  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.8k
812 Beiträge 97 Kommentatoren 458.0k Aufrufe 83 Beobachtet
  • A andygla
    Sorry absoluter rookie.
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ sudo apt update
    Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Get:3 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Hit:5 https://phoscon.de/apt/deconz buster InRelease
    Hit:6 https://deb.nodesource.com/node_12.x buster InRelease
    E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
    N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
    Do you want to accept these changes and continue updating from this repository? [y/N] y
    Err:3 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8C8C34C524098CB6
    Reading package lists... Done
    W: GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8C8C34C524098CB6
    E: The repository 'https://packages.grafana.com/oss/deb stable InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    pi@raspberrypi:~ $ sudo apt-get  install -y nodejs
    #688
    @andygla
    Und dann regelmäßig das System auf Stand halten.
    Das ist offenbar noch nie gemacht worden, der suite change ist nämlich schon fast ein Jahr her. Seither ist apt also nicht mehr angepackt worden...
    Regelmäßig alle paar Wochen:
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
      @andygla
      sudo apt update
      sudo reboot
      andygla
      #689
      hat funktioniert. Vielen Dank!!!
        spacecowboy.21
        #690
        Ich bräuchte mal eure hilfe.
        Ich habe versucht Node.js zu auf die 16.x Version zu bekommen.
        Das update ist auch ohne Fehler durchgelaufen.
        Node sollte ja auch gleich sein. Ist es aber nicht.
        x86_64
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v16.16.0
        v14.18.2
        8.15.1
        root
        /opt/iobroker
        Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
        Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease
        Building dependency tree
        All packages are up to date.
        nodejs:
          Installed: 16.16.0-deb-1nodesource1
          Candidate: 16.16.0-deb-1nodesource1
          Version table:
         *** 16.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
             8.10.0~dfsg-2ubuntu0.4 500
                500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
             8.10.0~dfsg-2ubuntu0.2 500
                500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
             8.10.0~dfsg-2 500
                500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
        wie bekomme ich das wieder gerade?
        • S spacecowboy.21
          x86_64
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v16.16.0
          v14.18.2
          8.15.1
          root
          /opt/iobroker
          nodejs:
            Version table:
               8.10.0~dfsg-2 500
          #691
          @spacecowboy-21
          Wie und was hast du gemacht? Insbesondere als root im Zusammenhang mit node14...
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          Eigentlich IMMER das gleiche...
          NICHT als root rumhampeln, NICHT am Paketmanager vorbei irgendwas ins System donnern.
            @spacecowboy-21
            spacecowboy.21
            #692
            Ok da hast du recht. Ich habe das ganze in mit root durchgeführt.
            Habe nun das ganze ohne root gemacht. Stehe aber noch vor dem gleichem Problem.
            Was kann ich noch machen?
            • S spacecowboy.21
              #693
              @spacecowboy-21
              Was hast du denn jetzt gemacht? HowTo gelesen? Falsche Pfade gelöscht?
                @spacecowboy-21
                spacecowboy.21
                #694
                ja die falschen Pfade habe ich gelöscht.
                das habe ich auch gemacht. Nicht unter root!
                sudo rm -rf /usr/local/lib/node*
                sudo rm -rf /usr/local/include/node*
                sudo rm -rf /usr/local/bin/node*
                Habe dann die Anleitung Punkt für Punkt abgearbeitet.
                sudo apt install nodejs --reinstall
                Danach
                iobroker fix
                Und es läuft wieder!
                Danke!!
                • Thomas BraunT Online
                  #695
                  @spacecowboy-21
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  sagt? Du hast gesehen, dass du da auch die falsche Distribution drin hattest?
                  • apollon77A apollon77
                    MOD-EDIT: Diese Anleitung ist veraltet. Update und Fix der nodejs Installation ist mittlerweile in dem Befehl iob nodejs-update enthalten
                    in diesem Artikel möchte ich einen Überblick geben, wie inzwischen (meint anno 2021 mit einem js-controller 3.x bzw 4.x) Node.js Updates bei ioBroker ausgeführt werden sollten bzw können.
                    Was ist Node.js und warum muss man es updaten?
