  4. admin interface leer
    5.8k
27 Beiträge 3 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • stephan1827S stephan1827
    @glasfaser hat leider nicht geholfen
    root@iobroker:/opt/iobroker# pkill -u iobroker
    root@iobroker:/opt/iobroker# iobroker host this
    Cannot use this command in multihost!
    iobroker host this
    Initialize current host
    Options:
      --help  Show help  [boolean]
    root@iobroker:/opt/iobroker# iobroker fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        Installing prerequisites (1/3)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
        Checking autostart (3/3)
    Unsupported init system, cannot enable autostart!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    root@iobroker:/opt/iobroker# iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 6308
    GlasfaserG Offline
    GlasfaserG Offline
    @stephan1827
    Multihost !?
    von
    iobroker start
    habe ich nichts geschrieben ... den Container solltest du dann anschließend neu starten
    stephan1827S 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @stephan1827
      Multihost !?
      von
      iobroker start
      stephan1827S Offline
      stephan1827
      @glasfaser yep, multihost, neustart des container macht auch keinen unterschied
        @stephan1827 sagte in admin interface leer:
        • system.adapter.web.0 : web : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8083, bind: 0.0.0.0, run as: admin
        Warum hast du die Ports anders !?
        GlasfaserG Offline
        GlasfaserG Offline
        @stephan1827
        @glasfaser sagte in admin interface leer:
        Was war hiermit !?
          nach einem Fehler habe ich eine Backup von meiner Docker Instanz wieder hergestellt. iobroker scheint normal zu laufen aber beim admin interface bekomme ich nur eine weiße Seite. Die admin Instanz läuft aber log steht.
          oot@iobroker:/opt/iobroker# node node_modules/iobroker.admin/main.js --logs
          2022-07-23 16:08:54.937  - error: admin.0 (30576) admin.0 invalid process id scenario 30454 vs. own ID 30576. Stopping
          2022-07-23 16:08:54.939  - info: admin.0 (30576) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          Weiß jemand was das bedeutet?
          GlasfaserG Offline
          GlasfaserG Offline
          Zeige mal Komplettlog wenn es nicht geht , nicht nur ein Ausszug davon :
          iobroker logs --watch
            @stephan1827
            Was war hiermit !?
            stephan1827
            @glasfaser Habe den port von admin auch auf 8081 gesetzt aber dann geht weder die Visu noch das admmin interface. Ich bin nicht mehr sicher warum ich den Port geändert habe aber das ist schon ewig so.
            2022-07-23 17:09:49.538  - info: admin.0 (420) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:09:49.540  - info: admin.0 (420) terminating http server on port 8081
            2022-07-23 17:09:49.541  - info: admin.0 (420) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:09:49.578  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
            2022-07-23 17:09:50.141  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:09:52.669  - info: host.iobroker instance system.adapter.admin.0 started with pid 2639
            2022-07-23 17:09:54.032  - info: admin.0 (2639) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:09:54.069  - info: admin.0 (2639) requesting all states
            2022-07-23 17:09:54.070  - info: admin.0 (2639) requesting all objects
            2022-07-23 17:09:55.077  - info: admin.0 (2639) received all objects
            2022-07-23 17:09:55.248  - info: admin.0 (2639) http server listening on port 8083
            2022-07-23 17:09:55.248  - info: admin.0 (2639) Use link "http://localhost:8083" to configure.
            2022-07-23 17:10:11.142  - info: host.iobroker received SIGTERM
            2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
            2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
            2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=true)
            2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
            2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.hue.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.fritzbox.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ebus.0 (force=false, process=true)
            2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.info.0 (force=false, process=true)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-weather.0 (force=false, process=false)
            2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2022-07-23 17:10:11.148  - info: host.iobroker stopInstance canceled schedule system.adapter.daswetter.0
            2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.systeminfo.0 (force=false, process=true)
            2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.bring.0 (force=false, process=true)
            2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.plenticore.0 (force=false, process=true)
            2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.vis-history.0 (force=false, process=false)
            2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=true)
            2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.yahka.0 (force=false, process=true)
            2022-07-23 17:10:11.154  - info: node-red.0 (477) kill node-red task
            2022-07-23 17:10:11.164  - info: admin.0 (2639) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.165  - info: admin.0 (2639) terminating http server on port 8083
            2022-07-23 17:10:11.166  - info: admin.0 (2639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.169  - info: javascript.0 (435) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.169  - info: pushover.0 (462) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.172  - info: hm-rpc.2 (603) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.170  - info: alexa2.0 (518) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.174  - info: ping.0 (675) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.174  - info: modbus.0 (633) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.175  - info: hm-rpc.1 (575) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.172  - info: alexa2.0 (518) terminating
            2022-07-23 17:10:11.173  - info: alexa2.0 (518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.178  - info: hue.0 (618) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.172  - info: hm-rpc.0 (560) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.179  - info: info.0 (723) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.178  - info: backitup.0 (693) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.180  - info: ebus.0 (708) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.171  - info: hm-rega.0 (545) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.181  - info: info.0 (723) cleaned everything up...
            2022-07-23 17:10:11.181  - info: info.0 (723) terminating
            2022-07-23 17:10:11.182  - info: info.0 (723) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.175  - info: fritzbox.0 (648) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.186  - info: bring.0 (1786) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.173  - info: hm-rpc.2 (603) binrpc -> 192.168.86.50:8701/ init ["xmlrpc_bin://192.168.86.35:8701",""]
            2022-07-23 17:10:11.185  - info: iot.0 (1129) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.187  - info: bring.0 (1786) [END] Stopping Bring! adapter...
            2022-07-23 17:10:11.188  - info: bring.0 (1786) terminating
            2022-07-23 17:10:11.188  - info: bring.0 (1786) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.185  - info: systeminfo.0 (1679) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.187  - info: systeminfo.0 (1679) terminating
            2022-07-23 17:10:11.188  - info: systeminfo.0 (1679) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.176  - info: hm-rpc.1 (575) xmlrpc -> 192.168.86.50:2010/ init ["http://192.168.86.35:2010",""]
            2022-07-23 17:10:11.179  - info: backitup.0 (693) cleaned everything up...
            2022-07-23 17:10:11.181  - info: backitup.0 (693) terminating
            2022-07-23 17:10:11.185  - info: backitup.0 (693) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.191  - info: plenticore.0 (1863) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.173  - info: hm-rpc.0 (560) xmlrpc -> 192.168.86.50:2001/ init ["http://192.168.86.35:2001",""]
            2022-07-23 17:10:11.181  - info: ebus.0 (708) cleaned everything up...
            2022-07-23 17:10:11.184  - info: ebus.0 (708) terminating
            2022-07-23 17:10:11.192  - info: ebus.0 (708) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.196  - info: node-red.0 (477) node-red exited with 0
            2022-07-23 17:10:11.183  - info: modbus.0 (633) terminating
            2022-07-23 17:10:11.192  - info: modbus.0 (633) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.194  - info: plenticore.0 (1863) [END] Stopping plenticore adapter...
            2022-07-23 17:10:11.195  - info: plenticore.0 (1863) terminating
            2022-07-23 17:10:11.196  - info: plenticore.0 (1863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.196  - info: iot.0 (1129) terminating
            2022-07-23 17:10:11.197  - info: iot.0 (1129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.194  - info: fritzbox.0 (648) terminating
            2022-07-23 17:10:11.200  - info: fritzbox.0 (648) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.201  - info: yahka.0 (2098) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.200  - info: jarvis.0 (2023) Got terminate signal TERMINATE_YOURSELF
            2022-07-23 17:10:11.193  - info: hm-rpc.2 (603) Disconnected
            2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaning up ...
            2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaned up ...
            2022-07-23 17:10:11.206  - info: yahka.0 (2098) terminating
            2022-07-23 17:10:11.207  - info: yahka.0 (2098) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.211  - info: hm-rpc.1 (575) Disconnected
            2022-07-23 17:10:11.207  - info: jarvis.0 (2023) Adapter stopped und unloaded.
            2022-07-23 17:10:11.207  - info: jarvis.0 (2023) terminating
            2022-07-23 17:10:11.209  - info: jarvis.0 (2023) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.213  - info: hm-rpc.1 (575) terminating
            2022-07-23 17:10:11.214  - info: hm-rpc.1 (575) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.219  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
            2022-07-23 17:10:11.220  - info: hm-rpc.0 (560) Disconnected
            2022-07-23 17:10:11.207  - info: hm-rpc.2 (603) terminating
            2022-07-23 17:10:11.208  - info: hm-rpc.2 (603) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
            2022-07-23 17:10:11.171  - info: javascript.0 (435) Stop script script.js.common.AlarmModus
            2022-07-23 17:10:11.190  - info: javascript.0 (435) Stop script script.js.common.Alexa
            2022-07-23 17:10:11.195  - info: javascript.0 (435) Stop script script.js.common.Solar
            2022-07-23 17:10:11.199  - info: javascript.0 (435) Stop script script.js.common.Homematic_Meldungen
            2022-07-23 17:10:11.220  - info: javascript.0 (435) Stop script script.js.common.Jarvis
            2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Zigbee
            2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Alarm
            2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.pushover.0 send kill signal
            2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
            2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal
            2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hue.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.fritzbox.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ping.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ebus.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.info.0 send kill signal
            2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
            2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.systeminfo.0 send kill signal
            2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.bring.0 send kill signal
            2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.plenticore.0 send kill signal
            2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.jarvis.0 send kill signal
            2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.yahka.0 send kill signal
            2022-07-23 17:10:11.230  - info: hue.0 (618) cleaned everything up...
            2022-07-23 17:10:11.231  - info: hue.0 (618) terminating
            2022-07-23 17:10:11.232  - info: hue.0 (618) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.221  - info: hm-rpc.0 (560) terminating
            2022-07-23 17:10:11.230  - info: hm-rpc.0 (560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.236  - info: javascript.0 (435) terminating
            2022-07-23 17:10:11.238  - info: javascript.0 (435) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.245  - info: hm-rega.0 (545) terminating
            2022-07-23 17:10:11.246  - info: hm-rega.0 (545) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.250  - info: plenticore.0 (1863) Logged out from API
            2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection changed: disconnect
            2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection lost
            2022-07-23 17:10:11.671  - info: pushover.0 (462) terminating
            2022-07-23 17:10:11.672  - info: pushover.0 (462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.676  - info: ping.0 (675) terminating
            2022-07-23 17:10:11.677  - info: ping.0 (675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-07-23 17:10:11.802  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.056  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.322  - info: history.0 (503) Terminated (NO_ERROR): Without reason
            2022-07-23 17:10:12.391  - info: host.iobroker stopInstance system.adapter.javascript.0 killing pid 435
            2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.pushover.0 killing pid 462
            2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rega.0 killing pid 545
            2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 killing pid 560
            2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 killing pid 575
            2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 killing pid 603
            2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hue.0 killing pid 618
            2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.ping.0 killing pid 675
            2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.jarvis.0 killing pid 2023
            2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.yahka.0 killing pid 2098
            2022-07-23 17:10:12.452  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.586  - info: host.iobroker instance system.adapter.ebus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.587  - info: host.iobroker instance system.adapter.systeminfo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.616  - info: host.iobroker instance system.adapter.bring.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.673  - info: pushover.0 (462) terminating with timeout
            2022-07-23 17:10:12.678  - info: ping.0 (675) terminating with timeout
            2022-07-23 17:10:12.638  - info: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.748  - info: host.iobroker instance system.adapter.plenticore.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:12.778  - info: host.iobroker instance system.adapter.fritzbox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.059  - info: host.iobroker instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.082  - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.186  - info: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.232  - info: host.iobroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.233  - info: host.iobroker instance system.adapter.jarvis.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.260  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.380  - info: host.iobroker instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.402  - info: host.iobroker instance system.adapter.ping.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:10:13.462  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2022-07-23 17:10:16.145  - info: host.iobroker stopInstance timeout 5000 system.adapter.node-red.0 killing pid  477
            2022-07-23 17:10:16.649  - info: node-red.0 (477) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-07-23 17:10:17.231  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2022-07-23 17:10:17.231  - info: host.iobroker All instances are stopped.
