  4. IO Broker auf 8081 nicht aufrufbar nach wiederherstellung
    5.5k
112 Beiträge 3 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @user4711
    Ja du mußt warten .... es müssen alle Adapter installiert werden , das macht er Admin selber !
    GEDULD !!
    U Offline
    U Offline
    user4711
    schrieb am zuletzt editiert von user4711
    @glasfaser ok hab log laufen lassen da wurde was installiert :
    2022-08-20 14:11:35.282  - warn: host.buanet-iobroker6 startInstance cannot find adapter "vis-material-advanced@1.7.0". Try to install it... 1 attempt
    2022-08-20 14:11:35.282  - info: host.buanet-iobroker6 iobroker url iobroker-community-adapters/ioBroker.vis-material-advanced#master vis-material-advanced using installedFrom
    2022-08-20 14:11:35.997  - info: host.buanet-iobroker6 iobroker npm-install: install iobroker-community-adapters/ioBroker.vis-material-advanced#master
    2022-08-20 14:11:36.445  - info: host.buanet-iobroker6 iobroker npm-install: NPM version: 8.15.0
    2022-08-20 14:11:36.446  - info: host.buanet-iobroker6 iobroker npm-install: Installing iobroker-community-adapters/ioBroker.vis-material-advanced#master... (System call)
    2022-08-20 14:11:46.288  - info: host.buanet-iobroker6 iobroker npm-install:
    2022-08-20 14:11:46.289  - info: host.buanet-iobroker6 iobroker npm-install: added 16 packages in 9s104 packages are looking for funding  run `npm fund` for details
    2022-08-20 14:11:46.325  - info: host.buanet-iobroker6 iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/ad
    min/vis-material-advanced.png vis-material-advanced.png image/png
    2022-08-20 14:11:46.356  - info: host.buanet-iobroker6 iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/ad
    min/words.js words.js application/javascript
    2022-08-20 14:11:46.361  - info: host.buanet-iobroker6 iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Noth
    ing was uploaded or deleted.
    2022-08-20 14:11:46.393  - info: host.buanet-iobroker6 iobroker npm-install: Update "system.adapter.vis-material-advanced.0"
    2022-08-20 14:11:48.414  - warn: host.buanet-iobroker6 startInstance cannot find adapter "vis-plumb@1.0.3". Try to install it... 1 attempt
    2022-08-20 14:11:48.414  - info: host.buanet-iobroker6 iobroker url ioBroker/ioBroker.vis-plumb#master vis-plumb using installedFrom
    2022-08-20 14:11:49.143  - info: host.buanet-iobroker6 iobroker npm-install: install ioBroker/ioBroker.vis-plumb#master
    2022-08-20 14:11:49.624  - info: host.buanet-iobroker6 iobroker npm-install: NPM version: 8.15.0
    2022-08-20 14:11:49.625  - info: host.buanet-iobroker6 iobroker npm-install: Installing ioBroker/ioBroker.vis-plumb#master... (System call)
    2022-08-20 14:11:55.317  - info: host.buanet-iobroker6 iobroker npm-install:
    2022-08-20 14:11:55.318  - info: host.buanet-iobroker6 iobroker npm-install: added 3 packages in 5s104 packages are looking for funding  run `npm fund` for details
    2022-08-20 14:11:55.348  - info: host.buanet-iobroker6 iobroker npm-install: upload [1] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/index.html index.htm
    l text/html
    2022-08-20 14:11:55.377  - info: host.buanet-iobroker6 iobroker npm-install: upload [0] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/plumb.png plumb.png
    image/png
    2022-08-20 14:11:55.381  - info: host.buanet-iobroker6 iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-plumb/www" was not found! Nothing was uplo
    aded or deleted.
    l text/html
    image/png
    aded or deleted.
    2022-08-20 14:11:56.422  - info: host.buanet-iobroker6 iobroker npm-install: exit 0
    bei aktive Instanzen steht aber immer noch nur Admin und backitup
    • U user4711
      l text/html
      image/png
      aded or deleted.
      l text/html
      image/png
      aded or deleted.
      GlasfaserG Offline
      GlasfaserG Offline
      #66
      @user4711
      Zeige mal ein Screenshot von den Instanzen
      U HomoranH 2 Antworten Letzte Antwort
        @user4711
        U Offline
        U Offline
        user4711
        #67
        @glasfaser
        • U user4711
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          #68
          @user4711
          Da stimmt was nicht ....
          das Backup wurde nicht installiert ... !
          da sollten alle Adapter-Instanzen kommen die du mal installiert hattest .
          Nimm BackitUp , kannst du dort ein Backup auswählen ,
          Bzw. lege dein Backup in den Ordner zuvor
          U 1 Antwort Letzte Antwort
            @user4711
            #69
            @glasfaser sagte in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
            @user4711
            @user4711 Warum muss man dich immer dazu auffordern?
            du hast doch inzwischen mitbekommen dass wir nicht sehen was du siehst.
