  4. Typescript compilation error global folder js adapter 6.0.0
21 Beiträge 7 Kommentatoren 3.7k Aufrufe 7 Beobachtet
  • E ErdyMurphy
    Also das Update auf NodeJS 16.17.0 hat keine Besserung gebracht. Oder muss ich sonst noch etwas aktualisieren)
    2022-08-28 22:59:00.300  - info: javascript.0 (31472) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.17.0, js-controller: 4.0.23
    2022-08-28 22:59:01.947  - info: javascript.0 (31472) requesting all states
    2022-08-28 22:59:01.949  - info: javascript.0 (31472) requesting all objects
    2022-08-28 22:59:03.325  - info: javascript.0 (31472) received all objects
    2022-08-28 22:59:03.473  - info: javascript.0 (31472) received all states
    2022-08-28 22:59:11.181  - info: javascript.0 (31472) script.js.global.global_logging: compiling TypeScript source...
    2022-08-28 22:59:11.441  - error: javascript.0 (31472) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-08-28 22:59:11.442  - error: javascript.0 (31472) unhandled promise rejection: Debug Failure. Unhandled SyntaxKind: Unknown.
    2022-08-28 22:59:11.443  - error: javascript.0 (31472) Error: Debug Failure. Unhandled SyntaxKind: Unknown.
        at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22)
        at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
        at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
        at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
        at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
        at emitTypeAliasDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114412:13)
        at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112795:32)
        at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9)
        at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17)
        at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17)
        at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13)
        at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13)
        at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17)
        at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17)
        at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24)
        at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13)
        at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13)
        at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13)
        at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62)
        at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:442:31)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1033:67)
        at processImmediate (node:internal/timers:468:21)
    2022-08-28 22:59:11.445  - error: javascript.0 (31472) Debug Failure. Unhandled SyntaxKind: Unknown.
    2022-08-28 22:59:11.551  - info: javascript.0 (31472) terminating
    2022-08-28 22:59:11.554  - warn: javascript.0 (31472) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-08-28 22:59:14.594  - error: host.raspberrypi Caught by controller[0]: DeprecationWarning: 'createNodeArray' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.595  - error: host.raspberrypi Caught by controller[1]: DeprecationWarning: 'createModifier' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.596  - error: host.raspberrypi Caught by controller[2]: DeprecationWarning: 'updateVariableStatement' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.596  - error: host.raspberrypi Caught by controller[3]: DeprecationWarning: 'updateTypeAliasDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.596  - error: host.raspberrypi Caught by controller[4]: DeprecationWarning: 'updateFunctionDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.596  - error: host.raspberrypi Caught by controller[5]: DeprecationWarning: 'createNamedExports' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.596  - error: host.raspberrypi Caught by controller[6]: DeprecationWarning: 'createExportDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[7]: DeprecationWarning: 'updateSourceFile' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[9]: Error: Debug Failure. Unhandled SyntaxKind: Unknown.