                    Node.js ist die Laufzeitumgebung der Programmiersprache JavaScript, in der ioBroker geschrieben ist. Ohne Node.js funktioniert ioBroker nicht. Node.js hast Du initial selbst installiert oder der ioBroker-Installer hat dies für dich getan.
                    Wie bei vielen Open-Source-Technologien üblich, entwickelt sich Node.js schnell weiter. Kleinere Updates, die die Stabilität und Sicherheit steigern oder gar neue Funktionen hinzufügen, erscheinen regelmäßig.
                    Node.js-Versionen mit gerader Hauptversionsnummer werden als LTS-Versionen (Long Term Support) bezeichnet und einige Jahre gepflegt (z.B. 12.x). Jedes Jahr kommt eine neue Version ins LTS - in diesem Jahr (2021) ist das Node.js 16, welche im April veröffentlicht wurde und ab Oktober 2021 eine LTS Version wird.
                    Im gleichem Zug erreichen frühere LTS-Versionen ihr Lebensende (EOL, End of Life). So hat Node.js 8 im April 2020 den EOL-Status erhalten und bekommt damit keine Updates mehr, Nodejs 10.x wird Ende April 2021 Ihr Lebensende erreichen. Es wird also keine Sicherheits-Updates mehr geben! Node.js 12.x wird im April 2022 eol geben.
                    Alle Node.js-Versionen mit ungeraden Versionsnummern sind Entwicklungsversionen und sollten nicht produktiv genutzt werden.
                    ioBroker nutzt viele Module und Erweiterungen aus der JavaScript Open-Source Szene, und dort kommt es regelmäßig vor, dass Versionen die EOL gehen zeitnah danach auch nicht weiter unterstützt werden. Das hat im ersten Schritt keine echte Auswirkung, aber mittelfristig wird es also Adapter, und später auch den js-controller geben, der EOL Versionen von Node.js nicht mehr unterstützt.
                    Node.js 10 wird mit dem js-controller 3.x voll unterstützt. Ab dem js-controller 4.0 (Februar 2022) ist Node.js 10.x nicht mehr untertsützt.
                    Auf welche Node.js Version updaten?
                    Aktuell empfiehlt ioBroker die Nutzung von Node.js 16.x.
                    Folgende Adapter haben momentan Probleme mit Node.js 14:
                    • jeelink
                    Folgende Adapter haben momentan Probleme mit Node.js 16:
                    • jeelink?
                    *Node.js 16.x wird auch vom js-controller 3.3 grundsätzlich unterstützt, aber nur mit npm 6! npm 7 bzw 8 sind mit dem js-controller 4.0 nutzbar.
                    Update vorbereiten
                    Node.js Version prüfen
                    Bevor man beginnt, sollte man in der Befehlszeile mit dem Befehl
                    node -v
                    überprüfen, welche Version von Node.js gerade installiert ist. Eine gute Idee ist es, diese Versionsangabe auch mit der Node.js-Version im Übersichts-Fenster des ioBroker-Admins für diesen Host zu vergleichen. Sollten sich die Versionen unterscheiden, sind mehrere Node.js-Varianten installiert, was zu Problemen führen kann. Diese Probleme müssen VOR dem Update dann behoben werden! Anleitung zB unter https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                    Betriebssystem prüfen
                    Dann auch prüfen was man für ein Betriebssystem hat. Vor allem im Raspi Umfeld sind gern auch älterer Systeme auf basis von "Debian jessie" oder "Debian wheezy" im Einsatz. Für die gibt es nichts was höher ist als Nodejs 10, da steht dann ggf auch ein Betriebssystemupdate an, was wir hier aber nicht behandeln können.
                    Unterstützte Linux Distributionen sind unter https://github.com/nodesource/distributions#debian-and-ubuntu-based-distributions aufgelistet.
                    Unter Debian und Ubuntu gibt es mit lsb_release -a eine Ausgabe was man aktuell nutzt.
                    js-controller Version prüfen
                    Weiterhin bitte prüfen welche js-controller Version Installiert ist (ebenfalls auf dem Host-Tab im Admin einsehbar).
