  4. Ganze Iobroker Version läuft langsam
    5.8k
286 Beiträge 8 Kommentatoren 31.9k Aufrufe 6 Beobachtet
  • stefu87_CHS stefu87_CH
    @glasfaser sagte in Ganze Iobroker Version läuft langsam:
    @stefu87_CH
    Welche Adapter hast du noch aus dem BETA Zweig geholt ..
    denn ganz oben bei
    iobroker update -i
    sehe ich den Adapter nicht !
    Aktueller Stand von jetzt gerade:
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "birthdays"    : 2.0.0    , installed 2.0.0
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.1.7    , installed 2.1.7
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.8
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "parser"       : 1.1.7    , installed 1.1.7
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Es sind noch Web Speedy, Applle-Find-me, myTime. Werden aber hier nicht aufgelistet. Sind aber bei den Adaptern drin und online
    #211
    @stefu87_ch sagte in Ganze Iobroker Version läuft langsam:
    dann ist was faul!
      dann ist was faul!
      GlasfaserG Offline
      GlasfaserG Offline
      #212
      @homoran sagte in Ganze Iobroker Version läuft langsam:
      dann ist was faul!
      Ich weiß nicht woher das kommt , gibt hier einige Threads dazu , aber bei
      iobroker update -i
      werden nicht alle angezeigt was installiert ist ,
      aber Thomas hast ihm schon ganz oben gesagt wie er Sie aus Beta holt .
      stefu87_CHS HomoranH Thomas BraunT 3 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        dann ist was faul!
        iobroker update -i
        stefu87_CHS Offline
        stefu87_CHS Offline
        stefu87_CH
        #213
        @glasfaser Was ist jetzt? Soll ich die hochziehen oder nicht?
        Cores: 1 × 8 = 8 cores
        Threads: 16
        mit Proxmox
        LXC Container mit Iobroker
          dann ist was faul!
          iobroker update -i
          #214
          @glasfaser ich fürchte das ist ein weitetes Problem. Diese Adapter sind wohl aus github.
          im Backup ist nur die Instanzen konfig und die Adapter werden dann danach installiert was hier wohl schiefgelaufen ist
            #215
            erst die Ausgabe der Browserkonsole
              dann ist was faul!
              iobroker update -i
              #216
              Das ist Krempel aus git.
                GlasfaserG Offline
                GlasfaserG Offline
                #217
                War in einer txt Datei
                Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. edit.html
                Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. jquery-1.11.2.min.js:4:29775
                window.controllers/Controllers sollte nicht mehr verwendet werden. Verwenden Sie es nicht für die Browser-Erkennung. ace.js:1:18478
                Version vis-canvas-gauges: 0.1.5 edit.html:3458:25
                Version Info-Adapter-Widget: 0.0.9 info.js:21:21
                Version vis-jqui-mfd: 1.0.12 edit.html:4618:21
                Version justgage: 1.0.2 justgage.js:115:21
                Uncaught (in promise) SyntaxError: JSON.parse: expected double-quoted property name at line 410 column 1 of the JSON data
                    getTranslation http://192.168.0.250:8082/vis/widgets/info/js/info.js:13
                info.js:13:47
                Version vis-map: 1.0.3 edit.html:8943:25
                Version material: 0.1.3 material.js:29:21
                Metro version: "1.2.0" edit.html:11279:10
                Version mytime: 0.0.1 mytime.js:36:21
                Download the Vue Devtools extension for a better development experience:
                https://github.com/vuejs/vue-devtools lib.min.js:43:9053
                You are running Vue in development mode.
                Make sure to turn on production mode when deploying for production.
