  4. Test Adapter HAM 5.2.0 (GitHub)
98 Beiträge 10 Kommentatoren 17.0k Aufrufe 14 Beobachtet
  • apollon77A Offline
    So also dann neuer Versuch @iPhilBln und alle ... Bitte 5.2.2 testen
    FabioF iPhilBlnI 2 Antworten Letzte Antwort
    • apollon77A apollon77
      FabioF Offline
      FabioF Offline
      Fabio
      schrieb am zuletzt editiert von Fabio
      @apollon77 geht leider nicht.
      2022-09-14 11:24:36.456 warn Do not restart adapter system.adapter.ham.0 because restart loop detected
      host.nuc
      2022-09-14 11:24:36.456	error	instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
      host.nuc
      host.nuc
      host.nuc
      host.nuc
      host.nuc
      host.nuc
      host.nuc
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82)
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[2]: at Array.shift (<anonymous>)
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[2]: [14.9.2022, 11:24:35] [ connectivity kit] RangeError: Maximum call stack size exceeded
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[1]: [14.9.2022, 11:24:35] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      host.nuc
      2022-09-14 11:24:36.456	error	Caught by controller[0]: [14.9.2022, 11:24:35] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      Iobroker:
      • Matter over Thread Hilfe
      • FabioF Fabio
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        host.nuc
        @fa-bio Ok,d as scheint irgendwie aber seeehr Pluginspezifisch zu sein. Hab Dir ne PN geschickt.
        FabioF 1 Antwort Letzte Antwort
          iPhilBlnI Offline
          iPhilBlnI Offline
          iPhilBln
          @apollon77 leider keine Änderung. Was mich nach wie vor wundert ist, dass die Debug Nachrichten nur 2 mal im Log bei der Initialisierung erscheinen, obwohl die Daten richtig abgeholt werden, wenn ich den Ventilator über die App steuere.
          log : ham.log.zip
            FabioF Offline
            FabioF Offline
            Fabio
            @apollon77
            host.nuc
            2022-09-14 12:14:57.525	info	Restart adapter system.adapter.ham.0 because enabled
            host.nuc
            2022-09-14 12:14:57.525	error	instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
            host.nuc
            host.nuc
            host.nuc
            host.nuc
            host.nuc
            host.nuc
            host.nuc
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82)
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[2]: at Array.shift (<anonymous>)
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[2]: [14.9.2022, 12:14:56] [ connectivity kit] RangeError: Maximum call stack size exceeded
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[1]: [14.9.2022, 12:14:56] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            host.nuc
            2022-09-14 12:14:57.525	error	Caught by controller[0]: [14.9.2022, 12:14:56] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            ham.0
            2022-09-14 12:14:57.175	debug	updateState Markise.Window-Covering.Name: set postponed value = Markise
            ham.0
            2022-09-14 12:14:57.129	debug	updateState Flurmarkise.Window-Covering.Name: set postponed value = Flurmarkise
            ham.0
            2022-09-14 12:14:57.129	info	updateState Markise.Window-Covering.Name: value = Markise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.086	debug	updateState Markise.Window-Covering.Target-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.086	debug	updateState Elternmarkise.Window-Covering.Name: set postponed value = Elternmarkise
            ham.0
            2022-09-14 12:14:57.085	info	updateState Flurmarkise.Window-Covering.Name: value = Flurmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.084	debug	updateState Büromarkise.Window-Covering.Name: set postponed value = Büromarkise
            ham.0
            2022-09-14 12:14:57.083	debug	updateState Flurmarkise.Window-Covering.Target-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.083	info	updateState Markise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
            ham.0
            2022-09-14 12:14:57.081	info	updateState Elternmarkise.Window-Covering.Name: value = Elternmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.080	debug	updateState Connectivity-kit-ledBox.Lightbulb.Brightness: set postponed value = 14
            ham.0
            2022-09-14 12:14:57.080	info	updateState Büromarkise.Window-Covering.Name: value = Büromarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.079	debug	updateState Markisenbeleuchtung.Switch.Name: set postponed value = Markisenbeleuchtung
            ham.0
