host.iobroker 2022-09-29 19:19:58.057	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    host.iobroker 2022-09-29 19:19:58.057	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
    host.iobroker 2022-09-29 19:19:58.056	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
    host.iobroker 2022-09-29 19:19:58.056	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iobroker 2022-09-29 19:19:58.056	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.iobroker 2022-09-29 19:19:58.056	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.iobroker 2022-09-29 19:19:58.055	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.iobroker 2022-09-29 19:19:58.055	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
    host.iobroker 2022-09-29 19:19:58.055	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
    host.iobroker 2022-09-29 19:19:58.055	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.iobroker 2022-09-29 19:19:58.054	error	Caught by controller[0]: ^
    host.iobroker 2022-09-29 19:19:58.054	error	Caught by controller[0]: throw err;
    host.iobroker 2022-09-29 19:19:58.053	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
    Muss ich den JS-Controller irgendwie neu installieren?
    @jannis-0 sagte in Error: Cannot find module 'node:os':
    Lass mich raten...
    Error 25?
    https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
    Und verbieg dir nicht die Installation per sudo!
    iobroker stop
    iobroker fix
    iobroker start
    • J Jannis 0
      nach einer richtigen langen Zeit ohne Probleme hat wohl ein Update (apt update, apt upgrade, das ich für Grafana gemacht hatte) irgendetwas zerschossen, was aber nur den Adapter von Tado (Heizung) stört. Sonst funktioniert wohl (?) alles fein wie immer :)
      host.iobroker 2022-09-29 12:37:13.609	error	instance system.adapter.tado.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker 2022-09-29 12:37:13.609	error	Caught by controller[0]: }
      host.iobroker 2022-09-29 12:37:13.608	error	Caught by controller[0]: ]
      host.iobroker 2022-09-29 12:37:13.608	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.tado/main.js'
      host.iobroker 2022-09-29 12:37:13.608	error	Caught by controller[0]: '/opt/iobroker/node_modules/@esm2cjs/is-online/cjs/index.js',
      host.iobroker 2022-09-29 12:37:13.608	error	Caught by controller[0]: requireStack: [
      host.iobroker 2022-09-29 12:37:13.608	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker 2022-09-29 12:37:13.607	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
      host.iobroker 2022-09-29 12:37:13.607	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
      host.iobroker 2022-09-29 12:37:13.607	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker 2022-09-29 12:37:13.607	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@esm2cjs/is-online/cjs/index.js:29:30)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      host.iobroker 2022-09-29 12:37:13.606	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      host.iobroker 2022-09-29 12:37:13.605	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.tado/main.js
      host.iobroker 2022-09-29 12:37:13.605	error	Caught by controller[0]: - /opt/iobroker/node_modules/@esm2cjs/is-online/cjs/index.js
      host.iobroker 2022-09-29 12:37:13.605	error	Caught by controller[0]: Require stack:
      host.iobroker 2022-09-29 12:37:13.605	error	Caught by controller[0]: Error: Cannot find module 'node:os'
      host.iobroker 2022-09-29 12:37:13.605	error	Caught by controller[0]: ^
      host.iobroker 2022-09-29 12:37:13.604	error	Caught by controller[0]: throw err;
      host.iobroker 2022-09-29 12:37:13.604	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
      Der node kann doch gar nicht fehlen, dann würde doch gar nichts mehr laufen? Er wird mir auch brav angezeigt.
      pi@iobroker:/opt/iobroker $ iobroker version
      4.0.23
      pi@iobroker:/opt/iobroker $ nodejs -v
      v16.17.1
      pi@iobroker:/opt/iobroker $ node -v
      v14.19.0
      pi@iobroker:/opt/iobroker $ npm -v
      6.14.16
      Den Tado Adapter habe ich bereits einmal entfernt und neu installiert, hat aber nicht geholfen :(
      Wo liegt denn der Fehler, das ich da was machen kann?
      Tausend Dank :)
      @jannis-0 Der Fehler liegt indirekt am Adapter.
      Der Adpater nutzt eine Librarydie ein Feature nutzt was er seit v16.0.0, v14.18.0 von Node.js verfügbar ist und hat das nicht in seiner package.json angegeben. AM besten Issue beim Adapter anlegen und Du Dein node.js updaten
      • apollon77A apollon77
        @apollon77 nodejs ist aber auf Stand. Fehlt ein Update der Deps im Adapter.
          @jannis-0
          Aah ok, sehe ich jetzt das ihr das eigentlich issue gelöst habt. Ja bitte aktuelle Javsscript Adapter version installieren bzw neu installieren
          • J Offline
            Jannis 0
            schrieb am zuletzt editiert von Jannis 0
            Yepp, hat geklappt: JS läuft nach Re-Installation wieder problemlos.
