  4. Smartmeter Fehler "Verbunden mit Gerät oder Dienst"
64 Beiträge 4 Kommentatoren 8.0k Aufrufe 2 Beobachtet
  • H haubada
    @thomas-braun said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
    Und ein Neustart des Adapters schaut wie im log aus?
    Das sieht so aus mit den Smartmeter Einstellungen vom letzten Bild:
    2022-08-07 19:26:16.212  - info: smartmeter.0 (12596) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-08-07 19:26:16.800  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-08-07 19:26:19.252  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 12612
    2022-08-07 19:26:23.300  - info: smartmeter.0 (12612) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-07 19:27:37.551  - info: admin.0 (1378) failed connection to socket.io from ::ffff:192.168.178.36:
    2022-08-07 19:27:37.570  - error: admin.0 (1378) Error: "error"
    2022-08-07 19:27:39.200  - info: admin.0 (1378) failed connection to socket.io from ::ffff:192.168.178.36:
    2022-08-07 19:27:39.211  - error: admin.0 (1378) Error: "error"
    2022-08-07 19:28:23.419  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:28:23.425  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
    2022-08-07 19:30:33.443  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:30:33.445  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
    2022-08-07 19:32:43.456  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:32:43.459  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
    2022-08-07 19:34:53.468  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:34:53.470  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
    2022-08-07 19:37:03.479  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:37:03.481  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
    2022-08-07 19:38:02.078  - info: smartmeter.0 (12612) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-07 19:38:24.305  - info: smartmeter.0 (12612) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    2022-08-07 19:38:29.875  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-08-07 19:38:29.891  - info: smartmeter.0 (12612) Got terminate signal TERMINATE_YOURSELF
    2022-08-07 19:38:29.896  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2022-08-07 19:38:29.897  - info: smartmeter.0 (12612) terminating
    2022-08-07 19:38:29.901  - info: smartmeter.0 (12612) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-08-07 19:38:30.500  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-08-07 19:38:32.986  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 12850
    2022-08-07 19:38:37.120  - info: smartmeter.0 (12850) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
    2022-08-07 19:40:37.239  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:40:37.243  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
    2022-08-07 19:42:47.260  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:42:47.264  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
    2022-08-07 19:44:57.279  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
    2022-08-07 19:44:57.281  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
    @haubada sagte in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
    /dev/ttyAMA0
    Stell mal auf das Gerät um. Nicht das der Kopf dort liegt.
    H 1 Antwort Letzte Antwort
      /dev/ttyAMA0
      haubada
      schrieb am zuletzt editiert von haubada
      /dev/ttyAMA0
      Ich habe das jetzt so eingestellt:
      Allerdings bleibt das gelbe Ausrufezeichen und die Fehlermeldung "Verbunden mit Gerät oder Dienst" rot
      Homoran meinte ja:
      da passen zeile 2 und 3 schonmal nicht zusammen
      wakeup und nur lesen
      --> Soll ich da was anderes einstellen, bin aus dem link auf die Schnelle auch nicht schlau geworden
      • H haubada
        /dev/ttyAMA0
        Homoran meinte ja:
        und warum bleibt das so?
        was sagt jetzt das log beim Neustart der Instanz?
        • H haubada
          /dev/ttyAMA0
          Homoran meinte ja:
          Homoran meinte ja:
          @homoran sagte in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
          EDIT: Thread bei elv zu Ende gelesen. müsste doch passen.
            haubada
            @homoran said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
            Das ist ja mein Problem seit Beginn des Threads!
            Ich bekommt den Adapter bzw. die Instanz nicht mehr auf grün.
            Das ist mein Log nach 2x Neustarten:
            2022-08-07 20:04:01.070  - info: host.raspberrypi Restart adapter system.adapter.smartmeter.0 because enabled
            2022-08-07 20:04:02.112  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 13814
            2022-08-07 20:04:03.961  - error: smartmeter.0 (13807) smartmeter.0 invalid process id scenario 13814 vs. own ID 13807. Stopping
            2022-08-07 20:04:03.970  - info: smartmeter.0 (13807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-08-07 20:04:04.552  - error: host.raspberrypi instance system.adapter.smartmeter.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
            2022-08-07 20:04:04.553  - info: host.raspberrypi Do not restart adapter system.adapter.smartmeter.0 because desired by instance
            2022-08-07 20:04:06.326  - info: smartmeter.0 (13814) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
            2022-08-07 20:04:37.047  - warn: smartmeter.0 (13814) Got terminate signal. Checking desired PID: 0 vs own PID 13814
            2022-08-07 20:04:37.068  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 13834
            2022-08-07 20:04:37.413  - info: smartmeter.0 (13814) terminating
            2022-08-07 20:04:37.418  - info: smartmeter.0 (13814) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-08-07 20:04:37.428  - warn: smartmeter.0 (13814) Got terminate signal. Checking desired PID: 13834 vs own PID 13814
            2022-08-07 20:04:38.013  - error: host.raspberrypi instance system.adapter.smartmeter.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
            2022-08-07 20:04:38.014  - info: host.raspberrypi Do not restart adapter system.adapter.smartmeter.0 because desired by instance
            2022-08-07 20:04:41.269  - info: smartmeter.0 (13834) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
            • H haubada
              nö, da steht jetzt ganz was anderes drin.
              läuft der zwei mal?
                läuft der zwei mal?
                haubada
                Das hätte ich als mein Problem geschrieben ganz oben:
                @haubada said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
                Leider geht aktuell mein Smartmeter Adapter nicht mehr in den grünen Betrieb und es kommt immer die Fehlermeldung bzw. bleibt rot "Verbunden mit Gerät oder Dienst". Bei den Protokollen kommt die Warnung: No or too long answer from Serial Devie after last request.