                See more tips at https://vuejs.org/guide/deployment.html lib.min.js:43:9256
                Version trashschedule: 2.0.2 trashschedule.js:152:21
                Version vis-material-advanced: 1.6.0 vis-material-advanced.js:184:21
                [2022-07-24T14:06:09.601Z] Try to connect socket.io.js:66:41
                2022-07-24T14:06:09.779Z Connected => authenticate conn.js:305:25
                2022-07-24T14:06:10.313Z Authenticated: true conn.js:326:33
                Version vis-materialdesign: 0.5.9 materialdesign.js:33:25
                sentry initialized for vis-materialdesign instrument.ts:129:35
                Request all states. instrument.ts:129:35
                Create inner vis object demoTemperature instrument.ts:129:35
                Create inner vis object demoHumidity instrument.ts:129:35
                "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"}, instrument.ts:129:35
                "data": {"en": "data", "de": "data", "ru": "data"}, 2 instrument.ts:129:35
                "string": {"en": "string", "de": "string", "ru": "string"}, instrument.ts:129:35
                "progress": {"en": "progress", "de": "progress", "ru": "progress"}, 2 instrument.ts:129:35
                "view": {"en": "view", "de": "view", "ru": "view"}, 5 instrument.ts:129:35
                "messages": {"en": "messages", "de": "messages", "ru": "messages"}, 2 instrument.ts:129:35
                  info.js:13:47
                  #218
                  @glasfaser danke!
                  sehe ich da wirklich keinen Error?
                    @glasfaser danke!
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #219
                    Nee ... nix !
                      #220
                      @stefu87_CH
                      ist das unmittelbar beim Versuch die Seite zu öffnen/reloaden (f5)?
                        Nee ... nix !
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #221
                        @stefu87_CH
                        Obwohl .... lasse mal ein Verbindungsfehler kommen / anzeigen und dann in der Konsole schauen !!
                          @stefu87_CH
                          stefu87_CHS Offline
                          stefu87_CHS Offline
                          stefu87_CH
                          #222
                          @stefu87_CH
                          console-export-2022-7-24_16-52-11.txt
                          Threads: 16
                          mit Proxmox
                            @stefu87_CH
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #223
                            @stefu87_ch
                            [2022-07-24T14:50:58.584Z] Try to connect socket.io.js:66:41
                            2022-07-24T14:50:58.736Z Connected => authenticate conn.js:305:25
                            info.js:13:47
                            2022-07-24T14:50:58.810Z Authenticated: true conn.js:326:33
                            Request all states. vis.js:3700:33
                            [2022-07-24T14:51:43.730Z] ws connection error: CLOSED_NO_STATUS instrument.ts:129:35
                            [2022-07-24T14:51:43.736Z] Start reconnect 0 instrument.ts:129:35
                            [2022-07-24T14:51:43.738Z] Try to connect instrument.ts:129:35
                            was offline for 0.029s instrument.ts:129:35
                            Trying connect... instrument.ts:129:35
                            [2022-07-24T14:51:53.740Z] Try to connect instrument.ts:129:35
                            [2022-07-24T14:51:53.783Z] Cannot send ping. Close connection: InvalidStateError: An attempt was made to use an object that is not, or is no longer, usable instrument.ts:129:35
                            [2022-07-24T14:51:53.785Z] Start reconnect 0 instrument.ts:129:35
                            Firefox kann keine Verbindung zu dem Server unter ws://192.168.0.250:8084/?sid=1658674313740 aufbauen. socket.io.js:134:21
                            [2022-07-24T14:51:53.786Z] Try to connect instrument.ts:129:35
                            Die Verbindung zu ws://192.168.0.250:8084/?sid=1658674313740 wurde unterbrochen, während die Seite geladen wurde. socket.io.js:134:21
                            [2022-07-24T14:51:53.787Z] Start reconnect 1 instrument.ts:129:35
                            Firefox kann keine Verbindung zu dem Server unter ws://192.168.0.250:8084/?sid=1658674313786 aufbauen. socket.io.js:134:21
                            [2022-07-24T14:51:53.788Z] ws connection error: CLOSE_ABNORMAL instrument.ts:129:35
                            [2022-07-24T14:51:53.794Z] Reconnect is already running 1 instrument.ts:129:35
                            Die Verbindung zu ws://192.168.0.250:8084/?sid=1658674313786 wurde unterbrochen, während die Seite geladen wurde. socket.io.js:134:21
                            [2022-07-24T14:51:53.796Z] Reconnect is already running 1 instrument.ts:129:35
                            [2022-07-24T14:51:53.797Z] ws connection error: CLOSE_ABNORMAL instrument.ts:129:35
                            [2022-07-24T14:51:53.801Z] Reconnect is already running 1 instrument.ts:129:35