            2022-09-14 12:14:57.078	debug	updateState Markise.Window-Covering.Position-State: set postponed value = 2
            ham.0
            2022-09-14 12:14:57.078	info	updateState Flurmarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
            ham.0
            2022-09-14 12:14:57.074	debug	updateState Elternmarkise.Window-Covering.Target-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.074	debug	updateState Büromarkise.Window-Covering.Target-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.074	info	updateState Connectivity-kit-ledBox.Lightbulb.Brightness: value = 14 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.brightness","name":"Brightness"}
            ham.0
            2022-09-14 12:14:57.073	info	updateState Markisenbeleuchtung.Switch.Name: value = Markisenbeleuchtung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.072	debug	updateState Flurmarkise.Window-Covering.Position-State: set postponed value = 2
            ham.0
            2022-09-14 12:14:57.072	info	updateState Markise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
            ham.0
            2022-09-14 12:14:57.071	debug	updateState Connectivity-kit-ledBox.Lightbulb.Name: set postponed value = Connectivity kit-ledBox
            ham.0
            2022-09-14 12:14:57.070	info	updateState Elternmarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
            ham.0
            2022-09-14 12:14:57.070	info	updateState Büromarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
            ham.0
            2022-09-14 12:14:57.069	debug	updateState Markisenbeleuchtung.Switch.On: set postponed value = false
            ham.0
            2022-09-14 12:14:57.068	debug	updateState Markise.Window-Covering.Current-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.068	info	updateState Flurmarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
            ham.0
            2022-09-14 12:14:57.066	debug	updateState Elternmarkise.Window-Covering.Position-State: set postponed value = 2
            ham.0
            2022-09-14 12:14:57.066	debug	updateState Büromarkise.Window-Covering.Position-State: set postponed value = 2
            ham.0
            2022-09-14 12:14:57.065	info	updateState Connectivity-kit-ledBox.Lightbulb.Name: value = Connectivity kit-ledBox /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:57.065	info	updateState Markisenbeleuchtung.Switch.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
            ham.0
            2022-09-14 12:14:57.064	info	updateState Markise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
            ham.0
            2022-09-14 12:14:57.063	debug	updateState Flurmarkise.Window-Covering.Current-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.062	info	updateState Elternmarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
            ham.0
            2022-09-14 12:14:57.061	info	updateState Büromarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
            ham.0
            2022-09-14 12:14:57.058	debug	updateState Connectivity-kit-ledBox.Lightbulb.On: set postponed value = false
            ham.0
            2022-09-14 12:14:57.057	debug	updateState Elternmarkise.Window-Covering.Current-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.057	info	updateChannel Markisenbeleuchtung.Switch: name =
            ham.0
            2022-09-14 12:14:57.057	debug	updateState Büromarkise.Window-Covering.Current-Position: set postponed value = 0
            ham.0
            2022-09-14 12:14:57.055	info	updateChannel Markise.Window-Covering: name =
            ham.0
            2022-09-14 12:14:57.055	info	updateState Flurmarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
            ham.0
            2022-09-14 12:14:57.053	info	updateState Connectivity-kit-ledBox.Lightbulb.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
            ham.0
            2022-09-14 12:14:57.052	info	updateState Elternmarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
            ham.0
            2022-09-14 12:14:57.051	info	updateState Büromarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
            ham.0
            2022-09-14 12:14:57.051	info	updateChannel Flurmarkise.Window-Covering: name =
            ham.0
            2022-09-14 12:14:57.050	debug	updateState Markisenbeleuchtung.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.049	debug	updateState Markise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.048	info	updateChannel Connectivity-kit-ledBox.Lightbulb: name =
            ham.0
            2022-09-14 12:14:57.047	info	updateChannel Elternmarkise.Window-Covering: name =
            ham.0
            2022-09-14 12:14:57.046	info	updateChannel Büromarkise.Window-Covering: name =
            ham.0
