  4. Node-Red
  5. [Gelöst] Werte von Clever Tanken
    6.5k
29 Beiträge 6 Kommentatoren 3.6k Aufrufe 4 Beobachtet
  • R rewenode
    @mickym Meinst du so?
           "id": "d43ad352c5585762",
           "type": "tab",
           "label": "Flow 3",
           "disabled": false,
           "info": "",
           "env": []
           "id": "67e607404c4e23a9",
           "type": "inject",
           "z": "d43ad352c5585762",
           "name": "",
           "props": [
                   "p": "trigger",
                   "v": "true",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 250,
           "y": 40,
           "wires": [
                   "978278b345db5c20"
           "id": "978278b345db5c20",
           "type": "http request",
           "name": "",
           "method": "GET",
           "ret": "txt",
           "paytoqs": "ignore",
           "url": "https://nopaste.net/WEArq4Mojd",
           "tls": "",
           "persist": false,
           "proxy": "",
           "insecureHTTPParser": false,
           "authType": "",
           "senderr": false,
           "headers": [],
           "x": 250,
           "y": 100,
           "wires": [
                   "8817da5505a0693f"
           "id": "8817da5505a0693f",
           "type": "html",
           "name": "",
           "property": "payload",
           "outproperty": "payload",
           "tag": "[class=\"price-type-name\"],[class=\"price-field\"]",
           "ret": "text",
           "as": "single",
           "x": 360,
           "y": 160,
           "wires": [
                   "df9f925401039198"
           "id": "49c238fb0d7c57f6",
           "type": "debug",
           "name": "debug 21",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 240,
           "y": 280,
           "wires": []
           "id": "df9f925401039198",
           "type": "change",
           "name": "combine art and price",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "(\t   $art :=  $filter(\t       payload,\t       function(\t        $v,$i){\t          ($i)%2=0  \t        }\t   );\t   $preis := $map(\t       $filter(\t           payload,\t           function(\t        $v,$i){\t          ($i)%2=1  \t        }\t       ),\t       function($v,$i){\t           $split($v,\"\\n\")[2].$trim().$number().$formatNumber(\"#0.00\")\t        }\t   )      \t        ;\t   $map(\t       $art,\t       function($v,$i){\t     $v & \": \" & $preis[$i]\t}\t   ){$split(\":\")[0]: $split(\":\")[1]}\t\t)",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 280,
           "y": 220,
           "wires": [
                   "49c238fb0d7c57f6"
    Reiner
    mickymM Offline
    mickymM Offline
    mickym
    @rewenode Ja und nein - hab mal den Output in eine Inject Node gegeben, um nicht dauern die Webabfrage zu machen.
    Klare Verbesserung aus der HTML Node - es werden nur die Textinhalte geholt.
    Generell verstehe ich es - dass Du intern nun auch 2 Arrays machst, indem Du die geraden Elemente der $art zuweist und die ungeraden der $kraftstoff.
    So bei dem Preis verstehe ich was Du machst - aber ich würde lieber Zahlen haben.
    Dann lass uns mal zu der Zeile kommen, die in meinen Augen Probleme macht:
     $split($v,"\n")[2].$trim().$number()
    Ich hab mal das formatNumber schon weggelassen, weil ich ja keine Strings haben möchte. Allerdings bekomme ich das Leerzeichen vor nicht weg.
    Laut Beschreibung sollten ja auch führende Leerzeichen entfernt werden:
    tut es aber nicht.
    Das Einzige wie ich es nun hin bekomme, ist wenn man das Objekt zusammensetzt, das ich es dort nochmal mache:
    $map(
           $art,
           function($v,$i){
         $v & ": " & $preis[$i]
       ){$split(":")[0]: $split(":")[1].$trim().$number()}
    Das eigentlich geniale an JSONATA bzw. verwirrende ist die Iteration zur Objekterzeugung - das geht einfach noch nicht so recht in meinem Schädel.
    Sprich wenn ich die splits weglasse hast Du einfach ein array in dem Du mit maps, die zusammengesetzt sind.
    $map(
           $art,
           function($v,$i){
    ergibt also das Array.