                            [2022-07-24T14:51:54.823Z] Try to connect instrument.ts:129:35
                            was offline for 1.091s instrument.ts:129:35
                            [2022-07-24T14:52:03.751Z] Try to connect instrument.ts:129:35
                            Uncaught DOMException: An attempt was made to use an object that is not, or is no longer, usable socket.io.js:237
                            was offline for 9.986s instrument.ts:129:35
                            [2022-07-24T14:52:08.764Z] ws connection error: CLOSED_NO_STATUS instrument.ts:129:35
                            [2022-07-24T14:52:08.768Z] Start reconnect 0 instrument.ts:129:35
                            [2022-07-24T14:52:08.769Z] Try to connect instrument.ts:129:35
                            [2022-07-24T14:52:08.789Z] ws connection error: CLOSED_NO_STATUS instrument.ts:129:35
                            [2022-07-24T14:52:08.794Z] Start reconnect 1 instrument.ts:129:35
                            Firefox kann keine Verbindung zu dem Server unter ws://192.168.0.250:8084/?sid=1658674328771 aufbauen. socket.io.js:134:21
                            Die Verbindung zu ws://192.168.0.250:8084/?sid=1658674328771 wurde unterbrochen, während die Seite geladen wurde. socket.io.js:134:21
                            [2022-07-24T14:52:08.797Z] Reconnect is already running 1 instrument.ts:129:35
                            [2022-07-24T14:52:08.798Z] ws connection error: CLOSE_ABNORMAL instrument.ts:129:35
                            [2022-07-24T14:52:08.800Z] Reconnect is already running 1 instrument.ts:129:35
                            [2022-07-24T14:52:10.112Z] Try to connect instrument.ts:129:35
                            was offline for 1.37s instrument.ts:129:35
                            stefu87_CHS HomoranH 2 Antworten Letzte Antwort
                              @stefu87_ch
                              info.js:13:47
                              stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              #224
                              @glasfaser sehe gerade bei den Adaptern, das der Socket-io rot ist und nicht starten will
                              Threads: 16
                              mit Proxmox
                              • DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #225
                                Ich kapier trotzdem immernoch nicht warum man ein neues System hochzieht und dann BEVOR man das System gescheit am laufen hat mit dem ganzen Schnickschnack füttert.
                                (port8084 zu ws ?)
                                Lehrling seit 1975 !!!
                                stefu87_CHS GlasfaserG HomoranH 3 Antworten Letzte Antwort
                                • DJMarc75D DJMarc75
                                  (port8084 zu ws ?)
                                  stefu87_CHS Offline
                                  stefu87_CHS Offline
                                  stefu87_CH
                                  #226
                                  @djmarc75 sagte in Ganze Iobroker Version läuft langsam:
                                  (port8084 zu ws ?)
                                  Wie soll denn meine Vis laufen? Der Rest funktioniert ja einwandfrei
                                  Threads: 16
                                  mit Proxmox
                                    (port8084 zu ws ?)
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #227
                                    port8084 zu ws
                                    Ist so eingestellt :
                                        connLink:      'http://localhost:8084',  // optional - URL of the socket.io adapter. By default it is same URL where the WEB server is.
                                    https://www.iobroker.net/#de/adapters/adapterref/iobroker.ws/README.md
                                      @stefu87_ch
                                      info.js:13:47
                                      #228
                                      da isser ja
                                        (port8084 zu ws ?)
                                        #229
                                        port8084 zu ws ?)
                                        klar, deswegen ja
                                        hast du inzwischen im web auch mal die ws Instanz ausgewählt?
                                        welchen Port nutzt diese?
                                        aber da warte ich auch noch auf die Antwort , was dann die Frage mit sich brächte, ob dercPort im Container durchgereicht wird
                                          port8084 zu ws ?)
                                          klar, deswegen ja
                                          stefu87_CHS Offline
                                          stefu87_CHS Offline
                                          stefu87_CH
                                          schrieb am zuletzt editiert von stefu87_CH
                                          #230
                                          Oh hab ich wohl übersehen:
                                          Threads: 16
                                          mit Proxmox
