  4. Einige Adapter starten nicht mehr
31 Beiträge 5 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • K kalle-r
    hier mal das Log vom Starten des Shelly Adapters
    2022-07-24 20:13:27.171  - info: host.raspi4-iobroker "system.adapter.shelly.0" enabled
    2022-07-24 20:13:27.898  - info: host.raspi4-iobroker instance system.adapter.shelly.0 started with pid 31107
    2022-07-24 20:13:29.397  - error: host.raspi4-iobroker Caught by controller[0]: node:internal/modules/cjs/loader:361
    2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:       throw err;
    2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:       ^
    2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/process-nextick-args/index.js'. Please verify that the package.json has a valid "main" entry
    2022-07-24 20:13:29.398  - error: host.raspi4-iobroker Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:353:19)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:566:18)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:27)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-07-24 20:13:29.399  - error: host.raspi4-iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:26:11)
    2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1105:14)
    2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32) {
    2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2022-07-24 20:13:29.400  - error: host.raspi4-iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/process-nextick-args/package.json',
    2022-07-24 20:13:29.401  - error: host.raspi4-iobroker Caught by controller[0]:   requestPath: 'process-nextick-args'
    2022-07-24 20:13:29.401  - error: host.raspi4-iobroker Caught by controller[0]: }
    2022-07-24 20:13:29.401  - error: host.raspi4-iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-07-24 20:13:29.401  - info: host.raspi4-iobroker Rebuild for adapter system.adapter.shelly.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    GlasfaserG Offline
    GlasfaserG Offline
    @kalle-r
    Wie lange hast du gewartet mit dem Backup einspielen ,,, das sieht noch weiter so aus als hättest du nicht lang genug gewartet ... deshalb fehlt die hälfte
    HomoranH K 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      @kalle-r
      Da stimmt etwas nicht mit deiner Nodejs
      den ( alle ) Adapter sind am mekern .
      @Thomas-Braun
      Eine Neuinstallation ( Raspberry ) , dann Backup einspielen briegt es besser , denn er hat alles in BETA sich reingeschaufelt
      @glasfaser ich fürchte er hat sich mit npm 8.15 alles zerschossen.
      ichbweiß gar nicht ob @kalle-r wieder mit node/npm sauber unterwegs ist
      mein Holzhammer wäre dann
      package-lock.json löschen
      npm cache clean --force
      update und ggf rebuild
      GlasfaserG K 2 Antworten Letzte Antwort
        @kalle-r
        @glasfaser sagte in Einige Adapter starten nicht mehr:
        doch, aber
        @kalle-r sagte in Einige Adapter starten nicht mehr:
        Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries.
          GlasfaserG Offline
          GlasfaserG Offline
          Er hat aber leider den Beta Status , auch noch dazu .
          Eher einen Neuanfang würde ich sagen ...
            @kalle-r
            kalle-r
            @glasfaser
            gute Frage.... das hat eine ganze Weile gedauert....
            soll ich das einfach nochmal starten?
            Ich hab von jedem Tag ein Backup, ich kann z.B. ja auch mal eins von vor dem Urlaub einspielen
            als definitiv alles noch lief...
            • K kalle-r
              @glasfaser
              nutzt ichts wenn das Fundament morsch ist
                kalle-r
                @homoran said in Einige Adapter starten nicht mehr:
                ok, dh. ich such die Datei package-lock.json und lösch die?
                npm cache clean --force => ist klar
                update und ggf rebuild => was genau muss ich da tun?
                HomoranH GlasfaserG 2 Antworten Letzte Antwort
                • K kalle-r
                  @kalle-r das ging als Frage an @Glasfaser
                  • K kalle-r
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @kalle-r
                    Den Pi neu aufsetzen mit
                    NODE.JS: V16.16.0
                    NPM: 8.11.0
                    dann ioBroker drauf ... dann Backup einspielen und WARTEN
                      @kalle-r
                      NODE.JS: V16.16.0
                      NPM: 8.11.0
                      kalle-r
                      @glasfaser
                      ok dann versuch ich das mal...
                      Vielen Dank jedenfalls schonmal für Eure Hilfe!