    Über das Verketten wird impliziert also jedes einzelne Array Element weiterverarbeitet. ;)
       $map(
           $art,
           function($v,$i){
    Das ist eigentlich das geniale an JSONATA - aber geht immer nicht so in den Kopf. Damit habe ich das gewünschte Ergebnis - wobei ich also
    oben jetzt nur noch das $trim() stehen habe - da dort aus mir unerfindlichen Gründen die Zahlenumwandlung nicht geht:
    Man kann das $trim() oben sogar ganz weglassen.
    Also insgesamt sieht es nun so aus:
       $art :=  $filter(
           payload,
           function(
            $v,$i){
              ($i)%2=0
       $preis := $map(
           $filter(
               payload,
               function(
            $v,$i){
              ($i)%2=1
           function($v,$i){
               $split($v,"\n")[2]
       $map(
           $art,
           function($v,$i){
    Der Punkt ist ja eigentlich ein Abkürzung für das map - wenn ich also diesen kleinen Punkt machen - wird quasi aus jeder Property wieder ein Array Element gebildet.
     $map(
           $art,
           function($v,$i){
       ).{$split(":")[0]: $split(":")[1].$trim().$number()}
    Dieser Punkt also ergibt dann:
    Im Prinzip habe ich das verstanden - ich muss nur diese Verkettungen noch in meinen Kopf bekommen - jedenfalls ist diese Funktion schon mal zum Abspeichern.
    Bleibt nur die Frage offen, warum funktioniert das Konvertieren in einen Zahlenwert oben nicht und unten schon???
    EDIT: habe es auch mit dem Mapping oben versucht - das ergibt auch immer wieder Strings:
    $preis := $map(
           $filter(
               payload,
               function(
            $v,$i){
              ($i)%2=1
           function($v,$i){
               $split($v,"\n")[2]
       ).$trim().$number() ;
    Erzeugt trotzdem:
    Na zumindest funktioniert es wenn man es unten bei der Objekterstellung macht. Ich versuche das jetzt trotzdem nochmal mit regEx.
    • R rewenode
             "type": "tab",
             "label": "Flow 3",
             "disabled": false,
             "info": "",
             "env": []
             "type": "inject",
             "name": "",
             "props": [
                     "p": "trigger",
                     "v": "true",
                     "vt": "bool"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 250,
             "y": 40,
             "wires": [
                     "978278b345db5c20"
             "name": "",
             "method": "GET",
             "ret": "txt",
             "tls": "",
             "persist": false,
             "proxy": "",
             "authType": "",
             "senderr": false,
             "headers": [],
             "x": 250,
             "y": 100,
             "wires": [
                     "8817da5505a0693f"
             "type": "html",
             "name": "",
             "ret": "text",
             "as": "single",
             "x": 360,
             "y": 160,
             "wires": [
                     "df9f925401039198"
             "type": "debug",
             "name": "debug 21",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 240,
             "y": 280,
             "wires": []
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 280,
             "y": 220,
             "wires": [
                     "49c238fb0d7c57f6"
      Reiner
      mickymM Offline
      mickymM Offline
      mickym
      @rewenode Lieber Reiner - ich danke Dir wieder einmal so recht herzlich. 👍 👍 👍
      • ich bin immer noch verwirrt aber ich habe es nun in einen Einzeiler geschafft - danke für Deine Ideen. Hat mich Zeit gekostet - aber mit dem JSONATA Exerciser habe ich mich schrittweise vorgetastet. ;)
      Die magische Zeile (JSONATA ist magisch) lautet:
      payload#$i[$i%2=0]{$$.payload[$i]:($$.payload[$i+1].$match(/\d\.\d+/).match.$number())}
      Damit reduziert sich der ganze Flow auf:
      Wenn man es als String dann auch noch mit den Nachkommastellen formatiert haben will kann man das dann ja noch einfach hinterher schieben. ;)
      payload#$i[$i%2=0]{$$.payload[$i]:($$.payload[$i+1].$match(/\d\.\d+/).match.$number().$formatNumber("#0.00"))}
             "id": "02ee08c829c2819c",
             "type": "html",
             "z": "d93c602e39839f86",
             "name": "",
             "ret": "text",
             "as": "single",
             "x": 630,
             "y": 1500,
             "wires": [
                     "c0a12f2315793304",
                     "605a896c2a98a031"
             "id": "c0a12f2315793304",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload#$i[$i%2=0]{$$.payload[$i]:($$.payload[$i+1].$match(/\\d\\.\\d+/).match.$number())}",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 930,
             "y": 1500,
             "wires": [
                     "c12b286429069877"
