  4. [gelöst] Backitup sichert nur noch historyDB
    5.8k
8 Beiträge 2 Kommentatoren 504 Aufrufe 2 Beobachtet
    Saibot88
    schrieb am zuletzt editiert von Saibot88
    gestern ist mir aufgefallen, dass der Backitup Adapter seit 24.07. nur noch die historyDB sichert. Bis zum 01.06. sicherte er noch javascrips, influxDB und ioBroker. Zwischen den beiden Daten wurden sogar garkeine Sicherungen erstellt. Die Backups werden bzw. sollen auf einem Stick an einer FritzBox abgelegt werden. Die Telegrambenachrichtigung ergibt keine Fehler.
    Habt ihr einen heißen Tipp woran es liegen könnte?
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [mount] - noserverino option: true
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=BackupIO,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.2/FRITZ.NAS/Volume/Backup_IoBroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] start with {"type":"creator","time":"04:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.15","port":"8088","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.15","port":"3001","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Tobias","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"shortWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [iobroker] - host.smartHome 4664 states saved
    [DEBUG] [iobroker] - host.smartHome 6268 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_08_24-08_53_35_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_08_24-08_54_03_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_08_24-08_54_44_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Error on Grafana Dashoard Request: AxiosError: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: pi_shutdown
    [DEBUG] [javascripts] - found Script: pi_reboot
    [DEBUG] [javascripts] - found Script: Szene_gemütlich_nach_Sonnenuntergang
    [DEBUG] [javascripts] - found Script: Hauswasserwerk
    [DEBUG] [javascripts] - found Script: Tag___Nacht_Umschaltung
    [DEBUG] [javascripts] - found Script: Weihnachtsbeleuchtung
    [DEBUG] [javascripts] - found Script: Laden
    [DEBUG] [javascripts] - found Script: Hinweis_Alarmanlage
    [DEBUG] [javascripts] - found Script: Geburtstage
    [DEBUG] [javascripts] - found Script: MinutenUhr
    [DEBUG] [javascripts] - found Script: Keller_lüften
    [DEBUG] [javascripts] - found Script: Müllerinnerung_Telegram_
    [DEBUG] [javascripts] - found Script: Multiroom_Amp_schalten
    [DEBUG] [javascripts] - found Script: Telegram_Menü
    [DEBUG] [javascripts] - found Script: Fully_Kiosk_Browser_restart
    [DEBUG] [javascripts] - found Script: Ventile_schalten
    [DEBUG] [javascripts] - found Script: Ventile_aus_wenn_Pumpe_aus
    [DEBUG] [javascripts] - found Script: Routine
    [DEBUG] [javascripts] - found Script: test
    [DEBUG] [javascripts] - found Script: Gastracker
    [DEBUG] [javascripts] - found Script: stumm_bei_Anruf
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_08_24-08_54_49_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - used copy path: /FRITZ.NAS/Volume/Backup_IoBroker
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
    [DEBUG] [telegram] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"04:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2022_08_24-08_53_35_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2022_08_24-08_54_03_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2022_08_24-08_54_44_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2022_08_24-08_54_49_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","historyDB","javascripts"],"types":["iobroker","influxDB","historyDB","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.15","port":"8088","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.15","port":"3001","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Tobias","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"24. August 2022 um 08:54 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"shortWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"04:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2022_08_24-08_53_35_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2022_08_24-08_54_03_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2022_08_24-08_54_44_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2022_08_24-08_54_49_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","historyDB","javascripts"],"types":["iobroker","influxDB","historyDB","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.15","port":"8088","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.15","port":"3001","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"24. August 2022 um 08:54 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Tobias","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"shortWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyJSON] start with {"type":"creator","time":"04:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2022_08_24-08_53_35_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2022_08_24-08_54_03_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2022_08_24-08_54_44_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2022_08_24-08_54_49_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","historyDB","javascripts"],"types":["iobroker","influxDB","historyDB","javascripts"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.15","port":"8088","dbversion":"1.x","token":"","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.15","port":"3001","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"24. August 2022 um 08:54 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Tobias","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"shortWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"deleteOldBackup":true,"ownDir":false,"dir":"/FRITZ.NAS/Volume/Backup_IoBroker","dirMinimal":"sharename/backupDir","user":"BackupIO","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Vielen Dank für eure Unterstützung
    • S Saibot88
      [EXIT] 0
      simatecS Offline
      simatecS Offline
      simatec
      @saibot88 Zeige mal die NAS Einstellungen der FB und von Backitup
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
        Saibot88
        @simatec Ich hoffe du kannst damit etwas anfangen. Die Verbindung zur NAS müsste eigentlich passen, denn es wird ja das historyDB Backup auf die Nas geschrieben, nur eben die restlichen Backups iobroker, javascrips und so weiter nicht.
        Für heute sind 3 Einträge auf der NAS, aber eben nur historyDB. Um 04 Uhr ist automatisch und die beiden anderen von mir manuell als Test gestartet wurden.
        • S Saibot88
          simatecS Offline
          simatecS Offline
          simatec
          @saibot88 Hmm 1KB History Backup?
          Ist da etwas beschädigt? Gefühlt kann nicht auf den Stick richtig geschrieben werden.
          Schalte mal die NAS Sicherung aus und teste erstmal lokal.
          Wenn das geht, können wir mit dem NAS weiterschauen.
            Saibot88
            @simatec scheint soweit zu funktionieren oder?
            pi@smartHome:/opt/iobroker/backups $ ls -l
            insgesamt 18468
            -rw-rw-r--+ 1 iobroker iobroker      87 24. Aug 13:15 historyDB_2022_08_24-13_15        _27_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 9999172 24. Aug 13:15 influxDB_2022_08_24-13_15_        19_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 8855570 24. Aug 13:15 iobroker_2022_08_24-13_14_        49_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker   39080 24. Aug 13:15 javascripts_2022_08_24-13_        15_31_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker    1333 24. Aug 13:15 zigbee.0_2022_08_24-13_15_        27_backupiobroker.tar.gz
            • S Saibot88
              insgesamt 18468
              simatecS Offline
              simatecS Offline
              simatec
              @saibot88 ja das schaut gut aus ... jetzt muss du mal dein FB prüfen.
              Starte sie ggfs. einfach mal neu
                Saibot88
                @simatec ich denke es läuft wieder. Ein simpler Neustart, das hätte mir auch selber einfallen müssen.
                Ich bedanke mich recht herzlich für deine Unterstützung.
                38e1d4f0-ec14-4a7f-83a3-719fd77b3148-grafik.png code_text
                • S Saibot88
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @saibot88 Kannst du das Thema bitte auf [gelöst] setzen