                        @kalle-r
                        NODE.JS: V16.16.0
                        NPM: 8.11.0
                        kalle-r
                        @glasfaser
                        So weit hat das geklappt, das einzige was noch klemmt ist der VIS Adapter:
                        host.raspberrypi
                        	2022-07-24 23:47:04.521	error	Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                        host.raspberrypi
                        	2022-07-24 23:47:03.520	info	iobroker npm-install: exit 25
                        host.raspberrypi
                        	2022-07-24 23:47:02.483	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                        vis.0
                        	2022-07-24 23:47:01.718	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        vis.0
                        	2022-07-24 23:47:01.716	info	terminating
                        vis.0
                        	2022-07-24 23:47:01.206	error	Not exists
                        vis.0
                        	2022-07-24 23:47:01.205	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
                        vis.0
                        	2022-07-24 23:47:01.202	error	unhandled promise rejection: Not exists
                        vis.0
                        	2022-07-24 23:47:01.201	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        vis.0
                        	2022-07-24 23:47:00.975	info	vis license is OK.
                        vis.0
                        	2022-07-24 23:47:00.752	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
                        host.raspberrypi
                        	2022-07-24 23:46:49.987	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                        host.raspberrypi
                        	2022-07-24 23:46:49.985	info	iobroker npm-install: NPM version: 8.11.0
                        host.raspberrypi
                        	2022-07-24 23:46:45.779	info	iobroker install vis@1.4.15 using installedVersion
                        host.raspberrypi
                        	2022-07-24 23:46:45.778	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                        host.raspberrypi
                        	2022-07-24 23:46:44.777	info	iobroker npm-install: exit 25
                        host.raspberrypi
                        	2022-07-24 23:46:43.733	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                        vis.0
                        	2022-07-24 23:46:42.894	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        vis.0
                        	2022-07-24 23:46:42.892	info	terminating
                        vis.0
                        	2022-07-24 23:46:42.384	error	Not exists
                        vis.0
                        	2022-07-24 23:46:42.382	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
                        vis.0
                        	2022-07-24 23:46:42.380	error	unhandled promise rejection: Not exists
                        vis.0
                        	2022-07-24 23:46:42.379	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        vis.0
                        	2022-07-24 23:46:42.102	info	vis license is OK.
                        vis.0
                        	2022-07-24 23:46:41.867	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
                        host.raspberrypi
                        	2022-07-24 23:46:31.142	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                        host.raspberrypi
                        	2022-07-24 23:46:31.140	info	iobroker npm-install: NPM version: 8.11.0
                        host.raspberrypi
                        	2022-07-24 23:46:26.924	info	iobroker install vis@1.4.15 using installedVersion
                        host.raspberrypi
                        	2022-07-24 23:46:26.923	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
                        host.raspberrypi
                        	2022-07-24 23:46:25.914	info	iobroker npm-install: exit 25
                        host.raspberrypi
                        	2022-07-24 23:46:24.829	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                        vis.0
                        	2022-07-24 23:46:23.990	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        vis.0
                        	2022-07-24 23:46:23.988	info	terminating
                        vis.0
                        	2022-07-24 23:46:23.481	error	Not exists
                        vis.0
                        	2022-07-24 23:46:23.480	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
                        vis.0
                        	2022-07-24 23:46:23.477	error	unhandled promise rejection: Not exists
                        vis.0
                        	2022-07-24 23:46:23.476	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        vis.0
                        	2022-07-24 23:46:23.254	info	vis license is OK.
                        vis.0
                        	2022-07-24 23:46:23.009	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
                        host.raspberrypi
                        	2022-07-24 23:46:12.323	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                        host.raspberrypi
                        	2022-07-24 23:46:12.322	info	iobroker npm-install: NPM version: 8.11.0
                        host.raspberrypi
                        	2022-07-24 23:46:08.095	info	iobroker install vis@1.4.15 using installedFrom
                        host.raspberrypi
                        	2022-07-24 23:46:08.094	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
                        host.raspberrypi
                        	2022-07-24 23:46:07.094	info	iobroker npm-install: exit 25
                        host.raspberrypi
                        	2022-07-24 23:46:06.068	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                        vis.0
                        	2022-07-24 23:46:05.202	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        vis.0
                        	2022-07-24 23:46:05.200	info	terminating
                        vis.0
                        	2022-07-24 23:46:04.693	error	Not exists
                        vis.0
                        	2022-07-24 23:46:04.692	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
                        vis.0
                        	2022-07-24 23:46:04.689	error	unhandled promise rejection: Not exists
                        vis.0
                        	2022-07-24 23:46:04.688	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        vis.0
                        	2022-07-24 23:46:04.467	info	vis license is OK.