             "id": "c12b286429069877",
             "type": "debug",
             "name": "Spritpreise als Zahlen",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1160,
             "y": 1500,
             "wires": []
             "id": "900da6162b9d83d1",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "trigger",
                     "v": "true",
                     "vt": "bool"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 190,
             "y": 1500,
             "wires": [
                     "f51fcc63c0935308"
             "id": "f51fcc63c0935308",
             "name": "",
             "method": "GET",
             "ret": "txt",
             "tls": "",
             "persist": false,
             "proxy": "",
             "authType": "",
             "senderr": false,
             "headers": [],
             "x": 350,
             "y": 1500,
             "wires": [
                     "02ee08c829c2819c"
             "id": "605a896c2a98a031",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload#$i[$i%2=0]{$$.payload[$i]:($$.payload[$i+1].$match(/\\d\\.\\d+/).match.$number().$formatNumber(\"#0.00\"))}",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 930,
             "y": 1540,
             "wires": [
                     "793bea5a23676fa7"
             "id": "793bea5a23676fa7",
             "type": "debug",
             "name": "Spritpreise formatiert als String",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1190,
             "y": 1540,
             "wires": []
      NodeRed ist einfach genial. ;)
      R 1 Antwort Letzte Antwort
      • mickymM mickym
               "type": "html",
               "name": "",
               "ret": "text",
               "as": "single",
               "x": 630,
               "y": 1500,
               "wires": [
                       "c0a12f2315793304",
                       "605a896c2a98a031"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 930,
               "y": 1500,
               "wires": [
                       "c12b286429069877"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1160,
               "y": 1500,
               "wires": []
               "type": "inject",
               "name": "",
               "props": [
                       "p": "trigger",
                       "v": "true",
                       "vt": "bool"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 190,
               "y": 1500,
               "wires": [
                       "f51fcc63c0935308"
               "name": "",
               "method": "GET",
               "ret": "txt",
               "tls": "",
               "persist": false,
               "proxy": "",
               "authType": "",
               "senderr": false,
               "headers": [],
               "x": 350,
               "y": 1500,
               "wires": [
                       "02ee08c829c2819c"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 930,
               "y": 1540,
               "wires": [
                       "793bea5a23676fa7"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1190,
               "y": 1540,
               "wires": []
        rewenode
        schrieb am zuletzt editiert von rewenode
        @mickym sagte in Werte auslesen von Webseite:
        Sehr gut !!! Die Verlockung ist immer groß, JSONata-Konstrukte bis zum Einzeiler zu komprimieren, zumal es oft möglich ist.
        Gründe, warum ich das oft versuche zu vermeiden sind:
        1. ich will auch 2 Wochen später noch kapieren, was ich hier eigentlich gemacht habe;-) Und wenn da noch RegEx-Ausdrücke drin sind, geht es fast nicht mehr ohne sinnige Kommentare
        2. Man kann da schon ganz schön Zeit verdaddeln nur um ein paar Zeilen Code einzusparen
        Aber Spaß kann das schon machen;-)
        Gruß und schönen Sonntag
        Reiner
        • R rewenode
          Reiner
          mickymM Offline
          mickymM Offline
          mickym
          @rewenode Wenn ich Dich als Fachmann schon mal da habe. ;)
          Wenn ich, wie anfangs 2 Arrays habe - und möchte eines als topics bzw. property und das andere als Value nehmen:
            "topic": [
              "topic_01",
              "topic_02",
              "topic_03",
              "topic_04",
              "topic_05",
              "topic_06"
            "payload": [
              2.1,
              1.96,
              2.02,
              2.11,
              2.09,
              1.08
          dann bringe ich es nicht hin ohne $distinct-Function ein sauberes Objekt zu bekommen:
          topic#$i@$t.payload@$p{$t:$p[$i]}
          topic#$i@$t.payload@$p{$t:$distinct($p[$i])}
          Gibts da noch eine andere Möglichkeit zu verhindern, dass der payload - mal Anzahl der Elemente in einem Array rauskommt. In dieser Variable $i scheint es ein ganzes Array .