                    Bei Versionen VOR js-controller 3.x, wenn möglich bitte zuerst den js-controller aktualisieren. Am besten auf mindestens die 3.2! Hierzu gibt es extra Threads im Forum wie z.B. https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable bzw https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
                    Adapter aktualisieren
                    Damit es nach dem Update zu keinen Inkompatibilitäten oder Probleme kommt, sollte man alle Adapter prüfen und aktualisieren. Vor allem Adapter mit nativen Bestandteilen, wie alles mit Serialport oder Bluetooth können Probleme bereiten. Hier am besten die Adapter-Readme's per Admin oder im GitHub prüfen, ob neue Versionen zur Verfügung stehen die die geplante Node.js Version explizit erst unterstützen.
                    Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                    Wenn man diesen Schritt nicht durchführt kann es zu unnötigen Problemen beim update der Adapter kommen!
                    Backup erstellen
                    Zuerst muss natürlich unbedingt ein Backup erstellt werden. Dazu kann z.B. der BackItUp-Adapter genutzt oder der Kommandozeilenbefehl
                    cd /opt/iobroker
                    iobroker backup
                    ausgeführt werden. Das Backup sollte aktuell sein, damit möglichst keine Daten verloren gehen.
                    Node.js updaten
                    Für Windows-Systeme kann ich leider gerade nichts genaues sagen, wir schauen das wir das noch ergänzen. Aufruf an die Community: Wer Schritte hat gern als eigener Post oder hier einbringen :-) Danke
                    Einen Post aus der Community gab es dazu: https://forum.iobroker.net/post/624003
                    Linux-Systeme
                    ioBroker stoppen
                    Zuerst ioBroker stoppen, damit Updates keine Nebeneffekte oder Abstürze verursachen.
                    iobroker stop
                    Bitte anschließend im Webbrowser prüfen, dass der ioBroker-Admin danach wirklich nicht mehr läuft. Sollte er weiterhin aufrufbar sein, dann den Rechner neu starten und nochmals „iobroker stop“ ausführen und erneut testen. Für die Techniker unter uns: Man kann auch mit einem Tool wie "top" prüfen, ob noch Prozesse existieren, die mit "io." beginnen. Die dann am besten mit einem beherzten "sudo kill -9 <ProzessID>" zwangsbeenden.
                    Node.js updaten
                    Jetzt aktualisiert man Node.js auf die gewünschte neue Version.
                    Unter Linux reicht es, dazu den Nodesource-Installationsbefehl für das jeweilige Betriebssystem auszuführen. Verschiedene Varianten (auch Root und Nicht-Root) sind unter https://github.com/nodesource/distributions#debinstall gelistet.
                    Zum Beispiel lauten die Befehle für einen Raspberry Pi der ein Debian bzw. Raspbian-Image verwendet wie folgt, wenn man nicht als root-User (z.B. richtig mit dem User "pi") angemeldet ist:
                    curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                    sudo apt install -y nodejs
                    Für Node.js 16 einfach in der URL oben anstelle der 14 eine 16 reinschreiben.
                    Für macOS gibt einen Installer auf https://nodejs.org/en/download/ , den man einfach ausführt.
                    Ob die Aktualisierung geklappt hat, kann man wieder mit dem Befehl
                    node -v
                    überprüfen.
                    Auch die npm Version sollte mit
                    npm -v
                    geprüft werden. Mit einem js-controller <4 sicherstellen das idealerweise keine 7.x/8.x von npm installiert ist!
                    ioBroker fixer ausführen
                    Da die Installation von Node.js einige Einstellungen am System verändert haben kann, ist es jetzt ratsam, den ioBroker-Installationsfixer aufzurufen. Das geschieht mit dem Befehl
                    iobroker fix
                    Er stellt unter anderem die für den Betrieb von ioBroker notwendigen Sicherheitseinstellungen wieder her und prüft und korrigiert alle Berechtigungen. Das kann einen Augenblick dauern, bitte Geduld haben.
                    Erster ioBroker Neustart NACH Update
                    Einige genutzte JavaScript Module haben binäre Teile, welche bei einem Node.js Update nicht mehr kompatibel sind und neu erstellt werden müssen.
