  4. Straßenverkehr - Zählen des Verkehrsaufkommen - Adapter?
    5.8k
telraam
67 Beiträge 6 Kommentatoren 2.9k Aufrufe 6 Beobachtet
    Beowolf
    Habe jetzt node-red installiert.
    Bei den Einstellungen im Adapter - muß ich da noch extra etwas einstellen?
    • B Beowolf
      @mickym
      Dann kommt das
      pi@SVPi-hole:~ $ {"status_code": 200, "message": "ok", "type": "FeatureCollection", "features": [{"type": "Feature", "geometry": {"type": "MultiLineString", "coordinates": [[[4.71129799121917, 50.8643967118925], [4.71131689135236, 50.8642862877756], [4.71132373881259, 50.8642670067756], [4.71137253782927, 50.8641296300352], [4.71143685119098, 50.8639917424206], [4.71151928065087, 50.8638146687918], [4.7116242705432, 50.8636377263723], [4.71172539021883, 50.8635120762697], [4.71176427433283, 50.8633690745834], [4.71188626758468, 50.8627563858191], [4.71190872556415, 50.8626435939865]]]}, "properties": {"oidn": 348917, "first_data_package": "2019-06-26T11:00:00.000Z", "last_data_package": "2021-05-02T10:56:15.402Z", "speed": 50, "oneway": false, "road_type": "", "road_speed": "", "pedestrian": 17.0750988142292, "bike": 103.873517786561, "car": 325.849802371542, "lorry": 19.9209486166008, "speed_histogram": [29.8814229249012, 48.3794466403162, 180.711462450593, 61.1857707509881, 1.42292490118577, 1.42292490118577, 0.0, 2.84584980237154], "speed_buckets": [0, 1, 2, 3, 4, 5, 6, 7]}}]}pi@SVPi-hole:~ $
      -bash: {status_code:: command not found
      mickymM Offline
      mickymM Offline
      mickym
      @beowolf sagte in Straßenverkehr - Zählen des Verkehrsaufkommen - Adapter?:
      Dann kommt das
      Na schaut doch wunderbar aus:
        "status_code": 200,
        "message": "ok",
        "features": [
            "type": "Feature",
            "geometry": {
              "coordinates": [
                    4.71129799121917,
                    50.8643967118925
                    4.71131689135236,
                    50.8642862877756
                    4.71132373881259,
                    50.8642670067756
                    4.71137253782927,
                    50.8641296300352
                    4.71143685119098,
                    50.8639917424206
                    4.71151928065087,
                    50.8638146687918
                    4.7116242705432,
                    50.8636377263723
                    4.71172539021883,
                    50.8635120762697
                    4.71176427433283,
                    50.8633690745834
                    4.71188626758468,
                    50.8627563858191
                    4.71190872556415,
                    50.8626435939865
            "properties": {
              "oidn": 348917,
              "speed": 50,
              "oneway": false,
              "road_type": "",
              "road_speed": "",
                29.8814229249012,
                48.3794466403162,
                180.711462450593,
                61.1857707509881,
                1.42292490118577,
                1.42292490118577,
                0,
                2.84584980237154
              "speed_buckets": [
                0,
                1,
                2,
                3,
                4,
                5,
                6,
      • B Beowolf
        mickymM Offline
        mickymM Offline
        mickym
        Und ggf. Palletten-Manager benutzen.
          Beowolf
          schrieb am zuletzt editiert von Beowolf
          Jetzt kommt das im Protokoll
          node-red.0
          	2022-09-30 18:05:34.225	warn	/opt/iobroker/node_modules/bcryptjs/dist/bcrypt.js:901 0xed93fa9b, 0xe8d3c48d, 0x2 SyntaxError: Unexpected end of input at Object.compileFunction (node:vm:360:18) at wrapSafe (node:internal/modules/cjs/loader:1055:15) at Module._compile (node:internal/modules/cjs/loader:1090:27) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/bcryptjs/index.js:29:18) at Module._compile (node:internal/modules/cjs/loader:1126:14)
          und wenn ich auf Node-Red klicke, kommt
          kann keine Verbindung zu dem Server unter 192.168.49.38:1880 aufbauen.
          • B Beowolf
            node-red.0
            mickymM Offline
            mickymM Offline
            mickym
            @beowolf Oje - dann hast Du wahrscheinlich wieder ein Systemproblem auf deiner Maschine und der Adapter installiert nicht richtig.
            Dann schmeiss den Adapter wieder runter. Dann müssen wir es halt wohl oder übel mit JS versuchen. Ansonsten musst halt deine Maschine auf Vordermann bringen. NodeJS und siehe Fehler 25 oben.
            Das ist aber wohl ein eigenes Thema und passt sicher nicht hierher.
            • mickymM mickym
              Beowolf
              @mickym sagte in Straßenverkehr - Zählen des Verkehrsaufkommen - Adapter?:
              Das nervt ein wenig an ioBroker. Hatte ihn neu aufgesetzt und trotzdem diese Fehlermeldung.
              Bin jetzt erst weg. Danke für die Hilfe.
                Beowolf
                So,
                ich habe jetzt mal eine ältere Version installiert. Diese dann deinstalliert und dann wieder die 4.0 installiert.
                Jetzt habe ich dieses "Startfenster" wenn ich Node-Red starte.
                Ist das dann so richtig? Der Node-Red Adapter heist 4.0.0
                Das hat aber mit Node-Red 3.0 nichts zu tun, oder?
