  4. Problem nach Update Admin adapter auf 6.2.6
    5.8k
59 Beiträge 4 Kommentatoren 5.8k Aufrufe 2 Beobachtet
  • F Flopsi
    @glasfaser sagte in Problem nach Update Admin adapter auf 6.2.6:
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.10
    v12.22.10
    6.14.16
    pi
    /opt/iobroker
    GlasfaserG Offline
    GlasfaserG Offline
    @flopsi
    ziehe mal auf 16 hoch... du bist ja schon lang nicht mehr aktuell
    und wo ist der Rest !?
    F 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @flopsi
      Flopsi
      @glasfaser welcher rest
      • F Flopsi
        GlasfaserG Offline
        GlasfaserG Offline
        @flopsi
          @flopsi
          Flopsi
          @glasfaser
          Adapter    "admin"        : 5.3.8    , installed 6.2.4
          Adapter    "alexa2"       : 3.11.2   , installed 3.18.6
          Adapter    "backitup"     : 2.4.9    , installed 2.4.10
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "firetv"       : 1.0.0    , installed 1.0.0
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "hue"          : 3.7.0    , installed 3.7.1
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.8   , installed 1.11.9
          Adapter    "jarvis"       : 3.0.11   , installed 3.0.13
          Adapter    "javascript"   : 5.7.0    , installed 6.0.0
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "kodi"         : 2.0.8    , installed 2.0.8
          Adapter    "linkeddevices": 1.4.3    , installed 1.5.5
          Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
          Adapter    "sayit"        : 1.12.3   , installed 1.12.6
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "socketio"     : 4.2.0    , installed 6.1.8
          Adapter    "sonos"        : 2.2.3    , installed 2.2.3
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "trashschedule": 2.0.2    , installed 1.4.5  [Updatable]
          Adapter    "web"          : 4.3.0    , installed 5.2.4
          Adapter    "windows-control": 0.1.5  , installed 0.1.5
          Adapter    "worx"         : 1.6.6    , installed 1.6.6
          Adapter    "ws"           : 1.3.0    , installed 2.1.3
          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
          Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
          Adapter    "zwave2"       : 2.5.0    , installed 2.6.0
          F GlasfaserG 2 Antworten Letzte Antwort
          • F Flopsi
            @glasfaser
            Flopsi
            @Glasfaser
            pi@raspberrypi4-iob:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            • F Offline
              Flopsi
              @glasfaser
              mehr kommt da nicht .....
              • F Flopsi
                @glasfaser
                @flopsi
                Komplett chaotisches Setup da.
                sudo apt update
                sagt?
                • F Flopsi
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @flopsi sagte in Problem nach Update Admin adapter auf 6.2.6:
                  Bitte immer die komplette Ein/ und Ausgabe posten !!!
                  Uns das ist jetzt mit dem Admin !??
                  • F Offline
                    Flopsi
                    @Glasfaser
                    pi@raspberrypi4-iob:/opt/iobroker $ sudo apt update
                    Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                    OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                    E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
                    N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
                    Möchten Sie diese Änderungen übernehmen und mit der Aktualisierung von diesem Depot fortfahren? [j/N] j
                    Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [391 kB]
                    E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
                    Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                    Holen:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58,8 kB]
                    Holen:7 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
                    Es wurden 13,6 MB in 24 s geholt (560 kB/s).
                    Aktualisierung für 193 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      Flopsi
                      @glasfaser
                      admin geht wieder
                      • F Flopsi
                        @glasfaser
                        admin geht wieder
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @flopsi
                        Komisch bist aktuell im BETA unterwegs ... aktuelle
                        ABER dein System hinkt hinterher . !!!!!!!!!
                        • F Flopsi
                          @Glasfaser
                          Ich glaube damit bist du bisher der Spitzenreiter...
                          iobroker stop
                          sudo apt full-upgrade
                          sudo reboot
                          • F Offline
                            Flopsi
                            @Glasfaser
                            Ja da hast du wohl recht bin Anfänger und habe mich da immer versucht selber rein zu denken wie man sieht mit nicht so gutem erfolg ......
                            Komme da auch so an meine Grenzen bin froh das alles läuft .....ich weis aber nicht wie man man alles sauber macht und aufräumt ohne das ich alles zerstöre ......
                            Was heist :
                            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                            • F Flopsi
                              @Glasfaser
                              Was heist :
                              Und warum tummelst du dich dann im Beta-Pool?
                              • F Flopsi
                                @Glasfaser
                                Was heist :
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Was heist :
                                Weil ... das die Empfohlene Version Nodejs 16 ist .
                                Das wir dir auch im Admin angezeigt
                                  iobroker stop
                                  sudo reboot
                                  Flopsi
                                  @thomas-braun sagte in Problem nach Update Admin adapter auf 6.2.6:
                                  mach ich dann jetzt mal .....
                                  • F Flopsi
                                    Zum ersten Mal offenbar...
                                      Was heist :
                                      Flopsi
                                      schrieb am zuletzt editiert von Flopsi
                                      @glasfaser
                                      das ist ne gute frage ich habe einfach immer alle updates gemacht die mir im Info angezeigt wurden ......
                                      • F Flopsi
                                        @glasfaser
                                        @flopsi
                                        Da werden aber keine Updates für dein Betriebssystem angezeigt.
                                        • F Flopsi
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @flopsi
                                          Dann hast du mal in der Zeit X , von Stable auf Beta den Verwahrungsort im Admin umgestellt