                    Automatische Rebuilds
                    ioBroker versucht seit dem js-controller 3.0 automatisch die Adapter zu erkennen die nicht starten weil Sie aktualisiert werden müssen. Dies funktioniert so das die typischen Fehlermeldungen erkannt werden und ioBroker dann die Aktualisierung versucht.
                    js-controller 3.x
                    Zuerst wird ein "rebuild" des betroffenen Adapters ausgeführt, falls das nicht hilft werden die Adapter-Abhängigkeiten aktualisiert.
                    js-controller 4.0
                    Zuerst wird versucht alle Adapter zu rebuilden, falls das nicht hilft wird versucht zielgerichtet die relevanten Module neu zu bauen.
                    Daher kann es sein das der Adapter mehrfach ersucht wird neu zu starten. Hier bitte UNBEDINGT Geduld haben! Erst wenn der Adapter dauerhaft rot bleibt und auch im Log steht das der Rebuild nicht geklappt hat aktiv werden!
                    Bei einigen Adaptern (zB iot die optionale native Abhängigkeiten haben) funktioniert die automatische Erkennung nicht und das rebuild muss manuell angestoßen werden. Dies kann dadurch erkannt werden das der Adapter "Rot" bleibt und nicht startet oder einzelne Funktionen nicht gehen und das als Fehler im Log steht. Dann sollte das Log geprüft werden (neben Admin stehen Logfiles auch unter /opt/iobroker/log/... zur Verfügung.
                    Manuelle Rebuilds
                    Hier zu gibt es iobroker rebuild, bzw die Kommandos die im Log angezeigt werden falls der Automatische Rebuild nicht funktioniert.
                    Sonderfälle (z.B. Serialport)
                    Leider gibt es Sonderfälle, wo auch die obigen Optionen das Rebuild nicht erledigen, einer davon ist Serialport.
                    Dort kann ein Log zB (auch nach allen Rebuild Versuchen) wie folgt aussehen
                    host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: }
                    host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: ]
                    host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node'
                    host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/default/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Release/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Release/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Debug/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Debug/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Release/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Debug/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/serialport.node',
                    host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: tries: [
                    host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30) {
                    host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/auto-detect.js:16:22)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:93:9)
                    host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/default/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Release/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Release/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Debug/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Debug/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Release/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Debug/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/serialport.node
                    host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                    host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: ^
                    host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: throw err
                    host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:96
                    Es gibt auch andere Fehlermeldungen die aber alle auf das gleiche hinauslaufen.
                    Die einfachste Option ist es dann manuell im richtigen Verzeichnis neu zu bauen.
                    In dem Fall das Verzeichenis mit "bindings" suchen - oben ist das /opt/iobroker/node_modules/serialport/node_modules/bindings ... bei neueren Versionen kann es auch etwas wie /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings sein.
                    Dann in dieses Verzeichnis wechseln und npm install --production ausführen. Danach den Adapter nochmal sneu starten, das sollte dann tun.
                    Ein weiterer Fall sind Adapter mit canvas Modul (ggf echarts oder Mihome-vacuum) wo es Probleme gebe kann.
                    Andere Sonderfälle muss man sich im Detail ansehen. Bitte unten Posten und wir unterstützen.
                    Weitere Notfall Optionen
                    Im früheren Artikel unter https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten sind noch weitere manuelle Möglichkeiten beschrieben ioBroker wieder zum laufen zu bekommen, aber diese sollten an sich nicht mehr nötig sein, gehen aber natürlich auch noch!
                    Dieser Artikel gilt also auch weiterhin.
                    Jetzt viel Erfolg und gebt bitte Feedback wie git es geklappt hat oder welche Probleme Ihr habt.
                    Ingo
                    chucky666C Online
                    chucky666C Online
                    chucky666
                    #696
                    Hallo Zusammen,
                    mir wird das Update angezeigt , kann man das gefahrlos Updaten ? oder gibt es mit der Version probleme ?
                    Node.js
                    v16.15.1 (Es gibt eine neuere Version: v16.16.0)
                    • chucky666C chucky666
                      Hallo Zusammen,
                      Node.js
                      #697
                      @chucky666
                      Hau drauf.