          Eventuell muss man da vorher was ausfiltern, weil im Beispiel - enthält das $i ja skalare Werte:
          EDIT:
          Ah ich habs 💡 💡 💡 - muss man vorher ausfiltern. 👍 👍
          topic#$i@$t.payload#$j@$p[$i=$j]{$t:$p}
          Hier noch die praktische Anwendung in Node-Red:
                 "id": "18c446aa69e28041",
                 "type": "debug",
                 "name": "debug 33",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 620,
                 "y": 1720,
                 "wires": []
                 "id": "42812429ed0f9f97",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "topic#$i@$t.payload#$j@$p[$i=$j]{$t:$p}",
                         "tot": "jsonata"
                         "t": "delete",
                         "p": "topic",
                         "pt": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 430,
                 "y": 1720,
                 "wires": [
                         "18c446aa69e28041"
                 "id": "c6812ad471a59a61",
                 "type": "comment",
                 "name": "Kombiniere 2 Array in ein Objekt",
                 "info": "",
                 "x": 250,
                 "y": 1660,
                 "wires": []
                 "id": "903758012f51ae5c",
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                         "p": "topic",
                         "v": "[\"Diesel\",\"Super E10\",\"Super E5\",\"SuperPlus\",\"LKW-Diesel\",\"LPG\"]",
                         "vt": "json"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "[2.1,1.96,2.02,2.11,2.09,1.08]",
                 "payloadType": "json",
                 "x": 230,
                 "y": 1720,
                 "wires": [
                         "42812429ed0f9f97"
          Sorry dass ich den Thread etwas missbraucht habe. - Aber vielleicht ist das ja auch für andere interessant. Höre jetzt auch auf. ;) -
          Danke Dir Reiner und auch einen schönen Sonntag. :)
          • mickymM mickym
              "topic": [
                "topic_01",
                "topic_02",
                "topic_03",
                "topic_04",
                "topic_05",
                "topic_06"
              "payload": [
                2.1,
                1.96,
                2.02,
                2.11,
                2.09,
                1.08
            EDIT:
                   "type": "debug",
                   "name": "debug 33",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 620,
                   "y": 1720,
                   "wires": []
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                           "t": "delete",
                           "p": "topic",
                           "pt": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 430,
                   "y": 1720,
                   "wires": [
                           "18c446aa69e28041"
                   "type": "comment",
                   "info": "",
                   "x": 250,
                   "y": 1660,
                   "wires": []
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "json"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 230,
                   "y": 1720,
                   "wires": [
                           "42812429ed0f9f97"
            rewenode
            @mickym So?
            $.topic#$i{$$.topic[$i]:$$.payload[$i]}
            Ja, sollte vlt. ein eigener Thread werden
            Reiner
            • R rewenode
              @mickym So?
              Reiner
              mickymM Offline
              mickymM Offline
              mickym
              @rewenode sagte in Werte auslesen von Webseite:
              Ja - das geht auch. :) - Meins ist umständlicher.
              Ist abgespeichert. ;)
              • mickymM mickym
                rewenode
                @mickym Oder auch so, um mal mit $zip zu spielen ;-)
                $zip($.topic,$.payload){$[0]:$[1]}
                #$i brauchts da natürlich nicht.
                In JSONata gibt es da immer 1000...
                Reiner
                • R rewenode
                  Reiner
                  mickymM Offline
                  mickymM Offline
                  mickym
                  Ich muss immer erst 2mal überlegen - OK die Zip Funktion ist ja beschrieben - aber ich bin wieder über das reduce in dem Objekt gestolpert. Das man mit 0 und 1 ja jedes Array-Element ;) durchiteriert wird - Aber auch sehr elegant.
