  4. Node-Red
  5. Umwandlungsproblem
    6.5k
Umwandlungsproblem
20 Beiträge 2 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    @joeysch sagte in Umwandlungsproblem:
    N/dca632478bdc/battery/1/Voltages/Cell1
    Ohne meinen Subflow aber noch viel einfacher:
    6d803206-c67f-4cef-a541-1e236b48ac98-image.png N/dca632478bdc/battery/1/Voltages/Cell1
           "id": "8b693b78cb89f916",
           "type": "change",
           "z": "02dece3d313bbbd7",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.value",
                   "tot": "msg"
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": ".*\\/Voltages\\/(.*)$",
                   "fromt": "re",
                   "to": "0_userdata.0.Spannung.$1",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 530,
           "y": 180,
           "wires": [
                   "284fe10c7fd197e5"
           "id": "284fe10c7fd197e5",
           "type": "ioBroker out",
           "name": "",
           "topic": "",
           "ack": "true",
           "autoCreate": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "V",
           "stateMin": "",
           "stateMax": "",
           "x": 740,
           "y": 180,
           "wires": []
           "id": "b9fe83e880bb2fa2",
           "type": "mqtt in",
           "name": "",
           "topic": "N/dca632478bdc/battery/1/Voltages/+",
           "qos": "2",
           "datatype": "json",
           "broker": "",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 250,
           "y": 180,
           "wires": [
                   "8b693b78cb89f916"
    Sollte Dir unter 0_userdata.0.Spannung die Werte aller Zellen anlegen.
    Halt darauf achten, dass Du im NodeRed Adapter die Option
    angehakt hast.
    Wenn Du den NodeRed Adapter im iobroker nutzt. Sonst kannst das Topic aber auch über die mqtt-Out Node freilassen und die topics dynamisch erstellen lassen in dem Du in der Change Node das Topic erstellst - halt dann nicht mit 0_userdata.0.Spannung.Cell1 sondern, halt mit dem von Dir gewünschtne Topic Batterie1/Cell1 usw.
    • mickymM mickym
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "fromt": "re",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 530,
             "y": 180,
             "wires": [
                     "284fe10c7fd197e5"
             "name": "",
             "topic": "",
             "ack": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "V",
             "stateMin": "",
             "stateMax": "",
             "x": 740,
             "y": 180,
             "wires": []
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "datatype": "json",
             "broker": "",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 250,
             "y": 180,
             "wires": [
                     "8b693b78cb89f916"
      angehakt hast.
      joeysch
      @mickym
      Funktioniert super, werd mal ein bisschen probieren, da ich auch noch andere Daten brauche.
      Komme auch mit dem Node Red des IoBrokers problemlos auf den Raspi.
      • J joeysch
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @joeysch Na ja das Problem ist halt, solange ich nur immer Ausschnitte Deiner Anforderung kenne ist das halt immer nur bruchstückhafte Hilfe.
        Aber immerhin, ist Dein Bildschirm etwas weniger lila. ;)
        • J Offline
          joeysch
          @mickym
          Ich habe vor zwei Batterieblöcke à 16 Zellen zu verwenden. So wie ich das sehe sind im Venus OS aber nur die Daten des ersten Block's enthalten.
          Ich bekomme die Daten von diesem Tool [https://github.com/Louisvdw/dbus-serialbattery]
          Gibt es eine Möglichkeit die Daten der zweiten Batterie schon vorher abzufangen? Oder vielleicht über einen Zusatz im Pythonscript über MQTT zu pulizieren?
          • J joeysch
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @joeysch ich glaube, ich kann Dir nicht helfen. Ich habe mir mal kurz die Beschreibung angeschaut und ich glaube bzw. weiß nicht, wie die Batterie verbunden ist. Aber so wie ich es verstanden habe, läuft die Kommunikation über eine serielle Schnittstelle und die kann man nicht teilen. Solange das Tool von sich aus nicht mehrere Batterien unterstützt, sehe ich eher schwarz. Vielleicht machst mal ein Issue zu diesem Tool auf.
            • mickymM mickym
              joeysch
              @mickym
              Bei mir fällt jetzt dauernd die MQTT Verbindung aus. Wenn ich das im Venus deaktiviere und wieder aktiviere kommt kurz was und dann nicht mehr. Was kann das sein?
              • J joeysch
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @joeysch eventuell bug in der mqtt Node von Node-red. Das habe ich leider bei einer Instanz auch. Probiere mal Neustart des Node-Red Adapters.
                • mickymM mickym
                  joeysch
                  @mickym Nein, es sieht aus als würde Venus keine Daten mehr liefern. Es steht "Verbunden" aber es kommt nichts. Hab auch schon ein paar mal neu gestartet.
                  • J joeysch
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @joeysch Dann schreib doch mal was mit einer mqtt-out Node in den mqtt Broker bei Venus und hole es mit einer mqtt-In Node wieder ab. Dann weisst Du wenigstens, dass der mqtt Broker richtig arbeitet. Wenn aber nichts reinkommt dann liegt es an diesem Tool. Da kann ich Dir aber nicht helfen.
                    • mickymM mickym
                      joeysch
                      schrieb am zuletzt editiert von joeysch
                      @mickym
                      Ich hab was gefunden.
                      Das Venus liefert die MQTT Daten nicht freiwillig. Man muß folgende Zeile in die rc.local einfügen
                      while :; do mosquitto_pub -h IP_ADRESSE -m '' -t 'R/EIGENE_NR/system/0/Serial'; sleep 30; done
                      Dann klappts auch mit den Daten.
                      • J joeysch
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @joeysch Ah OK - dann ist das also doch ein mosquitto Broker mit den mosquitto Clients installiert und diese werden in einem Shellskript publiziert.
                        Wie gesagt, was das Tool liefert habe ich keine Ahnung, aber Du siehst ja mit dem -t und Topic wie publiziert wird.
                        Eine Beschreibung zu den mosquitto Clients findest Du im Übrigen auf den normalen mosquitto Seiten:
                        https://mosquitto.org/man/mosquitto_pub-1.html
                        Und mit diesem rc.local - wird quasi ein Shell skript ausgeführt, dass in einer Endlosschleife läuft. Das ist zwar nicht besonders elegant, aber immerhin, weißt Du wie es funktioniert.
