  4. Node-Red
  5. Node Red Fehler bei Aktualisierung auf 4.0.0
    3.2k
    3.1k
7 Beiträge 2 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • F Offline
    frankyboy73
    Hi, ich habe versucht auf die Node Red Version 4.0.0 zu aktualisieren. Die Aktualisierung wurde mit Fehler Code 25 beendet. Jetzt kann ich den Adapter nicht mehr neu starten bzw. versucht er dauerhaft neu zu starten und gibt folgende Meldungen raus.
    node-red.0
    2022-09-22 18:49:32.147	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    host.raspberrypi
    2022-09-22 18:49:31.631	info	stopInstance timeout 5000 system.adapter.node-red.0 killing pid 3254
    node-red.0
    2022-09-22 18:49:30.526	info	node-red exited with 1
    node-red.0
    2022-09-22 18:49:30.513	warn	node:internal/modules/cjs/loader:959 throw err; ^Error: Cannot find module 'jsonfile/utils'Require stack:- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js- /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ]}
    node-red.0
    2022-09-22 18:49:29.466	info	Starting node-red: --max-old-space-size=1024 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    host.raspberrypi
    2022-09-22 18:49:26.630	info	stopInstance system.adapter.node-red.0 (force=false, process=true)
    host.raspberrypi
    2022-09-22 18:49:26.628	info	"system.adapter.node-red.0" disabled
    Schöne Grüße Frank
    • F frankyboy73
      node-red.0
      host.raspberrypi
      node-red.0
      node-red.0
      node-red.0
      host.raspberrypi
      host.raspberrypi
      @frankyboy73
      https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
      Dann
      iob update
      F 1 Antwort Letzte Antwort
        @frankyboy73
        Dann
        iob update
        frankyboy73
        Hi, habe ich gemacht, leider keine Änderung. Wenn ich zurück gehe auf NodeRed 3.3.1 funktioniert wieder alles, aber die 4.0.0 will nicht.
        $ iobroker upgrade node-red@4.0.0 --debug
        Update node-red from @3.3.1 to @4.0.0
        host.raspberrypi Adapter "system.adapter.node-red.0" is stopped.
        Installing iobroker.node-red@4.0.0... (System call)
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
        ERROR: Process exited with code 25
        pi@raspberrypi:~ $ iob update
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.5
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.9
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "node-red"     : 4.0.0    , installed 4.0.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sql"          : 2.1.8    , installed 2.1.8
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Schöne Grüße Frank
        • F frankyboy73
          @frankyboy73 sagte in Node Red Fehler bei Aktualisierung auf 4.0.0:
          Mach es über die richtige Konsole, nicht über die GUI.
            frankyboy73
            @thomas-braun Vielen Dank, jetzt scheint Alles wieder zu laufen. Beim ersten Versuch über das Konsole hatte ich noch ne Meldung das ich nen Ordner umbenennen sollte. Habe dann nochmals in /opt/iobroker/node_modules den Einzeiler drüber laufen lassen, danach ging das Update. Vielen Dank.
            Sollte ich in Zukunft immer Updates über die Konsole machen und nicht über die GUI?
            Schöne Grüße Frank
            • F frankyboy73
              Ich mach das bei meinen Systemen ausschließlich über das Terminal. Das lügt dich nicht an, das schluckt keine Meldungen, das ist schneller, das ist genauer, das tut was es tun soll. Ich mag die Konsole.
                frankyboy73
                @thomas-braun Stimmt, ohne hätte ich die Meldung auch nicht gesehen, dann werde ich das in Zukunft auch so machen, danke nochmal.
                Schöne Grüße Frank