                äuft der zwei mal?
                Das weiß ich ehrlich gesagt auch nicht.
                Beim Adapter steht: Installierte Instanzen: 1
                Es gibt nur Smartmeter.0
                • H haubada
                  äuft der zwei mal?
                  nicht instanzen
                  invalid process
                  Entweder raspi neubstartrn oder die beiden genannten Prozesse killen jnd Instanz neustarten.
                  liest du das log eigentlich?
                  davon steht jetzt nichts drin
                    nicht instanzen
                    invalid process
                    haubada
                    Entschuldigung, dass hatte ich falsch verstanden.
                    Natürlich stand da im Log aktuell nichts drin.
                    Die Warnung bzw. Fehlermeldung kommt immer erst nach einiger Zeit.
                    Ich haben den PI jetzt neu gestartet und nun sieht das log so aus:
                    Jetzt taucht es wieder auf...
                    2022-08-07 21:16:24.396  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2022-08-07 21:16:24.427  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2022-08-07 21:16:24.440  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2022-08-07 21:16:24.764  - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 1378
                    2022-08-07 21:16:25.217  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGTERM
                    2022-08-07 21:16:25.219  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code null ()
                    2022-08-07 21:16:25.220  - info: host.raspberrypi All instances are stopped.
                    2022-08-07 21:16:25.467  - info: host.raspberrypi terminated
                    2022-08-07 21:18:22.692  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                    2022-08-07 21:18:22.714  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-08-07 21:18:22.717  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
                    2022-08-07 21:18:22.720  - info: host.raspberrypi ip addresses: 192.168.178.38 2003:d5:2f37:b900:1620:5c72:4ba3:3833 fe80::73c4:fe5f:4aed:5009 192.168.178.101 2003:d5:2f37:b900:1ffe:f3d9:48c6:5719 fe80::dad3:d610:3368:c745
                    2022-08-07 21:18:24.538  - info: host.raspberrypi connected to Objects and States
                    2022-08-07 21:18:24.622  - info: host.raspberrypi added notifications configuration of host
                    2022-08-07 21:18:25.931  - info: host.raspberrypi 4 instances found
                    2022-08-07 21:18:25.955  - info: host.raspberrypi starting 4 instances
                    2022-08-07 21:18:26.093  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1281
                    2022-08-07 21:18:30.027  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 1464
                    2022-08-07 21:18:31.209  - info: admin.0 (1281) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                    2022-08-07 21:18:31.333  - info: admin.0 (1281) requesting all states
                    2022-08-07 21:18:31.336  - info: admin.0 (1281) requesting all objects
                    2022-08-07 21:18:32.455  - info: admin.0 (1281) received all objects
                    2022-08-07 21:18:33.187  - info: admin.0 (1281) Request actual repository...
                    2022-08-07 21:18:33.304  - info: admin.0 (1281) http server listening on port 8081
                    2022-08-07 21:18:33.306  - info: admin.0 (1281) Use link "http://localhost:8081" to configure.
                    2022-08-07 21:18:34.029  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2022-08-07 21:18:34.164  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1612
                    2022-08-07 21:18:37.104  - info: admin.0 (1281) Repository received successfully.
                    2022-08-07 21:18:38.129  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1623
                    2022-08-07 21:18:38.457  - info: smartmeter.0 (1464) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                    2022-08-07 21:18:39.629  - info: discovery.0 (1612) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
                    2022-08-07 21:18:44.350  - info: backitup.0 (1623) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
                    2022-08-07 21:18:45.789  - info: backitup.0 (1623) [iobroker] backup was activated at 02:40 every 1 day(s)
                    2022-08-07 21:20:38.594  - info: smartmeter.0 (1464) Error: No or too long answer from Serial Device after last request.
                    2022-08-07 21:20:38.598  - warn: smartmeter.0 (1464) No or too long answer from Serial Device after last request.
                    2022-08-07 21:22:43.610  - info: smartmeter.0 (1464) Error: No or too long answer from Serial Device after last request.
                    2022-08-07 21:22:43.613  - warn: smartmeter.0 (1464) No or too long answer from Serial Device after last request.
                      Meintest Du so?
                      ja das meinte ich.
                      ob es hilft ist eine Andere Frage.
                      hast du den Thread bei elv in meinem Link gelesen?
                      ttyS0 ist wirklich korrekt?
                        haubada
                        Ich habe gelesen...
                        ...dass es sein kann, dass die Schnittstelle defekt ist.