            2022-07-23 17:10:17.386  - info: host.iobroker terminated
            2022-07-23 17:10:42.082  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
            2022-07-23 17:10:42.085  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-07-23 17:10:42.086  - info: host.iobroker hostname: iobroker, node: v16.16.0
            2022-07-23 17:10:42.086  - info: host.iobroker ip addresses: 192.168.86.35 fe80::211:32ff:fee9:7b3f 172.17.0.1 fe80::42:1dff:fe89:d167 fe80::1821:8aff:fe81:9b4a
            2022-07-23 17:10:43.209  - info: host.iobroker connected to Objects and States
            2022-07-23 17:10:43.247  - info: host.iobroker added notifications configuration of host
            2022-07-23 17:10:43.733  - info: host.iobroker 40 instances found
            2022-07-23 17:10:43.767  - info: host.iobroker starting 30 instances
            2022-07-23 17:10:43.867  - info: host.iobroker instance system.adapter.admin.0 started with pid 419
            2022-07-23 17:10:45.168  - info: admin.0 (419) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:10:45.193  - info: admin.0 (419) requesting all states
            2022-07-23 17:10:45.194  - info: admin.0 (419) requesting all objects
            2022-07-23 17:10:46.268  - info: admin.0 (419) received all objects
            2022-07-23 17:10:46.474  - info: admin.0 (419) http server listening on port 8083
            2022-07-23 17:10:46.475  - info: admin.0 (419) Use link "http://localhost:8083" to configure.
            2022-07-23 17:10:47.948  - info: host.iobroker instance system.adapter.javascript.0 started with pid 434
            2022-07-23 17:10:49.737  - info: javascript.0 (434) starting. Version 5.7.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:10:50.576  - info: javascript.0 (434) requesting all states
            2022-07-23 17:10:50.577  - info: javascript.0 (434) requesting all objects
            2022-07-23 17:10:51.864  - info: host.iobroker instance system.adapter.pushover.0 started with pid 463
            2022-07-23 17:10:51.950  - info: javascript.0 (434) received all objects
            2022-07-23 17:10:51.964  - info: javascript.0 (434) received all states
            2022-07-23 17:10:52.007  - error: javascript.0 (434) The Mirror directory is not allowed to be a central ioBroker directory!
            2022-07-23 17:10:52.007  - error: javascript.0 (434) Directory /opt/iobroker/backups/scripte is not allowed to mirror files!
            2022-07-23 17:10:52.017  - info: javascript.0 (434) Start javascript script.js.common.AlarmModus
            2022-07-23 17:10:53.131  - info: pushover.0 (463) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:10:52.048  - info: javascript.0 (434) script.js.common.AlarmModus: registered 1 subscription and 0 schedules
            2022-07-23 17:10:52.048  - info: javascript.0 (434) Start javascript script.js.common.Alexa
            2022-07-23 17:10:52.054  - info: javascript.0 (434) script.js.common.Alexa: registered 13 subscriptions and 0 schedules
            2022-07-23 17:10:52.054  - info: javascript.0 (434) Start javascript script.js.common.Solar
            2022-07-23 17:10:52.115  - info: javascript.0 (434) script.js.common.Solar: registered 12 subscriptions and 10 schedules
            2022-07-23 17:10:52.116  - info: javascript.0 (434) Start javascript script.js.common.Homematic_Meldungen
            2022-07-23 17:10:53.529  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:10:53.530  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:10:53.531  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: registered 204 subscriptions and 1 schedule
            2022-07-23 17:10:53.651  - info: javascript.0 (434) Start javascript script.js.common.Jarvis
            2022-07-23 17:10:53.664  - info: javascript.0 (434) script.js.common.Jarvis: registered 30 subscriptions and 1 schedule
            2022-07-23 17:10:53.664  - info: javascript.0 (434) Start javascript script.js.common.Zigbee
            2022-07-23 17:10:53.668  - info: javascript.0 (434) script.js.common.Zigbee: registered 9 subscriptions and 0 schedules
            2022-07-23 17:10:53.673  - info: javascript.0 (434) Start javascript script.js.common.Alarm
            2022-07-23 17:10:53.677  - info: javascript.0 (434) script.js.common.Alarm: registered 17 subscriptions and 0 schedules
            2022-07-23 17:10:53.687  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:10:55.855  - info: host.iobroker instance system.adapter.node-red.0 started with pid 478
            2022-07-23 17:10:56.997  - info: node-red.0 (478) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:10:57.015  - info: node-red.0 (478) Requested NPM packages: ["node-red-contrib-bool-gate","node-red-contrib-azure-iot-hub"]
            2022-07-23 17:10:57.935  - info: node-red.0 (478) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
            2022-07-23 17:10:59.866  - info: host.iobroker instance system.adapter.history.0 started with pid 504
            2022-07-23 17:11:01.188  - warn: node-red.0 (478) 23 Jul 17:11:01 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
            2022-07-23 17:11:01.201  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iothub/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
            (Use `node --trace-deprecation ...` to show where the warning was created)
            2022-07-23 17:11:01.202  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
            (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-device-amqp-ws/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
            2022-07-23 17:11:01.207  - info: history.0 (504) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.history, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:01.349  - info: history.0 (504) enabled logging of hm-rega.0.18981 (Count=1), Alias=false
            2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.1981 (Count=2), Alias=false
            2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.2688 (Count=3), Alias=false
            2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.3039 (Count=4), Alias=false
            2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.9284 (Count=5), Alias=false
            2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.950 (Count=6), Alias=false
            2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.alarms (Count=7), Alias=false
            2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.maintenance (Count=8), Alias=false
            2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.ACTUAL_TEMPERATURE (Count=9), Alias=false
            2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.SET_TEMPERATURE (Count=10), Alias=false
            2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.VALVE_STATE (Count=11), Alias=false
            2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.ACTUAL_TEMPERATURE (Count=12), Alias=false
            2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.SET_TEMPERATURE (Count=13), Alias=false
            2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.VALVE_STATE (Count=14), Alias=false
            2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.ACTUAL_TEMPERATURE (Count=15), Alias=false
            2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.SET_TEMPERATURE (Count=16), Alias=false
            2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.VALVE_STATE (Count=17), Alias=false
            2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.ACTUAL_TEMPERATURE (Count=18), Alias=false
            2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.SET_TEMPERATURE (Count=19), Alias=false
            2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.VALVE_STATE (Count=20), Alias=false
            2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.ACTUAL_TEMPERATURE (Count=21), Alias=false
            2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.SET_TEMPERATURE (Count=22), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.VALVE_STATE (Count=23), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.HUMIDITY (Count=24), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.TEMPERATURE (Count=25), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.ACTUAL_TEMPERATURE (Count=26), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.SET_TEMPERATURE (Count=27), Alias=false
            2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.VALVE_STATE (Count=28), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.ACTUAL_TEMPERATURE (Count=29), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.SET_TEMPERATURE (Count=30), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.VALVE_STATE (Count=31), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.ACTUAL_TEMPERATURE (Count=32), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.SET_TEMPERATURE (Count=33), Alias=false
            2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.VALVE_STATE (Count=34), Alias=false
            2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.ACTUAL_TEMPERATURE (Count=35), Alias=false
            2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.SET_TEMPERATURE (Count=36), Alias=false
            2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.VALVE_STATE (Count=37), Alias=false
            2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22568 (Count=38), Alias=false
            2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22569 (Count=39), Alias=false
            2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.SET_POINT_TEMPERATURE (Count=40), Alias=false
            2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.LEVEL (Count=41), Alias=false
            2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.VALVE_STATE (Count=42), Alias=false
            2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.ACTUAL_TEMPERATURE (Count=43), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of daswetter.0.NextHours.Location_1.Day_1.current.temp_value (Count=44), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_DC_power (Count=45), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_AC_power (Count=46), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_AC_power (Count=47), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Grid (Count=48), Alias=false
            2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Grid (Count=49), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Used (Count=50), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used (Count=51), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used (Count=52), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used (Count=53), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used (Count=54), Alias=false
            2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_PV (Count=55), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV (Count=56), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV (Count=57), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV (Count=58), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid (Count=59), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid (Count=60), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid (Count=61), Alias=false
            2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid (Count=62), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid (Count=63), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid (Count=64), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid (Count=65), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid (Count=66), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark (Count=67), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark (Count=68), Alias=false
            2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark (Count=69), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark (Count=70), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV (Count=71), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark_Total (Count=72), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark_Total (Count=73), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark_Total (Count=74), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark_Total (Count=75), Alias=false
            2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used_Total (Count=76), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used_Total (Count=77), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used_Total (Count=78), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used_Total (Count=79), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV_Total (Count=80), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV_Total (Count=81), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV_Total (Count=82), Alias=false
            2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV_Total (Count=83), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid_Total (Count=84), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid_Total (Count=85), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid_Total (Count=86), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid_Total (Count=87), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid_Total (Count=88), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid_Total (Count=89), Alias=false
            2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid_Total (Count=90), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid_Total (Count=91), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_Percent (Count=92), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_Percent (Count=93), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro (Count=94), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro (Count=95), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro (Count=96), Alias=false
            2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro (Count=97), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro_Total (Count=98), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro_Total (Count=99), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro_Total (Count=100), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro_Total (Count=101), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Battery (Count=102), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Battery (Count=103), Alias=false
            2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery (Count=104), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery (Count=105), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery (Count=106), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery (Count=107), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery_Total (Count=108), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery_Total (Count=109), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery_Total (Count=110), Alias=false
            2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery_Total (Count=111), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery (Count=112), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery (Count=113), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery (Count=114), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery (Count=115), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery_Total (Count=116), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery_Total (Count=117), Alias=false
            2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery_Total (Count=118), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery_Total (Count=119), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower (Count=120), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower (Count=121), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower (Count=122), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower (Count=123), Alias=false
            2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower_Total (Count=124), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower_Total (Count=125), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower_Total (Count=126), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower_Total (Count=127), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Overpower (Count=128), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.SoC (Count=129), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.Charge_P (Count=130), Alias=false
            2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of jarvis.0.addNotification (Count=131), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.SET_POINT_TEMPERATURE (Count=132), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.LEVEL (Count=133), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.ACTUAL_TEMPERATURE (Count=134), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.kesseltemp.value (Count=135), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.boilertemp.value (Count=136), Alias=false
            2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.aussentemp.value (Count=137), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.kesselsolltemp.value (Count=138), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.aussentemp.value (Count=139), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.brauchwassersolltemp.value (Count=140), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.alive (Count=141), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.time (Count=142), Alias=false
            2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.alive (Count=143), Alias=false
            2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.time (Count=144), Alias=false
            2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.alive (Count=145), Alias=false
            2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.time (Count=146), Alias=false
            2022-07-23 17:11:03.858  - info: host.iobroker instance system.adapter.alexa2.0 started with pid 519
            2022-07-23 17:11:05.114  - info: alexa2.0 (519) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:07.862  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 546
            2022-07-23 17:11:08.321  - info: alexa2.0 (519) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2022-07-23 17:11:08.818  - info: alexa2.0 (519) Unknown Device, but enabling commands, Try it and report back if commands work.
