  4. Problem mit Adapter-Updates
    5.8k
adapter aktualisieren
20 Beiträge 3 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • K kekz
    @glasfaser
    Danke für den Hinweis!
    andre@deb-iobroker:~$ iobroker fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://security.debian.org stretch/updates InRelease
    OK:2 http://security.debian.org/debian-security stretch/updates InRelease
    OK:3 http://ftp.de.debian.org/debian stable InRelease
    Ign:4 http://ftp.be.debian.org/debian stretch InRelease
    OK:5 http://ftp.be.debian.org/debian stretch Release
    OK:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Ign:8 http://ftp.au.debian.org/debian stretch InRelease
    OK:9 http://ftp.au.debian.org/debian stretch Release
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    andre@deb-iobroker:~$ iobroker upgrade hs100 --debug
    This upgrade of "hs100" will introduce the following changes:
    -> 2.1.2:
    js-sontroller 4.x ledstate
    Would you like to upgrade hs100 from @2.0.7 to @2.1.2 now? [(y)es, (n)o]: y
    Update hs100 from @2.0.7 to @2.1.2
    NPM version: 8.15.0
    Installing iobroker.hs100@2.1.2... (System call)
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://codeload.github.com/homeinstalator/mikronode-ng/tar.gz/v1.0.11
    npm ERR! 404
    npm ERR! 404  'mikronode-ng@https://github.com/homeinstalator/mikronode-ng/archive/v1.0.11.tar.gz' is not in this registry.
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-21T11_53_54_537Z-debug-0.log
    upload [5] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/admin.d.ts admin.d.ts video/mp2t
    upload [4] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
    upload [3] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
    upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index_m.html index_m.html text/html
    upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/style.css style.css text/css
    upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
    Ich habe mal dieses mikronode-ng nachinstalliert.
    andre@deb-iobroker:~$ npm install mikronode-ng
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN cleanup Failed to remove some directories [
    npm WARN cleanup   [
    npm WARN cleanup     '/home/andre/node_modules/.diskusage-NoLfal0G',
    npm WARN cleanup     [Error: EACCES: permission denied, unlink '/home/andre/node_modules/.diskusage-NoLfal0G/build/Makefile'] {
    npm WARN cleanup       errno: -13,
    npm WARN cleanup       code: 'EACCES',
    npm WARN cleanup       syscall: 'unlink',
    npm WARN cleanup       path: '/home/andre/node_modules/.diskusage-NoLfal0G/build/Makefile'
    npm WARN cleanup     }
    npm WARN cleanup   ],
    npm WARN cleanup   [
    npm WARN cleanup     '/home/andre/node_modules/.unix-dgram-NMvJvOpB',
    npm WARN cleanup     [Error: EACCES: permission denied, unlink '/home/andre/node_modules/.unix-dgram-NMvJvOpB/build/Makefile'] {
    npm WARN cleanup       path: '/home/andre/node_modules/.unix-dgram-NMvJvOpB/build/Makefile'
    npm WARN cleanup     }
    npm WARN cleanup   ]
    npm WARN cleanup ]
    added 21 packages, removed 66 packages, changed 192 packages, and audited 247 packages in 17s
    14 packages are looking for funding
      run `npm fund` for details
    4 vulnerabilities (3 moderate, 1 high)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    npm notice
    npm notice New minor version of npm available! 8.15.0 -> 8.18.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.18.0
    npm notice Run npm install -g npm@8.18.0 to update!
    npm notice
    Das, in Verbindung mit iobroker fix, brachte leider keine Veränderung
    -> 2.1.2:
    NPM version: 8.15.0
    npm ERR! code E404
    npm ERR! 404
    npm ERR! 404
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-21T11_59_48_295Z-debug-0.log
    GlasfaserG Offline
    GlasfaserG Offline
    @kekz sagte in Problem mit Adapter-Updates:
    Habe ich nicht geschrieben, das du das machen sollst !!!
    siehe oben !!!!
    Da kannst du unendlich was machen , denn
    npm ERR! code E404
    • GlasfaserG Glasfaser
      npm ERR! code E404
      Verweist auf eine falsche URL
      Wo hast du die 2.0.7 her laut Github finde ich nur 2.0.6 dann 2.1.0 !?
      kekz
      @glasfaser said in Problem mit Adapter-Updates:
      npm ERR! code E404
      Das wird sicher einmal über die Adapter-Updates installiert worden sein.
      Andere Quellen nutze ich nicht.
      • K kekz
        npm ERR! code E404
        GlasfaserG Offline
        GlasfaserG Offline
        @kekz
        so jetzt die eingaben die ich oben gepostet habe durchführen !!