                        ...dass die richtige Konfiguration D0 Modus D; 9600 Bd; 1_7D_1P_E_1S ist (oder auch andere?!?! SML; 9600 Bd; 1_8D_0P_N_1S)
                        ...dass der Phototranisistor getauscht wurde (aber es ist ein anderes Modell?)
                        ...dass jemande den Volkszähler TTL-IR-Lesekopf nachgebaut hat
                        ...dass man die Position des Lesekopfs veränder kann (hab ich gemacht)
                        Auf was möchtest Du hinaus?
                        Soll ich mir einen anderen Lesekopf besorgen?
                        Ich bin leider kein Profi, sonst würde ich ja hier nicht um Hilfe fragen.
                        Ich weiß nur, erst ging mein Lesekopf am Logarex und jetzt geht er nicht mehr und ich kann den Grund nicht herausfinden.
                        • H haubada
                          Ich habe gelesen...
                          dann hast du nicht gelesen.
                          Der Logarex scheint mit der Zeit immer schwächere Signale zu senden.
                          so dass selbst die Optimierung eines der beiden Möglichkeiten nicht mehr reicht, sondrrn beides durchgeführt werdrn muss, was irgendwann auch nicht mehr ausreichend ist.
                          Selbst ganz neu scheinen die Signale deutlich schwächer zu sein, als bei anderen Zählern. Was auch dein Foto eindrucksvoll zeigt.
                            haubada
                            Besten Dank für Deine Einschätzung.
                            Mir ist schon klar, dass der Logarex wahrscheinlich das Problem ist.
                            Leider habe ich aber keinen Einfluss auf meinen verbauten Stromzähler.
                            Mir fällt somit nur noch ein:
                            • anderes Lesegerät (Volkszähler, oder anderes Modell)
                            • evtl. Optimierung meiner Platine mit anderen Widerständen
                            • evtl. doch noch ein Problem mit der initialisierung der seriellen Schnittstelle ttyS0
                              (vorher ging es ja auch immer wieder und jetzt geht gar nichts mehr, ich habe auch schon sehr viel verändert zwischenzeitlich)
                            • Info:OFF am Logarex?!?
                            Aber zu Sicherheit möchte ich BITTE nocheinmal die richtige Konfiguration für mein Smartmeter wissen?
                            D0 Modus D; 9600 Bd; 1_7D_1P_E_1S oder
                            Welche Werte sollte ich bitte hier einstellen?
                            Allgemeine Einstellungen:
                            Datenabfrageintervall
                            Datenübertragung
                            Daten-Protokoll
                            Einstellungen Datenübertragung:
                            Serielles Gerät: Name
                            Serielles Gerät: Baudrate
                            Serielles Gerät: Data-Bits
                            Serielles Gerät: Stop-Bits
                            Serielles Gerät: Parität
                            Wartezeit auf serielle Antwort
                            HomoranH 3 Antworten Letzte Antwort
                            • H haubada
                              Datenübertragung
                              Daten-Protokoll
                              wo bist du da?
                              warst du früher da schon einmal?
                              • H haubada
                                Datenübertragung
                                Daten-Protokoll
                                den Thread bei elv wirklich gelesen?
                                Zitat:
                                Im Photovoltaikforum berichten einige Nutzer, dass ihr Versorger auf Anfrage bereit war den Logarex-Zähler mit defekter Schnittstelle zu ersetzen.
                                die sind alle weitestgehend identisch
                                wäre laut Thread bei elv wahrscheinlich nur eine vorübergehende Maßnahme, da anscheinend die Sende LED schnell altert.
                                Den Thread wirklich gelesen?
                                wenn du zwischendrin die Schnittstelle per Konsole blockierst durchaus noch möglich
                                dann bekommst du nur noch die Zähletstände in kWh
                                der Adapter regelt das üblicherweise alleine. Nur die korrekte Schnittstelle und das Protokoll eintragen
                                • H haubada
                                  Datenübertragung
                                  Daten-Protokoll
                                  @haubada ist es dieser?
                                  https://wiki.volkszaehler.org/hardware/channels/meters/power/logarex_lk13b?s[]=logarex
                                  Versuch es mal mit diesen Daten.
                                  hast du die Daten nicht von deinem Netzbetreiber bekommen?
                                  Der Link auf der Seite ist auch sehr empfehlenswert
                                  https://www.photovoltaikforum.com/thread/111153-vzlogger-liest-keine-daten-vom-logarex-zähler/
                                  Für dich jetzt direkt das Fazit
                                  Bei den Zähler sind die IR Dioden schrott die sind sehr schwach und bei geben nach kurzer Zeit den geißt auf !!!
                                    haubada
                                    Hallo nochmals,
                                    ich habe mittlerweile einen neuen Zähler (auch wieder Logarex, aber neueres Modell) bekommen.
                                    Jetzt funktioniert es mit folgenden Einstellungen:
                                    Danke an alle!!!
                                    • H haubada
                                      Hallo nochmals,
                                      Danke an alle!!!
                                      Super!
                                      Hoffentlich bleibt es so, weil es
                                      aber neueres Modell