            2022-07-23 17:11:08.818  - info: alexa2.0 (519) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
            2022-07-23 17:11:08.819  - info: alexa2.0 (519)     Device-type:A3EVMLQTU6WL1W (ARTHUR_TARGET,SUPPORTS_LOCALE_SWITCH,FLASH_BRIEFING,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SOUND_SETTINGS,VOLUME_SETTING,MICROPHONE,CHANGE_NAME,SHARKNADO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,EARCONS,BT_PAIRING_FLOW_V2,ASCENDING_ALARM_VOLUME,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,PAIR_BT_SINK,DIALOG_INTERFACE_VERSION,TIMERS_AND_ALARMS,SUPPORTS_LOCALE,SPEECH_RECOGNIZER_USS,ACTIVE_AFTER_FRO,REMINDERS)
            2022-07-23 17:11:09.337  - info: hm-rega.0 (546) starting. Version 3.0.40 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:09.476  - info: hm-rega.0 (546) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
            2022-07-23 17:11:09.541  - info: hm-rega.0 (546) ReGaHSS 192.168.86.50 up
            2022-07-23 17:11:10.216  - warn: hm-rega.0 (546) time difference local-ccu 55s
            2022-07-23 17:11:11.868  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 561
            2022-07-23 17:11:13.109  - info: hm-rega.0 (546) request state values
            2022-07-23 17:11:13.714  - info: hm-rpc.0 (561) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:13.887  - info: hm-rpc.0 (561) xmlrpc server is trying to listen on 192.168.86.35:2001
            2022-07-23 17:11:13.888  - info: hm-rpc.0 (561) xmlrpc client is trying to connect to 192.168.86.50:2001/ with ["http://192.168.86.35:2001","iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
            2022-07-23 17:11:13.939  - info: hm-rpc.0 (561) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
            2022-07-23 17:11:13.958  - info: hm-rpc.0 (561) xmlrpc <- listDevices ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
            2022-07-23 17:11:14.036  - info: hm-rpc.0 (561) xmlrpc -> 179 devices
            2022-07-23 17:11:14.096  - info: hm-rpc.0 (561) Connected
            2022-07-23 17:11:14.646  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ1773663.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
            2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:14.648  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.OEQ0669002.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
            2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.230  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.327  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.328  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0871224.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
            2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:15.878  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 576
            2022-07-23 17:11:15.957  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0401353.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
            2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:15.959  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
            2022-07-23 17:11:16.330  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:16.429  - info: hm-rega.0 (546) Updated all datapoints
            2022-07-23 17:11:16.524  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
            2022-07-23 17:11:16.698  - info: hm-rega.0 (546) added/updated 1 objects
            2022-07-23 17:11:16.729  - info: hm-rega.0 (546) got 42 variables
            2022-07-23 17:11:17.509  - info: hm-rega.0 (546) added/updated 42 variables
            2022-07-23 17:11:17.510  - info: hm-rega.0 (546) deleted 0 variables
            2022-07-23 17:11:17.538  - info: hm-rega.0 (546) got 48 programs
            2022-07-23 17:11:17.550  - info: hm-rpc.1 (576) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:17.692  - info: hm-rpc.1 (576) xmlrpc server is trying to listen on 192.168.86.35:2010
            2022-07-23 17:11:17.693  - info: hm-rpc.1 (576) xmlrpc client is trying to connect to 192.168.86.50:2010/ with ["http://192.168.86.35:2010","iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
            2022-07-23 17:11:17.727  - info: hm-rpc.1 (576) Connected
            2022-07-23 17:11:17.738  - info: hm-rpc.1 (576) xmlrpc <- listDevices ["iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
            2022-07-23 17:11:17.812  - info: hm-rpc.1 (576) xmlrpc -> 0 devices
            2022-07-23 17:11:18.291  - info: hm-rpc.1 (576) xmlrpc <- newDevices 212
            2022-07-23 17:11:18.366  - info: hm-rpc.1 (576) new HMIP devices/channels after filter: 0
            2022-07-23 17:11:18.422  - info: hm-rega.0 (546) added/updated 48 programs
            2022-07-23 17:11:18.423  - info: hm-rega.0 (546) deleted 0 programs
            2022-07-23 17:11:19.856  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 591
            2022-07-23 17:11:21.206  - info: hm-rpc.2 (591) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc server is trying to listen on 192.168.86.35:8701
            2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc client is trying to connect to 192.168.86.50:8701/ with ["xmlrpc_bin://192.168.86.35:8701","iobroker:hm-rpc.2:2a319a3ec7ec9ea22f86865c577e678a"]
            2022-07-23 17:11:21.426  - info: hm-rpc.2 (591) binrpc -> listDevices 36
            2022-07-23 17:11:21.477  - info: hm-rpc.2 (591) new CUxD devices/channels after filter: 0
            2022-07-23 17:11:21.479  - info: hm-rpc.2 (591) Connected
            2022-07-23 17:11:23.126  - info: alexa2.0 (519) Subscribing to states...
            2022-07-23 17:11:23.990  - info: host.iobroker instance system.adapter.hue.0 started with pid 619
            2022-07-23 17:11:25.440  - info: hue.0 (619) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.hue, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:25.634  - info: hue.0 (619) skip switch: Daylight.configured
            2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunriseoffset
            2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunsetoffset
            2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemode
            2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemodevalues
            2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemode
            2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemodevalues
            2022-07-23 17:11:25.641  - info: hue.0 (619) created/updated 4 sensor channels
            2022-07-23 17:11:25.769  - info: hue.0 (619) created/updated 11 light channels
            2022-07-23 17:11:25.773  - info: hue.0 (619) created/updated 6 groups channels
            2022-07-23 17:11:25.776  - info: hue.0 (619) created/updated 25 scenes
            2022-07-23 17:11:25.776  - info: hue.0 (619) creating/updating bridge device
            2022-07-23 17:11:27.861  - info: host.iobroker instance system.adapter.modbus.0 started with pid 634
            2022-07-23 17:11:29.078  - info: modbus.0 (634) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:29.343  - info: modbus.0 (634) Connected to slave 192.168.86.153
            2022-07-23 17:11:31.880  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 649
            2022-07-23 17:11:33.369  - info: fritzbox.0 (649) starting. Version 0.5.0 (non-npm: ruhr70/ioBroker.fritzbox) in /opt/iobroker/node_modules/iobroker.fritzbox, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:33.394  - info: fritzbox.0 (649) try to connect: 192.168.86.1
            2022-07-23 17:11:33.395  - info: fritzbox.0 (649) Trying to connect to TR-064: 192.168.86.1:49000
            2022-07-23 17:11:33.419  - info: fritzbox.0 (649) adapter connected to fritzbox: 192.168.86.1
            2022-07-23 17:11:34.488  - info: fritzbox.0 (649) Successfully connected to TR-064
            2022-07-23 17:11:34.599  - warn: fritzbox.0 (649) TR-064: Error reading files from dir /tam: Error: ENOENT: no such file or directory, scandir 'tam'
            2022-07-23 17:11:35.861  - info: host.iobroker instance system.adapter.ping.0 started with pid 677
            2022-07-23 17:11:37.074  - info: ping.0 (677) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:37.183  - warn: ping.0 (677) Object ping.0.iobroker.Repeater3000. is invalid: obj.type has to exist
            2022-07-23 17:11:37.183  - warn: ping.0 (677) This object will not be created in future versions. Please report this to the developer.
            2022-07-23 17:11:37.184  - error: ping.0 (677) Cannot update channel : ping.0.iobroker.Repeater3000 Error: Error: The id "ping.0.iobroker.Repeater3000." is invalid. Ids are not allowed to end in "."
            2022-07-23 17:11:39.863  - info: host.iobroker instance system.adapter.backitup.0 started with pid 695
            2022-07-23 17:11:41.163  - info: backitup.0 (695) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:41.222  - info: backitup.0 (695) [iobroker] backup was activated at 02:00 every 3 day(s)
            2022-07-23 17:11:41.260  - info: backitup.0 (695) [ccu] backup was activated at 01:30 every 7 day(s)
            2022-07-23 17:11:43.860  - info: host.iobroker instance system.adapter.ebus.0 started with pid 710
            2022-07-23 17:11:45.187  - info: ebus.0 (710) starting. Version 3.0.2 (non-npm: rg-engineering/ioBroker.ebus) in /opt/iobroker/node_modules/iobroker.ebus, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:47.860  - info: host.iobroker instance system.adapter.info.0 started with pid 725
            2022-07-23 17:11:49.855  - info: info.0 (725) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:49.916  - info: info.0 (725) Reading/updating systemdata.
            2022-07-23 17:11:50.375  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
            2022-07-23 17:11:50.399  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
            2022-07-23 17:11:50.444  - info: info.0 (725) Reading CPU data every 3 seconds.
            2022-07-23 17:11:50.510  - info: info.0 (725) cpu Temp res = {"main":46,"cores":[47,47,48,49],"max":49,"socket":[],"chipset":null}
            2022-07-23 17:11:50.528  - info: info.0 (725) Reading CPU temp data every 3 seconds.
            2022-07-23 17:11:50.546  - info: info.0 (725) Reading CPU current speed every 3 seconds.
            2022-07-23 17:11:50.579  - info: info.0 (725) Reading memory data every 3 seconds.
            2022-07-23 17:11:50.668  - info: info.0 (725) Reading battery data every 8 seconds.
            2022-07-23 17:11:51.085  - info: info.0 (725) Reading user data every 8 seconds.
            2022-07-23 17:11:51.159  - info: info.0 (725) Reading process data every 8 seconds.
            2022-07-23 17:11:51.660  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev4.size" has to be type "string" but received type "number"
            2022-07-23 17:11:51.663  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
            2022-07-23 17:11:51.664  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev1.size" has to be type "string" but received type "number"
            2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev2.size" has to be type "string" but received type "number"
            2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev3.size" has to be type "string" but received type "number"
            2022-07-23 17:11:51.691  - info: info.0 (725) Reading disk data every 8 seconds.
            2022-07-23 17:11:51.862  - info: host.iobroker instance system.adapter.iot.0 started with pid 1109
            2022-07-23 17:11:52.318  - info: info.0 (725) Reading network data every 3 seconds.
            2022-07-23 17:11:53.362  - info: iot.0 (1109) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.iot, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:53.400  - info: iot.0 (1109) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2022-07-23 17:11:53.698  - info: iot.0 (1109) Connection changed: connect
            2022-07-23 17:11:57.012  - info: vis.0 (1230) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:11:57.181  - info: vis.0 (1230) vis license is OK.