                      Pedder007P 1 Antwort Letzte Antwort
                        @spacecowboy-21
                        spacecowboy.21
                        #698
                        sieht doch gut aus. Oder sehe ich das falsch.
                        stefan@ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.16.0
                        v16.16.0
                        8.11.0
                        stefan
                        /home/stefan
                        Hit:1 https://deb.nodesource.com/node_16.x focal InRelease
                        Hit:2 https://dl.yarnpkg.com/debian stable InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                        Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
                        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        nodejs:
                          Version table:
                                500 https://deb.nodesource.com/node_16.x focal/main amd64 Packages
                             10.19.0~dfsg-3ubuntu1 500
                                500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                        stefan@ioBroker:~$
                        • S spacecowboy.21
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.16.0
                          v16.16.0
                          8.11.0
                          stefan
                          /home/stefan
                          nodejs:
                            Version table:
                          stefan@ioBroker:~$
                          #699
                          @spacecowboy-21 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                          Hit:2 https://dl.yarnpkg.com/ debian stable InRelease
                          alles andere ist Ubuntu
                          • S spacecowboy.21
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.16.0
                            v16.16.0
                            8.11.0
                            stefan
                            /home/stefan
                            nodejs:
                              Version table:
                            stefan@ioBroker:~$
                            #700
                            Schmeiß das raus, yarnpgk braucht es im ioBroker-Umfeld nicht. Wir nutzen npm.
                              @chucky666
                              Hau drauf.
                              Pedder007P Offline
                              Pedder007P Offline
                              Pedder007
                              schrieb am zuletzt editiert von Pedder007
                              #701
                              @thomas-braun, @apollon77 was soll man sagen, auf den Slaves lief 16.06. nun völlig unauffällig seit gut 2 Wochen.
                              Gerade eben den Master umgestellt und (fast) alles lüppt weiter.
                              Lediglich BLE brauchte einen manuelle Re-Build, war aber danach auch direkt wieder da.
                              Danke wie immer für die super Vorbereitung, auch an alle die sonst noch beteiligt waren 👍 👍 👍
                              Achso, dass war der erste ioBroker Neustart ohne das wahllos irgendwelche ZigBee Aktoren (via ConBee Adapter) rumgeschaltet hätten.
                              Kann das mit dem neuen Node zusammenhängen? - eher nicht, oder?
                              Pedder
                              All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                              Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                              Under construction: Smart-WoMo auf Raspi4
                              • C Offline
                                Chrisdor
                                #702
                                Hallo zusammen, bräuchte eure Hilfe.
                                Habe heute mein Multihost System einem größeren Upgrade/Update unterzogen. Ubuntu 20.04Lts auf 22.04Lts und Node.js von 14.x auf 16.17.0 NPM auf 8.15.0
                                Upgrade/Update hat auch überall fehlerfrei funktioniert.
                                Leider startet der Adapter klf-200 nicht mehr.
                                Habe den automatischen rebuild abgewartet und ihn dann manuell gestartet, leider auch ohne Erfolg.
