<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Probleme bei js-controller update]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
bei js-controller Update bekomme ich Fehler:</p>
<pre><code>pi@ioBroker-Pi4:/opt/iobroker $ iob update
node:internal/modules/cjs/loader:959
  throw err;
Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
    at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    at node:internal/main/run_main_module:17:47 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
</code></pre>
<p dir="auto">Ich habe versucht das zu fixen mit</p>
<pre><code>sudo -H -u iobroker npm install iobroker.js-controller
</code></pre>
<p dir="auto">Erhalte aber auch hier Fehler:</p>
<pre><code>pi@ioBroker-Pi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/agent-base
npm ERR! dest /opt/iobroker/node_modules/.agent-base-ZzrsLltQ
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -&gt; '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
npm ERR!     /home/iobroker/.npm/_logs/2022-08-27T17_05_34_936Z-debug-0.log
</code></pre>
<p dir="auto">In der Log-Datei steht:</p>
<pre><code>7592 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -&gt; '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
7593 verbose cwd /opt/iobroker
7594 verbose Linux 5.15.56-v7l+
7595 verbose node v16.17.0
7596 verbose npm  v8.15.0
7597 error code ENOTEMPTY
7598 error syscall rename
7599 error path /opt/iobroker/node_modules/agent-base
7600 error dest /opt/iobroker/node_modules/.agent-base-ZzrsLltQ
7601 error errno -39
7602 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -&gt; '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
7603 verbose exit -39
7604 timing npm Completed in 144667ms
7605 verbose unfinished npm timer reify 1661619935284
7606 verbose unfinished npm timer reify:retireShallow 1661620078359
7607 verbose code -39
7608 error A complete log of this run can be found in:
7608 error     /home/iobroker/.npm/_logs/2022-08-27T17_05_34_936Z-debug-0.log
</code></pre>
<p dir="auto">Was kann ich tun?</p>
<p dir="auto">Viele Grüße</p>
]]></description><link>https://forum.iobroker.net/topic/57523/probleme-bei-js-controller-update</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 07:05:29 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/57523.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Aug 2022 17:14:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Probleme bei js-controller update on Sun, 28 Aug 2022 12:31:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omnedon" aria-label="Profile: omnedon">@<bdi>omnedon</bdi></a> Okay.</p>
]]></description><link>https://forum.iobroker.net/post/848869</link><guid isPermaLink="true">https://forum.iobroker.net/post/848869</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 28 Aug 2022 12:31:45 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme bei js-controller update on Sun, 28 Aug 2022 12:25:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Hier die Ausgabe:</p>
Used repository: stable
Adapter    "admin"        : 6.2.17   , installed 5.4.9  [Updatable]
Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
Adapter    "backitup"     : 2.4.10   , installed 2.4.12
Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
Adapter    "daswetter"    : 3.1.2    , installed 3.1.4
Adapter    "devices"      : 1.0.12   , installed 1.0.12
Adapter    "discovery"    : 3.0.5    , installed 3.0.5
Adapter    "dwd"          : 2.8.3    , installed 2.8.3
Adapter    "email"        : 1.1.3    , installed 1.1.3
Adapter    "ems-esp"      : 1.15.0   , installed 1.15.0
Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
Adapter    "history"      : 2.2.0    , installed 2.2.1
Adapter    "hm-rega"      : 3.0.40   , installed 3.0.43
Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.15
Adapter    "homekit-controller": 0.5.1, installed 0.5.1
Adapter    "ical"         : 1.13.1   , installed 1.13.1
Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "influxdb"     : 3.1.7    , installed 3.1.8
Adapter    "info"         : 1.9.19   , installed 1.9.19
Adapter    "javascript"   : 6.0.0    , installed 6.0.1
Controller "js-controller": 4.0.23   , installed 4.0.23
Adapter    "km200"        : 2.0.3    , installed 2.0.3
Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
Adapter    "melcloud"     : 1.1.6    , installed 1.1.6
Adapter    "mobile"       : 1.0.1    , installed 1.0.1
Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
Adapter    "nina"         : 0.0.25   , installed 0.0.25
Adapter    "odl"          : 2.0.5    , installed 2.0.5
Adapter    "ping"         : 1.5.3    , installed 1.5.3
Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
Adapter    "robonect"     : 0.1.4    , installed 0.1.4
Adapter    "roomba"       : 1.1.4    , installed 1.1.4
Adapter    "samsung"      : 0.5.8    , installed 0.5.11
Adapter    "scenes"       : 2.3.9    , installed 2.3.9
Adapter    "shelly"       : 6.0.0    , installed 6.0.0
Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
Adapter    "socketio"     : 4.2.0    , installed 4.2.0
Adapter    "synology"     : 2.1.9    , installed 2.1.9
Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
Adapter    "telegram"     : 1.13.0   , installed 1.14.1
Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
Adapter    "upnp"         : 1.0.21   , installed 1.0.21
Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
Adapter    "vis-hqwidgets": 1.2.0    , installed 1.3.0
Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
Adapter    "vis-weather"  : 2.5.5    , installed 2.5.6
Adapter    "web"          : 4.3.0    , installed 4.3.0
Adapter    "withings"     : 0.0.9    , installed 0.0.9
Adapter    "ws"           : 1.3.0    , installed 1.3.0
Adapter    "yahka"        : 0.13.1   , installed 0.13.1
Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
</code></pre>
<p dir="auto">Nur der admin-Adapter muss noch upgedatet werden.</p>
]]></description><link>https://forum.iobroker.net/post/848867</link><guid isPermaLink="true">https://forum.iobroker.net/post/848867</guid><dc:creator><![CDATA[Omnedon]]></dc:creator><pubDate>Sun, 28 Aug 2022 12:25:38 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme bei js-controller update on Sun, 28 Aug 2022 11:36:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omnedon" aria-label="Profile: omnedon">@<bdi>omnedon</bdi></a></p>
<p dir="auto">Den js-controller updated man eigentlich anders.<br />
Wie bist du da jetzt unterwegs?</p>
<pre><code>iobroker update
</code></pre>
<p dir="auto">mal posten.</p>
]]></description><link>https://forum.iobroker.net/post/848859</link><guid isPermaLink="true">https://forum.iobroker.net/post/848859</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 28 Aug 2022 11:36:49 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme bei js-controller update on Sun, 28 Aug 2022 11:29:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Danke - es hat funktioniert!</p>
]]></description><link>https://forum.iobroker.net/post/848856</link><guid isPermaLink="true">https://forum.iobroker.net/post/848856</guid><dc:creator><![CDATA[Omnedon]]></dc:creator><pubDate>Sun, 28 Aug 2022 11:29:53 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme bei js-controller update on Sat, 27 Aug 2022 17:19:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omnedon" aria-label="Profile: omnedon">@<bdi>omnedon</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8">https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8</a></p>
]]></description><link>https://forum.iobroker.net/post/848555</link><guid isPermaLink="true">https://forum.iobroker.net/post/848555</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 27 Aug 2022 17:19:43 GMT</pubDate></item></channel></rss>