            2022-07-23 17:11:57.982  - info: vis.0 (1230) Terminated (NO_ERROR): Without reason
            2022-07-23 17:11:58.572  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            2022-07-23 17:11:59.856  - info: host.iobroker instance system.adapter.web.0 started with pid 1377
            2022-07-23 17:12:01.178  - info: web.0 (1377) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:01.332  - info: web.0 (1377) socket.io server listening on port 8081
            2022-07-23 17:12:01.335  - info: web.0 (1377) http server listening on port 8081
            2022-07-23 17:12:04.949  - info: vis-google-fonts.0 (1444) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:05.540  - info: vis-google-fonts.0 (1444) Terminated (NO_ERROR): Without reason
            2022-07-23 17:12:06.133  - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
            2022-07-23 17:12:07.867  - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * *
            2022-07-23 17:12:07.889  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 1573
            2022-07-23 17:12:09.198  - info: daswetter.0 (1573) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:11.797  - info: host.iobroker instance system.adapter.systeminfo.0 started with pid 1679
            2022-07-23 17:12:13.193  - info: systeminfo.0 (1679) starting. Version 0.3.0 (non-npm: frankjoke/ioBroker.systeminfo) in /opt/iobroker/node_modules/iobroker.systeminfo, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:14.173  - info: systeminfo.0 (1679) Startup Systeminfo Adapter systeminfo.0: {  startup: '',  items: [    {      name: 'Piko.[Type/Value]',      type: 'web',      source: 'http://192.168.86.157/measurements.xml',      regexp: "Device.Measurements.Measurement[?(@.Type=='AC_Power' || @.Type=='DC_Voltage' || @.Type=='DC_Current')]",      conv: 'xml',      role: 'number',      write: '',      sched: '*/10 * * * * *'    }  ],  lang: 'de',  latitude: 51.9793,  longitude: 7.7942}
            2022-07-23 17:12:14.309  - info: systeminfo.0 (1679) Adapter systeminfo.0 started and found 1/3 items/states to process.
            2022-07-23 17:12:15.864  - info: host.iobroker instance system.adapter.bring.0 started with pid 1787
            2022-07-23 17:12:17.300  - info: bring.0 (1787) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:17.791  - info: bring.0 (1787) [LOGIN] Successfully logged in as stephan
            2022-07-23 17:12:19.040  - info: daswetter.0 (1573) still wrong data structure from server received! repaired...
            2022-07-23 17:12:19.872  - info: host.iobroker instance system.adapter.plenticore.0 started with pid 1863
            2022-07-23 17:12:21.457  - info: plenticore.0 (1863) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:21.478  - info: plenticore.0 (1863) [START] Starting adapter plenticore v2.2.0r237
            2022-07-23 17:12:21.529  - info: plenticore.0 (1863) Configured Wp of panel(s) is 0
            2022-07-23 17:12:21.530  - info: plenticore.0 (1863) [INFO] Configured polling interval: 20000
            2022-07-23 17:12:21.801  - info: web.0 (1377) ==> Connected system.user.admin from ::ffff:192.168.86.118
            2022-07-23 17:12:21.894  - info: plenticore.0 (1863) Not enabling forecast data.
            2022-07-23 17:12:21.895  - info: plenticore.0 (1863) Not enabling MinSoC forecast data.
            2022-07-23 17:12:22.606  - info: daswetter.0 (1573) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2022-07-23 17:12:23.115  - info: daswetter.0 (1573) cleaned everything up...
            2022-07-23 17:12:23.191  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-07-23 17:12:23.916  - info: host.iobroker instance system.adapter.jarvis.0 started with pid 2066
            2022-07-23 17:12:25.208  - info: jarvis.0 (2066) starting. Version 3.0.12-beta.3 (non-npm: Zefau/ioBroker.jarvis#bacd7221d9990610ee6c684e0ec6fddd397cde79) in /opt/iobroker/node_modules/iobroker.jarvis, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:25.258  - info: jarvis.0 (2066) Found Backups for layout.
            2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for styles.
            2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for settings.
            2022-07-23 17:12:25.261  - info: jarvis.0 (2066) Found Backups for widgets.
            2022-07-23 17:12:25.284  - info: jarvis.0 (2066) Found Backups for devices.
            2022-07-23 17:12:27.798  - info: host.iobroker instance system.adapter.yahka.0 started with pid 2140
            2022-07-23 17:12:29.202  - info: yahka.0 (2140) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.16.0, js-controller: 4.0.23
            2022-07-23 17:12:29.224  - info: yahka.0 (2140) adapter ready, checking config
            2022-07-23 17:12:29.232  - info: yahka.0 (2140) adding Wohnzimmer Heizung with UUID: 2521183a-dec7-421a-a763-c10f4be10961
            2022-07-23 17:12:29.237  - info: yahka.0 (2140) publishing bridge iobroker on 0.0.0.0 using ciao
            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            • stephan1827S stephan1827
              @glasfaser Habe den port von admin auch auf 8081 gesetzt aber dann geht weder die Visu noch das admmin interface. Ich bin nicht mehr sicher warum ich den Port geändert habe aber das ist schon ewig so.
              2022-07-23 17:09:49.538  - info: admin.0 (420) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:09:49.540  - info: admin.0 (420) terminating http server on port 8081
              2022-07-23 17:09:49.541  - info: admin.0 (420) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:09:49.578  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
              2022-07-23 17:09:50.141  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:09:52.669  - info: host.iobroker instance system.adapter.admin.0 started with pid 2639
              2022-07-23 17:09:54.032  - info: admin.0 (2639) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:09:54.069  - info: admin.0 (2639) requesting all states
              2022-07-23 17:09:54.070  - info: admin.0 (2639) requesting all objects
              2022-07-23 17:09:55.077  - info: admin.0 (2639) received all objects
              2022-07-23 17:09:55.248  - info: admin.0 (2639) http server listening on port 8083
              2022-07-23 17:09:55.248  - info: admin.0 (2639) Use link "http://localhost:8083" to configure.
              2022-07-23 17:10:11.142  - info: host.iobroker received SIGTERM
              2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
              2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
              2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=true)
              2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
              2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.hue.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.fritzbox.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ebus.0 (force=false, process=true)
              2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.info.0 (force=false, process=true)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-weather.0 (force=false, process=false)
              2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.daswetter.0 (force=false, process=false)
              2022-07-23 17:10:11.148  - info: host.iobroker stopInstance canceled schedule system.adapter.daswetter.0
              2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.systeminfo.0 (force=false, process=true)
              2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.bring.0 (force=false, process=true)
              2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.plenticore.0 (force=false, process=true)
              2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.vis-history.0 (force=false, process=false)
              2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=true)
              2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.yahka.0 (force=false, process=true)
              2022-07-23 17:10:11.154  - info: node-red.0 (477) kill node-red task
              2022-07-23 17:10:11.164  - info: admin.0 (2639) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.165  - info: admin.0 (2639) terminating http server on port 8083
              2022-07-23 17:10:11.166  - info: admin.0 (2639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.169  - info: javascript.0 (435) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.169  - info: pushover.0 (462) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.172  - info: hm-rpc.2 (603) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.170  - info: alexa2.0 (518) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.174  - info: ping.0 (675) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.174  - info: modbus.0 (633) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.175  - info: hm-rpc.1 (575) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.172  - info: alexa2.0 (518) terminating
              2022-07-23 17:10:11.173  - info: alexa2.0 (518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.178  - info: hue.0 (618) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.172  - info: hm-rpc.0 (560) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.179  - info: info.0 (723) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.178  - info: backitup.0 (693) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.180  - info: ebus.0 (708) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.171  - info: hm-rega.0 (545) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.181  - info: info.0 (723) cleaned everything up...
              2022-07-23 17:10:11.181  - info: info.0 (723) terminating
              2022-07-23 17:10:11.182  - info: info.0 (723) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.175  - info: fritzbox.0 (648) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.186  - info: bring.0 (1786) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.173  - info: hm-rpc.2 (603) binrpc -> 192.168.86.50:8701/ init ["xmlrpc_bin://192.168.86.35:8701",""]
              2022-07-23 17:10:11.185  - info: iot.0 (1129) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.187  - info: bring.0 (1786) [END] Stopping Bring! adapter...
              2022-07-23 17:10:11.188  - info: bring.0 (1786) terminating
              2022-07-23 17:10:11.188  - info: bring.0 (1786) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.185  - info: systeminfo.0 (1679) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.187  - info: systeminfo.0 (1679) terminating
              2022-07-23 17:10:11.188  - info: systeminfo.0 (1679) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.176  - info: hm-rpc.1 (575) xmlrpc -> 192.168.86.50:2010/ init ["http://192.168.86.35:2010",""]
              2022-07-23 17:10:11.179  - info: backitup.0 (693) cleaned everything up...
              2022-07-23 17:10:11.181  - info: backitup.0 (693) terminating
              2022-07-23 17:10:11.185  - info: backitup.0 (693) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.191  - info: plenticore.0 (1863) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.173  - info: hm-rpc.0 (560) xmlrpc -> 192.168.86.50:2001/ init ["http://192.168.86.35:2001",""]
              2022-07-23 17:10:11.181  - info: ebus.0 (708) cleaned everything up...
              2022-07-23 17:10:11.184  - info: ebus.0 (708) terminating
              2022-07-23 17:10:11.192  - info: ebus.0 (708) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.196  - info: node-red.0 (477) node-red exited with 0
              2022-07-23 17:10:11.183  - info: modbus.0 (633) terminating
              2022-07-23 17:10:11.192  - info: modbus.0 (633) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.194  - info: plenticore.0 (1863) [END] Stopping plenticore adapter...
              2022-07-23 17:10:11.195  - info: plenticore.0 (1863) terminating
              2022-07-23 17:10:11.196  - info: plenticore.0 (1863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.196  - info: iot.0 (1129) terminating
              2022-07-23 17:10:11.197  - info: iot.0 (1129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.194  - info: fritzbox.0 (648) terminating
              2022-07-23 17:10:11.200  - info: fritzbox.0 (648) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.201  - info: yahka.0 (2098) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.200  - info: jarvis.0 (2023) Got terminate signal TERMINATE_YOURSELF
              2022-07-23 17:10:11.193  - info: hm-rpc.2 (603) Disconnected
              2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaning up ...
              2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaned up ...
              2022-07-23 17:10:11.206  - info: yahka.0 (2098) terminating
              2022-07-23 17:10:11.207  - info: yahka.0 (2098) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.211  - info: hm-rpc.1 (575) Disconnected
              2022-07-23 17:10:11.207  - info: jarvis.0 (2023) Adapter stopped und unloaded.
              2022-07-23 17:10:11.207  - info: jarvis.0 (2023) terminating
              2022-07-23 17:10:11.209  - info: jarvis.0 (2023) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.213  - info: hm-rpc.1 (575) terminating
              2022-07-23 17:10:11.214  - info: hm-rpc.1 (575) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.219  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
              2022-07-23 17:10:11.220  - info: hm-rpc.0 (560) Disconnected
              2022-07-23 17:10:11.207  - info: hm-rpc.2 (603) terminating
              2022-07-23 17:10:11.208  - info: hm-rpc.2 (603) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
              2022-07-23 17:10:11.171  - info: javascript.0 (435) Stop script script.js.common.AlarmModus
              2022-07-23 17:10:11.190  - info: javascript.0 (435) Stop script script.js.common.Alexa
              2022-07-23 17:10:11.195  - info: javascript.0 (435) Stop script script.js.common.Solar
              2022-07-23 17:10:11.199  - info: javascript.0 (435) Stop script script.js.common.Homematic_Meldungen
              2022-07-23 17:10:11.220  - info: javascript.0 (435) Stop script script.js.common.Jarvis
              2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Zigbee
              2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Alarm
              2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.pushover.0 send kill signal
              2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
              2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal
              2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hue.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.fritzbox.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ping.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ebus.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.info.0 send kill signal
              2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
              2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.systeminfo.0 send kill signal
              2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.bring.0 send kill signal
              2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.plenticore.0 send kill signal
              2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.jarvis.0 send kill signal
              2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.yahka.0 send kill signal
              2022-07-23 17:10:11.230  - info: hue.0 (618) cleaned everything up...
