  4. Problem mit laufenden Neustarts von ioBroker
    5.8k
13 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • T tomtaz
    @glasfaser said in Problem mit laufenden Neustarts von ioBroker:
    Ich denke mal , dann du bist du auch im Beta-Zweig unterwegs.
    Ja bin ich.
    Anbei die gewünschten Ausgaben:
    iobroker@iobroker:~$ cd /opt/iobroker
    iobroker@iobroker:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
    iobroker@iobroker:/opt/iobroker$ iobroker update -i
    Used repository: Beta (latest)
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "admin"        : 6.2.4    , installed 6.2.4
    Adapter    "alexa2"       : 3.18.6   , installed 3.18.6
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "divera247"    : 0.2.0    , installed 0.1.2  [Updatable]
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "ecovacs-deebot": 1.4.5   , installed 1.4.5
    Adapter    "hmip"         : 1.18.0   , installed 1.18.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 6.1.8    , installed 6.1.8
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "web"          : 5.2.4    , installed 5.2.4
    Adapter    "ws"           : 2.1.3    , installed 2.1.3
    iobroker@iobroker:/opt/iobroker$ iobroler list instances
    -bash: iobroler: Kommando nicht gefunden.
    iobroker@iobroker:/opt/iobroker$ iobroker list instances
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: tomtaz
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.divera247.0              : divera247             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.life360.0                : life360               : ioBroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    iobroker@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
    [sudo] Passwort für iobroker:
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    iobroker@iobroker:/opt/iobroker$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v12.22.12
    v16.16.0
    8.14.0
    iobroker
    /opt/iobroker
    iobroker@iobroker:/opt/iobroker$ ls -la /opt/iobroker/log
    insgesamt 252
    drwxrwxr-x+ 2 iobroker iobroker   4096 28. Jul 09:15 .
    drwxrwxr-x+ 8 iobroker iobroker   4096 19. Jul 14:07 ..
    -rw-rw-r--+ 1 iobroker iobroker  10719 23. Jul 00:00 iobroker.2022-07-22.log.gz
    -rw-rw-r--+ 1 iobroker iobroker  10339 24. Jul 00:00 iobroker.2022-07-23.log.gz
    -rw-rw-r--+ 1 iobroker iobroker  22889 25. Jul 00:00 iobroker.2022-07-24.log.gz
    -rw-rw-r--+ 1 iobroker iobroker  11568 26. Jul 00:00 iobroker.2022-07-25.log.gz
    -rw-rw-r--+ 1 iobroker iobroker  12151 27. Jul 00:00 iobroker.2022-07-26.log.gz
    -rw-rw-r--+ 1 iobroker iobroker  10506 28. Jul 00:00 iobroker.2022-07-27.log.gz
    -rw-rw-r--+ 1 iobroker iobroker 153044 28. Jul 09:15 iobroker.2022-07-28.log
    -rw-rwxr--+ 1 iobroker iobroker    377 28. Jul 00:00 iobroker-audit.json
    lrwxrwxrwx  1 iobroker iobroker     23 28. Jul 09:15 iobroker.current.log -> iobroker.2022-07-28.log
    @tomtaz
    nodeJS falsch installiert.
    Schau in meiner Signatur wie es richtig gemacht wird.
    • T tomtaz
      Ja bin ich.
      + instance is alive
      x86_64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v12.22.12
      v16.16.0
      8.14.0
      iobroker
      /opt/iobroker
      insgesamt 252
      GlasfaserG Offline
      GlasfaserG Offline
      @tomtaz sagte in Problem mit laufenden Neustarts von ioBroker:
      iobroker@iobroker
      und nicht den iobroker als User nehmen !
      • GlasfaserG Glasfaser
        iobroker@iobroker
        tomtaz
        Heist das, ich muss mein System wieder neu aufsetzen? Oder soll ich Node.js nur nicht als ioBroker installieren?
        • T tomtaz
          @tomtaz
          Nein, du sollst dir einen user anlegen, falls du keinen hast, den in die Gruppe 'iobroker' setzen und dann nach der Anleitung aus meiner Signatur nodeJS sauber installieren.
          Wie hast du denn jetzt nodeJS16 installiert?
          • W Online
            W Online
            Wildbill
            @tomtaz Deine Fragen lassen darauf schließen, dass Du in Linux alles andere als fit bist. Sicher, dass es dann bei Dir Sinn macht als Beta-Tester unterwegs zu sein? Ich würde Dir eher nahelegen, erst einmal ein System mit stable zu fahren um in Linux ein wenig sattelfest zu werden. Dann kannst Du sicher sein, dass eventuelle Probleme eher nicht mit iobroker, sondern mit einer Fehlbedienung bzw. falschem Umgang mit Linux zu tun hat.
            So wie jetzt scheinst Du ja nicht selbst unterscheiden zu können, ob Probleme eher von Seiten iobroker (weil eine Beta-Version eventuell Probleme macht), oder von Seiten Linux, weil da etwas falsch installiert/konfiguriert wurde zu tun haben. Das macht IMHO überhaupt keinen Sinn.
            Wenn Du einen oder mehrere Adapter aus Beta brauchst, weil im stable etwas fehlt, was Du gerne hättest, dann spricht überhaupt nichts dagegen DIESE(N) Adapter aus Beta zu ziehen. Aber das System selbst sollte auf stable laufen, wenn man da nicht ganz fit ist.
            Gruss, Jürgen
            • T tomtaz
              Ja bin ich.
              + instance is alive
              x86_64
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/local/bin/npm
              v12.22.12
              v16.16.0
              8.14.0
              iobroker
              /opt/iobroker
              insgesamt 252
              GlasfaserG Offline
              GlasfaserG Offline
              EDIT ...
                tomtaz
                Vielen Dank erst mal für die vielen Antworten.
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.16.0
                v16.16.0
                8.11.0
                tomtaz
                /home/tomtaz
                OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                OK:2 http://deb.debian.org/debian bullseye InRelease
                OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           16.16.0-deb-1nodesource1
                  Installationskandidat: 16.16.0-deb-1nodesource1
                  Versionstabelle:
                 *** 16.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                     12.22.12~dfsg-1~deb11u1 500
                        500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                tomtaz@iobroker:~$
                @wildbill said in Problem mit laufenden Neustarts von ioBroker:
                Naja, das letzte System das ich aufgesetzt habe, war ebenfalls beta - da gab es die Probleme nicht. Stimmt, ein Linux-Guru bin ich nicht, weiß aber wohl, welchen knopf ich wo drücken muss. Tatsächlich habe ich allerdings mit nodejs und npm usw. beruflich nicht viel zu tun. Von daher kann der Eindruck entstehen, dass ich gar keinen Plan von Linux habe.
                Btw.: Die neuste nodejs Version is die 18. Allerdings funktioniert damit der SQL-Adapter nicht.
                • T tomtaz
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.16.0
                  v16.16.0
                  8.11.0
                  tomtaz
                  /home/tomtaz
                  nodejs:
                    Versionstabelle:
                  tomtaz@iobroker:~$
                  Die V 18 ist auch noch nicht für ioBroker die empohlene Version. U. a. aus solchen Gründen.
                    tomtaz
                    @thomas-braun said in Problem mit laufenden Neustarts von ioBroker:
                    Hab ich mir gedacht und deshalb direkt die 16. installiert. Damit funzt alles wieder. Danke.
                      tomtaz
                      das Problem hat sich damit erledigt. Der Fehler ist nicht mehr aufgetreten. Vielen Dank für eure Hilfe.