                • B Beowolf
                  So,
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @beowolf Ja das ist richtig - Adapter 4.0.0 enthält Version 3.0.2 von Node Red - damit bist du auf neuestem Stand.
                  • mickymM mickym
                    Beowolf
                    @mickym
                    Jepp - Version 3.0.2
                    • B Beowolf
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @beowolf Wenn Du dann soweit bist, sag Bescheid.
                        Beowolf
                        Bescheid
                        Bescheid
                        • B Beowolf
                          Bescheid
                          Bescheid
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @beowolf Gut nachdem Du noch nie mit Node Red gearbeitet - hast - hier mal ein paar einfache Dinge, damit Du das importieren kannst, was ich hier poste:
                          Da ich keinen gültigen API Key habe - musst Du das halt entsprechend ändern und ggf. den Output hier posten:
                          Um diesen kleinen Flow zu importieren, öffnest Du den Spoiler und kopierst den Code in die Zwischenablage.
                                 "id": "e15dd6a9358db81a",
                                 "type": "http request",
                                 "z": "289f539dcc33814e",
                                 "name": "",
                                 "method": "GET",
                                 "ret": "txt",
                                 "paytoqs": "ignore",
                                 "url": "https://telraam-api.net/v1",
                                 "tls": "",
                                 "persist": false,
                                 "proxy": "",
                                 "insecureHTTPParser": false,
                                 "authType": "",
                                 "senderr": false,
                                 "headers": [
                                         "keyType": "other",
                                         "keyValue": "X-Api-Key",
                                         "valueType": "other",
                                         "valueValue": "gw66fwef89"
                                 "credentials": {},
                                 "x": 690,
                                 "y": 3020,
                                 "wires": [
                                         "8d5ab3a2329e56f6"
                                 "id": "281b6d18fa782690",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "true",
                                 "payloadType": "bool",
                                 "x": 510,
                                 "y": 3020,
                                 "wires": [
                                         "e15dd6a9358db81a"
                                 "id": "8d5ab3a2329e56f6",
                                 "type": "debug",
                                 "name": "Straßenverkehrzahlen",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "payload",
                                 "targetType": "msg",
                                 "statusVal": "",
                                 "statusType": "auto",
                                 "x": 920,
                                 "y": 3020,
                                 "wires": []
                          Den Import machst Du folgendermassen- Du gehst in das Menü - 3 Striche in der schwarzen Tielleiste und dann import.
                          Dann kopierst Du den Inhalt der Zwischenablage - da rein:
                          und drückst auf Import:
                          Anschließend drückst Du auf Übernehmen:
                          Anschließend klickst Du auf die HTTP-Request Node und gibst dort deinen API-Key ein - dann meldest Dich wenn Du soweit bist.
                          das Debug Fenster ist der Käfer. ;)
                            Beowolf
                            jepp -hab ich
                            • B Beowolf
                              jepp -hab ich
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @beowolf Trigger tust Du in dem Du auf den Knopf links neben der Inject Node drückst - dann bitte die Ausgabe des Debug-Fensters posten:
                                Beowolf
                                "msg": "hello! Telraam server 2.0 is up and running",
                                "env": "prod"
                                • B Beowolf
                                  "env": "prod"
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @beowolf Sehr gut - bitte zukünftig - das einfach in Code-Tags den Output dann kann ich das dann selbst bearbeiten.
                                  Jedenfalls funktioniert mal dein API - Key.
                                  Jetzt kannst Du die API ja schon nutzen inde Du in die HTTP Request node - oben in der URL erst mal die URL austauscst mit der ID die Dich interessiert - also sollte ja dann der gleiche Output rauskommen wie mit der CURL.
                                  Es sollte also so ein Objekt rauskommen:
                                    Beowolf
                                    Bei
                                    https://telraam-api.net/v1/cameras/segment/9000002533
                                    kommt das
                                    {"status_code": 200, "message": "ok", "camera": [{"instance_id": 5843, "mac": 202481599336532, "user_id": 4381, "segment_id": 9000002533, "direction": true, "status": "active", "manual": false, "time_added": "2022-09-09T13:27:57.864Z", "time_end": null, "last_data_package": "2022-10-02T20:12:41.696Z", "first_data_package": "2022-09-09T13:28:05.011Z", "pedestrians_left": true, "pedestrians_right": true, "bikes_left": true, "bikes_right": true, "cars_left": true, "cars_right": true, "is_calibration_done": "yes", "hardware_version": 0}, {"instance_id": 4013, "mac": 202481592368789, "user_id": 4381, "segment_id": 9000002533, "direction": true, "status": "non_active", "manual": false, "time_added": "2021-08-07T16:54:47.641Z", "time_end": null, "last_data_package": "2021-10-15T10:08:29.443Z", "first_data_package": "2021-08-07T17:00:00.000Z", "pedestrians_left": true, "pedestrians_right": true, "bikes_left": true, "bikes_right": true, "cars_left": true, "cars_right": true, "is_calibration_don...
                                    • B Beowolf
                                      Bei
                                      kommt das
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      Um den Wert richtig reinzukopieren. musst Du den Wert kopieren und zwar über das Debug Fenster mit der Schaltfläche Wert kopieren und zwar ganz oben die payload:
                                      Ist aber egal ich denke es dürfte ähnlich sein, wie das was ich gerade kopiert habe.
                                      • mickymM mickym
                                        Beowolf
                                        @mickym
                                        Bei mir sieht das so aus
                                        • B Beowolf
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @beowolf Ah OK - dann war das mein Fehler - in der Http-Request Node bitte auf JSON Objekt umstellen:
