  4. Adapter-Update nicht möglich
    5.8k
32 Beiträge 2 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • M martin
    martin@iobroker:~$ iobroker repo list
    Active repo(s): beta
    martin@iobroker:~$ iobroker repo unset beta
    Repository "beta" deactivated.
    Active repo(s):
    martin@iobroker:~$ iobroker repo set DAS_STABLE_REPO
    Cannot activate repository: Repository "DAS_STABLE_REPO" not found.
    @martin
    Transferleistung...
    iobroker repo set stable
      @martin
      Transferleistung...
      martin
      Danke.
      Als User verlangt er ein Root-Passwort das ich nicht kenne. Deshalb wieder als root. Den Admin-Adapter hat er upgedatet. Über das Web-Interface kann ich aber immer noch nicht updaten.
      root@iobroker:~# iobroker repo set stable
      Repository "stable" set as active.
      Active repo(s): stable
      root@iobroker:~# iobroker stop
      root@iobroker:~# iobroker fix
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installation fixer!
          Script version: 2022-06-03
          Installing prerequisites (1/3)
      OK:1 http://security.debian.org/debian-security buster/updates InRelease
      OK:2 http://deb.debian.org/debian buster InRelease
      OK:3 http://deb.debian.org/debian buster-updates InRelease
      OK:4 https://deb.nodesource.com/node_16.x buster InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      root@iobroker:~# iobroker update
      Used repository: stable
      Adapter    "admin"        : 6.2.20   , installed 6.0.0  [Updatable]
      Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
      Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.4.10   , installed 2.2.4  [Updatable]
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.4
      Adapter    "discovery"    : 3.0.5    , installed 2.7.5  [Updatable]
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "ical"         : 1.13.1   , installed 1.11.6 [Updatable]
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.0.2  [Updatable]
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.0.2  [Updatable]
      Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
      Adapter    "iot"          : 1.11.8   , installed 1.9.3  [Updatable]
      Adapter    "javascript"   : 6.0.0    , installed 5.2.21 [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "meross"       : 1.13.0   , installed 1.14.0
      Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
      Adapter    "mqtt"         : 4.0.7    , installed 2.4.1  [Updatable]
      Adapter    "node-red"     : 3.3.1    , installed 1.13.0 [Updatable]
      Adapter    "octoprint"    : 4.0.0    , installed 3.2.0  [Updatable]
      Adapter    "ping"         : 1.5.3    , installed 1.5.2  [Updatable]
      Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
      Adapter    "simple-api"   : 2.7.0    , installed 2.6.2  [Updatable]
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "snmp"         : 2.1.7    , installed 0.5.0  [Updatable]
      Adapter    "socketio"     : 4.2.0    , installed 4.1.0  [Updatable]
      Adapter    "sonoff"       : 2.5.1    , installed 2.4.7  [Updatable]
      Adapter    "synology"     : 2.1.9    , installed 1.1.3  [Updatable]
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.14.1   , installed 1.11.1 [Updatable]
      Adapter    "terminal"     : 0.2.6    , installed 0.1.2  [Updatable]
      Adapter    "text2command" : 2.2.2    , installed 2.1.1  [Updatable]
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
      Adapter    "tuya"         : 3.6.15   , installed 3.6.15
      Adapter    "upnp"         : 1.0.21   , installed 1.0.20 [Updatable]
      Adapter    "vis"          : 1.4.15   , installed 1.4.8  [Updatable]
      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.3.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.6  [Updatable]
      Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "web"          : 4.3.0    , installed 4.1.1  [Updatable]
      Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.1.6  [Updatable]
      Adapter    "ws"           : 1.3.0    , installed 2.1.5
      root@iobroker:~# iobroker upgrade admin@6.2.20 --debug
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.2.20:
      Corrected GUI issues
      -> 6.2.19:
      Corrected some issues
      -> 6.2.18:
      Corrected GUI bugs on custom settings
      -> 6.2.17:
      Corrected GUI bug on intro tab
      -> 6.2.16:
      Corrected many GUI issues
      Added `stable` flag for repositories
      Added reset button for repositories
      Improved `writeFile` function for socket communication
      -> 6.2.14:
      Fix for OAuth2 authentication response success page
      -> 6.2.13:
      Corrected JSON config
      Would you like to upgrade admin from @6.0.0 to @6.2.20 now? [(y)es, (n)o]: y
      Update admin from @6.0.0 to @6.2.20
      host.iobroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.20... (System call)
      removed 5 packages, and changed 4 packages in 32s
      130 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.admin.0"
      upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.iobroker Adapter "system.adapter.admin.0" is started
      root@iobroker:~# iobroker start
      root@iobroker:~#
      • M martin
        Danke.
