<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Javascript startet nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo.</p>
<p dir="auto">Die Probleme reissen nicht ab.<br />
Hab die Konfig vom Javascript-Adapter geöffnet und "dewpoint" gelöscht und wieder eingetragen.<br />
Seitdem ist der Adapter rot.</p>
<pre><code>host.TinkerboardS
	2022-08-23 14:49:46.582	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.TinkerboardS
	2022-08-23 14:49:46.582	error	Caught by controller[0]: }
host.TinkerboardS
	2022-08-23 14:49:46.582	error	Caught by controller[0]: requestPath: 'coffee-script'
host.TinkerboardS
	2022-08-23 14:49:46.582	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script/package.json',
host.TinkerboardS
	2022-08-23 14:49:46.582	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:7:10)
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
host.TinkerboardS
	2022-08-23 14:49:46.581	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
host.TinkerboardS
	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
host.TinkerboardS
	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:27)
host.TinkerboardS
	2022-08-23 14:49:46.580	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:566:18)
host.TinkerboardS
	2022-08-23 14:49:46.577	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:353:19)
host.TinkerboardS
	2022-08-23 14:49:46.577	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
host.TinkerboardS
	2022-08-23 14:49:46.576	error	Caught by controller[0]: ^
host.TinkerboardS
	2022-08-23 14:49:46.576	error	Caught by controller[0]: throw err;
host.TinkerboardS
	2022-08-23 14:49:46.575	error	Caught by controller[0]: node:internal/modules/cjs/loader:361
</code></pre>
<p dir="auto">Habe dann noch versucht ein Upgrade zu machen</p>
<pre><code>Update javascript from @5.7.0 to @6.0.0
NPM version: 8.11.0
Installing iobroker.javascript@6.0.0... (System call)
host.TinkerboardS Cannot install iobroker.javascript@6.0.0: 217
pi@TinkerboardS:~$ cd /opt/iobroker/node_modules/iobroker.javascript
pi@TinkerboardS:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev
[sudo] Passwort für pi:
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver
npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver' -&gt; '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ'
npm ERR!     /home/iobroker/.npm/_logs/2022-08-23T12_44_55_265Z-debug-0.log
pi@TinkerboardS:/opt/iobroker/node_modules/iobroker.javascript$ rm -r /opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ
rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
&gt; iobroker.javascript@5.7.0 postinstall
&gt; node ./install/installTypings.js
Installing NodeJS typings...
latest @types: 18, installed node: 16
Could not install NodeJS typings. This is not critical.
Reason:
npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
npm ERR! Object for dependency "get-intrinsic" is empty.
npm ERR! Something went wrong. Regenerate the package-lock.json with "npm install".
npm ERR! If using a shrinkwrap, regenerate with "npm shrinkwrap".
npm ERR!     /home/iobroker/.npm/_logs/2022-08-23T12_47_23_141Z-debug.log
added 9 packages, removed 461 packages, changed 156 packages, and audited 92 packages in 54s
7 packages are looking for funding
  run `npm fund` for details
</code></pre>
<p dir="auto">Traue mich nicht das TB neu zu starten, wer weiss, was dann nicht mehr funktioniert.</p>
]]></description><link>https://forum.iobroker.net/topic/57389/javascript-startet-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 09:21:59 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/57389.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Aug 2022 12:58:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 16:48:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">Werde ich auch machen.<br />
Ich muss nur mein jetziges System erstmal wieder ans laufen bekommen.<br />
Dann kann ich in Ruhe das neue System aufziehen.<br />
Habe noch ein TB als Reserve</p>
]]></description><link>https://forum.iobroker.net/post/846626</link><guid isPermaLink="true">https://forum.iobroker.net/post/846626</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 16:48:56 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 14:03:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846555">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Habe noch ein komplette Image vom Mai, dass werde ich drüberbügeln,</p>
</blockquote>
<p dir="auto">da ist dann aber auch kein neueres Betriebssystem drauf :-(</p>
<blockquote>
<p dir="auto">Habe Backups von History, iobroker, hometaic und redis</p>
</blockquote>
<p dir="auto">die sollst du <strong>nach</strong> der Neuinstallation des Grundsystems draufspielen</p>
]]></description><link>https://forum.iobroker.net/post/846559</link><guid isPermaLink="true">https://forum.iobroker.net/post/846559</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 14:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:54:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">Habe noch ein komplette Image vom Mai, dass werde ich drüberbügeln,<br />
und danach ein Backup von einem Zeitpunkt vor dem Update.<br />
]]></description><link>https://forum.iobroker.net/post/846555</link><guid isPermaLink="true">https://forum.iobroker.net/post/846555</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:48:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/846550">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846547">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Die Installation des neuen Systems dauert, da ich ja alles einzeln installiern muss.</p>