              2022-07-23 17:10:11.231  - info: hue.0 (618) terminating
              2022-07-23 17:10:11.232  - info: hue.0 (618) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.221  - info: hm-rpc.0 (560) terminating
              2022-07-23 17:10:11.230  - info: hm-rpc.0 (560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.236  - info: javascript.0 (435) terminating
              2022-07-23 17:10:11.238  - info: javascript.0 (435) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.245  - info: hm-rega.0 (545) terminating
              2022-07-23 17:10:11.246  - info: hm-rega.0 (545) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.250  - info: plenticore.0 (1863) Logged out from API
              2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection changed: disconnect
              2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection lost
              2022-07-23 17:10:11.671  - info: pushover.0 (462) terminating
              2022-07-23 17:10:11.672  - info: pushover.0 (462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.676  - info: ping.0 (675) terminating
              2022-07-23 17:10:11.677  - info: ping.0 (675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-07-23 17:10:11.802  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.056  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.322  - info: history.0 (503) Terminated (NO_ERROR): Without reason
              2022-07-23 17:10:12.391  - info: host.iobroker stopInstance system.adapter.javascript.0 killing pid 435
              2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.pushover.0 killing pid 462
              2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rega.0 killing pid 545
              2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 killing pid 560
              2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 killing pid 575
              2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 killing pid 603
              2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hue.0 killing pid 618
              2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.ping.0 killing pid 675
              2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.jarvis.0 killing pid 2023
              2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.yahka.0 killing pid 2098
              2022-07-23 17:10:12.452  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.586  - info: host.iobroker instance system.adapter.ebus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.587  - info: host.iobroker instance system.adapter.systeminfo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.616  - info: host.iobroker instance system.adapter.bring.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.673  - info: pushover.0 (462) terminating with timeout
              2022-07-23 17:10:12.678  - info: ping.0 (675) terminating with timeout
              2022-07-23 17:10:12.638  - info: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.748  - info: host.iobroker instance system.adapter.plenticore.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:12.778  - info: host.iobroker instance system.adapter.fritzbox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.059  - info: host.iobroker instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.082  - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.186  - info: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.232  - info: host.iobroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.233  - info: host.iobroker instance system.adapter.jarvis.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.260  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.380  - info: host.iobroker instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.402  - info: host.iobroker instance system.adapter.ping.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:10:13.462  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
              2022-07-23 17:10:16.145  - info: host.iobroker stopInstance timeout 5000 system.adapter.node-red.0 killing pid  477
              2022-07-23 17:10:16.649  - info: node-red.0 (477) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2022-07-23 17:10:17.231  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2022-07-23 17:10:17.231  - info: host.iobroker All instances are stopped.
              2022-07-23 17:10:17.386  - info: host.iobroker terminated
              2022-07-23 17:10:42.082  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
              2022-07-23 17:10:42.085  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
              2022-07-23 17:10:42.086  - info: host.iobroker hostname: iobroker, node: v16.16.0
              2022-07-23 17:10:42.086  - info: host.iobroker ip addresses: 192.168.86.35 fe80::211:32ff:fee9:7b3f 172.17.0.1 fe80::42:1dff:fe89:d167 fe80::1821:8aff:fe81:9b4a
              2022-07-23 17:10:43.209  - info: host.iobroker connected to Objects and States
              2022-07-23 17:10:43.247  - info: host.iobroker added notifications configuration of host
              2022-07-23 17:10:43.733  - info: host.iobroker 40 instances found
              2022-07-23 17:10:43.767  - info: host.iobroker starting 30 instances
              2022-07-23 17:10:43.867  - info: host.iobroker instance system.adapter.admin.0 started with pid 419
              2022-07-23 17:10:45.168  - info: admin.0 (419) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:10:45.193  - info: admin.0 (419) requesting all states
              2022-07-23 17:10:45.194  - info: admin.0 (419) requesting all objects
              2022-07-23 17:10:46.268  - info: admin.0 (419) received all objects
              2022-07-23 17:10:46.474  - info: admin.0 (419) http server listening on port 8083
              2022-07-23 17:10:46.475  - info: admin.0 (419) Use link "http://localhost:8083" to configure.
              2022-07-23 17:10:47.948  - info: host.iobroker instance system.adapter.javascript.0 started with pid 434
              2022-07-23 17:10:49.737  - info: javascript.0 (434) starting. Version 5.7.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:10:50.576  - info: javascript.0 (434) requesting all states
              2022-07-23 17:10:50.577  - info: javascript.0 (434) requesting all objects
              2022-07-23 17:10:51.864  - info: host.iobroker instance system.adapter.pushover.0 started with pid 463
              2022-07-23 17:10:51.950  - info: javascript.0 (434) received all objects
              2022-07-23 17:10:51.964  - info: javascript.0 (434) received all states
              2022-07-23 17:10:52.007  - error: javascript.0 (434) The Mirror directory is not allowed to be a central ioBroker directory!
              2022-07-23 17:10:52.007  - error: javascript.0 (434) Directory /opt/iobroker/backups/scripte is not allowed to mirror files!
              2022-07-23 17:10:52.017  - info: javascript.0 (434) Start javascript script.js.common.AlarmModus
              2022-07-23 17:10:53.131  - info: pushover.0 (463) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:10:52.048  - info: javascript.0 (434) script.js.common.AlarmModus: registered 1 subscription and 0 schedules
              2022-07-23 17:10:52.048  - info: javascript.0 (434) Start javascript script.js.common.Alexa
              2022-07-23 17:10:52.054  - info: javascript.0 (434) script.js.common.Alexa: registered 13 subscriptions and 0 schedules
              2022-07-23 17:10:52.054  - info: javascript.0 (434) Start javascript script.js.common.Solar
              2022-07-23 17:10:52.115  - info: javascript.0 (434) script.js.common.Solar: registered 12 subscriptions and 10 schedules
              2022-07-23 17:10:52.116  - info: javascript.0 (434) Start javascript script.js.common.Homematic_Meldungen
              2022-07-23 17:10:53.529  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:10:53.530  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:10:53.531  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: registered 204 subscriptions and 1 schedule
              2022-07-23 17:10:53.651  - info: javascript.0 (434) Start javascript script.js.common.Jarvis
              2022-07-23 17:10:53.664  - info: javascript.0 (434) script.js.common.Jarvis: registered 30 subscriptions and 1 schedule
              2022-07-23 17:10:53.664  - info: javascript.0 (434) Start javascript script.js.common.Zigbee
              2022-07-23 17:10:53.668  - info: javascript.0 (434) script.js.common.Zigbee: registered 9 subscriptions and 0 schedules
              2022-07-23 17:10:53.673  - info: javascript.0 (434) Start javascript script.js.common.Alarm
              2022-07-23 17:10:53.677  - info: javascript.0 (434) script.js.common.Alarm: registered 17 subscriptions and 0 schedules
              2022-07-23 17:10:53.687  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:10:55.855  - info: host.iobroker instance system.adapter.node-red.0 started with pid 478
              2022-07-23 17:10:56.997  - info: node-red.0 (478) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:10:57.015  - info: node-red.0 (478) Requested NPM packages: ["node-red-contrib-bool-gate","node-red-contrib-azure-iot-hub"]
              2022-07-23 17:10:57.935  - info: node-red.0 (478) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
              2022-07-23 17:10:59.866  - info: host.iobroker instance system.adapter.history.0 started with pid 504
              2022-07-23 17:11:01.188  - warn: node-red.0 (478) 23 Jul 17:11:01 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
              2022-07-23 17:11:01.201  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iothub/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
              (Use `node --trace-deprecation ...` to show where the warning was created)
              2022-07-23 17:11:01.202  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
              (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-device-amqp-ws/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
              2022-07-23 17:11:01.207  - info: history.0 (504) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.history, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:01.349  - info: history.0 (504) enabled logging of hm-rega.0.18981 (Count=1), Alias=false
              2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.1981 (Count=2), Alias=false
              2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.2688 (Count=3), Alias=false
              2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.3039 (Count=4), Alias=false
              2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.9284 (Count=5), Alias=false
              2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.950 (Count=6), Alias=false
              2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.alarms (Count=7), Alias=false
              2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.maintenance (Count=8), Alias=false
              2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.ACTUAL_TEMPERATURE (Count=9), Alias=false
              2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.SET_TEMPERATURE (Count=10), Alias=false
              2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.VALVE_STATE (Count=11), Alias=false
              2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.ACTUAL_TEMPERATURE (Count=12), Alias=false
              2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.SET_TEMPERATURE (Count=13), Alias=false
              2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.VALVE_STATE (Count=14), Alias=false
              2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.ACTUAL_TEMPERATURE (Count=15), Alias=false
              2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.SET_TEMPERATURE (Count=16), Alias=false
              2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.VALVE_STATE (Count=17), Alias=false
              2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.ACTUAL_TEMPERATURE (Count=18), Alias=false
              2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.SET_TEMPERATURE (Count=19), Alias=false
              2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.VALVE_STATE (Count=20), Alias=false
              2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.ACTUAL_TEMPERATURE (Count=21), Alias=false
              2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.SET_TEMPERATURE (Count=22), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.VALVE_STATE (Count=23), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.HUMIDITY (Count=24), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.TEMPERATURE (Count=25), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.ACTUAL_TEMPERATURE (Count=26), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.SET_TEMPERATURE (Count=27), Alias=false
              2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.VALVE_STATE (Count=28), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.ACTUAL_TEMPERATURE (Count=29), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.SET_TEMPERATURE (Count=30), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.VALVE_STATE (Count=31), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.ACTUAL_TEMPERATURE (Count=32), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.SET_TEMPERATURE (Count=33), Alias=false
              2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.VALVE_STATE (Count=34), Alias=false
              2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.ACTUAL_TEMPERATURE (Count=35), Alias=false
              2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.SET_TEMPERATURE (Count=36), Alias=false
              2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.VALVE_STATE (Count=37), Alias=false
              2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22568 (Count=38), Alias=false
              2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22569 (Count=39), Alias=false
              2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.SET_POINT_TEMPERATURE (Count=40), Alias=false
              2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.LEVEL (Count=41), Alias=false
              2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.VALVE_STATE (Count=42), Alias=false
              2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.ACTUAL_TEMPERATURE (Count=43), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of daswetter.0.NextHours.Location_1.Day_1.current.temp_value (Count=44), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_DC_power (Count=45), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_AC_power (Count=46), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_AC_power (Count=47), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Grid (Count=48), Alias=false
              2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Grid (Count=49), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Used (Count=50), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used (Count=51), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used (Count=52), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used (Count=53), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used (Count=54), Alias=false
              2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_PV (Count=55), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV (Count=56), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV (Count=57), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV (Count=58), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid (Count=59), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid (Count=60), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid (Count=61), Alias=false
              2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid (Count=62), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid (Count=63), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid (Count=64), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid (Count=65), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid (Count=66), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark (Count=67), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark (Count=68), Alias=false
              2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark (Count=69), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark (Count=70), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV (Count=71), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark_Total (Count=72), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark_Total (Count=73), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark_Total (Count=74), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark_Total (Count=75), Alias=false
              2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used_Total (Count=76), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used_Total (Count=77), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used_Total (Count=78), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used_Total (Count=79), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV_Total (Count=80), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV_Total (Count=81), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV_Total (Count=82), Alias=false
              2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV_Total (Count=83), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid_Total (Count=84), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid_Total (Count=85), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid_Total (Count=86), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid_Total (Count=87), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid_Total (Count=88), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid_Total (Count=89), Alias=false
              2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid_Total (Count=90), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid_Total (Count=91), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_Percent (Count=92), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_Percent (Count=93), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro (Count=94), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro (Count=95), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro (Count=96), Alias=false
              2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro (Count=97), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro_Total (Count=98), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro_Total (Count=99), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro_Total (Count=100), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro_Total (Count=101), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Battery (Count=102), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Battery (Count=103), Alias=false
              2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery (Count=104), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery (Count=105), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery (Count=106), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery (Count=107), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery_Total (Count=108), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery_Total (Count=109), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery_Total (Count=110), Alias=false
              2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery_Total (Count=111), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery (Count=112), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery (Count=113), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery (Count=114), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery (Count=115), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery_Total (Count=116), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery_Total (Count=117), Alias=false
              2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery_Total (Count=118), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery_Total (Count=119), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower (Count=120), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower (Count=121), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower (Count=122), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower (Count=123), Alias=false
              2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower_Total (Count=124), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower_Total (Count=125), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower_Total (Count=126), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower_Total (Count=127), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Overpower (Count=128), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.SoC (Count=129), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.Charge_P (Count=130), Alias=false
              2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of jarvis.0.addNotification (Count=131), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.SET_POINT_TEMPERATURE (Count=132), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.LEVEL (Count=133), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.ACTUAL_TEMPERATURE (Count=134), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.kesseltemp.value (Count=135), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.boilertemp.value (Count=136), Alias=false
              2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.aussentemp.value (Count=137), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.kesselsolltemp.value (Count=138), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.aussentemp.value (Count=139), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.brauchwassersolltemp.value (Count=140), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.alive (Count=141), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.time (Count=142), Alias=false
              2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.alive (Count=143), Alias=false
              2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.time (Count=144), Alias=false
              2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.alive (Count=145), Alias=false
              2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.time (Count=146), Alias=false
              2022-07-23 17:11:03.858  - info: host.iobroker instance system.adapter.alexa2.0 started with pid 519
              2022-07-23 17:11:05.114  - info: alexa2.0 (519) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:07.862  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 546
              2022-07-23 17:11:08.321  - info: alexa2.0 (519) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2022-07-23 17:11:08.818  - info: alexa2.0 (519) Unknown Device, but enabling commands, Try it and report back if commands work.
