  4. Backitup kein JavaScript Restore möglich!
103 Beiträge 7 Kommentatoren 11.2k Aufrufe 7 Beobachtet
  • GlasfaserG Glasfaser
    @benjamincz
    Zeige mal die Ausgaben , ich habe da so eine Befürchtung.
    Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
    cd /opt/iobroker
    npm ls | grep -E 'github.com|ERR'
    iobroker update -i
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    zu CodeTags ...
    Verzeichniss und auch deine Backups gehören root ... sollte iobroker sein
    wxrwxrwx 2 root root 0 Aug 28 20:36 tmp
    BenjaminCz
    @glasfaser ```
    code_text
    ```pi@raspberrypi:~ $ cd /opt/iobroker
    iobroker update -i
    ├── iobroker.samsung_tizen@0.0.12 (git+ssh://git@github.com/dahuby/iobroker.sams        ung_tizen.git#defeef34bd3f460c77b4fff115de34fd1c11bff7)
    Adapter    "admin"        : 6.2.17   , installed 6.2.17
    Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
    Adapter    "backitup"     : 2.4.10   , installed 2.4.12
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.9
    Adapter    "jarvis"       : 3.0.11   , installed 3.0.13
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pushover"     : 3.0.2    , installed 3.0.2
    Adapter    "samsung"      : 0.5.8    , installed 0.5.11
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "web"          : 4.3.0    , installed 5.2.2
    Adapter    "ws"           : 1.3.0    , installed 2.1.2
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    pi
    /opt/iobroker
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    nodejs:
      Installed: 16.17.0-deb-1nodesource1
      Candidate: 16.17.0-deb-1nodesource1
      Version table:
     *** 16.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
    pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ cd /opt/iobroker
    iobroker update -i
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs        ├── iobroker.samsung_tizen@0.0.12 (git+ssh://git@github.com/dahuby/iobroker.samsung_tizen.git#defeef34bd3f460c77b4fff115de34fd1c11bff7)
    Used repository: Stable (default) (git+ssh://git@github.com/dahuby/iobroker.sams        Adapter    "admin"        : 6.2.17   , installed 6.2.17
    Adapter    "device-reminder": 1.2.9  , installed 1.2.97
    Adapter    "discovery"    : 3.0.5    , installed 3.0.52
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    pi
    /opt/iobroker
    nodejs:
      @benjamincz
      cd /opt/iobroker
      iobroker update -i
      zu CodeTags ...
      BenjaminCz
      @glasfaser said in Backitup kein JavaScript Restore möglich!:
      wie soll ich dass genau verstehen bzw umsetzen. Also im NAS habe ich Benutzer IOBroker und das zugehörige pw. Was genau muss ich dann ändern ?
      Und vielen vielen dank für die Mühe und unterstützung!
      • B BenjaminCz
        BenjaminCz
        @benjamincz said in Backitup kein JavaScript Restore möglich!:
        wie soll ich dass genau verstehen bzw umsetzen. Also im NAS habe ich Benutzer IOBroker und das zugehörige pw. Das gleiche steht auch dann im Backitup Config "NAS/Kopieren" wie im Screenshot oben. Was genau muss ich dann ändern ?
        • B BenjaminCz
          Hallo ich habe einen NAS Server von Western Digital und das Backup von History, Raspberrymatic, Javascript wird auch auf den NAS in den Backup Ordner Hinterlegt. (CIFS) Möchte ich allerdings z.b das Javascript bzw die Scripte zurück Einspielen also Restore dann kommt der Fehler:
          Error:
          {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
          kann mir Hier einer weiter Helfen ?
          Habe da was zwar im Forum gelesen mit Benutzer ? aber schlauer bin ich da leider nicht geworden.
          Wenn ich per Filezilla auf dem IOBroker drauf bin dann steht dort der Backup Ordner und user ist root root und wenn ich da hinein gehe und dort Backups lösche sind diese dann auch auf dem NAS gelöscht.
          simatecS Offline
          simatecS Offline
          simatec
          @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
          Deine Benutzerrechte scheinen nicht zu stimmen, so dass der Schreibzugriff fehlt.
