  4. HEX in RGB Umwandeln?
    5.8k
88 Beiträge 3 Kommentatoren 9.9k Aufrufe 3 Beobachtet
  • B Bacado
    @mickym nein es geht nur mit den 3 kompletten nodes
    mickymM Offline
    mickymM Offline
    mickym
    @bacado sagte in HEX in RGB Umwandeln?:
    Ok dann nimm mal diese 4 ist zwar eine Node mehr, ist aber besser:
            "id": "c2fb59500ac5b5fb",
            "type": "change",
            "z": "289f539dcc33814e",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$split(payload,',')\t",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 530,
            "y": 3140,
            "wires": [
                    "1a82d9ca08d4e9a3"
            "id": "1a82d9ca08d4e9a3",
            "type": "split",
            "name": "",
            "splt": "\\n",
            "spltType": "str",
            "arraySplt": 1,
            "arraySpltType": "len",
            "stream": false,
            "addname": "",
            "x": 710,
            "y": 3140,
            "wires": [
                    "32d39137ef37cfea"
            "id": "9e1bfb38feb75c41",
            "type": "join",
            "name": "",
            "mode": "auto",
            "build": "object",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": "false",
            "timeout": "",
            "count": "",
            "reduceRight": false,
            "x": 1070,
            "y": 3140,
            "wires": [
                    "3f77d23474222067"
            "id": "32d39137ef37cfea",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$number(payload)\t",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 890,
            "y": 3140,
            "wires": [
                    "9e1bfb38feb75c41"
    Ich schau mal ob ich das in einen Change Node packen kann - aber mit der JSONATA Syntax bin ich auch manchmal auf Kriegsfuss.
    Die erste Node macht das Array, die split Node splittet es in einzelne Nachrichten auf, damit man es mit der nächsten Node in Zahlen umwandelt, die JOIN Node setzt das Array wieder zusammen, wie es die split Node auseinander genommen hat. ;)
    • mickymM mickym
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 530,
              "y": 3140,
              "wires": [
                      "1a82d9ca08d4e9a3"
              "type": "split",
              "name": "",
              "splt": "\\n",
              "spltType": "str",
              "arraySplt": 1,
              "stream": false,
              "addname": "",
              "x": 710,
              "y": 3140,
              "wires": [
                      "32d39137ef37cfea"
              "type": "join",
              "name": "",
              "mode": "auto",
              "build": "object",
              "key": "topic",
              "joiner": "\\n",
              "timeout": "",
              "count": "",
              "x": 1070,
              "y": 3140,
              "wires": [
                      "3f77d23474222067"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 890,
              "y": 3140,
              "wires": [
                      "9e1bfb38feb75c41"
      mickymM Offline
      mickymM Offline
      mickym
      So ich habs geschafft: ;) - ich muss immer ausprobieren. Ganz verstehen tue ich die Syntax selbst nicht.
      Also hier diese Change Node alleine müsste nun ausreichen:
             "id": "bb22c4c3aa0dbaba",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "$split(payload,',').$number()",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 730,
             "y": 3260,
             "wires": [
                     "c9d0a193b390e021"
      Der Punkt dient als map Operator, sodass gleich eine Funktion anhängen kann. Also mit dem Code machst einfach aus einem String ein numerisches Array.
      Es ist einfach genial - aber manchmal auch für mich zu abstrakt. ;)
      Also mit dieser Change Node einfach die vorherigen 3 bzw. 4 Nodes ersetzen.
      • mickymM mickym
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 730,
               "y": 3260,
               "wires": [
                       "c9d0a193b390e021"
        Bacado
        @mickym ja das geht auch, aber wie du schon sagst die Farbübersetzung ist echt Grotte. Aber vorerst gehts nicht besser. Da muss sich mal einer hinsetzen und fürs HabPanel nen colorpicker schreiben der RGB raus gibt oder Hex. Ideal einer der alle 3 als Output hat.
