  4. Node Red startet nicht nach Raspberry OS update
    5.8k
84 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • E etzeste13
    @etzeste13 aber node red geht weiterhin nicht...
    ich befürchte fast, dass ich nodes verwende die in diesen versionen nicht mehr unterstützt werden... wie findet man das den raus, oder vielleicht am besten wieder was down-graden?
    2022-09-01 22:31:03.664  - info: node-red.0 (3757) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2022-09-01 22:31:15.181  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
    2022-09-01 22:31:15.278  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] Encrypted credentials not found
    2022-09-01 22:31:15.413  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] [modbus-client:SPR8] Client -> fsm init state after new
    2022-09-01 22:31:15.415  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] [modbus-client:SPR8] Client -> first fsm init in 500 ms Serial@/dev/ttyUSB0:19200bit/s default Unit-Id: 1
    2022-09-01 22:31:15.610  - info: node-red.0 (4177) Sets unsupported
    2022-09-01 22:31:15.615  - info: node-red.0 (4177) Sets unsupported
    2022-09-01 22:31:15.944  - error: node-red.0 (3757) 1 Sep 22:31:15 - [error] Error: Module did not self-register: '/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/build/Release/bindings.node'.
        at Object.Module._extensions..node (node:internal/modules/cjs/loader:1210:18)
        at Module.load (node:internal/modules/cjs/loader:1004:32)
        at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        at Module.require (node:internal/modules/cjs/loader:1028:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at bindings (/opt/iobroker/iobroker-data/node-red/node_modules/bindings/bindings.js:112:48)
        at Object.<anonymous> (/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/lib/linux.js:2:36)
        at Module._compile (node:internal/modules/cjs/loader:1126:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    2022-09-01 22:31:15.974  - info: node-red.0 (3757) node-red exited with 1
    mickymM Offline
    mickymM Offline
    mickym
    @etzeste13 Wie hast Du das den rausgefunden. ;) Wenn Du den Node-Red Adapter installierst - dann hast Du ja erst mal noch gar nichts drin - hast Du einfach Deine flows.json reinkopiert?
    mickymM E 2 Antworten Letzte Antwort
    • mickymM mickym
      mickymM Offline
      mickymM Offline
      mickym
      @mickym Hast Du denn Dein alten Verzeichnis noch zur Verfügung - ich kenn mich nur nicht mit master und slaves aus. Wo liegt denn Dein node-red Datenverzeichnis?
      • mickymM mickym
        etzeste13
        @mickym ich habe einfach aus dem browser-cache den ich im firefox noch offen hatte nach dem installieren des adapters auf aktualisieren gedrückt... und geschaut was passiert.... kopiert hatte ich noch gar nix..
        • E etzeste13
          mickymM Offline
          mickymM Offline
          mickym
          @etzeste13 Aber du hast doch den ganzen Adapter gelöscht - habe ich verstanden?
          E 1 Antwort Letzte Antwort
          • mickymM mickym
            etzeste13
            @mickym ja habe ich gemacht, aber interessanterweise war es in der adapteransicht nach wie vor blau markiert bei dem betroffenen slave...
            eben den, den wir beide soeben repariert haben
            E mickymM 2 Antworten Letzte Antwort
            • E etzeste13
              etzeste13
              @etzeste13 soll ich vorerst diese flows.json löschen, bzw. den asapter nochmals versuchen zu löschen?
              • E etzeste13
                mickymM Offline
                mickymM Offline
                mickym
                @etzeste13 Dann empfehle ich mal Dein jetziges NodeRed Daten Verzeichnis zu suchen. Vielleicht ist das auch Dein Problem - weil unter Umständen das data Verzeichnis vielleicht auf dem Master war - ich hab da keine Ahnung .
                Sicher erst mal was Du hast. - Weiss ja nicht wieviel flows Du schon hast? - Weisst Du denn wo Dein NodeRed Datenverzeichnis liegt?
                Srich schau mal unter /opt/iobroker/iobroker-data - ob darunter ein node-red Verzeichnis existiert.
                • mickymM mickym
                  etzeste13
                  @mickym ja das verzeichnis habe ich gefunden, da sind folgende datein drinnen...
                  pi@RasPi3B3:/opt/iobroker/iobroker-data/node-red $ ls
                  flows.json  node_modules  package-lock.json  settings.js
                  lib         package.json  projects
                  • E etzeste13
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @etzeste13 Und das ist nur auf dem Slave oder auf dem Master?
                    • mickymM mickym
                      etzeste13
                      @mickym das ist jetzt am slave, am master habe ich nichts von node red gefunden...
                      • mickymM mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @mickym
                        @etzeste13 sagte in Node Red startet nicht nach Raspberry OS update:
                        Ok sehr gut - dann versuchen wir mal was ähnliches mit Node_red was wir mit dem iobroker gemacht haben.
                        Es gibt allerdings das Problem, dass Dein flows-credentials.json fehlt. Die ist seit neuestem aber verschlüsselt. Das moniert das Teil auch an und Du musst im Prinzip alle Credentials neu eingeben - also in allen Konfigurationsnodes - oder wo Du irgendwelche Zugangsdaten hast.
                        • mickymM mickym
                          @mickym
                          etzeste13
                          @mickym ich hatte keine passwörter in verwendung, vielleicht ist Sie deshalb nicht da...