              2022-07-23 17:11:08.818  - info: alexa2.0 (519) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
              2022-07-23 17:11:08.819  - info: alexa2.0 (519)     Device-type:A3EVMLQTU6WL1W (ARTHUR_TARGET,SUPPORTS_LOCALE_SWITCH,FLASH_BRIEFING,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SOUND_SETTINGS,VOLUME_SETTING,MICROPHONE,CHANGE_NAME,SHARKNADO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,EARCONS,BT_PAIRING_FLOW_V2,ASCENDING_ALARM_VOLUME,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,PAIR_BT_SINK,DIALOG_INTERFACE_VERSION,TIMERS_AND_ALARMS,SUPPORTS_LOCALE,SPEECH_RECOGNIZER_USS,ACTIVE_AFTER_FRO,REMINDERS)
              2022-07-23 17:11:09.337  - info: hm-rega.0 (546) starting. Version 3.0.40 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:09.476  - info: hm-rega.0 (546) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
              2022-07-23 17:11:09.541  - info: hm-rega.0 (546) ReGaHSS 192.168.86.50 up
              2022-07-23 17:11:10.216  - warn: hm-rega.0 (546) time difference local-ccu 55s
              2022-07-23 17:11:11.868  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 561
              2022-07-23 17:11:13.109  - info: hm-rega.0 (546) request state values
              2022-07-23 17:11:13.714  - info: hm-rpc.0 (561) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:13.887  - info: hm-rpc.0 (561) xmlrpc server is trying to listen on 192.168.86.35:2001
              2022-07-23 17:11:13.888  - info: hm-rpc.0 (561) xmlrpc client is trying to connect to 192.168.86.50:2001/ with ["http://192.168.86.35:2001","iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
              2022-07-23 17:11:13.939  - info: hm-rpc.0 (561) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
              2022-07-23 17:11:13.958  - info: hm-rpc.0 (561) xmlrpc <- listDevices ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
              2022-07-23 17:11:14.036  - info: hm-rpc.0 (561) xmlrpc -> 179 devices
              2022-07-23 17:11:14.096  - info: hm-rpc.0 (561) Connected
              2022-07-23 17:11:14.646  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ1773663.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
              2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:14.648  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.OEQ0669002.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
              2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.230  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.327  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.328  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0871224.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
              2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:15.878  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 576
              2022-07-23 17:11:15.957  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0401353.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
              2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:15.959  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
              2022-07-23 17:11:16.330  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:16.429  - info: hm-rega.0 (546) Updated all datapoints
              2022-07-23 17:11:16.524  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
              2022-07-23 17:11:16.698  - info: hm-rega.0 (546) added/updated 1 objects
              2022-07-23 17:11:16.729  - info: hm-rega.0 (546) got 42 variables
              2022-07-23 17:11:17.509  - info: hm-rega.0 (546) added/updated 42 variables
              2022-07-23 17:11:17.510  - info: hm-rega.0 (546) deleted 0 variables
              2022-07-23 17:11:17.538  - info: hm-rega.0 (546) got 48 programs
              2022-07-23 17:11:17.550  - info: hm-rpc.1 (576) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:17.692  - info: hm-rpc.1 (576) xmlrpc server is trying to listen on 192.168.86.35:2010
              2022-07-23 17:11:17.693  - info: hm-rpc.1 (576) xmlrpc client is trying to connect to 192.168.86.50:2010/ with ["http://192.168.86.35:2010","iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
              2022-07-23 17:11:17.727  - info: hm-rpc.1 (576) Connected
              2022-07-23 17:11:17.738  - info: hm-rpc.1 (576) xmlrpc <- listDevices ["iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
              2022-07-23 17:11:17.812  - info: hm-rpc.1 (576) xmlrpc -> 0 devices
              2022-07-23 17:11:18.291  - info: hm-rpc.1 (576) xmlrpc <- newDevices 212
              2022-07-23 17:11:18.366  - info: hm-rpc.1 (576) new HMIP devices/channels after filter: 0
              2022-07-23 17:11:18.422  - info: hm-rega.0 (546) added/updated 48 programs
              2022-07-23 17:11:18.423  - info: hm-rega.0 (546) deleted 0 programs
              2022-07-23 17:11:19.856  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 591
              2022-07-23 17:11:21.206  - info: hm-rpc.2 (591) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc server is trying to listen on 192.168.86.35:8701
              2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc client is trying to connect to 192.168.86.50:8701/ with ["xmlrpc_bin://192.168.86.35:8701","iobroker:hm-rpc.2:2a319a3ec7ec9ea22f86865c577e678a"]
              2022-07-23 17:11:21.426  - info: hm-rpc.2 (591) binrpc -> listDevices 36
              2022-07-23 17:11:21.477  - info: hm-rpc.2 (591) new CUxD devices/channels after filter: 0
              2022-07-23 17:11:21.479  - info: hm-rpc.2 (591) Connected
              2022-07-23 17:11:23.126  - info: alexa2.0 (519) Subscribing to states...
              2022-07-23 17:11:23.990  - info: host.iobroker instance system.adapter.hue.0 started with pid 619
              2022-07-23 17:11:25.440  - info: hue.0 (619) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.hue, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:25.634  - info: hue.0 (619) skip switch: Daylight.configured
              2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunriseoffset
              2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunsetoffset
              2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemode
              2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemodevalues
              2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemode
              2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemodevalues
              2022-07-23 17:11:25.641  - info: hue.0 (619) created/updated 4 sensor channels
              2022-07-23 17:11:25.769  - info: hue.0 (619) created/updated 11 light channels
              2022-07-23 17:11:25.773  - info: hue.0 (619) created/updated 6 groups channels
              2022-07-23 17:11:25.776  - info: hue.0 (619) created/updated 25 scenes
              2022-07-23 17:11:25.776  - info: hue.0 (619) creating/updating bridge device
              2022-07-23 17:11:27.861  - info: host.iobroker instance system.adapter.modbus.0 started with pid 634
              2022-07-23 17:11:29.078  - info: modbus.0 (634) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:29.343  - info: modbus.0 (634) Connected to slave 192.168.86.153
              2022-07-23 17:11:31.880  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 649
              2022-07-23 17:11:33.369  - info: fritzbox.0 (649) starting. Version 0.5.0 (non-npm: ruhr70/ioBroker.fritzbox) in /opt/iobroker/node_modules/iobroker.fritzbox, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:33.394  - info: fritzbox.0 (649) try to connect: 192.168.86.1
              2022-07-23 17:11:33.395  - info: fritzbox.0 (649) Trying to connect to TR-064: 192.168.86.1:49000
              2022-07-23 17:11:33.419  - info: fritzbox.0 (649) adapter connected to fritzbox: 192.168.86.1
              2022-07-23 17:11:34.488  - info: fritzbox.0 (649) Successfully connected to TR-064
              2022-07-23 17:11:34.599  - warn: fritzbox.0 (649) TR-064: Error reading files from dir /tam: Error: ENOENT: no such file or directory, scandir 'tam'
              2022-07-23 17:11:35.861  - info: host.iobroker instance system.adapter.ping.0 started with pid 677
              2022-07-23 17:11:37.074  - info: ping.0 (677) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:37.183  - warn: ping.0 (677) Object ping.0.iobroker.Repeater3000. is invalid: obj.type has to exist
              2022-07-23 17:11:37.183  - warn: ping.0 (677) This object will not be created in future versions. Please report this to the developer.
              2022-07-23 17:11:37.184  - error: ping.0 (677) Cannot update channel : ping.0.iobroker.Repeater3000 Error: Error: The id "ping.0.iobroker.Repeater3000." is invalid. Ids are not allowed to end in "."
              2022-07-23 17:11:39.863  - info: host.iobroker instance system.adapter.backitup.0 started with pid 695
              2022-07-23 17:11:41.163  - info: backitup.0 (695) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:41.222  - info: backitup.0 (695) [iobroker] backup was activated at 02:00 every 3 day(s)
              2022-07-23 17:11:41.260  - info: backitup.0 (695) [ccu] backup was activated at 01:30 every 7 day(s)
              2022-07-23 17:11:43.860  - info: host.iobroker instance system.adapter.ebus.0 started with pid 710
              2022-07-23 17:11:45.187  - info: ebus.0 (710) starting. Version 3.0.2 (non-npm: rg-engineering/ioBroker.ebus) in /opt/iobroker/node_modules/iobroker.ebus, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:47.860  - info: host.iobroker instance system.adapter.info.0 started with pid 725
              2022-07-23 17:11:49.855  - info: info.0 (725) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:49.916  - info: info.0 (725) Reading/updating systemdata.
              2022-07-23 17:11:50.375  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
              2022-07-23 17:11:50.399  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
              2022-07-23 17:11:50.444  - info: info.0 (725) Reading CPU data every 3 seconds.
              2022-07-23 17:11:50.510  - info: info.0 (725) cpu Temp res = {"main":46,"cores":[47,47,48,49],"max":49,"socket":[],"chipset":null}
              2022-07-23 17:11:50.528  - info: info.0 (725) Reading CPU temp data every 3 seconds.
              2022-07-23 17:11:50.546  - info: info.0 (725) Reading CPU current speed every 3 seconds.
              2022-07-23 17:11:50.579  - info: info.0 (725) Reading memory data every 3 seconds.
              2022-07-23 17:11:50.668  - info: info.0 (725) Reading battery data every 8 seconds.
