  4. Probleme bei js-controller update
    5.8k
6 Beiträge 2 Kommentatoren 641 Aufrufe 2 Beobachtet
  • OmnedonO Online
    OmnedonO Online
    Omnedon
    bei js-controller Update bekomme ich Fehler:
    pi@ioBroker-Pi4:/opt/iobroker $ iob update
    node:internal/modules/cjs/loader:959
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Ich habe versucht das zu fixen mit
    sudo -H -u iobroker npm install iobroker.js-controller
    Erhalte aber auch hier Fehler:
    pi@ioBroker-Pi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/agent-base
    npm ERR! dest /opt/iobroker/node_modules/.agent-base-ZzrsLltQ
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -> '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-27T17_05_34_936Z-debug-0.log
    In der Log-Datei steht:
    7592 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -> '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
    7593 verbose cwd /opt/iobroker
    7594 verbose Linux 5.15.56-v7l+
    7595 verbose node v16.17.0
    7596 verbose npm  v8.15.0
    7597 error code ENOTEMPTY
    7598 error syscall rename
    7599 error path /opt/iobroker/node_modules/agent-base
    7600 error dest /opt/iobroker/node_modules/.agent-base-ZzrsLltQ
    7601 error errno -39
    7602 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -> '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
    7603 verbose exit -39
    7604 timing npm Completed in 144667ms
    7605 verbose unfinished npm timer reify 1661619935284
    7606 verbose unfinished npm timer reify:retireShallow 1661620078359
    7607 verbose code -39
    7608 error A complete log of this run can be found in:
    7608 error     /home/iobroker/.npm/_logs/2022-08-27T17_05_34_936Z-debug-0.log
    Was kann ich tun?
    Viele Grüße
    • OmnedonO Omnedon
        throw err;
        requireStack: []
      npm ERR! errno -39
      Was kann ich tun?
      Viele Grüße
      @omnedon
      https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
      OmnedonO 1 Antwort Letzte Antwort
        @omnedon
        OmnedonO Online
        OmnedonO Online
        Omnedon
        Danke - es hat funktioniert!
        • OmnedonO Omnedon
          @omnedon
          Den js-controller updated man eigentlich anders.
          Wie bist du da jetzt unterwegs?
          iobroker update
          mal posten.
            @omnedon
            iobroker update
            mal posten.
            OmnedonO Online
            OmnedonO Online
            Omnedon
            Hier die Ausgabe:
            Used repository: stable
            Adapter    "admin"        : 6.2.17   , installed 5.4.9  [Updatable]
            Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
            Adapter    "backitup"     : 2.4.10   , installed 2.4.12
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "daswetter"    : 3.1.2    , installed 3.1.4
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "ems-esp"      : 1.15.0   , installed 1.15.0
            Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "history"      : 2.2.0    , installed 2.2.1
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.43
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.15
            Adapter    "homekit-controller": 0.5.1, installed 0.5.1
            Adapter    "ical"         : 1.13.1   , installed 1.13.1
            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
            Adapter    "influxdb"     : 3.1.7    , installed 3.1.8
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "javascript"   : 6.0.0    , installed 6.0.1
            Controller "js-controller": 4.0.23   , installed 4.0.23
            Adapter    "km200"        : 2.0.3    , installed 2.0.3
            Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
            Adapter    "melcloud"     : 1.1.6    , installed 1.1.6
            Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
            Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "odl"          : 2.0.5    , installed 2.0.5
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "robonect"     : 0.1.4    , installed 0.1.4
            Adapter    "roomba"       : 1.1.4    , installed 1.1.4
            Adapter    "samsung"      : 0.5.8    , installed 0.5.11
            Adapter    "shelly"       : 6.0.0    , installed 6.0.0
            Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "synology"     : 2.1.9    , installed 2.1.9
            Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.13.0   , installed 1.14.1
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.3.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.6
            Adapter    "withings"     : 0.0.9    , installed 0.0.9
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
            Nur der admin-Adapter muss noch upgedatet werden.
            • OmnedonO Omnedon
              Hier die Ausgabe:
              @omnedon Okay.