            Aber der BLE will immer noch nicht, obwohl er den Re-build bekommt:
            ble.0 2022-09-30 08:37:56.279	error	Terminating because A dependency requires a rebuild.
            host.iobroker 2022-09-30 08:36:23.448	info	iobroker npm-rebuild: Rebuilding native modules ...
            host.iobroker 2022-09-30 08:36:13.851	info	iobroker rebuild
            host.iobroker 2022-09-30 08:36:13.851	warn	adapter "ble" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
            host.iobroker 2022-09-30 08:36:13.850	info	system.adapter.ble.0 will be rebuilt
            host.iobroker 2022-09-30 08:36:13.850	info	Adapter system.adapter.ble.0 needs rebuild and will be restarted afterwards.
            host.iobroker 2022-09-30 08:36:13.849	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
            ble.0 2022-09-30 08:36:13.068	info	starting scanner process...
            ble.0 2022-09-30 08:36:13.046	info	monitoring all services
            ble.0 2022-09-30 08:36:13.045	info	enabled plugins: Xiaomi, mi-flora, _default
            ble.0 2022-09-30 08:36:13.044	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
            ble.0 2022-09-30 08:36:12.977	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.17.1, js-controller: 4.0.23
            host.iobroker 2022-09-30 08:36:10.883	info	instance system.adapter.ble.0 started with pid 30495
            host.iobroker 2022-09-30 08:36:10.668	info	iobroker npm-rebuild: exit 0
            host.iobroker 2022-09-30 08:36:09.655	info	iobroker npm-rebuild: Rebuilding native modules done
            host.iobroker 2022-09-30 08:36:09.654	info	iobroker npm-rebuild:
            host.iobroker 2022-09-30 08:36:09.617	info	iobroker npm-rebuild: rebuilt dependencies successfully
            host.iobroker 2022-09-30 08:36:06.512	info	"system.adapter.ble.0" enabled
            und zusätzlich von mir händisch:
            iob rebuild ble
            hilft leider auch nicht :(
            "...different version of Node.js..." macht mich nervös, ich habe ja extra node/nodejs gestern aufgeräumt?
            • J Jannis 0
              iob rebuild ble
              GlasfaserG Offline
              GlasfaserG Offline
              https://forum.iobroker.net/post/863317
              • GlasfaserG Glasfaser
                Jannis 0
                @glasfaser
                pi@iobroker:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.ble
                pi@iobroker:/opt/iobroker/node_modules/iobroker.ble $ npm install --omit=dev
                added 79 packages, and audited 80 packages in 1m
                6 packages are looking for funding
                  run `npm fund` for details
                found 0 vulnerabilities
                pi@iobroker:/opt/iobroker/node_modules/iobroker.ble $ sudo reboot
                BLE läuft wieder mit grün :)
                Dafür ist jetzt der NUT-Adapter für die USV weg?
                nut.0 2022-09-30 09:19:09.193	error	Error happend: Error: connect ECONNREFUSED 192.168.32.153:3493
                nut.0 2022-09-30 09:19:08.959	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.nut, node: v16.17.1, js-controller: 4.0.23
                nut.0 2022-09-30 09:19:03.334	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                nut.0 2022-09-30 09:19:03.331	info	terminating
                nut.0 2022-09-30 09:19:03.328	info	Got terminate signal TERMINATE_YOURSELF
                nut.0 2022-09-30 09:16:46.737	error	Error happend: Error: connect ECONNREFUSED 192.168.32.153:3493
                nut.0 2022-09-30 09:16:46.208	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.nut, node: v16.17.1, js-controller: 4.0.23
                und MI-Home auch:
                mihome-vacuum.0 2022-09-30 09:19:22.286	info	IOT enabled, create state
                mihome-vacuum.0 2022-09-30 09:19:22.201	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.1, js-controller: 4.0.23
                mihome-vacuum.0 2022-09-30 09:19:16.595	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mihome-vacuum.0 2022-09-30 09:19:16.592	info	terminating
                mihome-vacuum.0 2022-09-30 09:19:16.589	error	Socket Close
                mihome-vacuum.0 2022-09-30 09:19:16.583	info	Got terminate signal TERMINATE_YOURSELF
                mihome-vacuum.0 2022-09-30 09:16:55.841	info	IOT enabled, create state
                mihome-vacuum.0 2022-09-30 09:16:55.694	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.1, js-controller: 4.0.23
                • J Jannis 0
                  @glasfaser
                  und MI-Home auch:
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Zu nut ... Verbindung abgelehnt .
                    Jannis 0
                    @glasfaser Es war ein "einfaches" Rechte-Problem von /etc/nut/.
                    Danke euch allen: es läuft! = System wieder 1 Jahr nicht anfassen! ;P
                    • J Jannis 0
                      @jannis-0 sagte in [Gelöst] Error: Cannot find module 'node:os':
                      Dummer Ansatz.
                        Dummer Ansatz.
                        Jannis 0
                        @thomas-braun Wieso denn? Ernst gemeint: was ist denn die Alternative? :)
                        • J Jannis 0
                          @jannis-0
                          Sein System regelmäßig vollständig auf aktuellen Stand halten natürlich.
                          Regelmäßig bedeutet hier nicht einmal im Jahr zu Weihnachten.
                          • J Offline
                            Jannis 0
                            @thomas-braun Ach so, nö. Aktualisierungen kommen schon unterjährig rein :)