              2022-07-23 17:11:51.085  - info: info.0 (725) Reading user data every 8 seconds.
              2022-07-23 17:11:51.159  - info: info.0 (725) Reading process data every 8 seconds.
              2022-07-23 17:11:51.660  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev4.size" has to be type "string" but received type "number"
              2022-07-23 17:11:51.663  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
              2022-07-23 17:11:51.664  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev1.size" has to be type "string" but received type "number"
              2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev2.size" has to be type "string" but received type "number"
              2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev3.size" has to be type "string" but received type "number"
              2022-07-23 17:11:51.691  - info: info.0 (725) Reading disk data every 8 seconds.
              2022-07-23 17:11:51.862  - info: host.iobroker instance system.adapter.iot.0 started with pid 1109
              2022-07-23 17:11:52.318  - info: info.0 (725) Reading network data every 3 seconds.
              2022-07-23 17:11:53.362  - info: iot.0 (1109) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.iot, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:53.400  - info: iot.0 (1109) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2022-07-23 17:11:53.698  - info: iot.0 (1109) Connection changed: connect
              2022-07-23 17:11:57.012  - info: vis.0 (1230) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:11:57.181  - info: vis.0 (1230) vis license is OK.
              2022-07-23 17:11:57.982  - info: vis.0 (1230) Terminated (NO_ERROR): Without reason
              2022-07-23 17:11:58.572  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
              2022-07-23 17:11:59.856  - info: host.iobroker instance system.adapter.web.0 started with pid 1377
              2022-07-23 17:12:01.178  - info: web.0 (1377) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:01.332  - info: web.0 (1377) socket.io server listening on port 8081
              2022-07-23 17:12:01.335  - info: web.0 (1377) http server listening on port 8081
              2022-07-23 17:12:04.949  - info: vis-google-fonts.0 (1444) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:05.540  - info: vis-google-fonts.0 (1444) Terminated (NO_ERROR): Without reason
              2022-07-23 17:12:06.133  - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
              2022-07-23 17:12:07.867  - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * *
              2022-07-23 17:12:07.889  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 1573
              2022-07-23 17:12:09.198  - info: daswetter.0 (1573) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:11.797  - info: host.iobroker instance system.adapter.systeminfo.0 started with pid 1679
              2022-07-23 17:12:13.193  - info: systeminfo.0 (1679) starting. Version 0.3.0 (non-npm: frankjoke/ioBroker.systeminfo) in /opt/iobroker/node_modules/iobroker.systeminfo, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:14.173  - info: systeminfo.0 (1679) Startup Systeminfo Adapter systeminfo.0: {  startup: '',  items: [    {      name: 'Piko.[Type/Value]',      type: 'web',      source: 'http://192.168.86.157/measurements.xml',      regexp: "Device.Measurements.Measurement[?(@.Type=='AC_Power' || @.Type=='DC_Voltage' || @.Type=='DC_Current')]",      conv: 'xml',      role: 'number',      write: '',      sched: '*/10 * * * * *'    }  ],  lang: 'de',  latitude: 51.9793,  longitude: 7.7942}
              2022-07-23 17:12:14.309  - info: systeminfo.0 (1679) Adapter systeminfo.0 started and found 1/3 items/states to process.
              2022-07-23 17:12:15.864  - info: host.iobroker instance system.adapter.bring.0 started with pid 1787
              2022-07-23 17:12:17.300  - info: bring.0 (1787) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:17.791  - info: bring.0 (1787) [LOGIN] Successfully logged in as stephan
              2022-07-23 17:12:19.040  - info: daswetter.0 (1573) still wrong data structure from server received! repaired...
              2022-07-23 17:12:19.872  - info: host.iobroker instance system.adapter.plenticore.0 started with pid 1863
              2022-07-23 17:12:21.457  - info: plenticore.0 (1863) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:21.478  - info: plenticore.0 (1863) [START] Starting adapter plenticore v2.2.0r237
              2022-07-23 17:12:21.529  - info: plenticore.0 (1863) Configured Wp of panel(s) is 0
              2022-07-23 17:12:21.530  - info: plenticore.0 (1863) [INFO] Configured polling interval: 20000
              2022-07-23 17:12:21.801  - info: web.0 (1377) ==> Connected system.user.admin from ::ffff:192.168.86.118
              2022-07-23 17:12:21.894  - info: plenticore.0 (1863) Not enabling forecast data.
              2022-07-23 17:12:21.895  - info: plenticore.0 (1863) Not enabling MinSoC forecast data.
              2022-07-23 17:12:22.606  - info: daswetter.0 (1573) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2022-07-23 17:12:23.115  - info: daswetter.0 (1573) cleaned everything up...
              2022-07-23 17:12:23.191  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-07-23 17:12:23.916  - info: host.iobroker instance system.adapter.jarvis.0 started with pid 2066
              2022-07-23 17:12:25.208  - info: jarvis.0 (2066) starting. Version 3.0.12-beta.3 (non-npm: Zefau/ioBroker.jarvis#bacd7221d9990610ee6c684e0ec6fddd397cde79) in /opt/iobroker/node_modules/iobroker.jarvis, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:25.258  - info: jarvis.0 (2066) Found Backups for layout.
              2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for styles.
              2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for settings.
              2022-07-23 17:12:25.261  - info: jarvis.0 (2066) Found Backups for widgets.
              2022-07-23 17:12:25.284  - info: jarvis.0 (2066) Found Backups for devices.
              2022-07-23 17:12:27.798  - info: host.iobroker instance system.adapter.yahka.0 started with pid 2140
              2022-07-23 17:12:29.202  - info: yahka.0 (2140) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.16.0, js-controller: 4.0.23
              2022-07-23 17:12:29.224  - info: yahka.0 (2140) adapter ready, checking config
              2022-07-23 17:12:29.232  - info: yahka.0 (2140) adding Wohnzimmer Heizung with UUID: 2521183a-dec7-421a-a763-c10f4be10961
              2022-07-23 17:12:29.237  - info: yahka.0 (2140) publishing bridge iobroker on 0.0.0.0 using ciao
              @stephan1827 sagte in admin interface leer:
              Ändern, mit dem jetzigen Setup läufst du Gefahr da Schleifen anzulegen.
              stephan1827S 1 Antwort Letzte Antwort
              • stephan1827S stephan1827
                @glasfaser Habe den port von admin auch auf 8081 gesetzt aber dann geht weder die Visu noch das admmin interface. Ich bin nicht mehr sicher warum ich den Port geändert habe aber das ist schon ewig so.
                2022-07-23 17:09:49.538  - info: admin.0 (420) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:09:49.540  - info: admin.0 (420) terminating http server on port 8081
                2022-07-23 17:09:49.541  - info: admin.0 (420) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:09:49.578  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                2022-07-23 17:09:50.141  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:09:52.669  - info: host.iobroker instance system.adapter.admin.0 started with pid 2639
                2022-07-23 17:09:54.032  - info: admin.0 (2639) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:09:54.069  - info: admin.0 (2639) requesting all states
                2022-07-23 17:09:54.070  - info: admin.0 (2639) requesting all objects
                2022-07-23 17:09:55.077  - info: admin.0 (2639) received all objects
                2022-07-23 17:09:55.248  - info: admin.0 (2639) http server listening on port 8083
                2022-07-23 17:09:55.248  - info: admin.0 (2639) Use link "http://localhost:8083" to configure.
                2022-07-23 17:10:11.142  - info: host.iobroker received SIGTERM
                2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-07-23 17:10:11.143  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=true)
                2022-07-23 17:10:11.144  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
                2022-07-23 17:10:11.145  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.hue.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.fritzbox.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.ebus.0 (force=false, process=true)
                2022-07-23 17:10:11.146  - info: host.iobroker stopInstance system.adapter.info.0 (force=false, process=true)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.vis-weather.0 (force=false, process=false)
                2022-07-23 17:10:11.147  - info: host.iobroker stopInstance system.adapter.daswetter.0 (force=false, process=false)
                2022-07-23 17:10:11.148  - info: host.iobroker stopInstance canceled schedule system.adapter.daswetter.0
                2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.systeminfo.0 (force=false, process=true)
                2022-07-23 17:10:11.148  - info: host.iobroker stopInstance system.adapter.bring.0 (force=false, process=true)
                2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.plenticore.0 (force=false, process=true)
                2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.vis-history.0 (force=false, process=false)
                2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=true)
                2022-07-23 17:10:11.149  - info: host.iobroker stopInstance system.adapter.yahka.0 (force=false, process=true)
                2022-07-23 17:10:11.154  - info: node-red.0 (477) kill node-red task
                2022-07-23 17:10:11.164  - info: admin.0 (2639) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.165  - info: admin.0 (2639) terminating http server on port 8083
                2022-07-23 17:10:11.166  - info: admin.0 (2639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.169  - info: javascript.0 (435) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.169  - info: pushover.0 (462) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.172  - info: hm-rpc.2 (603) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.170  - info: alexa2.0 (518) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.174  - info: ping.0 (675) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.174  - info: modbus.0 (633) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.175  - info: hm-rpc.1 (575) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.172  - info: alexa2.0 (518) terminating
                2022-07-23 17:10:11.173  - info: alexa2.0 (518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.178  - info: hue.0 (618) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.172  - info: hm-rpc.0 (560) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.179  - info: info.0 (723) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.178  - info: backitup.0 (693) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.180  - info: ebus.0 (708) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.171  - info: hm-rega.0 (545) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.181  - info: info.0 (723) cleaned everything up...
                2022-07-23 17:10:11.181  - info: info.0 (723) terminating
                2022-07-23 17:10:11.182  - info: info.0 (723) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.175  - info: fritzbox.0 (648) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.186  - info: bring.0 (1786) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.173  - info: hm-rpc.2 (603) binrpc -> 192.168.86.50:8701/ init ["xmlrpc_bin://192.168.86.35:8701",""]
                2022-07-23 17:10:11.185  - info: iot.0 (1129) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.187  - info: bring.0 (1786) [END] Stopping Bring! adapter...
                2022-07-23 17:10:11.188  - info: bring.0 (1786) terminating
                2022-07-23 17:10:11.188  - info: bring.0 (1786) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.185  - info: systeminfo.0 (1679) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.187  - info: systeminfo.0 (1679) terminating
                2022-07-23 17:10:11.188  - info: systeminfo.0 (1679) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.176  - info: hm-rpc.1 (575) xmlrpc -> 192.168.86.50:2010/ init ["http://192.168.86.35:2010",""]
                2022-07-23 17:10:11.179  - info: backitup.0 (693) cleaned everything up...
                2022-07-23 17:10:11.181  - info: backitup.0 (693) terminating
                2022-07-23 17:10:11.185  - info: backitup.0 (693) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.191  - info: plenticore.0 (1863) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.173  - info: hm-rpc.0 (560) xmlrpc -> 192.168.86.50:2001/ init ["http://192.168.86.35:2001",""]
                2022-07-23 17:10:11.181  - info: ebus.0 (708) cleaned everything up...
                2022-07-23 17:10:11.184  - info: ebus.0 (708) terminating
                2022-07-23 17:10:11.192  - info: ebus.0 (708) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.196  - info: node-red.0 (477) node-red exited with 0
                2022-07-23 17:10:11.183  - info: modbus.0 (633) terminating
                2022-07-23 17:10:11.192  - info: modbus.0 (633) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.194  - info: plenticore.0 (1863) [END] Stopping plenticore adapter...