            2022-09-14 12:14:57.045	info	updateState Markisenbeleuchtung.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:57.045	debug	updateState Flurmarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.043	info	updateState Markise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:57.043	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.042	debug	updateState Elternmarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.042	debug	updateState Büromarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
            ham.0
            2022-09-14 12:14:57.041	debug	updateState Markisenbeleuchtung.Accessory-Information.Serial-Number: set postponed value = ogp:9341619
            ham.0
            2022-09-14 12:14:56.998	info	updateState Flurmarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:56.998	debug	updateState Markise.Accessory-Information.Serial-Number: set postponed value = ogp:922101
            ham.0
            2022-09-14 12:14:56.997	info	updateState Connectivity-kit-ledBox.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:56.996	info	updateState Büromarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:56.995	info	updateState Markisenbeleuchtung.Accessory-Information.Serial-Number: value = ogp:9341619 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.996	info	updateState Elternmarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            ham.0
            2022-09-14 12:14:56.994	debug	updateState Flurmarkise.Accessory-Information.Serial-Number: set postponed value = ogp:6106340
            ham.0
            2022-09-14 12:14:56.993	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Serial-Number: set postponed value = ogp:15728639
            ham.0
            2022-09-14 12:14:56.993	debug	updateState Elternmarkise.Accessory-Information.Serial-Number: set postponed value = ogp:13160805
            ham.0
            2022-09-14 12:14:56.992	debug	updateState Büromarkise.Accessory-Information.Serial-Number: set postponed value = ogp:12414329
            ham.0
            2022-09-14 12:14:56.992	info	updateState Markise.Accessory-Information.Serial-Number: value = ogp:922101 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.991	debug	updateState Markisenbeleuchtung.Accessory-Information.Name: set postponed value = Markisenbeleuchtung
            ham.0
            2022-09-14 12:14:56.990	info	updateState Flurmarkise.Accessory-Information.Serial-Number: value = ogp:6106340 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.989	info	updateState Connectivity-kit-ledBox.Accessory-Information.Serial-Number: value = ogp:15728639 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.988	info	updateState Elternmarkise.Accessory-Information.Serial-Number: value = ogp:13160805 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.988	info	updateState Büromarkise.Accessory-Information.Serial-Number: value = ogp:12414329 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            ham.0
            2022-09-14 12:14:56.988	debug	updateState Markise.Accessory-Information.Name: set postponed value = Markise
            ham.0
            2022-09-14 12:14:56.987	info	updateState Markisenbeleuchtung.Accessory-Information.Name: value = Markisenbeleuchtung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.986	debug	updateState Flurmarkise.Accessory-Information.Name: set postponed value = Flurmarkise
            ham.0
            2022-09-14 12:14:56.985	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Name: set postponed value = Connectivity kit-ledBox
            ham.0
            2022-09-14 12:14:56.985	debug	updateState Elternmarkise.Accessory-Information.Name: set postponed value = Elternmarkise
            ham.0
            2022-09-14 12:14:56.984	debug	updateState Büromarkise.Accessory-Information.Name: set postponed value = Büromarkise
            ham.0
            2022-09-14 12:14:56.984	info	updateState Markise.Accessory-Information.Name: value = Markise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.983	debug	updateState Markisenbeleuchtung.Accessory-Information.Model: set postponed value = Light
            ham.0
            2022-09-14 12:14:56.982	info	updateState Flurmarkise.Accessory-Information.Name: value = Flurmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.982	info	updateState Connectivity-kit-ledBox.Accessory-Information.Name: value = Connectivity kit-ledBox /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.981	info	updateState Elternmarkise.Accessory-Information.Name: value = Elternmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.980	info	updateState Büromarkise.Accessory-Information.Name: value = Büromarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            ham.0