          Stelle mal auf SMB 3.1.1 um und führe mal einen iob fix durch.
          Zeige mal die Ausgabe von:
          ls -lah /opt/iobroker/backups
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          L B 2 Antworten Letzte Antwort
          • simatecS simatec
            legro
            schrieb am zuletzt editiert von legro
            @simatec
            Ich schlage mich wohl mit demselben Fehler herum - lediglich sind's bei mir andere Adapter: YAHKA und ZigBee.
            Versuche ich nun das Backup von YAHKA einzuspielen, erhalte ich folgende Fehlermeldung; dasselbe geschieht in vergleichbarer Weise bei ZigBee.
            Erwartet BackItUp etwa die Backup-Datei im Verzeichnis /opt/iobroker/backups/yahka_0.hapdate/, oder wie soll ich das verstehen?
            Und hier meine Hausaufgaben ..
            pi@raspiBullseye:~ $ iob fix
            library: loaded
            Library version=2022-06-15
            ioBroker or some processes are still running:
             io.telegram.0
             io.admin.0
             io.javascript.0
             io.pushover.0
             io.scenes.0
             io.daikin.0
             io.daikin.1
             io.daikin.2
             io.hue.0
             io.modbus.0
             io.netatmo.0
             io.rpi2.0
             io.shelly.0
             io.web.0
             io.info.0
             io.trashschedule.0
             io.tankerkoenig.0
             io.backitup.0
            Please stop them first and try again!
            pi@raspiBullseye:~ $ ls -lah /opt/iobroker/backups
            total 8.0K
            drwxrwxr-x+ 2 iobroker iobroker 4.0K Aug 29 10:24 .
            drwxrwxr-x+ 6 iobroker iobroker 4.0K Aug 29 10:24 ..
            Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
            GlasfaserG simatecS 2 Antworten Letzte Antwort
            • L legro
              @simatec
              library: loaded
               io.telegram.0
               io.admin.0
               io.javascript.0
               io.pushover.0
               io.scenes.0
               io.daikin.0
               io.daikin.1
               io.daikin.2
               io.hue.0
               io.modbus.0
               io.netatmo.0
               io.rpi2.0
               io.shelly.0
               io.web.0
               io.info.0
               io.trashschedule.0
               io.tankerkoenig.0
               io.backitup.0
              total 8.0K
              GlasfaserG Offline
              GlasfaserG Offline
              @legro
              Über deinen Beitrag steht ein ( ToDo ) .
              hast du das auch gemacht , bzw. was sagt die Ausgabe davon , wer ist der Besitzer .
              • L legro
                @simatec
                library: loaded
                 io.telegram.0
                 io.admin.0
                 io.javascript.0
                 io.pushover.0
                 io.scenes.0
                 io.daikin.0
                 io.daikin.1
                 io.daikin.2
                 io.hue.0
                 io.modbus.0
                 io.netatmo.0
                 io.rpi2.0
                 io.shelly.0
                 io.web.0
                 io.info.0
                 io.trashschedule.0
                 io.tankerkoenig.0
                 io.backitup.0
                total 8.0K
                simatecS Offline
                simatecS Offline
                simatec
                @legro Entweder ihr überprüft die Userrechte auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                Grundsätzlich ist es aber kein Problem von Backitup sondern ein Problem eurer NAS Konfiguration
                L 1 Antwort Letzte Antwort
                • simatecS simatec
                  BenjaminCz
                  @simatec
                  pi@raspberrypi:~ $ ls -lah /opt/iobroker/backups
                  total 131M
                  drwxrwxrwx  2 root     root        0 Aug 29 08:11  .
                  drwxrwxr-x+ 8 iobroker iobroker 4.0K Aug 28 20:49  ..