</blockquote>
<p dir="auto">Backups einspielen.</p>
</blockquote>
<p dir="auto">nutzt nix wenn er noch piVCCU braucht.<br />
Das dauert schon 15-30 Minuten Hand-On</p>
]]></description><link>https://forum.iobroker.net/post/846554</link><guid isPermaLink="true">https://forum.iobroker.net/post/846554</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:48:30 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Ok, werde ich erstmal machen.</p>
]]></description><link>https://forum.iobroker.net/post/846552</link><guid isPermaLink="true">https://forum.iobroker.net/post/846552</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:44:31 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:44:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846547">Javascript startet nicht mehr</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/846550</link><guid isPermaLink="true">https://forum.iobroker.net/post/846550</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:44:03 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:43:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">Das ist richtig.<br />
Habe es damals aus dem All-in-One Image installiert.<br />
Werde nun tatsächlich ein neues System aufsetzen müssen.</p>
<p dir="auto">Bekomme ich den JS wieder ans rennen, oder muss ich ein älteres Image aufspielen?<br />
]]></description><link>https://forum.iobroker.net/post/846547</link><guid isPermaLink="true">https://forum.iobroker.net/post/846547</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:43:12 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:40:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846540">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">armbian stretch</p>
</blockquote>
<p dir="auto">Uralt!</p>
<p dir="auto">ist das noch aus zeiten der All_In_One Images mit<br />
<blockquote>
<p dir="auto">piVCCU</p>
</blockquote>
<p dir="auto">???</p>
<p dir="auto">Das musst du mal komplett neu aufsetzen</p>
]]></description><link>https://forum.iobroker.net/post/846543</link><guid isPermaLink="true">https://forum.iobroker.net/post/846543</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:40:06 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:38:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a></p>
<p dir="auto">Stretch ist tot, installier eine lebendiges Release.</p>
]]></description><link>https://forum.iobroker.net/post/846542</link><guid isPermaLink="true">https://forum.iobroker.net/post/846542</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:37:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">OK. Habe jetzt verstanden.</p>
<pre><code>pi@TinkerboardS:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
pi@TinkerboardS:~$ uname -m &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; whoami &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
armv7l
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.16.0
v16.16.0
8.11.0
pi
/home/pi
Ign:1 http://httpredir.debian.org/debian stretch InRelease
OK:2 http://security.debian.org stretch/updates InRelease
OK:3 http://httpredir.debian.org/debian stretch-updates InRelease
OK:4 http://httpredir.debian.org/debian stretch-backports InRelease
OK:5 http://httpredir.debian.org/debian stretch Release
OK:7 https://deb.nodesource.com/node_16.x stretch InRelease
OK:6 http://mirrors.xtom.de/armbian stretch InRelease
OK:8 https://www.pivccu.de/piVCCU stable InRelease
Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
N: Datei »pivccu.list‘« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
nodejs:
  Installiert:           16.16.0-1nodesource1
  Installationskandidat: 16.17.0-1nodesource1
  Versionstabelle:
     16.17.0-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x stretch/main armhf Packages
 *** 16.16.0-1nodesource1 100
        100 /var/lib/dpkg/status
     8.11.1~dfsg-2~bpo9+1 100
        100 http://httpredir.debian.org/debian stretch-backports/main armhf Packages
     4.8.2~dfsg-1 500
        500 http://httpredir.debian.org/debian stretch/main armhf Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/846540</link><guid isPermaLink="true">https://forum.iobroker.net/post/846540</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:37:43 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:35:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a></p>
<p dir="auto">Vollständige Ein- und Ausgabezeilen zu</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs
</code></pre>
<p dir="auto">bitte.</p>
]]></description><link>https://forum.iobroker.net/post/846537</link><guid isPermaLink="true">https://forum.iobroker.net/post/846537</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:35:15 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:34:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846533">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Was meinst du damit? Bin leicht überfordert</p>
</blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-Braun">@<bdi>thomas-Braun</bdi></a> hat dir zwei Befehle in code-tags gepostet<br />
die sollst du ausführen und die Ein- und Ausgabe davon wiederum in code-tags posten</p>
]]></description><link>https://forum.iobroker.net/post/846536</link><guid isPermaLink="true">https://forum.iobroker.net/post/846536</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:34:55 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:34:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Ich würde Normal sagen, und stable.</p>