            2022-09-14 12:14:56.978	debug	updateState Markise.Accessory-Information.Model: set postponed value = Awning
            ham.0
            2022-09-14 12:14:56.978	debug	updateState Flurmarkise.Accessory-Information.Model: set postponed value = Awning
            ham.0
            2022-09-14 12:14:56.978	info	updateState Markisenbeleuchtung.Accessory-Information.Model: value = Light /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.978	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Model: set postponed value = Light
            ham.0
            2022-09-14 12:14:56.977	debug	updateState Elternmarkise.Accessory-Information.Model: set postponed value = Awning
            ham.0
            2022-09-14 12:14:56.977	debug	updateState Büromarkise.Accessory-Information.Model: set postponed value = Awning
            ham.0
            2022-09-14 12:14:56.974	info	updateState Markise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.974	info	updateState Flurmarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.972	info	updateState Connectivity-kit-ledBox.Accessory-Information.Model: value = Light /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.972	info	updateState Elternmarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.972	info	updateState Büromarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            ham.0
            2022-09-14 12:14:56.970	debug	updateState Markisenbeleuchtung.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.969	debug	updateState Markise.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.969	debug	updateState Flurmarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.968	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.968	debug	updateState Elternmarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.968	debug	updateState Büromarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
            ham.0
            2022-09-14 12:14:56.966	info	updateState Markisenbeleuchtung.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.966	info	updateState Markise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.965	info	updateState Flurmarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.965	info	updateState Connectivity-kit-ledBox.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.964	info	updateState Elternmarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.963	info	updateState Büromarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
            ham.0
            2022-09-14 12:14:56.963	debug	updateState Markisenbeleuchtung.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.962	debug	updateState Markise.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.962	debug	updateState Flurmarkise.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.961	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.961	debug	updateState Elternmarkise.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.959	debug	updateState Büromarkise.Accessory-Information.Identify: set value = false
            ham.0
            2022-09-14 12:14:56.958	info	updateState Markisenbeleuchtung.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.958	info	updateState Markise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.958	info	updateState Flurmarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.957	info	updateState Connectivity-kit-ledBox.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.957	info	updateState Elternmarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.956	info	updateState Büromarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
            ham.0
            2022-09-14 12:14:56.953	info	updateChannel Markisenbeleuchtung.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.952	info	updateChannel Markise.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.952	info	updateChannel Flurmarkise.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.951	info	updateChannel Connectivity-kit-ledBox.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.951	info	updateChannel Elternmarkise.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.950	info	updateChannel Büromarkise.Accessory-Information: name =
            ham.0
            2022-09-14 12:14:56.947	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            ham.0
            2022-09-14 12:14:56.947	info	terminating
            ham.0
            2022-09-14 12:14:56.943	info	cleaned everything up...
            ham.0
            2022-09-14 12:14:56.935	error	Maximum call stack size exceeded
            ham.0
            2022-09-14 12:14:56.934	error	RangeError: Maximum call stack size exceeded at Array.shift (<anonymous>) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
            ham.0