                  -rwxrwxrwx  1 root     root     4.8M Aug 27 22:41 'historyDB_2022_08_27-22_41_49                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.8M Aug 27 23:06 'historyDB_2022_08_27-23_06_27                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.8M Aug 28 08:11 'historyDB_2022_08_28-08_10_36                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.9M Aug 28 21:01 'historyDB_2022_08_28-20_59_57                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.9M Aug 28 21:03 'historyDB_2022_08_28-21_02_05                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.9M Aug 28 21:10 'historyDB_2022_08_28-21_09_47                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     4.9M Aug 29 08:11 'historyDB_2022_08_29-08_10_36                                          _IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.8M Aug 27 22:41 'iobroker_2022_08_27-22_41_32_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     7.0M Aug 27 23:06 'iobroker_2022_08_27-23_06_11_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     7.0M Aug 28 08:10 'iobroker_2022_08_28-08_10_20_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     7.0M Aug 28 21:01 'iobroker_2022_08_28-20_59_41_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     7.0M Aug 28 21:03 'iobroker_2022_08_28-21_01_48_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.4M Aug 28 21:10 'iobroker_2022_08_28-21_09_32_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     7.0M Aug 29 08:10 'iobroker_2022_08_29-08_10_20_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 27 22:42 'jarvis.0_2022_08_27-22_41_55_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 27 23:06 'jarvis.0_2022_08_27-23_06_34_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 28 08:11 'jarvis.0_2022_08_28-08_10_42_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 28 21:01 'jarvis.0_2022_08_28-21_00_06_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 28 21:03 'jarvis.0_2022_08_28-21_02_11_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 28 21:11 'jarvis.0_2022_08_28-21_09_53_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     6.7M Aug 29 08:11 'jarvis.0_2022_08_29-08_10_42_                                          IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     354K Aug 22 08:11 'javascripts_2022_08_22-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     359K Aug 27 22:42 'javascripts_2022_08_27-22_41_                                          58_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     359K Aug 27 23:06 'javascripts_2022_08_27-23_06_                                          37_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     359K Aug 28 08:11 'javascripts_2022_08_28-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     359K Aug 28 21:01 'javascripts_2022_08_28-21_00_                                          09_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     359K Aug 28 21:03 'javascripts_2022_08_28-21_02_                                          14_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root      399 Aug 28 21:11 'javascripts_2022_08_28-21_09_                                          56_IOBroker Backup_backupiobroker.tar.gz'
                  -rwxrwxrwx  1 root     root     367K Aug 29 08:11 'javascripts_2022_08_29-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                  pi@raspberrypi:~ $
                  Danke vielmals. Ich frage mich nur was ich nun machen soll bzw. wo genau der Fehler liegt...
                  • B BenjaminCz
                    @simatec
                    total 131M
                    pi@raspberrypi:~ $
                    @benjamincz
                    War die Freigabe des NAS zu dem Zeitpunkt gemountet?
                      @benjamincz
                      BenjaminCz
                      @thomas-braun ja
                      • B BenjaminCz
                        @thomas-braun ja
                        @benjamincz
                        Und auf dem NAS ist das ganze wie angelegt?
                        GlasfaserG B 2 Antworten Letzte Antwort
                          @benjamincz
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @thomas-braun sagte in Backitup kein JavaScript Restore möglich!:
                          @benjamincz
                          In deinen Einstellung ist aber dieser Pfad .
                          und du zeigst auf der Pi .
                            @benjamincz
                            BenjaminCz
                            @thomas-braun Es handlet sich um die Western Digital Cloud EX2 Ultra 8TB. DOrt habe ich einen Benutzer Erstellt namens iobroker und das passwort dazu. Der Freigabe Ordner Heißt IOBroker-Backup. Dort Ist ein Unterordner namens IOBroker und ein Unterordner namens Raspberymatic. In jedem Unterordner werden also Backups Hinterlegt. Sie sind auch Erfolgreich auf dem NAS laufwerk dann auch Drauf. Es geht Jarvis nicht zu Restoren und es geht auch kein Javascript. IOBroker gesamt Restore Funktioniert und auch History geht.
                            Ich lese immer lokal Update einspielen ja aber der Backup ordner in opt/iobroker/backups ist ja gleichzeitig der ordner auf meinem NAS. D.h wenn ich dort etwas lösche ist es auch dann auf meinem NAS gelöscht.
                            • B BenjaminCz
                              Das ist richtig (und korrekt auch...)
                              Zeig mal die Einstellungen im NAS.
                                @benjamincz
                                BenjaminCz
                                @glasfaser
                                Ja der Backup Ordner Stimmt schon.