                        vis.0
                        	2022-07-24 23:46:04.212	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
                        host.raspberrypi
                        	2022-07-24 23:45:52.730	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                        host.raspberrypi
                        	2022-07-24 23:45:52.728	info	iobroker npm-install: NPM version: 8.11.0
                        host.raspberrypi
                        	2022-07-24 23:45:48.355	info	iobroker install vis@1.4.15 using installedFrom
                        host.raspberrypi
                        	2022-07-24 23:45:48.354	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
                        host.raspberrypi
                        	2022-07-24 23:45:48.008	info	"system.adapter.vis.0" enabled
                        Gibt's dazu vielleicht noch einen Lösungansatz?
                        • K kalle-r
                          @glasfaser
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          vis.0
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Ja ,erstmal Vis 1.4.0 installieren , dann auf 1.4.15
                          https://forum.iobroker.net/topic/55574/vis-1-14-5-lässt-sich-nicht-installieren
                          • H Offline
                            Helikiller
                            Ich habe das gleiche Problem!
                            Statusinformationen werden eingelesen....
                            Aktualisierung für 93 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            Was kann man jetzt noch machen? Gibt einen Befehl für diese Pakete?
                            /opt/iobroker/log$ apt list --upgradable
                            WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                            Auflistung...
                            base-files/oldstable 10.3+rpi1+deb10u12 armhf [aktualisierbar von: 10.3+rpi1+deb10u10]
                            bind9-host/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            cifs-utils/oldstable 2:6.8-2+deb10u1 armhf [aktualisierbar von: 2:6.8-2]
                            curl/oldstable 7.64.0-4+deb10u3 armhf [aktualisierbar von: 7.64.0-4+deb10u2]
                            debconf-i18n/oldstable 1.5.71+deb10u1 all [aktualisierbar von: 1.5.71]
                            debconf-utils/oldstable 1.5.71+deb10u1 all [aktualisierbar von: 1.5.71]
                            debconf/oldstable 1.5.71+deb10u1 all [aktualisierbar von: 1.5.71]
                            distro-info-data/oldstable 0.41+deb10u5 all [aktualisierbar von: 0.41+deb10u3]
                            dpkg-dev/oldstable 1.19.8 all [aktualisierbar von: 1.19.7]
                            dpkg/oldstable 1.19.8 armhf [aktualisierbar von: 1.19.7]
                            firmware-atheros/oldstable 1:20190114-2+rpt4 all [aktualisierbar von: 1:20190114-2+rpt1]
                            firmware-brcm80211/oldstable 1:20190114-2+rpt4 all [aktualisierbar von: 1:20190114-2+rpt1]
                            firmware-libertas/oldstable 1:20190114-2+rpt4 all [aktualisierbar von: 1:20190114-2+rpt1]
                            firmware-misc-nonfree/oldstable 1:20190114-2+rpt4 all [aktualisierbar von: 1:20190114-2+rpt1]
                            firmware-realtek/oldstable 1:20190114-2+rpt4 all [aktualisierbar von: 1:20190114-2+rpt1]
                            gzip/oldstable 1.9-3+deb10u1 armhf [aktualisierbar von: 1.9-3]
                            icu-devtools/oldstable 63.1-6+deb10u3 armhf [aktualisierbar von: 63.1-6+deb10u1]
                            libasound2-data/oldstable 1.1.8-1+rpt2 all [aktualisierbar von: 1.1.8-1+rpt1]
                            libasound2/oldstable 1.1.8-1+rpt2 armhf [aktualisierbar von: 1.1.8-1+rpt1]