            2022-09-14 12:14:56.926	error	unhandled promise rejection: Maximum call stack size exceeded
            ham.0
            2022-09-14 12:14:56.926	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            ham.0
            2022-09-14 12:14:56.925	debug	setState Markise.Window-Covering.Name: set value = Markise
            ham.0
            2022-09-14 12:14:56.923	debug	Char change event: undefined --> Markise
            ham.0
            2022-09-14 12:14:56.923	debug	setState Flurmarkise.Window-Covering.Name: set value = Flurmarkise
            ham.0
            2022-09-14 12:14:56.922	debug	Char change event: undefined --> Flurmarkise
            ham.0
            2022-09-14 12:14:56.922	debug	setState Elternmarkise.Window-Covering.Name: set value = Elternmarkise
            ham.0
            2022-09-14 12:14:56.920	debug	Char change event: undefined --> Elternmarkise
            ham.0
            2022-09-14 12:14:56.920	debug	setState Büromarkise.Window-Covering.Name: set value = Büromarkise
            ham.0
            2022-09-14 12:14:56.918	debug	Char change event: undefined --> Büromarkise
            ham.0
            2022-09-14 12:14:56.918	debug	setState Markise.Window-Covering.Target-Position: set value = 0
            ham.0
            2022-09-14 12:14:56.916	debug	setState Flurmarkise.Window-Covering.Target-Position: set value = 0
            ham.0
            2022-09-14 12:14:56.915	debug	Char change event: undefined --> 0
            ham.0
            2022-09-14 12:14:56.916	debug	Char change event: undefined --> 0
            ham.0
            2022-09-14 12:14:56.915	debug	setState Connectivity-kit-ledBox.Lightbulb.Brightness: set value = 14
            ham.0
            2022-09-14 12:14:56.913	debug	Char change event: undefined --> 14
            ham.0
            2022-09-14 12:14:56.913	debug	setState Elternmarkise.Window-Covering.Target-Position: set value = 0
            ham.0
            2022-09-14 12:14:56.911	debug	Char change event: undefined --> 0
            ham.0
            2022-09-14 12:14:56.911	debug	setState Büromarkise.Window-Covering.Target-Position: set value = 0
            ham.0
            2022-09-14 12:14:56.909	debug	Char change event: undefined --> 0
            ham.0
            2022-09-14 12:14:56.909	debug	setState Markisenbeleuchtung.Switch.Name: set value = Markisenbeleuchtung
            ham.0
            2022-09-14 12:14:56.907	debug	Char change event: undefined --> Markisenbeleuchtung
            ham.0
            2022-09-14 12:14:56.907	debug	setState Markise.Window-Covering.Position-State: set value = 2
            Iobroker:
            • iPhilBlnI iPhilBln
              log : ham.log.zip
              @iphilbln Du hast aber schon gesehen was er so geloggt hat?
              zb:
              2022-09-14 11:32:18.033 - debug: ham.0 (106531) Characteristic warning for Standventilator.Standventilator.Swing-Mode: warn-message characteristic was supplied illegal value: number 30 exceeded maximum of 1 Error:
              Rotation Speed auf 30 sieht für mich so aus als ob es geklappt hat weil es vom device nochmal bestätigt wurde
              Ok nur Active ist komisch ...ich schaue nochmal
              EDIT: Ne nix komisch nur meine lokalen Fake-Änderungen weil ich so ein Gerät nicht habe waren weg ...
              Also bei mir geht das alles und es ändern sich auch werte.
              Bei Dir im Log ist nur auffällig das Du Active scheinbar immer aus schaltest (auf 0) .... die 1-Werte kommen immer nur wenn das gerät die setzt scheinbar ?!
              Ich bin gerade am Ende meiner Idee was Dein Xiaomi Fan kram angeht. Lokal kann ich sehen das die Calls da in der Library ankommen wo Sie sollen ... Keine Idee warum das bei dir nicht tut
              iPhilBlnI 1 Antwort Letzte Antwort
                zb:
                iPhilBlnI Offline
                iPhilBlnI Offline
                iPhilBln
                @apollon77
                --> War mein versehen, hab den falschen Datenpunkt geändert weil der direkt unter fanspeed ist. Hat also keine Aussagekraft.
                Hmm ja wie gesagt, wenn ich im ioBroker die Datenpunkte ändere kommt nichts an, würde ja sonst auch im Log stehen. Hatte jetzt in der Zwischenzeit auch mal den gesamten Adapter gelöscht und nen clean install durchgeführt aber Verhalten bleibt identisch. Daten werden abgeholt, können aber nicht gesetzt werden.
                Sofern du Lust und Zeit hast könntest du mir noch eine index.js (oder auch andere Dateien) zukommen lassen, wo weitere logging Punkte enthalten sind. Dann füge ich die gerne mit ein. Mehr kann ich denke ich nicht tun bis auf das Angebot mit nem VPN Zugang. Trotzdem schon mal riesen Dank für deine Bemühungen.