        @glasfaser sagte in Problem mit Adapter-Updates:
        @kekz
        iobroker stop
        rm -rf  /opt/iobroker/package.json
        iobroker start
        iobroker upgrade hs100@2.1.2
          siehe oben !!!!
          npm ERR! code E404
          kekz
          siehe oben !!!!
          npm ERR! code E404
          Ist ja in Ordnung. Du brauchst nicht schreien.
          Ich habe den Hinweis in der Ausgabe als eine fehlende dependency interpretiert.
          Darüber hinaus kann ich auch selbst probieren, also immer schön ruhig bleiben.
          iobroker stop
          iobroker start
          andre@deb-iobroker:~$ iobroker upgrade hs100@2.1.2 --debug
          -> 2.1.2:
          NPM version: 8.15.0
          added 1 package, removed 4552 packages, and changed 15 packages in 8s
          1 package is looking for funding
          Update "system.adapter.hs100.0"
          Cannot upgrade: Cannot find module 'mime'
          Require stack:
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          andre@deb-iobroker:~$ iobroker start
          • K kekz
            siehe oben !!!!
            npm ERR! code E404
            iobroker stop
            iobroker start
            -> 2.1.2:
            NPM version: 8.15.0
            Require stack:
            GlasfaserG Offline
            GlasfaserG Offline
            Ich bin ruhig ...
            nur du möchstest hier Hilfe und machst etwas noch zwischendurch
            Kannst du ja gerne machen ich halte dich nicht auf ,
            aber wer schon mit root unterwegs ist ... ich weise darauf hin ..
            du änderst es ..
            dann machst du Befehle mit sudo vorraus ....
            Was soll ich noch dazu weiter sagen !?
              Ich bin ruhig ...
              du änderst es ..
              kekz
              Ich bin ruhig ...
              Kannst du ja geren machen ich halte dich nicht auf ,
              aber wer schon mit root unterwegs bist ... ich weise daruf hin ..
              du änderst es ..
              Du bist sicher vieles, aber ruhig nicht.
              Wenn mir jemand Postings im Befehlston entgegenknallt, versehen mit zahlreichen Ausrufezeichen, dann kann ich das nicht als "ruhig" empfinden.
              Mag sein, dass das dein normaler Umgangston ist. Meiner nicht.
              Deinen stark abwertenden Subtext mal ganz außen vor...
              Dennoch danke für deine Hilfe.
                kekz
                schrieb am zuletzt editiert von kekz
                andre@deb-iobroker:~$ iobroker stop
                [sudo] Passwort für andre:
                andre@deb-iobroker:~$ rm -rf  /opt/iobroker/package.json
                -> 2.1.2:
                NPM version: 8.15.0
                added 1 package, removed 4552 packages, and changed 15 packages in 10s
                Require stack:
                Das Update des Adapters läuft durch. Ich sehe kurz im iobroker Admin, dass Version 2.1.2 installiert ist.
                Danach crasht der iobroker Admin sofort.
                library: loaded
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                andre@deb-iobroker:~$ curl -sL https://iobroker.net/fix.sh | bash -
                library: loaded
                Letzteres kann ich mir nun nicht erklären
                • K kekz
                  @glasfaser
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  -> 2.1.2:
                  NPM version: 8.15.0
                  npm ERR! code E404
                  npm ERR! 404
                  npm ERR! 404
                  npm WARN cleanup   [
                  npm WARN cleanup     }
                  npm WARN cleanup   ],
                  npm WARN cleanup   [
                  npm WARN cleanup     }
                  npm WARN cleanup   ]
                  npm WARN cleanup ]
                  npm notice
                  npm notice
                  -> 2.1.2:
                  NPM version: 8.15.0
                  npm ERR! code E404
                  npm ERR! 404
                  npm ERR! 404
                  Im falschen Ordner. Darüber hinaus fährst du das längst tote Stretch, hast aber Quellen für Buster/Bullseye drin. Von root abgesehen. Da läuft so einiges falsch.
                    kekz
                    Schlägst Du eine Neuinstallation vor?
                    • K kekz
                      @kekz
                      Ich schlage vor erstmal dein System geradezurücken und ordentlich damit umzugehen.
                      Das tote Stretch-Pferd kannst du aber aufhören zu reiten. Installier ein Bullseye.
                        @kekz
                        kekz
                        @thomas-braun said in Problem mit Adapter-Updates:
                        @kekz
                        Aha.
                        Ok, gut. Mache ich :)
                        • K kekz
                          @kekz
                          Aha.
                          @kekz
                          Und lass den root in Ruhe im neuen System.
                            @kekz
                            kekz
                            Verstanden :)
                            Danke!