                            libbind9-161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libc-bin/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libc-dev-bin/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libc-l10n/oldstable 2.28-10+rpt2+rpi1+deb10u1 all [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libc6-dbg/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libc6-dev/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libc6/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            libcairo-gobject2/oldstable 1.16.0-4+rpt1+deb10u1 armhf [aktualisierbar von: 1.16.0-4+rpt1]
                            libcairo-script-interpreter2/oldstable 1.16.0-4+rpt1+deb10u1 armhf [aktualisierbar von: 1.16.0-4+rpt1]
                            libcairo2-dev/oldstable 1.16.0-4+rpt1+deb10u1 armhf [aktualisierbar von: 1.16.0-4+rpt1]
                            libcairo2/oldstable 1.16.0-4+rpt1+deb10u1 armhf [aktualisierbar von: 1.16.0-4+rpt1]
                            libcurl3-gnutls/oldstable 7.64.0-4+deb10u3 armhf [aktualisierbar von: 7.64.0-4+deb10u2]
                            libcurl4/oldstable 7.64.0-4+deb10u3 armhf [aktualisierbar von: 7.64.0-4+deb10u2]
                            libdns-export1104/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libdns1104/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libdpkg-perl/oldstable 1.19.8 all [aktualisierbar von: 1.19.7]
                            libexpat1-dev/oldstable 2.2.6-2+deb10u4 armhf [aktualisierbar von: 2.2.6-2+deb10u1]
                            libexpat1/oldstable 2.2.6-2+deb10u4 armhf [aktualisierbar von: 2.2.6-2+deb10u1]
                            libgmp10/oldstable 2:6.1.2+dfsg-4+deb10u1 armhf [aktualisierbar von: 2:6.1.2+dfsg-4]
                            libgssapi-krb5-2/oldstable 1.17-3+deb10u3 armhf [aktualisierbar von: 1.17-3+deb10u2]
                            libicu-dev/oldstable 63.1-6+deb10u3 armhf [aktualisierbar von: 63.1-6+deb10u1]
                            libicu63/oldstable 63.1-6+deb10u3 armhf [aktualisierbar von: 63.1-6+deb10u1]
                            libisc-export1100/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libisc1100/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libisccc161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libisccfg163/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            libk5crypto3/oldstable 1.17-3+deb10u3 armhf [aktualisierbar von: 1.17-3+deb10u2]
                            libkrb5-3/oldstable 1.17-3+deb10u3 armhf [aktualisierbar von: 1.17-3+deb10u2]
                            libkrb5support0/oldstable 1.17-3+deb10u3 armhf [aktualisierbar von: 1.17-3+deb10u2]
                            libldap-2.4-2/oldstable 2.4.47+dfsg-3+rpi1+deb10u7 armhf [aktualisierbar von: 2.4.47+dfsg-3+rpi1+deb10u6]
                            libldap-common/oldstable 2.4.47+dfsg-3+rpi1+deb10u7 all [aktualisierbar von: 2.4.47+dfsg-3+rpi1+deb10u6]
                            liblwres161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u7 armhf [aktualisierbar von: 1:9.11.5.P4+dfsg-5.1+deb10u5]
                            liblzma5/oldstable 5.2.4-1+deb10u1 armhf [aktualisierbar von: 5.2.4-1]
                            libntfs-3g883/oldstable 1:2017.3.23AR.3-3+deb10u2 armhf [aktualisierbar von: 1:2017.3.23AR.3-3]
                            libperl5.28/oldstable 5.28.1-6+deb10u1 armhf [aktualisierbar von: 5.28.1-6]
                            libpolkit-agent-1-0/oldstable 0.105-25+rpt1+deb10u1 armhf [aktualisierbar von: 0.105-25+rpt1]
                            libpolkit-backend-1-0/oldstable 0.105-25+rpt1+deb10u1 armhf [aktualisierbar von: 0.105-25+rpt1]
                            libpolkit-gobject-1-0/oldstable 0.105-25+rpt1+deb10u1 armhf [aktualisierbar von: 0.105-25+rpt1]
                            libraspberrypi-bin/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            libraspberrypi-dev/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            libraspberrypi-doc/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            libraspberrypi0/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            libsasl2-2/oldstable 2.1.27+dfsg-1+deb10u2 armhf [aktualisierbar von: 2.1.27+dfsg-1+deb10u1]