        • B Bacado
          mickymM Offline
          mickymM Offline
          mickym
          @bacado Wie war denn die Übersetzung der API die ich gepostet habe`?
          Also die #ee1bfb aus 287,91,84. Kann auch noch was anderes probieren wenn Du willst. Also stimmt es überein.
          Wenn Du die API nutzen willst, dann musst nach dem Deploy bisschen warten bis sich die Bibliothek installiert hast.
          https://www.npmjs.com/package/hsl-to-hex. Du musst das aber nicht installieren, dass macht NodeRed selbst.
          Hier mal der Flow:
                 "id": "0c572419db8fa9ab",
                 "type": "function",
                 "z": "31f4359ae915c063",
                 "name": "HSL in HEX",
                 "func": "var hsl= hslToHex;\n\nmsg.payload = hsl(msg.payload[0], msg.payload[1], msg.payload[2]);\nreturn msg;",
                 "outputs": 1,
                 "noerr": 0,
                 "initialize": "",
                 "finalize": "",
                 "libs": [
                         "var": "hslToHex",
                         "module": "hsl-to-hex"
                 "x": 950,
                 "y": 200,
                 "wires": [
                         "591341360b9809a7"
                 "id": "591341360b9809a7",
                 "type": "debug",
                 "name": "",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "false",
                 "statusVal": "",
                 "statusType": "auto",
                 "x": 1130,
                 "y": 200,
                 "wires": []
                 "id": "a28c7b2204c7441c",
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "287,91,84",
                 "payloadType": "str",
                 "x": 560,
                 "y": 200,
                 "wires": [
                         "cc93714eb6589eeb"
                 "id": "cc93714eb6589eeb",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 750,
                 "y": 200,
                 "wires": [
                         "0c572419db8fa9ab"
          Kannst ja dann anstelle der inject Node die iobroker IN Node dran hängen.
          • mickymM mickym
            Hier mal der Flow:
                   "type": "function",
                   "outputs": 1,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [
                           "var": "hslToHex",
                   "x": 950,
                   "y": 200,
                   "wires": [
                           "591341360b9809a7"
                   "type": "debug",
                   "name": "",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1130,
                   "y": 200,
                   "wires": []
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 560,
                   "y": 200,
                   "wires": [
                           "cc93714eb6589eeb"
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 750,
                   "y": 200,
                   "wires": [
                           "0c572419db8fa9ab"
            Bacado
            @mickym https://www.npmjs.com/package/hsl-to-hex die hab ich aktuell drin und der gibt bei den werten 287,91,84 den rgb #EBB1FB wert aus. dein RGB #ee1bfb kommt schon ehr hin mit der farbe die leuchtet.
            mickymM B 3 Antworten Letzte Antwort
            • B Bacado
              mickymM Offline
              mickymM Offline
              mickym
              @bacado Hast DU keinen Dreher drin, dann wär es nämlich exakt dasselbe.
              • B Bacado
                Bacado
                #66
                @mickym die API hab ich scheinbar irgendwie übersehen. Ich mache kopie&Paste
                • B Bacado
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #67
                  @bacado Einfach den Flow importieren und bissi warten.
                  • B Bacado
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #68
                    Das ist identisch die gleich die ich gepostet habe. ;) - Also damit sollte mit dem Flow das Ergebnis in jedem Fall identisch sein. ;)
                    • mickymM mickym
                      Bacado
                      #69
                      Alle 3 Flows haben das selbe Ergebniss, aber der Colorpicker und das licht was wirklich an ist sind Welten!
                      • B Bacado
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #70
                        @bacado Na ja - dann ist das aber eher ein Hardwareproblem, wie ggf. die Farbwerte in der Hardware umgesetzt werden. ;) - Also vielleicht eher ein Hardware als Softwareproblem. Du kannst ja in den Datenpunkt direkte RGB Werte eingeben, die Du Dir von einem Internet RGB Picker nutzt. Der ColorPicker im NodeRed Dashboard gibt übrigens RGB Werte aus. Das kannst ja mal testen. ;)
                        Letztlich kann ich Dir aber dabei nicht helfen. Der Vorteil bei der HSL Notation - ist, dass man ja ggf. immer ein Offset zu Helligkeit und/oder Stättigung rechnen kann, um ggf Farben, die die Hardware nicht darstellen kann ausgleichen kann.