                          • E etzeste13
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @etzeste13 OK - dann mach trotzdem mal folgendes: Sichere Dir mal folgende Dateien weg:
                            flows.json, package.json
                            Schau ob das lib Verzeichnis leer ist.
                            Welche Version des Node-Red Adapters läuft?
                            Der hat vorher gar nicht mehr installiert ausgesehen? - Geh auch noch mal ins /opt/iobroker Verzeichnis und mach nochmal
                            npm list
                            Ach ja ich sehe ein projects- Verzeichnis - hattest Du die project Funktion in Node Red aktiviert?
                            • mickymM mickym
                              npm list
                              etzeste13
                              schrieb am zuletzt editiert von etzeste13
                              @mickym
                              OK, vorerst das Node-Red verzeichnis ist gesicher... lib ordner ist leer, nur ein weiteres auch leere unterverzeichnis mit flows
                              pi@RasPi3B3:/opt/iobroker/iobroker-data/node-red $ ls -la
                              insgesamt 220
                              drwxrwxr-x+  5 iobroker iobroker  4096 28. Aug 22:58 .
                              drwxrwxr-x+  5 iobroker iobroker  4096  7. Feb 2022  ..
                              -rw-rwxr--+  1 iobroker iobroker 40709 28. Aug 16:17 .config.nodes.json
                              -rw-rwxr--+  1 iobroker iobroker 41788 28. Aug 16:17 .config.nodes.json.backup
                              -rw-rwxr--+  1 iobroker iobroker    22  8. Feb 2022  .config.projects.json
                              -rw-rwxr--+  1 iobroker iobroker     2  8. Feb 2022  .config.projects.json.backup
                              -rw-rwxr--+  1 iobroker iobroker   777 28. Aug 16:19 .config.users.json
                              -rw-rwxr--+  1 iobroker iobroker   704 28. Aug 16:19 .config.users.json.backup
                              -rw-rwxr--+  1 iobroker iobroker 14026  1. Sep 18:42 flows.json
                              -rw-rwxr--+  1 iobroker iobroker 22981 28. Aug 22:58 .flows.json.backup
                              drwxrwxr-x+  3 iobroker iobroker  4096  7. Feb 2022  lib
                              drwxrwxr-x+ 79 iobroker iobroker  4096  7. Feb 2022  node_modules
                              -rw-rwxr--+  1 iobroker iobroker   195  7. Feb 2022  package.json
                              -rw-rwxr--+  1 iobroker iobroker 31594  7. Feb 2022  package-lock.json
                              drwxrwxr-x+  3 iobroker iobroker  4096  7. Feb 2022  projects
                              -rw-rwxr--+  1 iobroker iobroker 24430  1. Sep 22:27 settings.js
                              Node-RED asapter ist v3.3.1
                              npm list
                              i@RasPi3B3:/opt/iobroker $ npm list
                              iobroker.inst@3.0.0 /opt/iobroker
                              ├── iobroker.admin@6.2.20
                              ├── iobroker.backitup@2.4.12
                              ├── iobroker.discovery@3.0.5
                              ├── iobroker.info@1.9.19
                              ├── iobroker.js-controller@4.0.23
                              ├── iobroker.modbus@5.0.5
                              ├── iobroker.node-red@3.3.1
                              └── iobroker.rpi2@1.3.2
                              pi@RasPi3B3:/opt/iobroker $
                              • E etzeste13
                                @mickym
                                insgesamt 220
                                npm list
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @etzeste13 Mach nochmal bitte darüber ls -la - nicht nur ls wie vorher.
                                • mickymM mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @mickym Nein im
                                  ls -la /opt/iobroker/iobroker-data/node-red
                                  • mickymM mickym
                                    @mickym Nein im
                                    etzeste13
                                    @mickym
                                    pi@RasPi3B3:/opt/iobroker/iobroker-data/node-red $ ls -la /opt/iobroker/iobroker-data/node-red
                                    insgesamt 220
                                    • E etzeste13
                                      @mickym
                                      insgesamt 220
                                      npm list
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @mickym
                                      insgesamt 220
                                      Ah OK sehr interessant - Du hast doch die Projektfunktion in Node-Red benutzt. Da sieht das andes aus. ;)
                                      Dan zeig bitte Deine Projekte:
                                      /opt/iobroker/iobroker-data/node-red/projects
                                      • mickymM mickym
                                        @mickym
                                        insgesamt 220
                                        etzeste13
                                        @mickym said in Node Red startet nicht nach Raspberry OS update:
                                        projekte hatte ich nicht bewusst benutzt... habe da immer nicht jetzt gedrückt...
                                        pi@RasPi3B3:/opt/iobroker/iobroker-data/node-red/projects $ ls -la
                                        insgesamt 12
                                        drwxrwxr-x+ 3 iobroker iobroker 4096  7. Feb 2022  .
                                        drwxrwxr-x+ 5 iobroker iobroker 4096 28. Aug 22:58 ..
                                        drwxrwxr-x+ 2 iobroker iobroker 4096  7. Feb 2022  .sshkeys
                                        • E etzeste13
                                          insgesamt 12
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @etzeste13 Ok - eigenartig - gut der Node-Red Adapter wurde automatisch wieder installiert:
                                          Gut Du hast aber wahrscheinlich nicht die versteckten dateien weggesichert aus dem /opt/iobroker/iobroker-data/node-red Verzeichnis