                            libsasl2-modules-db/oldstable 2.1.27+dfsg-1+deb10u2 armhf [aktualisierbar von: 2.1.27+dfsg-1+deb10u1]
                            libssl1.1/oldstable 1.1.1n-0+deb10u3 armhf [aktualisierbar von: 1.1.1d-0+deb10u6+rpt1]
                            libtiff5/oldstable 4.1.0+git191117-2~deb10u4 armhf [aktualisierbar von: 4.1.0+git191117-2~deb10u2]
                            libtirpc-common/oldstable 1.1.4-0.4+deb10u1 all [aktualisierbar von: 1.1.4-0.4]
                            libtirpc3/oldstable 1.1.4-0.4+deb10u1 armhf [aktualisierbar von: 1.1.4-0.4]
                            libxml2/oldstable 2.9.4+dfsg1-7+deb10u4 armhf [aktualisierbar von: 2.9.4+dfsg1-7+deb10u2]
                            linux-libc-dev/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            locales/oldstable 2.28-10+rpt2+rpi1+deb10u1 all [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            multiarch-support/oldstable 2.28-10+rpt2+rpi1+deb10u1 armhf [aktualisierbar von: 2.28-10+rpt2+rpi1]
                            ntfs-3g/oldstable 1:2017.3.23AR.3-3+deb10u2 armhf [aktualisierbar von: 1:2017.3.23AR.3-3]
                            openssl/oldstable 1.1.1n-0+deb10u3 armhf [aktualisierbar von: 1.1.1d-0+deb10u6+rpt1]
                            perl-base/oldstable 5.28.1-6+deb10u1 armhf [aktualisierbar von: 5.28.1-6]
                            perl-modules-5.28/oldstable 5.28.1-6+deb10u1 all [aktualisierbar von: 5.28.1-6]
                            perl/oldstable 5.28.1-6+deb10u1 armhf [aktualisierbar von: 5.28.1-6]
                            policykit-1/oldstable 0.105-25+rpt1+deb10u1 armhf [aktualisierbar von: 0.105-25+rpt1]
                            psmisc/oldstable 23.2-1+deb10u1 armhf [aktualisierbar von: 23.2-1]
                            publicsuffix/oldstable 20220811.1734-0+deb10u1 all [aktualisierbar von: 20190415.1030-1]
                            python3-debconf/oldstable 1.5.71+deb10u1 all [aktualisierbar von: 1.5.71]
                            raspberrypi-bootloader/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            raspberrypi-kernel/oldstable 1:1.20220308~buster-1 armhf [aktualisierbar von: 1:1.20210831-3~buster]
                            raspberrypi-net-mods/oldstable 1.3.2 all [aktualisierbar von: 1.3.0]
                            raspberrypi-sys-mods/oldstable 20211005 armhf [aktualisierbar von: 20210901]
                            rpi-eeprom/oldstable 13.12-1~buster armhf [aktualisierbar von: 12.9-1]
                            rsyslog/oldstable 8.1901.0-1+deb10u2 armhf [aktualisierbar von: 8.1901.0-1]
                            tzdata/oldstable 2021a-0+deb10u6 all [aktualisierbar von: 2021a-0+deb10u1]
                            vim-common/oldstable 2:8.1.0875-5+deb10u2 all [aktualisierbar von: 2:8.1.0875-5]
                            vim-tiny/oldstable 2:8.1.0875-5+deb10u2 armhf [aktualisierbar von: 2:8.1.0875-5]
                            xxd/oldstable 2:8.1.0875-5+deb10u2 armhf [aktualisierbar von: 2:8.1.0875-5]
                            xz-utils/oldstable 5.2.4-1+deb10u1 armhf [aktualisierbar von: 5.2.4-1]
                            zlib1g-dev/oldstable 1:1.2.11.dfsg-1+deb10u1 armhf [aktualisierbar von: 1:1.2.11.dfsg-1]
                            zlib1g/oldstable 1:1.2.11.dfsg-1+deb10u1 armhf [aktualisierbar von: 1:1.2.11.dfsg-1]
                            LG Helikiller
                            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                            • H Helikiller
                              Auflistung...
                              @helikiller sagte in Einige Adapter starten nicht mehr:
                              Natürlich. Absoluter Standard...
                              iobroker stop
                              sudo apt update
                              sudo apt full-upgrade
                              sudo reboot
                              Künftig regelmäßig!!! machen.
                              • H Helikiller
                                Auflistung...
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Welches !?