                        • mickymM mickym
                          Bacado
                          #71
                          @mickym bin schon an der nächsten Sache dran, das Thema Colorpicker vom HabPanel nervt mega aber das ist die schönste Vis von der Aufbauart im vergleich zu den anderen. Hab halt mega viele übersetzungen bei mir am laufen. Hab in meinem Haus KNX dazu Zigbee dann noch was auf der Homebridge alles über den IoBroker am laufen NodeRed dient jetzt auch als übersetzer alles Sachen mit denen ich mich schonmal grob vor ein paar Jahren beschäftigt habe und wusste, okay das geht. Aber das die Umsetzung so heftig wird, krass. Die KNX Programierung hat mich schon ne menge zeit und nerven gekostet nun das alles übern IoBroker das alles was nicht KNX ist, trozdem mit den Touchpanels gesteuert wird. Und jetzt die Visu die nochmal Übersetzungen braucht. hab mit 200h gerechnet die ich aber schon überschritten habe.
                          • B Bacado
                            Bacado
                            #72
                            @bacado jetzt muss ich schauen das ich den Color Picker auf HSV auf splitte. aber das ist für dich sicherlich ne kleinigkeit aus dem einen wert 3 werte auszugeben die ich wieder in iobroker schreiben kann?
                            • B Bacado
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #73
                              @bacado Das heisst Du willst das Array in 3 einzelne Datenpunkte schreiben?
                              • mickymM mickym
                                Bacado
                                schrieb am zuletzt editiert von Bacado
                                #74
                                @mickym ich muss schauen weil ich eigentlich ein RGB wert ins KNX schicken kann. Aber da muss ich schauen ob ich dort kollisionen bekomme weil ich auf einem anderen schon die HSV werte auf absolute setze. das kann sein das sich relativ und absoult nicht vertragen.
                                • B Bacado
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #75
                                  Meinst Du so?
                                  B 2 Antworten Letzte Antwort
                                  • mickymM mickym
                                    Meinst Du so?
                                    Bacado
                                    #76
                                    @mickym ja das müsste dann sein allerdings hat der Colorpicker ein Color Item und ein Brightness Item das verwirrt
                                    • B Bacado
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #77
                                      @bacado Nein das wird mit einberechnet - ist beim NR Color Picker auch so:
                                      Das heisst wenn ich die Brightness ändere - ändert sich der RGB Wert. Schwarz kann ein Lampe ja nicht darstellen^^ - das ist halt aus.
                                      Sobald die Helligkeit bei 100% ist - spielen alle anderen Werte keine Rolle ist immer weiß:
                                      ist die Hellligkeit 0 ist immer schwarz:
                                      • mickymM mickym
                                        Bacado
                                        #78
                                        das ist der Colorpicker und rechts in dem gelben Feld ist das was man dann sieht und drunter ist nochmal seperat ne Helligkeitseinstellung sind 2 verschiedene Datenpunkte im IoBroker.
                                        • B Bacado
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #79
                                          @bacado Für die Steuerung der Lampen sind das aber ggf. unterschiedliche Funktionen. Das heißt wenn Du rechts die Helligkeit auf 100% machst, dann ist das volle Leuchtstärke hat aber überhaupt nichts mit der Farbe zu tun.
                                          Ein Helligkeit von 100 auf die Farbe bezogen ist aber immer weiß.
                                          In meinen Augen sind das 2 verschiedene Stiefel. Das eine ist zum Dimmen durch Regelung der Leuchtstärke Strom und das andere ist Farbe mischen. ;)
