  4. Synology und IR-Lesekopf für Stromzähler
    6.7k
46 Beiträge 5 Kommentatoren 7.6k Aufrufe 5 Beobachtet
  • C Carsten6273
    @glasfaser
    Ich habe gerade noch einmal das Log von ioBroker angesehen. Da sehe ich zwei Fehler, habe aber keine Idee was es sein könnte..
    2022-08-14 14:09:10.338 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
    2022-08-14 14:09:10.344 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-08-14 14:09:10.345 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.16.0
    2022-08-14 14:09:10.346 - info: host.buanet-iobroker1 ip addresses: 192.168.1.250 2001:16b8:1765:3100:211:32ff:fe8b:988f fe80::211:32ff:fe8b:988f
    2022-08-14 14:09:10.724 - info: host.buanet-iobroker1 connected to Objects and States
    2022-08-14 14:09:10.748 - info: host.buanet-iobroker1 Node.js version has changed from unknown to 16.16.0
    2022-08-14 14:09:10.808 - info: host.buanet-iobroker1 added notifications configuration of host
    2022-08-14 14:09:11.051 - info: host.buanet-iobroker1 3 instances found
    2022-08-14 14:09:11.060 - info: host.buanet-iobroker1 starting 3 instances
    2022-08-14 14:09:11.112 - info: host.buanet-iobroker1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-08-14 14:09:11.152 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 1124
    2022-08-14 14:09:11.323 - info: host.buanet-iobroker1 Created UUID: 815f69c0-0883-443a-9893-4090acf8daf0
    2022-08-14 14:09:12.932 - info: admin.0 (1124) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 14:09:12.972 - info: admin.0 (1124) requesting all states
    2022-08-14 14:09:12.973 - info: admin.0 (1124) requesting all objects
    2022-08-14 14:09:13.042 - info: admin.0 (1124) received all objects
    2022-08-14 14:09:13.075 - info: admin.0 (1124) Request actual repository...
    2022-08-14 14:09:13.086 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-08-14 14:09:13.091 - info: admin.0 (1124) http server listening on port 8081
    2022-08-14 14:09:13.092 - info: admin.0 (1124) Use link "http://localhost:8081" to configure.
    2022-08-14 14:09:13.246 - warn: admin.0 (1124) Repository cannot be read: Active repo - stable
    2022-08-14 14:09:13.247 - warn: admin.0 (1124) Active repository "stable cannot be read
    2022-08-14 14:09:14.649 - info: admin.0 (1124) Repository received successfully.
    2022-08-14 14:09:15.120 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 1139
    2022-08-14 14:09:16.428 - info: discovery.0 (1139) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 14:09:19.125 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 1154
    2022-08-14 14:09:20.631 - info: backitup.0 (1154) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 14:09:20.689 - info: backitup.0 (1154) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-08-14 20:33:59.799 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-08-14 20:33:59.806 - info: admin.0 (1124) Got terminate signal TERMINATE_YOURSELF
    2022-08-14 20:33:59.810 - info: admin.0 (1124) terminating http server on port 8081
    2022-08-14 20:33:59.811 - info: admin.0 (1124) terminating
    2022-08-14 20:33:59.812 - info: admin.0 (1124) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-08-14 20:33:59.846 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
    2022-08-14 20:34:00.358 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-08-14 20:34:02.876 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 20347
    2022-08-14 20:34:04.363 - info: admin.0 (20347) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 20:34:04.401 - info: admin.0 (20347) requesting all states
    2022-08-14 20:34:04.402 - info: admin.0 (20347) requesting all objects
    2022-08-14 20:34:04.688 - info: admin.0 (20347) received all objects
    2022-08-14 20:34:05.030 - info: admin.0 (20347) Request actual repository...
    2022-08-14 20:34:05.040 - info: admin.0 (20347) http server listening on port 8081
    2022-08-14 20:34:05.041 - info: admin.0 (20347) Use link "http://localhost:8081" to configure.
    2022-08-14 20:34:05.180 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-08-14 20:34:05.446 - info: admin.0 (20347) failed connection to socket.io from ::ffff:192.168.1.66:
    2022-08-14 20:34:05.450 - error: admin.0 (20347) Error: "error"
    2022-08-14 20:34:06.824 - info: admin.0 (20347) Repository received successfully.