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        -> 6.2.20:
        -> 6.2.19:
        -> 6.2.18:
        -> 6.2.17:
        -> 6.2.16:
        -> 6.2.14:
        -> 6.2.13:
        NPM version: 8.15.0
        root@iobroker:~#
        @martin sagte in Adapter-Update nicht möglich:
        Das ist das Passwort des users, der per sudo root-Rechte erhalten kann, ohne das root-Kennwort kennen zu müssen.
        Aaaaaaarrrrrrrggggghhhh!!!
        Richte dein System gescheit ein! Lies eine Anleitung!
        usermod -aG sudo martin
        • M martin
          Danke.
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          -> 6.2.20:
          -> 6.2.19:
          -> 6.2.18:
          -> 6.2.17:
          -> 6.2.16:
          -> 6.2.14:
          -> 6.2.13:
          NPM version: 8.15.0
          root@iobroker:~#
          @martin
          Und wenn deine User vernünftig aufgesetzt sind:
            @martin
            martin
            @thomas-braun said in Adapter-Update nicht möglich:
            Jetzt bin ich wieder im Rennen. Vielen Dank für deine tolle und immer so schnelle Hilfe.
            • M martin
              @martin
              Final drüber schauen:
              sudo whoami
              who -r
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              iobroker update
                @martin
                sudo whoami
                who -r
                iobroker update
                martin
                martin@iobroker:~$ sudo whoami
                root
                martin@iobroker:~$ who -r
                         Runlevel 5   2022-09-03 11:55
                martin@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                martin@iobroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                martin
                /home/martin
                Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                nodejs:
                  Installiert:           16.17.0-deb-1nodesource1
                  Installationskandidat: 16.17.0-deb-1nodesource1
                  Versionstabelle:
                 *** 16.17.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
                     10.24.0~dfsg-1~deb10u1 500
                        500 http://deb.debian.org/debian buster/main amd64 Packages
                        500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                martin@iobroker:~$ iobroker update
                Adapter    "admin"        : 6.2.20   , installed 6.2.20
                Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                martin@iobroker:~$
                • M martin
                  root
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  martin
                  /home/martin
                  nodejs:
                    Versionstabelle:
                  martin@iobroker:~$
                  root
                  Funktionert also jetzt wie vorgesehen. Also NIE mehr root werden, immer mit dem 'martin' arbeiten.
                  Bring den Oldtimer-Stadel auf Stand:
                  iobroker update
                  iobroker upgrade all -y
                    root
                    iobroker update
                    martin
                    @thomas-braun Alles klar, kein root mehr.
                    Ich update jetzt die Adapter über das Web-Interface.
                    Den Oldtimer-Stadel trotzdem mit den 2 Befehlen noch auf Stand bringen?
                    • M martin
                      Mach es über die Konsole, geht schneller, ist robuster und ist informativer.
                        martin
                        @thomas-braun - alle Adapter wurden nicht upgedatet. Wenn ich es jetzt über das Web-Interface mache kommt bei allen der gleiche Fehler:
                        $ iobroker upgrade javascript@6.0.0
                        Update javascript from @5.2.21 to @6.0.0
                        NPM version: 8.15.0
                        Installing iobroker.javascript@6.0.0... (System call)
                        host.iobroker Cannot install iobroker.javascript@6.0.0: 217
                        ERROR: Process exited with code 25
                        • M martin
                          NPM version: 8.15.0
                          @martin
                          Und warum nicht über die Konsole?