                  @apollon77
                  @iphilbln sagte in Test Adapter HAM 5.2.0 (GitHub):
                  Und du bist sicher das die index.js noch mit dem Logging drin und nicht überschrieben wurde? :-)
                  naja neben VPN wäre ich eher bei einer Anydesk session. Freitag ggf dafür zeit
                  • FabioF Fabio
                    @apollon77
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    host.nuc
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    ham.0
                    @fa-bio Ok, seems there was a buggy plugin version on npm ... we try if fixed version of plugin work again
                      FabioF Offline
                      FabioF Offline
                      Fabio
                      @apollon77 ich danke dir ganz herzlich.
                      So, dank dir läuft jetzt auch die 5.2.2 perfekt mit dem homebridge-tahoma@2.241 Plug in. 👍
                      Iobroker:
                        iPhilBlnI Offline
                        iPhilBlnI Offline
                        iPhilBln
                        schrieb am zuletzt editiert von iPhilBln
                        @apollon77 ja bin mir da absolut sicher.
                        Ich bearbeite die über VS Code mit nem ssh Zugang.
                        Dein Wrapper Modul lädt die Module unter folgendem Pfad:
                        /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-xiaomi-fan
                        Die index.js sieht aktuell wie folgt aus:
                         /*----------========== HOMEBRIDGE STATE SETTERS/GETTERS ==========----------*/
                          getPowerState(callback) {
                            let isFanOn = false;
                            if (this.fanDevice && this.fanDevice.isFanConnected()) {
                              isFanOn = this.fanDevice.isPowerOn();
                            this.logInfo(`DEBUG: getPowerState() -> Callback: ${isFanOn}`);
                            callback(null, isFanOn ? Characteristic.Active.ACTIVE : Characteristic.Active.INACTIVE);
                          setPowerState(state, callback) {
                            this.logInfo(`DEBUG: setPowerState() -> value: ${state}`);
                              let isPowerOn = state === Characteristic.Active.ACTIVE;
                              // only fire the setPowerOn method when we want to turn off the fan or the fan is off
                              // the rotaion speed slider fires this method many times even when the fan is already on so i need to limit that
                              if (isPowerOn === false || this.fanDevice.isPowerOn() === false) {
                                this.fanDevice.setPowerOn(isPowerOn);
                              this.logInfo(`DEBUG: setPowerState() -> Callback: ${isPowerOn}`);
                              callback();
                            } else {
                              this.logInfo(`DEBUG: setPowerState() -> Callback: cannot set power state`);
                              callback(this.createError(`cannot set power state`));
                          getFanState(callback) {
                            let fanState = Characteristic.CurrentFanState.INACTIVE;
                              fanState = this.fanDevice.isPowerOn() ? Characteristic.CurrentFanState.BLOWING_AIR : Characteristic.CurrentFanState.IDLE
                            this.logInfo(`DEBUG: getFanState() -> Callback: ${fanState}`);
                            callback(null, fanState);
                          getRotationSpeed(callback) {
                            let fanRotationSpeed = 0;
                              fanRotationSpeed = this.fanDevice.getRotationSpeed();
                              fanRotationSpeed = this.adjustToPercentageRange(fanRotationSpeed);
                            this.logInfo(`DEBUG: getRotationSpeed() -> Callback: ${fanRotationSpeed}`);
                            callback(null, fanRotationSpeed);
                          setRotationSpeed(value, callback) {
                            this.logInfo(`DEBUG: setRotationSpeed() -> value: ${value}`);
                              // use debounce to limit the number of calls when the user slides the rotation slider
                              if (this.rotationSpeedTimeout) clearTimeout(this.rotationSpeedTimeout);
                              this.rotationSpeedTimeout = setTimeout(() => this.fanDevice.setRotationSpeed(value), 500);
                              this.logInfo(`DEBUG: setRotationSpeed() -> Callback: ${value}`);
                              callback();
                            } else {
                              this.logInfo(`DEBUG: setRotationSpeed() -> Callback: cannot set rotation speed`);
                              callback(this.createError(`cannot set rotation speed`));
                        Hab es eben nochmal über das Terminal kontrolliert dass auch die richtige index.js editiert wird in VS Code.