]]></description><link>https://forum.iobroker.net/post/846535</link><guid isPermaLink="true">https://forum.iobroker.net/post/846535</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:34:34 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846525">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Welche 3 Möglichkeiten gibt es denn?</p>
</blockquote>
<ul>
<li>"normal"</li>
<li>über npm</li>
<li>über Github</li>
</ul>
<p dir="auto">für "normal" kommt es außerdem noch auf das eingestellte Repo an: stable oder Beta</p>
]]></description><link>https://forum.iobroker.net/post/846534</link><guid isPermaLink="true">https://forum.iobroker.net/post/846534</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:33:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> said in <a href="/post/846521">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">und die Ein- und Ausgabe der geposteten Befehle?<br />
nix unterschlagen bitte</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/846533</link><guid isPermaLink="true">https://forum.iobroker.net/post/846533</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:33:51 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:31:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> said in <a href="/post/846517">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Alleine da gibt es drei Möglichkeiten</p>
</blockquote>
<p dir="auto">Da bin ich raus.<br />
War froh, dass das System bis dahin einwandfrei lief.<br />
]]></description><link>https://forum.iobroker.net/post/846525</link><guid isPermaLink="true">https://forum.iobroker.net/post/846525</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:31:12 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:30:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a></p>
<p dir="auto">Trag die mal aus.<br />
Und dann bitte die angefragten Dinge beibringen.</p>
]]></description><link>https://forum.iobroker.net/post/846524</link><guid isPermaLink="true">https://forum.iobroker.net/post/846524</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:30:29 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:30:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846516">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Habe "tail" und "dewpoint" als zusätzliche Module eingetragen.</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/846521</link><guid isPermaLink="true">https://forum.iobroker.net/post/846521</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:29:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846513">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Installiert über Adapter</p>
</blockquote>
<p dir="auto">Alleine da gibt es drei Möglichkeiten :-)</p>
<blockquote>
<p dir="auto">Seite dem Update von NODE und NPM habe ich nur Probleme</p>
</blockquote>
<p dir="auto">Vermutlich wegen des möglicherweise strengeren Verhaltens von  npm v8 bei bisher unbestraften Fehlern.</p>
<p dir="auto">Aber dazu gibt es schon genug Threads</p>
]]></description><link>https://forum.iobroker.net/post/846517</link><guid isPermaLink="true">https://forum.iobroker.net/post/846517</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:29:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/846516</link><guid isPermaLink="true">https://forum.iobroker.net/post/846516</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:26:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">JS-Script 5.7.0<br />
JS controller 4.0.23<br />
NPM 8.11.0<br />
Node 16.16.0</p>
]]></description><link>https://forum.iobroker.net/post/846513</link><guid isPermaLink="true">https://forum.iobroker.net/post/846513</guid><dc:creator><![CDATA[GregorS]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:26:57 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:18:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a></p>
<p dir="auto">Wie bist du denn da so grundsätzlich unterwegs:</p>
</code></pre>
<p dir="auto">Sind im javascript-Adapter zusätzliche Module eingetragen? Welche?</p>
]]></description><link>https://forum.iobroker.net/post/846498</link><guid isPermaLink="true">https://forum.iobroker.net/post/846498</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:18:52 GMT</pubDate></item><item><title><![CDATA[Reply to Javascript startet nicht mehr on Tue, 23 Aug 2022 13:09:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregors" aria-label="Profile: gregors">@<bdi>gregors</bdi></a> sagte in <a href="/post/846485">Javascript startet nicht mehr</a>:</p>
<blockquote>
<p dir="auto">code: 'MODULE_NOT_FOUND',</p>
</blockquote>
<p dir="auto">welche Version von js hast du?<br />
und wie installiert?</p>
<blockquote>
<p dir="auto">/opt/iobroker/node_modules/iobroker.javascript/node_modules/<span style="color:#ff0000"><strong>coffee-script</strong></span>/package.json</p>
</blockquote>
<p dir="auto">ist IMHO nicht mehr im js-Adapter enthalten.</p>
<p dir="auto"><a href="https://github.com/ioBroker/ioBroker.javascript#600-2022-07-18" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.javascript#600-2022-07-18</a></p>
<blockquote>
<p dir="auto">(bluefox) Removed support of coffeescript</p>
</blockquote>
<blockquote>
</blockquote>
<p dir="auto">war möglicherweise keine gute Idee</p>
]]></description><link>https://forum.iobroker.net/post/846490</link><guid isPermaLink="true">https://forum.iobroker.net/post/846490</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 23 Aug 2022 13:09:16 GMT</pubDate></item></channel></rss>