                                • B BenjaminCz
                                  @glasfaser
                                  BenjaminCz
                                  @benjamincz
                                  Hier sieht man es nochmals Besser.
                                  • B BenjaminCz
                                    @benjamincz
                                    @benjamincz
                                    Ich nicht. Besser sieht man es mit:
                                    ls -lA /opt/iobroker/backups
                                    Und zeig mal die Ausgabe zu
                                    mount
                                      BenjaminCz
                                      NAS Config
                                      Thomas BraunT simatecS 2 Antworten Letzte Antwort
                                      • B BenjaminCz
                                        NAS Config
                                        @benjamincz
                                        Das Ding kann NFS? Dann nimm das.
                                          @benjamincz
                                          mount
                                          BenjaminCz
                                          pi@raspberrypi:~ $ ls -lA /opt/iobroker/backups
                                          total 153272
                                          -rwxrwxrwx 1 root root 4999539 Aug 27 22:41 'historyDB_2022_08_27-22_41_49_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5000593 Aug 27 23:06 'historyDB_2022_08_27-23_06_27_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5020588 Aug 28 08:11 'historyDB_2022_08_28-08_10_36_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5048947 Aug 28 21:01 'historyDB_2022_08_28-20_59_57_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5049642 Aug 28 21:03 'historyDB_2022_08_28-21_02_05_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5049642 Aug 28 21:10 'historyDB_2022_08_28-21_09_47_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5074239 Aug 29 08:11 'historyDB_2022_08_29-08_10_36_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 5105235 Aug 29 19:49 'historyDB_2022_08_29-19_48_37_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7094978 Aug 27 22:41 'iobroker_2022_08_27-22_41_32_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7288161 Aug 27 23:06 'iobroker_2022_08_27-23_06_11_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7287843 Aug 28 08:10 'iobroker_2022_08_28-08_10_20_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7313016 Aug 28 21:01 'iobroker_2022_08_28-20_59_41_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7312941 Aug 28 21:03 'iobroker_2022_08_28-21_01_48_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 6617941 Aug 28 21:10 'iobroker_2022_08_28-21_09_32_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7277232 Aug 29 08:10 'iobroker_2022_08_29-08_10_20_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7281200 Aug 29 19:49 'iobroker_2022_08_29-19_48_20_IOBroker Backup_backupiobroker.tar.gz'
                                          drwxrwxrwx 2 root root       0 Aug 29 19:55  jarvis_0
                                          -rwxrwxrwx 1 root root 7014516 Aug 27 22:42 'jarvis.0_2022_08_27-22_41_55_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 27 23:06 'jarvis.0_2022_08_27-23_06_34_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 28 08:11 'jarvis.0_2022_08_28-08_10_42_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 28 21:01 'jarvis.0_2022_08_28-21_00_06_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 28 21:03 'jarvis.0_2022_08_28-21_02_11_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 28 21:11 'jarvis.0_2022_08_28-21_09_53_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 29 08:11 'jarvis.0_2022_08_29-08_10_42_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root 7014516 Aug 29 19:49 'jarvis.0_2022_08_29-19_48_43_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  361727 Aug 22 08:11 'javascripts_2022_08_22-08_10_45_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  367316 Aug 27 22:42 'javascripts_2022_08_27-22_41_58_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  367314 Aug 27 23:06 'javascripts_2022_08_27-23_06_37_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  367316 Aug 28 08:11 'javascripts_2022_08_28-08_10_45_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  367414 Aug 28 21:01 'javascripts_2022_08_28-21_00_09_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  367418 Aug 28 21:03 'javascripts_2022_08_28-21_02_14_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root     399 Aug 28 21:11 'javascripts_2022_08_28-21_09_56_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  374980 Aug 29 08:11 'javascripts_2022_08_29-08_10_45_IOBroker Backup_backupiobroker.tar.gz'
                                          -rwxrwxrwx 1 root root  374982 Aug 29 19:49 'javascripts_2022_08_29-19_48_46_IOBroker Backup_backupiobroker.tar.gz'
                                          drwxrwxrwx 2 root root       0 Aug 29 19:55  tmpScripts
                                          Ist das so Richtig ?
