  4. javascript - fehler im log nach update
    3.2k
    3.1k
errorjavascript
5 Beiträge 3 Kommentatoren 744 Aufrufe 3 Beobachtet
  • bahnuhrB Offline
    bahnuhrB Offline
    bahnuhr
    ich habe eben mein System von 16.17.0 auf 16.17.1 gebracht.
    Beim Starten von iob hat dann der js folgenden Fehler ausgeworfen.
    host.iobroker
    2022-09-25 08:43:49.225	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker
    2022-09-25 08:43:49.225	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2022-09-25 08:43:49.225	error	Caught by controller[0]: }
    host.iobroker
    2022-09-25 08:43:49.225	error	Caught by controller[0]: requestPath: 'virtual-tsc'
    host.iobroker
    2022-09-25 08:43:49.225	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/package.json',
    host.iobroker
    2022-09-25 08:43:49.224	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    2022-09-25 08:43:49.224	error	Caught by controller[0]: {
    host.iobroker
    2022-09-25 08:43:49.224	error	Caught by controller[0]: at node:internal/main/run_main_module:17:47
    host.iobroker
    2022-09-25 08:43:49.224	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    host.iobroker
    2022-09-25 08:43:49.224	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:22:24)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iobroker
    2022-09-25 08:43:49.223	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.iobroker
    2022-09-25 08:43:49.222	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.iobroker
    2022-09-25 08:43:49.222	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.iobroker
    2022-09-25 08:43:49.222	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
    host.iobroker
    2022-09-25 08:43:49.222	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
    host.iobroker
    2022-09-25 08:43:49.222	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js'. Please verify that the package.json has a valid "main" entry
    host.iobroker
    2022-09-25 08:43:49.221	error	Caught by controller[0]: ^
    host.iobroker
    2022-09-25 08:43:49.221	error	Caught by controller[0]: throw err;
    host.iobroker
    2022-09-25 08:43:49.221	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
    host.iobroker
    2022-09-25 08:43:48.865	info	instance system.adapter.javascript.0 started with pid 53047
    Vorher wurde 3x versucht einen rebuild zu machen.
    Wie in der letzten Zeile (oben) wurd manuell installiert.
    Also per putty:
    npm install iobroker.javascript --production
    Dies scheint geklappt zu haben, der Adapter wird grün.
    Im log kamen aber immer noch:
    javascript.0
    2022-09-25 08:46:01.157	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.0
    2022-09-25 08:46:01.155	error	npm
    javascript.0
    2022-09-25 08:46:00.880	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.0
    2022-09-25 08:46:00.878	error	npm
    javascript.0
    2022-09-25 08:46:00.500	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.0
    2022-09-25 08:46:00.498	error	npm
    javascript.0
    2022-09-25 08:46:00.083	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    javascript.0
    2022-09-25 08:45:51.161	info	npm install express --omit=dev (System call)
    javascript.0
    2022-09-25 08:45:51.105	info	starting. Version 6.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.17.1, js-controller: 4.0.23
    Könnt ihr mir sagen, was es damit auf sich hat ?
    Fragen:
    warum wurde der rebuild nicht durchgeführt ?
    Was sind dies für Fehlermeldungen ?
    mfg
    Dieter
    Nachtrag:
    Der issue Hinweis kommt nicht von mir; wurde automatisch eingesetzt.
    Danke.
    • bahnuhrB bahnuhr
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      Also per putty:
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Fragen:
      mfg
      Dieter
      Nachtrag:
      krobi
      schrieb am zuletzt editiert von krobi
      @bahnuhr du hast nodejs upgedatet aber sonst nix. Welche Version hat den dein JavaScript Adapter? Meiner hat Version 6.0.3.
      Edit: ah sorry sehe im log dass das passt, iob fix schon probiert?
      • K krobi
        bahnuhrB Offline
        bahnuhrB Offline
        bahnuhr
        @krobi sagte in javascript - fehler im log nach update:
        iob fix
        probier ich gleich.
        Danke.
        • bahnuhrB bahnuhr
          iob fix
          probier ich gleich.
          @bahnuhr
          Was ist denn jetzt konkret das Problem? Läuft doch.
            @bahnuhr
            bahnuhrB Offline
            bahnuhrB Offline
            bahnuhr
            @thomas-braun sagte in javascript - fehler im log nach update:
            @bahnuhr
            Wollte halt nur wissen warum dies überhaupt kam.
            Aber ja, es läuft.
            Danke.