                                2022-08-20 20:09:06.883 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                                2022-08-20 20:09:06.884 - error: host.e-server Caught by controller[0]: throw err;
                                2022-08-20 20:09:06.885 - error: host.e-server Caught by controller[0]: ^
                                2022-08-20 20:09:06.885 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2022-08-20 20:09:06.886 - error: host.e-server Caught by controller[0]: Require stack:
                                2022-08-20 20:09:06.886 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                                2022-08-20 20:09:06.886 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                2022-08-20 20:09:06.887 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                2022-08-20 20:09:06.887 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                2022-08-20 20:09:06.892 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                2022-08-20 20:09:06.892 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                                2022-08-20 20:09:06.893 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                2022-08-20 20:09:06.893 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                2022-08-20 20:09:06.893 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                                2022-08-20 20:09:06.894 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                2022-08-20 20:09:06.895 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                2022-08-20 20:09:06.895 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2022-08-20 20:09:06.897 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                                2022-08-20 20:09:06.897 - error: host.e-server Caught by controller[0]: }
                                2022-08-20 20:09:06.898 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-08-20 20:09:06.898 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
                                2022-08-20 20:09:06.912 - info: host.e-server system.adapter.klf200.0 will be rebuilt
                                2022-08-20 20:09:06.914 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2022-08-20 20:09:06.915 - info: host.e-server iobroker rebuild
                                2022-08-20 20:09:10.236 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                                2022-08-20 20:10:21.756 - info: host.e-server iobroker npm-rebuild: rebuilt dependencies successfully
                                2022-08-20 20:10:21.800 - info: host.e-server iobroker npm-rebuild:
                                2022-08-20 20:10:21.802 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules done
                                2022-08-20 20:10:22.819 - info: host.e-server iobroker npm-rebuild: exit 0
                                2022-08-20 20:10:23.075 - info: host.e-server instance system.adapter.klf200.0 started with pid 12401
                                2022-08-20 20:10:24.597 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                                2022-08-20 20:10:24.597 - error: host.e-server Caught by controller[0]: throw err;
                                2022-08-20 20:10:24.598 - error: host.e-server Caught by controller[0]: ^
                                2022-08-20 20:10:24.598 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2022-08-20 20:10:24.598 - error: host.e-server Caught by controller[0]: Require stack:
                                2022-08-20 20:10:24.599 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                                2022-08-20 20:10:24.599 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                2022-08-20 20:10:24.600 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                2022-08-20 20:10:24.600 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                2022-08-20 20:10:24.600 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                2022-08-20 20:10:24.601 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                                2022-08-20 20:10:24.601 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                2022-08-20 20:10:24.601 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                2022-08-20 20:10:24.602 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                                2022-08-20 20:10:24.602 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                2022-08-20 20:10:24.602 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                2022-08-20 20:10:24.603 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2022-08-20 20:10:24.604 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                                2022-08-20 20:10:24.604 - error: host.e-server Caught by controller[0]: }
                                2022-08-20 20:10:24.605 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-08-20 20:10:24.605 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
                                2022-08-20 20:10:24.606 - info: host.e-server system.adapter.klf200.0 will be rebuilt
                                2022-08-20 20:10:24.606 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                2022-08-20 20:10:24.606 - info: host.e-server iobroker rebuild
                                2022-08-20 20:10:26.000 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                                2022-08-20 20:11:37.309 - info: host.e-server iobroker npm-rebuild: rebuilt dependencies successfully
                                2022-08-20 20:11:37.358 - info: host.e-server iobroker npm-rebuild:
                                2022-08-20 20:11:37.359 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules done
                                2022-08-20 20:11:38.376 - info: host.e-server iobroker npm-rebuild: exit 0
                                2022-08-20 20:11:38.645 - info: host.e-server instance system.adapter.klf200.0 started with pid 12774
                                2022-08-20 20:11:40.173 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                                2022-08-20 20:11:40.174 - error: host.e-server Caught by controller[0]: throw err;
                                2022-08-20 20:11:40.174 - error: host.e-server Caught by controller[0]: ^
                                2022-08-20 20:11:40.174 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2022-08-20 20:11:40.175 - error: host.e-server Caught by controller[0]: Require stack:
                                2022-08-20 20:11:40.175 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                                2022-08-20 20:11:40.176 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                2022-08-20 20:11:40.176 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                2022-08-20 20:11:40.176 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                2022-08-20 20:11:40.177 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                2022-08-20 20:11:40.177 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                                2022-08-20 20:11:40.177 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                2022-08-20 20:11:40.178 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                2022-08-20 20:11:40.178 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                                2022-08-20 20:11:40.178 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                2022-08-20 20:11:40.179 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                2022-08-20 20:11:40.179 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2022-08-20 20:11:40.180 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                                2022-08-20 20:11:40.180 - error: host.e-server Caught by controller[0]: }
