  4. Javascript startet nicht mehr
    5.8k
24 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    Hallo.
    Die Probleme reissen nicht ab.
    Hab die Konfig vom Javascript-Adapter geöffnet und "dewpoint" gelöscht und wieder eingetragen.
    Seitdem ist der Adapter rot.
    host.TinkerboardS
    	2022-08-23 14:49:46.582	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.TinkerboardS
    	2022-08-23 14:49:46.582	error	Caught by controller[0]: }
    host.TinkerboardS
    	2022-08-23 14:49:46.582	error	Caught by controller[0]: requestPath: 'coffee-script'
    host.TinkerboardS
    	2022-08-23 14:49:46.582	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script/package.json',
    host.TinkerboardS
    	2022-08-23 14:49:46.582	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:7:10)
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.TinkerboardS
    	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.TinkerboardS
    	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    host.TinkerboardS
    	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:27)
    host.TinkerboardS
    	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:566:18)
    host.TinkerboardS
    	2022-08-23 14:49:46.577	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:353:19)
    host.TinkerboardS
    	2022-08-23 14:49:46.577	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.TinkerboardS
    	2022-08-23 14:49:46.576	error	Caught by controller[0]: ^
    host.TinkerboardS
    	2022-08-23 14:49:46.576	error	Caught by controller[0]: throw err;
    host.TinkerboardS
    	2022-08-23 14:49:46.575	error	Caught by controller[0]: node:internal/modules/cjs/loader:361
    Habe dann noch versucht ein Upgrade zu machen
    Update javascript from @5.7.0 to @6.0.0
    NPM version: 8.11.0
    Installing iobroker.javascript@6.0.0... (System call)
    host.TinkerboardS Cannot install iobroker.javascript@6.0.0: 217
    pi@TinkerboardS:~$ cd /opt/iobroker/node_modules/iobroker.javascript
    pi@TinkerboardS:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev
    [sudo] Passwort für pi:
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver
    npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ'
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-23T12_44_55_265Z-debug-0.log
    pi@TinkerboardS:/opt/iobroker/node_modules/iobroker.javascript$ rm -r /opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ
    rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.javascript@5.7.0 postinstall
    > node ./install/installTypings.js
    Installing NodeJS typings...
    latest @types: 18, installed node: 16
    Could not install NodeJS typings. This is not critical.
    Reason:
    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm ERR! Object for dependency "get-intrinsic" is empty.
    npm ERR! Something went wrong. Regenerate the package-lock.json with "npm install".
    npm ERR! If using a shrinkwrap, regenerate with "npm shrinkwrap".
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-23T12_47_23_141Z-debug.log
    added 9 packages, removed 461 packages, changed 156 packages, and audited 92 packages in 54s
    7 packages are looking for funding
      run `npm fund` for details
    Traue mich nicht das TB neu zu starten, wer weiss, was dann nicht mehr funktioniert.
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Hallo.
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      host.TinkerboardS
      NPM version: 8.11.0
      npm ERR! errno -39
      Reason:
      @gregors sagte in Javascript startet nicht mehr:
      welche Version von js hast du?
      und wie installiert?
      ist IMHO nicht mehr im js-Adapter enthalten.
      https://github.com/ioBroker/ioBroker.javascript#600-2022-07-18
      (bluefox) Removed support of coffeescript
      war möglicherweise keine gute Idee
      GregorSG 1 Antwort Letzte Antwort
      • GregorSG GregorS
        Hallo.
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        NPM version: 8.11.0
        npm ERR! errno -39
        Reason:
        @gregors
        Wie bist du denn da so grundsätzlich unterwegs:
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Sind im javascript-Adapter zusätzliche Module eingetragen? Welche?
          GregorSG Offline
          GregorSG Offline
          GregorS
          Installiert über Adapter
          JS-Script 5.7.0
          JS controller 4.0.23
          NPM 8.11.0
          Node 16.16.0
          Seite dem Update von NODE und NPM habe ich nur Probleme
            @gregors
            GregorSG Offline
            GregorSG Offline
            GregorS
            Habe "tail" und "dewpoint" als zusätzliche Module eingetragen.
            • GregorSG GregorS
              JS-Script 5.7.0
              NPM 8.11.0
              Node 16.16.0
              Alleine da gibt es drei Möglichkeiten :-)
              Vermutlich wegen des möglicherweise strengeren Verhaltens von npm v8 bei bisher unbestraften Fehlern.