              @user4711
              U Offline
              U Offline
              user4711
              #70
              @glasfaser sorry war einges ausgeblendet, und viele Instanzen nichgt gestartet
              JS läuft, VIS wird auch angezeigt aber verstümmlet fehlen fast alle Anzeigen
              • U user4711
                #71
                @user4711 du sollst während des Neubauens der Pakete nichts machen außer warten!
                U GlasfaserG 2 Antworten Letzte Antwort
                  U Offline
                  U Offline
                  user4711
                  #72
                  @homoran hab ja eigentlich nut im terminal die Log angeschaut, aber kann nochmal alles neu starten .
                  GlasfaserG HomoranH 2 Antworten Letzte Antwort
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #73
                    @homoran sagte in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
                    @user4711
                    GEDULD !!
                    • U user4711
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #74
                      @user4711
                      Deshalb von mir am Anfang ...
                      Also ganz ruhig .... wird schon alles wieder funktionieren .
                      • U user4711
                        #75
                        @user4711 sagte in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
                        das ist ok, aber wie sieht man da, dass
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #76
                          Weil er noch nicht fertig ist !!!
                            U Offline
                            U Offline
                            user4711
                            #77
                            @glasfaser ok ich war bischen zu schnell und ungeduldig sorry, neue install läuft, wer abrutscht darf nochmal 🙃
                              #78
                              @user4711
                              Die Adapter werden weitestgehend in alphabetischer Reihenfolge installiert.
                              Wenn die vis-Widgets noch nicht fertig sind können sie auch nicht angezeigt werden.
                              Aber jede Störung der Installation z.B. durch manuellen Eingriff, Neustart, Reboot o.ä. unterbricht diese Installation möglicherweise in einem undefinierten Zustand, was zu einer komplett unbrauchbaren Installation führen kann.
                                @user4711
                                U Offline
                                U Offline
                                user4711
                                #79
                                @homoran ok seit mehr als 10min passiert jetz nix mehr im log :
                                2022-08-20 15:04:25.491  - error: host.buanet-iobroker6 iobroker npm-install: host.buanet-iobroker6 Cannot install iobroker.vis@1.4.15: 6
                                2022-08-20 15:04:26.504  - info: host.buanet-iobroker6 iobroker npm-install: exit 25
                                2022-08-20 15:04:27.504  - warn: host.buanet-iobroker6 startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                                2022-08-20 15:04:27.505  - info: host.buanet-iobroker6 iobroker install vis@1.4.15 using installedVersion
                                2022-08-20 15:04:28.811  - info: host.buanet-iobroker6 iobroker npm-install: NPM version: 8.11.0
                                2022-08-20 15:04:28.812  - info: host.buanet-iobroker6 iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                                2022-08-20 15:04:32.183  - info: vis.0 (3209) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
                                2022-08-20 15:04:32.312  - info: vis.0 (3209) vis license is OK.
                                2022-08-20 15:04:32.514  - error: vis.0 (3209) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was n
                                ot handled with .catch().
                                2022-08-20 15:04:32.515  - error: vis.0 (3209) unhandled promise rejection: Not exists
                                2022-08-20 15:04:32.517  - error: vis.0 (3209) Error: Not exists
                                    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                    at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
                                    at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
                                    at processImmediate (node:internal/timers:468:21)
                                2022-08-20 15:04:32.517  - error: vis.0 (3209) Not exists
                                2022-08-20 15:04:33.020  - info: vis.0 (3209) terminating
                                2022-08-20 15:04:33.021  - warn: vis.0 (3209) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2022-08-20 15:04:33.688  - error: host.buanet-iobroker6 iobroker npm-install: host.buanet-iobroker6 Cannot install iobroker.vis@1.4.15: 6
                                2022-08-20 15:04:34.701  - info: host.buanet-iobroker6 iobroker npm-install: exit 25
                                2022-08-20 15:04:35.702  - error: host.buanet-iobroker6 Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                2022-08-20 15:09:38.695  - info: host.buanet-iobroker6 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2022-08-20 15:16:24.391  - info: host.buanet-iobroker6 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                • U user4711
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #80
                                  Dazu habe ich dir oben ... schon etwas geschrieben , was du machen sollst !
                                  • U user4711
                                    #81
                                    @user4711 und wie sieht es unter Instanzen aus?
                                    ggf. nach einem Reload
                                      U Offline
                                      U Offline
                                      user4711
                                      #82
                                      @glasfaser said in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
                                      hab ich gemacht und dann die ganzen instanzen gestartet, aber nach wie vor JS läuft VIS wieder verstümmelt .
                                      auch neu gestrartet.
                                      GlasfaserG HomoranH 3 Antworten Letzte Antwort
                                      • U user4711
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #83
                                        Zeigen ...
                                        kann damit nichts anfangen
                                        • U user4711
                                          #84
                                          hab ich gemacht
                                          wie immer: zeigen! 😡