                          Schau ob das passt:
                          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                            @martin
                            Schau ob das passt:
                            martin
                            @thomas-braun - der Fehler ist passend, die Lösung bringt nur Fehler:
                            imist/test/parse.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/test/whitespace.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/test/dotted.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/test/default_bool.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/.travis.yml' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/index.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/package.json' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/LICENSE' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/node_modules/min                                  imist/readme.markdown' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.optimist-H5AiMKOs/readme.markdown'                                   ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.meross/node_modules/.cooki                                  e-07UevKAB/HISTORY.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.meross/node_modules/.cooki                                  e-07UevKAB/index.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.meross/node_modules/.cooki                                  e-07UevKAB/package.json' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.meross/node_modules/.cooki                                  e-07UevKAB/README.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.meross/node_modules/.cooki                                  e-07UevKAB/LICENSE' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/test/utf7-rfc2152.js                                  ' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/test/utf7-imap.js' i                                  st nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/utf7.js' ist nicht m                                  öglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/package.json' ist ni                                  cht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/README.md' ist nicht                                   möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/LICENSE' ist nicht m                                  öglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  package.json' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  README.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  LICENSE' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  semver.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  range.bnf' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/semver/                                  bin/semver' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.utf7-gXQqnCoX/node_modules/.bin/se                                  mver' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.sourceanalytix/node_module                                  s/.cookie-xYMqCZmN/HISTORY.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.sourceanalytix/node_module                                  s/.cookie-xYMqCZmN/index.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.sourceanalytix/node_module                                  s/.cookie-xYMqCZmN/package.json' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.sourceanalytix/node_module                                  s/.cookie-xYMqCZmN/README.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.sourceanalytix/node_module                                  s/.cookie-xYMqCZmN/LICENSE' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/CHANGELOG.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/lib/nopt.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/package.json' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/README.md' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/LICENSE' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.                                  nopt-ymS3KfJH/bin/nopt.js' ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/CHANGELOG.md'                                   ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/lib/re.js' ist                                   nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/index.js' ist                                   nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/package.json'                                   ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/README.md' ist                                   nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.linkify-it-80agQhl4/LICENSE' ist n                                  icht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM/index.js' ist                                   nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM/package.json'                                   ist nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM/README.md' is                                  t nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM/LICENSE' ist                                   nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.http-errors-k8WIaDDV/HISTORY.md' i                                  st nicht möglich: Keine Berechtigung
                            rm: das Entfernen von '/opt/iobroker/node_modules/.nodemailer-nLsVvFJS/CONTRIBUTING.m                                  d' ist nicht möglich: Keine Berechtigung
                            martin@iobroker:/opt/iobroker/node_modules$
                            Und diese "Keine Berechtigung" zieht sich auf über 1000 Zeilen weiter.
                            • M martin
                              Das ist eine Spätfolge von deinem herumgehampel als root.
                              Als 'martin'
                              groups
                              sagt?
                                Als 'martin'
                                groups
                                sagt?
                                martin
                                martin@iobroker:~$ groups
                                martin cdrom floppy sudo audio dip video plugdev netdev bluetooth scanner
                                martin@iobroker:~$
                                • M martin
                                  martin@iobroker:~$
                                  @martin
                                  sudo usermod -aG iobroker martin
                                  exit
                                  Neueinloggen, dann nochmal
                                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                    @martin
                                    exit
                                    martin
                                    sudo usermod -aG iobroker groups
                                    martin@iobroker:~$ sudo usermod -aG iobroker groups
                                    [sudo] Passwort für martin:
                                    usermod: Benutzer »groups« ist nicht vorhanden.
                                    martin@iobroker:~$
                                    • M martin
                                      martin@iobroker:~$
                                      @martin
                                      Sorry.
                                        @martin
                                        Sorry.
                                        martin
                                        martin@iobroker:~$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*                                               -????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                        martin@iobroker:~$ iobroker update javascript@6.0.0 --debug
                                        Used repository: javascript@6.0.0
                                        Error: unknown repository is active - "javascript@6.0.0". Known: stable, beta
                                        martin@iobroker:~$
                                        • M martin
                                          martin@iobroker:~$
                                          @martin
                                          iobroker repo list