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22)
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
    2022-08-28 22:59:14.597  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at emitTypeAliasDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114412:13)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112795:32)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
    2022-08-28 22:59:14.598  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
    2022-08-28 22:59:14.599  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
    2022-08-28 22:59:14.599  - error: host.raspberrypi Caught by controller[9]:     at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
    2022-08-28 22:59:14.599  - error: host.raspberrypi Caught by controller[9]:     at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9)
    2022-08-28 22:59:14.599  - error: host.raspberrypi Caught by controller[9]:     at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17)
    2022-08-28 22:59:14.599  - error: host.raspberrypi Caught by controller[9]:     at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17)
    2022-08-28 22:59:14.600  - error: host.raspberrypi Caught by controller[9]:     at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13)
    2022-08-28 22:59:14.600  - error: host.raspberrypi Caught by controller[9]:     at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13)
    2022-08-28 22:59:14.600  - error: host.raspberrypi Caught by controller[9]:     at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17)
    2022-08-28 22:59:14.600  - error: host.raspberrypi Caught by controller[9]:     at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17)
    2022-08-28 22:59:14.600  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13)
    2022-08-28 22:59:14.601  - error: host.raspberrypi Caught by controller[9]:     at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62)
    2022-08-28 22:59:14.602  - error: host.raspberrypi Caught by controller[9]:     at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:442:31)
    2022-08-28 22:59:14.602  - error: host.raspberrypi Caught by controller[9]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1033:67)
    2022-08-28 22:59:14.602  - error: host.raspberrypi Caught by controller[9]:     at processImmediate (node:internal/timers:468:21)
    2022-08-28 22:59:14.602  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-08-28 22:59:14.602  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2022-08-28 22:59:23.983  - info: host.raspberrypi "system.adapter.javascript.0" disabled
    2022-08-28 22:59:27.453  - info: host.raspberrypi "system.adapter.zigbee.0" disabled
    GlasfaserG Offline
    GlasfaserG Offline
    @erdymurphy
    Könnte das passen !?
    hier bei Github :
    https://github.com/ioBroker/ioBroker.javascript/issues/1106
    P 1 Antwort Letzte Antwort
    • E Offline
      ErdyMurphy
      @glasfaser said in Typescript compilation error global folder js adapter 6.0.0:
      ja das passt sehr gut... muss ich mir mal überlegen ob ich TS downgrade oder alles wieder in JS umwandele... Auf jeden Fall Danke für Deine Unterstützung!
      • GlasfaserG Glasfaser
        @erdymurphy
        hier bei Github :
        Peet_b
        @glasfaser
        Hey, ich habe genau das selbe Problem. Wie könnte man denn TS Downgraden?
        Peet
        • P Peet_b
          @glasfaser
          Peet
          tklein
          @peet_b bist du da weitergekommen? habe auch das problem
          • E ErdyMurphy
            tklein
            @erdymurphy wie kann man ts downgraden?
            • T tklein
              mdietrich
              @tklein Ich habe den Javascript-Adapter aus GitHub installiert. Dort wurde der Fix reingemerged. Damit klappts.
              • M mdietrich
                GlasfaserG Offline
                GlasfaserG Offline
                @mdietrich sagte in Typescript compilation error global folder js adapter 6.0.0:
                aus GitHub
                Nicht aus Github ziehen ...
                wenn schon , dann auf die freigegebene Beta upgraden .
                  aus GitHub
                  tklein
                  @glasfaser da zeigt er mir aber nix neueres als meine 6.0.0 an
                  8b3ff2d0-a556-48b5-82a2-2537178c4c4b-grafik.png Dann also mit einem Downgrade versuchen?
                  • Thomas BraunT Online
                    @tklein
                    iobroker update -i
                    zeigen.
                      @tklein
                      iobroker update -i
                      zeigen.