                        Ich logge mit folgendem Befehl:
                        tail -f /opt/iobroker/log/iobroker.current.log | grep ham.0 > ham.log
                        Danach kopiere ich es rüber auf meine Mac mit dem Befehl:
                        scp ham.log philippmielke@10.0.10.4:/Users/philippmielke/Desktop/ham.log
                        Im Log steht dann folgendes:
                        states können gesetzt werden: ham.log.zip
                        states können NICHT gesetzt werden: ham_kaputt.log.zip
                                callback();
                              } else {
                                callback();
                              } else {
                          DEBUG:
                          Hm ... haste mal nach "DEBUG: set" gegreppt in dem File ... da ist was drin
                          2022-09-14 13:25:00.723 - debug: ham.0 (111330) [9/14/2022, 1:25:00 PM] [xiaomifan] [Standventilator] DEBUG: setPowerState() -> value: 0
                          2022-09-14 13:25:31.921 - debug: ham.0 (111330) [9/14/2022, 1:25:31 PM] [xiaomifan] [Standventilator] DEBUG: setRotationSpeed() -> value: 30
                          Gefühlt sendet der das nur raus wenn das gerät auch an ist ...
                            DEBUG:
                            iPhilBlnI Offline
                            iPhilBlnI Offline
                            iPhilBln
                            @apollon77 du kannst dir das logfile auch einfach in den Chrome Browser ziehen und dann nach Begriffen durchsuchen. So mach ich das aktuell.
                            rechts wird einem auch angezeigt wo er die Begriffe gefunden hat. Finde ich recht praktisch.
                              Ok, dann hoffe ich das die 5.2.3 jetzt endgültig alle Issues löst :-)
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                @apollon77 Guten Morgen,
                                musste nur noch im Ham Adapter von homebridge-tahoma@2.241 auf homebridge-tahoma ändern.
                                Alles läuft sehr gut, keine Fehler Daten werden alle empfangen.👍
                                Iobroker:
                                • FabioF Fabio
                                  @fa-bio Die "Gefahr" wenn Du es ohne Version angibst ist halt das pot der Start des Adapters wieder ein update installiert und was nicht geht ... als vorsichtig sein
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    @apollon77 ja das dachte ich auch, aber als ich den Ham Adapter heute morgen aktualisiert habe, hat er im Log ein Fehler ausgeben wegen der Version Angabe. Dadurch konnte ich dann die Markisen nicht steuern, also habe ich dann die Version Angabe entfernt und dann funktionierte alles wieder wie immer.
                                    Iobroker:
                                    • FabioF Fabio
                                      @fa-bio haste den Fehler noch? Log is ja unter /opt/iobroker/log/...
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        @apollon77 nein leider gelöscht. Jetzt steht da auch wieder von alleine die Version mit drin drin. ham.jpg
                                        Iobroker:
                                          iPhilBlnI Offline
                                          iPhilBlnI Offline
                                          iPhilBln
                                          @apollon77 hier wie versprochen mein Feedback zur Race condition:
                                          Adapter abonniert jetzt zuverlässig die states. 👍
                                          Was mich irritiert hat, dass wenn in der config.JSON des Geräts die einzelnen Optionen auf false stehen und man den Datenpunkt im iobroker steuern möchte weil er noch aus einer älteren config existiert, führt das zum Absturz des ham Adapters. Soll heißen, es existieren Datenpunkte im iobroker die zum Absturz des Adapters führen wenn sie auf false in der config stehen.
                                          Ansonsten funktioniert jetzt aber alles einwandfrei. Nochmals riesen Dank.