    2022-08-14 20:34:23.240 - info: discovery.0 (1139) Done discovering serial devices. 5 packages received
    2022-08-14 20:34:23.246 - info: discovery.0 (1139) Found 6 addresses
    2022-08-14 20:34:24.282 - warn: discovery.0 (1139) write: 10;VERSION;
    2022-08-14 20:34:24.284 - warn: discovery.0 (1139) Received: ����
    2022-08-14 20:34:24.343 - info: discovery.0 (1139) Discovery finished. Found new or modified 7 instances
    2022-08-14 20:34:24.398 - info: discovery.0 (1139) Discovery finished
    2022-08-14 20:35:04.096 - info: host.buanet-iobroker1 iobroker add smartmeter --host buanet-iobroker1
    2022-08-14 20:35:06.485 - info: host.buanet-iobroker1 iobroker NPM version: 8.11.0
    2022-08-14 20:35:06.486 - info: host.buanet-iobroker1 iobroker Installing iobroker.smartmeter@3.3.4... (System call)
    2022-08-14 20:35:12.858 - info: host.buanet-iobroker1 iobroker
    2022-08-14 20:35:12.859 - info: host.buanet-iobroker1 iobroker added 4 packages in 6s38 packages are looking for funding run `npm fund` for details
    2022-08-14 20:35:12.886 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 install adapter smartmeter
    2022-08-14 20:35:12.925 - info: host.buanet-iobroker1 iobroker upload [5] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
    2022-08-14 20:35:12.956 - info: host.buanet-iobroker1 iobroker upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
    2022-08-14 20:35:12.965 - info: host.buanet-iobroker1 iobroker upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
    2022-08-14 20:35:12.974 - info: host.buanet-iobroker1 iobroker upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
    2022-08-14 20:35:12.982 - info: host.buanet-iobroker1 iobroker upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
    2022-08-14 20:35:12.991 - info: host.buanet-iobroker1 iobroker upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
    2022-08-14 20:35:13.020 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter created/updated
    2022-08-14 20:35:13.047 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 create instance smartmeter
    2022-08-14 20:35:13.055 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.alive created
    2022-08-14 20:35:13.061 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.connected created
    2022-08-14 20:35:13.072 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.compactMode created
    2022-08-14 20:35:13.080 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.cpu created
    2022-08-14 20:35:13.086 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.cputime created
    2022-08-14 20:35:13.096 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memHeapUsed created
    2022-08-14 20:35:13.106 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memHeapTotal created
    2022-08-14 20:35:13.114 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memRss created
    2022-08-14 20:35:13.124 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.uptime created
    2022-08-14 20:35:13.130 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.inputCount created
    2022-08-14 20:35:13.136 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.outputCount created
    2022-08-14 20:35:13.142 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.eventLoopLag created
    2022-08-14 20:35:13.148 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.sigKill created
    2022-08-14 20:35:13.154 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.logLevel created
    2022-08-14 20:35:13.159 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object smartmeter.0.info created
    2022-08-14 20:35:13.164 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object smartmeter.0.info.connection created
    2022-08-14 20:35:13.168 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 Set default value of smartmeter.0.info.connection: false
    2022-08-14 20:35:13.180 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0 created
    2022-08-14 20:35:14.200 - info: host.buanet-iobroker1 iobroker exit 0
    2022-08-14 20:35:16.209 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 started with pid 20461
    2022-08-14 20:35:18.025 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:18.113 - info: smartmeter.0 (20461) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 20:35:18.138 - error: smartmeter.0 (20461) Serial port device is undefined, check your configuration!
    2022-08-14 20:35:19.120 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:20.354 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:21.408 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:22.494 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:23.573 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:24.701 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:25.777 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:26.826 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:27.919 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:28.993 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:30.043 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:31.098 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:32.200 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:33.254 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:34.305 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:35.368 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:36.449 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:35:37.575 - info: smartmeter.0 (20461) List of port: []
    2022-08-14 20:36:57.106 - info: host.buanet-iobroker1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-08-14 20:36:57.111 - info: smartmeter.0 (20461) Got terminate signal TERMINATE_YOURSELF
    2022-08-14 20:36:57.113 - info: smartmeter.0 (20461) terminating
    2022-08-14 20:36:57.114 - info: smartmeter.0 (20461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-08-14 20:36:57.150 - info: host.buanet-iobroker1 stopInstance system.adapter.smartmeter.0 send kill signal
    2022-08-14 20:36:57.647 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-08-14 20:37:00.173 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 started with pid 20569
    2022-08-14 20:37:01.881 - info: smartmeter.0 (20569) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-14 20:37:11.933 - info: smartmeter.0 (20569) Error: No or too long answer from Serial Device after last request.
    2022-08-14 20:37:11.934 - warn: smartmeter.0 (20569) No or too long answer from Serial Device after last request.
    GlasfaserG Offline
    GlasfaserG Offline
    @carsten6273 sagte in Synology und IR-Lesekopf für Stromzähler:
    • GlasfaserG Glasfaser
      @glasfaser
      deswegen
      @Carsten6273 immer zeigen und nicht erzählen
      C 1 Antwort Letzte Antwort
        @glasfaser
        deswegen
        Carsten6273
        So stelle ich es ein:
        klicke auf Speichern und Schliessen und beim nächsten Öffnen sehe ich wieder das
        • C Carsten6273
          GlasfaserG Offline
          GlasfaserG Offline
          du must etwas warte ( so bei mir ) bis es alles kommt .
          dauert ca. 15-30 Sekunden ,
          erst so ...