                      tklein
                      @thomas-braun da ist der 6.0.1 mit drin
                      Used repository: beta
                      Adapter    "accuweather"  : 1.2.4    , installed 1.2.1  [Updatable]
                      Adapter    "admin"        : 6.2.20   , installed 6.2.17 [Updatable]
                      Adapter    "alarm"        : 3.1.1    , installed 3.1.1
                      Adapter    "alexa2"       : 3.19.7   , installed 3.11.2 [Updatable]
                      Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
                      Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                      Adapter    "ble"          : 0.13.0   , installed 0.13.0
                      Adapter    "bmw"          : 2.5.5    , installed 2.5.5
                      Adapter    "bring"        : 1.8.1    , installed 1.8.1
                      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                      Adapter    "cul"          : 2.0.2    , installed 2.0.2
                      Adapter    "daswetter"    : 3.1.4    , installed 3.1.2  [Updatable]
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                      Adapter    "devices"      : 1.0.12   , installed 1.0.12
                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                      Adapter    "email"        : 1.1.3    , installed 1.1.3
                      Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                      Adapter    "fhem"         : 1.6.3    , installed 1.6.3
                      Adapter    "flot"         : 1.11.0   , installed 1.11.0
                      Adapter    "followthesun" : 0.3.9    , installed 0.3.9
                      Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
                      Adapter    "geofency"     : 1.2.2    , installed 1.1.1  [Updatable]
                      Adapter    "ham"          : 5.1.0    , installed 5.0.2  [Updatable]
                      Adapter    "history"      : 2.2.1    , installed 2.2.0  [Updatable]
                      Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                      Adapter    "ical"         : 1.13.2   , installed 1.13.1 [Updatable]
                      Adapter    "influxdb"     : 3.1.8    , installed 3.1.7  [Updatable]
                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                      Adapter    "intex"        : 0.0.7    , installed 0.0.7
                      Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                      Adapter    "javascript"   : 6.0.1    , installed 6.0.0  [Updatable]
                      Controller "js-controller": 4.0.23   , installed 4.0.23
                      Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
                      Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                      Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
                      Adapter    "meross"       : 1.14.0   , installed 1.13.0 [Updatable]
                      Adapter    "milight"      : 0.3.6    , installed 0.3.6
                      Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                      Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                      Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                      Adapter    "parcel"       : 0.0.20   , installed 0.0.20
                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                      Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                      Adapter    "rest-api"     : 1.0.4    , installed 1.0.1  [Updatable]
                      Adapter    "rflink"       : 2.1.6    , installed 2.1.6
                      Adapter    "ring"         : 3.1.1    , installed 3.0.4  [Updatable]
                      Adapter    "sayit"        : 1.12.6   , installed 1.12.3 [Updatable]
                      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                      Adapter    "simple-api"   : 2.7.1    , installed 2.7.0  [Updatable]
                      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                      Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
                      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.12-1 [Updatable]
                      Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
                      Adapter    "sql"          : 2.1.8    , installed 2.1.7  [Updatable]
                      Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                      Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                      Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                      Adapter    "text2command" : 2.2.2    , installed 2.2.2
                      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                      Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.2.0  [Updatable]
                      Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
                      Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.1  [Updatable]
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
                      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                      Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.2  [Updatable]
                      Adapter    "wled"         : 0.6.7    , installed 0.6.7
                      Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
                      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                      Adapter    "zigbee"       : 1.7.6    , installed 1.7.5  [Updatable]
                      • T tklein
                        @tklein Dann kannst du ja jetzt upgraden.
                        iobroker upgrade javascript
                        Wenn du generell volles Beta-Repo fährst, upgrade den Rest auch. Wenn nur der javascript auf Beta laufen soll stell das Repository wieder auf 'stable' zurück.
                        T 2 Antworten Letzte Antwort
                          tklein
                          @thomas-braun said in Typescript compilation error global folder js adapter 6.0.0:
                          Danke für deine Hilfe. Ich update nur den einen und stelle dann wieder auf stable. Bin da einer von den vorsichtigen. :-)
                            tklein
                            @thomas-braun update hat geklappt, aber adapter wird auch wieder rot.
                            javascript.0
                            11884	2022-09-02 10:32:29.376	error	Debug Failure. Unhandled SyntaxKind: Unknown.
                            javascript.0
                            11884	2022-09-02 10:32:29.376	error	Error: Debug Failure. Unhandled SyntaxKind: Unknown. at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13) at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114436:13) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112799:32) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13) at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13) at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17) at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13) at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13) at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13) at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13) at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62) at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1078:64) at processImmediate (node:internal/timers:468:21)
                            javascript.0
                            11884	2022-09-02 10:32:29.376	error	unhandled promise rejection: Debug Failure. Unhandled SyntaxKind: Unknown.
                            javascript.0
                            11884	2022-09-02 10:32:29.375	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            R 1 Antwort Letzte Antwort
                            • T tklein
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              rtamas
                              @tklein https://github.com/ioBroker/ioBroker.javascript/issues/1132