                                2022-08-20 20:11:40.180 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-08-20 20:11:40.181 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
                                2022-08-20 20:11:40.181 - info: host.e-server system.adapter.klf200.0 will be rebuilt
                                2022-08-20 20:11:40.182 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                2022-08-20 20:11:40.182 - info: host.e-server iobroker rebuild
                                2022-08-20 20:11:41.489 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                                2022-08-20 20:12:54.635 - info: host.e-server iobroker npm-rebuild: rebuilt dependencies successfully
                                2022-08-20 20:12:54.681 - info: host.e-server iobroker npm-rebuild:
                                2022-08-20 20:12:54.683 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules done
                                2022-08-20 20:12:55.699 - info: host.e-server iobroker npm-rebuild: exit 0
                                2022-08-20 20:12:56.091 - info: host.e-server instance system.adapter.klf200.0 started with pid 13147
                                2022-08-20 20:12:57.608 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                                2022-08-20 20:12:57.608 - error: host.e-server Caught by controller[0]: throw err;
                                2022-08-20 20:12:57.609 - error: host.e-server Caught by controller[0]: ^
                                2022-08-20 20:12:57.609 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2022-08-20 20:12:57.610 - error: host.e-server Caught by controller[0]: Require stack:
                                2022-08-20 20:12:57.610 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                                2022-08-20 20:12:57.610 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                2022-08-20 20:12:57.611 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                2022-08-20 20:12:57.611 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                2022-08-20 20:12:57.611 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                2022-08-20 20:12:57.612 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                                2022-08-20 20:12:57.612 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                2022-08-20 20:12:57.612 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                2022-08-20 20:12:57.613 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                                2022-08-20 20:12:57.613 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                2022-08-20 20:12:57.613 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                2022-08-20 20:12:57.614 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2022-08-20 20:12:57.614 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                                2022-08-20 20:12:57.614 - error: host.e-server Caught by controller[0]: }
                                2022-08-20 20:12:57.615 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-08-20 20:12:57.615 - info: host.e-server Rebuild for adapter system.adapter.klf200.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                2022-08-20 20:13:05.729 - info: mihome-vacuum.0 (11949) create state for carpet_mode
                                • C Chrisdor
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #703
                                  @chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                  cd /opt/iobroker/node_modules/iobroker.klf200/
                                  npm install --omit=dev
                                  und wie ... !?
                                  C 1 Antwort Letzte Antwort
                                  • GlasfaserG Glasfaser
                                    und wie ... !?
                                    Chrisdor
                                    #704
                                    @glasfaser habe es nach der Anleitung ganz am Anfang gemacht.
                                    dein Vorschlag funktioniert leider auch nicht.
                                    npm ERR! code ERESOLVE
                                    npm ERR! ERESOLVE unable to resolve dependency tree
                                    npm ERR!
                                    npm ERR! While resolving: iobroker.klf200@1.0.1
                                    npm ERR! Found: eslint@7.32.0
                                    npm ERR! node_modules/eslint
                                    npm ERR!   dev eslint@"^7.1.0" from the root project
                                    npm ERR!
                                    npm ERR! Could not resolve dependency:
                                    npm ERR! peer eslint@"^5.0.0 || ^6.0.0" from @typescript-eslint/parser@2.34.0
                                    npm ERR! node_modules/@typescript-eslint/parser
                                    npm ERR!   dev @typescript-eslint/parser@"^2.34.0" from the root project
                                    npm ERR!   peer @typescript-eslint/parser@"^2.0.0" from @typescript-eslint/eslint-plugin@2.34.0
                                    npm ERR!   node_modules/@typescript-eslint/eslint-plugin
                                    npm ERR!     dev @typescript-eslint/eslint-plugin@"^2.34.0" from the root project
                                    npm ERR!
                                    npm ERR! Fix the upstream dependency conflict, or retry
                                    npm ERR! this command with --force, or --legacy-peer-deps
                                    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                                    npm ERR!
                                    npm ERR! See /home/iobroker/.npm/eresolve-report.txt for a full report.
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-20T21_02_24_597Z-debug-0.log
                                    • C Chrisdor
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #705
                                      @chrisdor
                                      Die komplette Ein/Ausgabe posten ... da fehlt der Anfang !
                                      • C Chrisdor
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #706
                                        ist seit NodeJS16 / NPM8
                                        nicht mehr
                                          @chrisdor
                                          Chrisdor
                                          #707
                                          @glasfaser meinst du das?
                                          e-server@e-server:/opt/iobroker/node_modules/iobroker.klf200$ npm install --omit=dev
                                          (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠋ idealTree:iobroker.klf200: sill idealTree buildDeps
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!