          ... Zeit x .. danach ist es alles ausgefüllt .
          nutzt du VPN !?
            erst so ...
            nutzt du VPN !?
            Carsten6273
            @glasfaser
            Du hast recht, ich war zu ungeduldig
            Das Log sieht aber nicht viel besser aus
            Und ansonsten kein VPN
            • C Carsten6273
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Nimm alle Einstellungen so wie ich ... nur das bei dir /dev/ttyACM0 rein kommt
              EDIT :
              So wie ganz oben schon gezeigt :
              C M 2 Antworten Letzte Antwort
                EDIT :
                Carsten6273
                @glasfaser
                Ich hätte jetzt
                bekomme dann aber wieder einen Fehler zur seriellen Schnittstelle
                • C Carsten6273
                  @glasfaser
                  Ich hätte jetzt
                  Carsten6273
                  @carsten6273
                  Wenn man es richtig macht, geht es jetzt auch
                  GlasfaserG C 2 Antworten Letzte Antwort
                  • C Carsten6273
                    @carsten6273
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @carsten6273
                    Nicht so hektisch sein ... dann klappt es auch !!!!
                    • C Carsten6273
                      @carsten6273
                      Carsten6273
                      @carsten6273
                      Ich teste gleich noch einmal weiter, aber in den Instanzen sehe ich den grünen Status.....
                      Was nutzt du zum Visualisieren der Daten?
                      • C Carsten6273
                        @carsten6273
                        GlasfaserG Offline
                        GlasfaserG Offline
                        sourceanalytix
                        Angregung ... Beispiel bei History_Wallbox
                        https://forum.iobroker.net/topic/40926/vorlage-view-visualisierung-emobility-vw-connect-audi
                          sourceanalytix
                          Carsten6273
                          @glasfaser
                          Danke, ich werfe mal Morgen einen Blick drauf. Deine Reaktionsgeschwindigkeit war super. Und die Lösung so einfach. Viele andere Webseiten zeigen aber andere Einstellungen....
                          • C Carsten6273
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Naja ... dazu sage ich mal nicht´s ....
                            Das ist der Haupt-Thread , wenn du nochmal was brauchen solltest :
                            https://forum.iobroker.net/topic/4685/adapter-smartmeter
                              Carsten6273
                              @glasfaser
                              Eine Frage ist bei mir heute noch aufgekommen:
                              Ich habe den Stromzähler jetzt mit der Pin entsperrt und dieser zeigt dann die weiteren Infos wie Momentverbrauch usw. an. Leider kommen diese Infos jetzt nicht im iobroker an. Ich sehe weiterhin nur die Gesamtzähler. Was muss ich denn jetzt noch verändern?
                              • C Carsten6273
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Nichts ... die Datenpunkte werden dazu selbstständig erzeugt .
                                Auch dauerhaft gespeichert ... codiert !
                                C GlasfaserG 2 Antworten Letzte Antwort
                                  Carsten6273
                                  @glasfaser
                                  Danke für deine schnellen Antworten. Leider vermisse ich in meinen Daten noch den Momentanverbrauch. Meine Ansicht sieht so aus
                                  Eigentlich müsste ich doch noch weitere Werte sehen können oder?
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @Carsten6273
                                    Jipp da fehlen die freigeschalteten Werte
                                    @glasfaser sagte in Synology und IR-Lesekopf für Stromzähler:
                                    Wenn es freigeschaltet ist , dann wären auch die Datenpunkte z.b. mit Komma Werte
                                    • C Carsten6273
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      hast du auch die Schnittstelle/weiteres Datenpaket danach im Menue freigeschaltet .
                                      EDIT :
                                      Beispiel :
                                      Thomas WT C 2 Antworten Letzte Antwort
                                        EDIT :
                                        Beispiel :
                                        Thomas WT Offline
                                        Thomas WT Offline
                                        Thomas W
                                        @glasfaser said in Synology und IR-Lesekopf für Stromzähler:
                                        EDIT :
                                        Beispiel :
                                        habe da mal eine Frage. Ich habe mir ein Hichi IR USB Lesekopf gekauft und diesen an meine Synology angeschlossen. An der Synology ist bereits ein Zigbee Stick angeschlossen und zwar unter /dev/ttyACM0
                                        In der Synology (Systeminfos) finde ich den Hichi USB Stick, in Linux jedoch nicht. Sollte dieser nicht unter /dev/ttyUSB... auftauchen?
                                        • Thomas WT Thomas W
                                          EDIT :
                                          Beispiel :
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @thomas-w sagte in Synology und IR-Lesekopf für Stromzähler:
                                          https://www.photovoltaikforum.com/thread/179903-ehz-kaifa-mb310-per-hichi-usb-nativ-in-synology-auslesen-ohne-docker/
                                          Thomas WT 1 Antwort Letzte Antwort