              Aber dazu gibt es schon genug Threads
              • GregorSG GregorS
                und die Ein- und Ausgabe der geposteten Befehle?
                nix unterschlagen bitte
                • GregorSG GregorS
                  @gregors
                  Trag die mal aus.
                  Und dann bitte die angefragten Dinge beibringen.
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    @homoran said in Javascript startet nicht mehr:
                    Da bin ich raus.
                    War froh, dass das System bis dahin einwandfrei lief.
                    Welche 3 Möglichkeiten gibt es denn?
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      Was meinst du damit? Bin leicht überfordert
                      • GregorSG GregorS
                        Da bin ich raus.
                        • "normal"
                        • über npm
                        • über Github
                        für "normal" kommt es außerdem noch auf das eingestellte Repo an: stable oder Beta
                          • "normal"
                          • über npm
                          • über Github
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          Ich würde Normal sagen, und stable.
                          • GregorSG GregorS
                            @thomas-Braun hat dir zwei Befehle in code-tags gepostet
                            die sollst du ausführen und die Ein- und Ausgabe davon wiederum in code-tags posten
                            • GregorSG GregorS
                              @gregors
                              Vollständige Ein- und Ausgabezeilen zu
                              bitte.
                                @gregors
                                bitte.
                                GregorSG Offline
                                GregorSG Offline
                                GregorS
                                OK. Habe jetzt verstanden.
                                pi@TinkerboardS:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                pi@TinkerboardS:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.16.0
                                v16.16.0
                                8.11.0
                                pi
                                /home/pi
                                Ign:1 http://httpredir.debian.org/debian stretch InRelease
                                OK:2 http://security.debian.org stretch/updates InRelease
                                OK:3 http://httpredir.debian.org/debian stretch-updates InRelease
                                OK:4 http://httpredir.debian.org/debian stretch-backports InRelease
                                OK:5 http://httpredir.debian.org/debian stretch Release
                                OK:7 https://deb.nodesource.com/node_16.x stretch InRelease
                                OK:6 http://mirrors.xtom.de/armbian stretch InRelease
                                OK:8 https://www.pivccu.de/piVCCU stable InRelease
                                Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                                N: Datei »pivccu.list‘« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                                nodejs:
                                  Installiert:           16.16.0-1nodesource1
                                  Installationskandidat: 16.17.0-1nodesource1
                                  Versionstabelle:
                                     16.17.0-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x stretch/main armhf Packages
                                 *** 16.16.0-1nodesource1 100
                                     8.11.1~dfsg-2~bpo9+1 100
                                        100 http://httpredir.debian.org/debian stretch-backports/main armhf Packages
                                     4.8.2~dfsg-1 500
                                        500 http://httpredir.debian.org/debian stretch/main armhf Packages
                                • GregorSG GregorS
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.16.0
                                  v16.16.0
                                  8.11.0
                                  pi
                                  /home/pi
                                  nodejs:
                                    Versionstabelle:
                                       4.8.2~dfsg-1 500
                                  @gregors
                                  Stretch ist tot, installier eine lebendiges Release.
                                  • GregorSG GregorS
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.16.0
                                    v16.16.0
                                    8.11.0
                                    pi
                                    /home/pi
                                    nodejs:
                                      Versionstabelle:
                                         4.8.2~dfsg-1 500
                                    armbian stretch
                                    Uralt!
                                    ist das noch aus zeiten der All_In_One Images mit
                                    piVCCU
                                    Das musst du mal komplett neu aufsetzen
                                      armbian stretch
                                      Uralt!
                                      piVCCU
                                      GregorSG Offline
                                      GregorSG Offline
                                      GregorS
                                      Das ist richtig.
                                      Habe es damals aus dem All-in-One Image installiert.
                                      Werde nun tatsächlich ein neues System aufsetzen müssen.
                                      Bekomme ich den JS wieder ans rennen, oder muss ich ein älteres Image aufspielen?
                                      Die Installation des neuen Systems dauert, da ich ja alles einzeln installiern muss.
                                      • GregorSG GregorS
                                        Das ist richtig.
                                        Backups einspielen.
                                        GregorSG HomoranH 2 Antworten Letzte Antwort
                                          Backups einspielen.
                                          GregorSG Offline
                                          GregorSG Offline
                                          GregorS
                                          Ok, werde ich erstmal machen.