                  • mickymM mickym
                    rewenode
                    @mickym zurück zum eigentlichen Thema. Einen hätte ich noch :-)
                    Mit einem besseren Selektor wird es dann nur ein ganz kurzer Einzeiler
                    .price-type-name, [id|=current-price]
                    Und im Change dann:
                    payload#$i[($i%2)=0]{$$.payload[$i]:$$.payload[$i+1].$number()}
                    Reiner
                    • R rewenode
                      Und im Change dann:
                      Reiner
                      mickymM Offline
                      mickymM Offline
                      mickym
                      Das mit dem JSONATA ist ja nun nach den vorherigen Ausführungen zu erklären ;) - aber mit den CSS Selektoren bist Du mir im Vorteil - auch wenn es in der Hilfe zur HTML Node verlinkt ist: https://github.com/fb55/css-select#user-content-supported-selectors
                      Aber ich bevorzuge dann die andere Schreibweise mit [class="price-type-name"] und dann die Vergleiche zu machen. Das mit dem vorangestellten Punkt einer Klasse entspricht - ist mir bei CSS zwar prinzipiell bekannt, aber hätte ich hier nie verwendet. ;)
                      Ok - ich merke - ich beginne das mit den CSS Selektoren erst langsam zu verstehen. Dann geht das was @merlin2k11 gesagt hat, dass es nicht exakt übereinstimmen muss. :) - Klasse.
                      Dann gehen aber noch ein paar mehr Selektoren:
                      Ich hab heute jedenfalls wieder einiges von Dir gelernt.
                      Vielen Dank! :)
                      EDIT:
                      Noch eine Info - wenn man eine Standalone Version von NodeRed nutzt, kann man auch den doppelten Kontextspeicher verwenden, dann muss man für solche Tests keine Webanfragen machen. ;)
                      • mickymM mickym
                        Vielen Dank! :)
                        EDIT:
                        rewenode
                        👍 wieder was gelernt
                        • R rewenode
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @rewenode Ich mach mal noch einen neuen Thread auf - weil ich immer wieder auf Verständnisprobleme stoße.
                          Aus einem anderen Thread - gabs auch eine Anforderung - ich habs zwar geschafft, fand das aber wieder umständlich. Um den Thread nicht vollständig hier zu kapern, habe ich mal einen eigenen aufgemacht: https://forum.iobroker.net/topic/57856/jsonata-verständnisprobleme
                            merlin2k11
                            ähm ... topic#$i@$t.payload#$j@$p[$i=$j]{$t:$p}
                            Ihr müsst doch was geraucht haben... was auch immer es war ich will es auch damit ich verstehe was ihr da gebaut habt. Wie war das? Das ist Magisch?
                            Ich habe auch nach dem dritten mal lesen nur Fragezeichen und keine Ahnung was ihr da gebaut habt - aber es klappt und das war ja mein Ziel :)
                            Ich danke euch 🎆 🎆 🎈
                            • M merlin2k11
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @merlin2k11 Wie gesagt die finale Version sieht nun so aus:
                                     "id": "84644114056d7367",
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "trigger",
                                             "v": "true",
                                             "vt": "bool"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 170,
                                     "y": 1940,
                                     "wires": [
                                             "18b108dc8d983dbe"
                                     "id": "18b108dc8d983dbe",
                                     "name": "",
                                     "method": "GET",
                                     "ret": "txt",
                                     "tls": "",
                                     "persist": false,
                                     "proxy": "",
                                     "authType": "",
                                     "senderr": false,
                                     "headers": [],
                                     "x": 330,
                                     "y": 1940,
                                     "wires": [
                                             "58c77855680f94e2"
                                     "id": "58c77855680f94e2",
                                     "type": "html",
                                     "name": "",
                                     "tag": ".price-type-name, [id|=current-price]",
                                     "ret": "html",
                                     "as": "single",
                                     "x": 620,
                                     "y": 1940,
                                     "wires": [
                                             "06b25788793b83a0"
                                     "id": "74f9010595f6e982",
                                     "type": "debug",
                                     "name": "[id|=current-price]",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1190,
                                     "y": 1940,
                                     "wires": []
                                     "id": "06b25788793b83a0",
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "payload#$i[($i%2)=0]{$$.payload[$i]:$$.payload[$i+1].$number()}",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 930,
                                     "y": 1940,
                                     "wires": [
                                             "74f9010595f6e982"