                2022-07-23 17:10:11.195  - info: plenticore.0 (1863) terminating
                2022-07-23 17:10:11.196  - info: plenticore.0 (1863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.196  - info: iot.0 (1129) terminating
                2022-07-23 17:10:11.197  - info: iot.0 (1129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.194  - info: fritzbox.0 (648) terminating
                2022-07-23 17:10:11.200  - info: fritzbox.0 (648) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.201  - info: yahka.0 (2098) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.200  - info: jarvis.0 (2023) Got terminate signal TERMINATE_YOURSELF
                2022-07-23 17:10:11.193  - info: hm-rpc.2 (603) Disconnected
                2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaning up ...
                2022-07-23 17:10:11.204  - info: yahka.0 (2098) cleaned up ...
                2022-07-23 17:10:11.206  - info: yahka.0 (2098) terminating
                2022-07-23 17:10:11.207  - info: yahka.0 (2098) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.211  - info: hm-rpc.1 (575) Disconnected
                2022-07-23 17:10:11.207  - info: jarvis.0 (2023) Adapter stopped und unloaded.
                2022-07-23 17:10:11.207  - info: jarvis.0 (2023) terminating
                2022-07-23 17:10:11.209  - info: jarvis.0 (2023) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.213  - info: hm-rpc.1 (575) terminating
                2022-07-23 17:10:11.214  - info: hm-rpc.1 (575) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.219  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                2022-07-23 17:10:11.220  - info: hm-rpc.0 (560) Disconnected
                2022-07-23 17:10:11.207  - info: hm-rpc.2 (603) terminating
                2022-07-23 17:10:11.208  - info: hm-rpc.2 (603) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                2022-07-23 17:10:11.171  - info: javascript.0 (435) Stop script script.js.common.AlarmModus
                2022-07-23 17:10:11.190  - info: javascript.0 (435) Stop script script.js.common.Alexa
                2022-07-23 17:10:11.195  - info: javascript.0 (435) Stop script script.js.common.Solar
                2022-07-23 17:10:11.199  - info: javascript.0 (435) Stop script script.js.common.Homematic_Meldungen
                2022-07-23 17:10:11.220  - info: javascript.0 (435) Stop script script.js.common.Jarvis
                2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Zigbee
                2022-07-23 17:10:11.226  - info: javascript.0 (435) Stop script script.js.common.Alarm
                2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.pushover.0 send kill signal
                2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
                2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal
                2022-07-23 17:10:11.225  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.hue.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.fritzbox.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ping.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.ebus.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.info.0 send kill signal
                2022-07-23 17:10:11.226  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
                2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.systeminfo.0 send kill signal
                2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.bring.0 send kill signal
                2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.plenticore.0 send kill signal
                2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.jarvis.0 send kill signal
                2022-07-23 17:10:11.227  - info: host.iobroker stopInstance system.adapter.yahka.0 send kill signal
                2022-07-23 17:10:11.230  - info: hue.0 (618) cleaned everything up...
                2022-07-23 17:10:11.231  - info: hue.0 (618) terminating
                2022-07-23 17:10:11.232  - info: hue.0 (618) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.221  - info: hm-rpc.0 (560) terminating
                2022-07-23 17:10:11.230  - info: hm-rpc.0 (560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.236  - info: javascript.0 (435) terminating
                2022-07-23 17:10:11.238  - info: javascript.0 (435) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.245  - info: hm-rega.0 (545) terminating
                2022-07-23 17:10:11.246  - info: hm-rega.0 (545) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.250  - info: plenticore.0 (1863) Logged out from API
                2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection changed: disconnect
                2022-07-23 17:10:11.251  - info: iot.0 (1129) Connection lost
                2022-07-23 17:10:11.671  - info: pushover.0 (462) terminating
                2022-07-23 17:10:11.672  - info: pushover.0 (462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.676  - info: ping.0 (675) terminating
                2022-07-23 17:10:11.677  - info: ping.0 (675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-07-23 17:10:11.802  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.056  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.159  - info: host.iobroker instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.322  - info: history.0 (503) Terminated (NO_ERROR): Without reason
                2022-07-23 17:10:12.391  - info: host.iobroker stopInstance system.adapter.javascript.0 killing pid 435
                2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.pushover.0 killing pid 462
                2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rega.0 killing pid 545
                2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.0 killing pid 560
                2022-07-23 17:10:12.392  - info: host.iobroker stopInstance system.adapter.hm-rpc.1 killing pid 575
                2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hm-rpc.2 killing pid 603
                2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.hue.0 killing pid 618
                2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.ping.0 killing pid 675
                2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.jarvis.0 killing pid 2023
                2022-07-23 17:10:12.393  - info: host.iobroker stopInstance system.adapter.yahka.0 killing pid 2098
                2022-07-23 17:10:12.452  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.586  - info: host.iobroker instance system.adapter.ebus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.587  - info: host.iobroker instance system.adapter.systeminfo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.616  - info: host.iobroker instance system.adapter.bring.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.673  - info: pushover.0 (462) terminating with timeout
                2022-07-23 17:10:12.678  - info: ping.0 (675) terminating with timeout
                2022-07-23 17:10:12.638  - info: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.748  - info: host.iobroker instance system.adapter.plenticore.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:12.778  - info: host.iobroker instance system.adapter.fritzbox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.059  - info: host.iobroker instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.082  - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.165  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.186  - info: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.232  - info: host.iobroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.233  - info: host.iobroker instance system.adapter.jarvis.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.260  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.380  - info: host.iobroker instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.402  - info: host.iobroker instance system.adapter.ping.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:10:13.462  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                2022-07-23 17:10:16.145  - info: host.iobroker stopInstance timeout 5000 system.adapter.node-red.0 killing pid  477
                2022-07-23 17:10:16.649  - info: node-red.0 (477) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2022-07-23 17:10:17.231  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2022-07-23 17:10:17.231  - info: host.iobroker All instances are stopped.
                2022-07-23 17:10:17.386  - info: host.iobroker terminated
                2022-07-23 17:10:42.082  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
                2022-07-23 17:10:42.085  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-07-23 17:10:42.086  - info: host.iobroker hostname: iobroker, node: v16.16.0
                2022-07-23 17:10:42.086  - info: host.iobroker ip addresses: 192.168.86.35 fe80::211:32ff:fee9:7b3f 172.17.0.1 fe80::42:1dff:fe89:d167 fe80::1821:8aff:fe81:9b4a
                2022-07-23 17:10:43.209  - info: host.iobroker connected to Objects and States
                2022-07-23 17:10:43.247  - info: host.iobroker added notifications configuration of host
                2022-07-23 17:10:43.733  - info: host.iobroker 40 instances found
                2022-07-23 17:10:43.767  - info: host.iobroker starting 30 instances
                2022-07-23 17:10:43.867  - info: host.iobroker instance system.adapter.admin.0 started with pid 419
                2022-07-23 17:10:45.168  - info: admin.0 (419) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:10:45.193  - info: admin.0 (419) requesting all states
                2022-07-23 17:10:45.194  - info: admin.0 (419) requesting all objects
                2022-07-23 17:10:46.268  - info: admin.0 (419) received all objects
                2022-07-23 17:10:46.474  - info: admin.0 (419) http server listening on port 8083
                2022-07-23 17:10:46.475  - info: admin.0 (419) Use link "http://localhost:8083" to configure.
                2022-07-23 17:10:47.948  - info: host.iobroker instance system.adapter.javascript.0 started with pid 434
                2022-07-23 17:10:49.737  - info: javascript.0 (434) starting. Version 5.7.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:10:50.576  - info: javascript.0 (434) requesting all states
                2022-07-23 17:10:50.577  - info: javascript.0 (434) requesting all objects
                2022-07-23 17:10:51.864  - info: host.iobroker instance system.adapter.pushover.0 started with pid 463
                2022-07-23 17:10:51.950  - info: javascript.0 (434) received all objects
                2022-07-23 17:10:51.964  - info: javascript.0 (434) received all states
                2022-07-23 17:10:52.007  - error: javascript.0 (434) The Mirror directory is not allowed to be a central ioBroker directory!
                2022-07-23 17:10:52.007  - error: javascript.0 (434) Directory /opt/iobroker/backups/scripte is not allowed to mirror files!
                2022-07-23 17:10:52.017  - info: javascript.0 (434) Start javascript script.js.common.AlarmModus
                2022-07-23 17:10:53.131  - info: pushover.0 (463) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:10:52.048  - info: javascript.0 (434) script.js.common.AlarmModus: registered 1 subscription and 0 schedules
                2022-07-23 17:10:52.048  - info: javascript.0 (434) Start javascript script.js.common.Alexa
                2022-07-23 17:10:52.054  - info: javascript.0 (434) script.js.common.Alexa: registered 13 subscriptions and 0 schedules
                2022-07-23 17:10:52.054  - info: javascript.0 (434) Start javascript script.js.common.Solar
                2022-07-23 17:10:52.115  - info: javascript.0 (434) script.js.common.Solar: registered 12 subscriptions and 10 schedules
                2022-07-23 17:10:52.116  - info: javascript.0 (434) Start javascript script.js.common.Homematic_Meldungen
                2022-07-23 17:10:53.529  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:10:53.530  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:10:53.531  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: registered 204 subscriptions and 1 schedule
                2022-07-23 17:10:53.651  - info: javascript.0 (434) Start javascript script.js.common.Jarvis
                2022-07-23 17:10:53.664  - info: javascript.0 (434) script.js.common.Jarvis: registered 30 subscriptions and 1 schedule
                2022-07-23 17:10:53.664  - info: javascript.0 (434) Start javascript script.js.common.Zigbee
                2022-07-23 17:10:53.668  - info: javascript.0 (434) script.js.common.Zigbee: registered 9 subscriptions and 0 schedules
                2022-07-23 17:10:53.673  - info: javascript.0 (434) Start javascript script.js.common.Alarm
                2022-07-23 17:10:53.677  - info: javascript.0 (434) script.js.common.Alarm: registered 17 subscriptions and 0 schedules
                2022-07-23 17:10:53.687  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:10:55.855  - info: host.iobroker instance system.adapter.node-red.0 started with pid 478
                2022-07-23 17:10:56.997  - info: node-red.0 (478) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:10:57.015  - info: node-red.0 (478) Requested NPM packages: ["node-red-contrib-bool-gate","node-red-contrib-azure-iot-hub"]
                2022-07-23 17:10:57.935  - info: node-red.0 (478) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                2022-07-23 17:10:59.866  - info: host.iobroker instance system.adapter.history.0 started with pid 504
                2022-07-23 17:11:01.188  - warn: node-red.0 (478) 23 Jul 17:11:01 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                2022-07-23 17:11:01.201  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iothub/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
                (Use `node --trace-deprecation ...` to show where the warning was created)
                2022-07-23 17:11:01.202  - warn: node-red.0 (478) (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
                (node:493) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/azure-iot-device-amqp-ws/node_modules/azure-iot-amqp-base/package.json' of 'main.js'. Please either fix that or report it to the module author
                2022-07-23 17:11:01.207  - info: history.0 (504) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.history, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:01.349  - info: history.0 (504) enabled logging of hm-rega.0.18981 (Count=1), Alias=false
                2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.1981 (Count=2), Alias=false
                2022-07-23 17:11:01.350  - info: history.0 (504) enabled logging of hm-rega.0.2688 (Count=3), Alias=false
                2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.3039 (Count=4), Alias=false
                2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.9284 (Count=5), Alias=false
                2022-07-23 17:11:01.351  - info: history.0 (504) enabled logging of hm-rega.0.950 (Count=6), Alias=false
                2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.alarms (Count=7), Alias=false
                2022-07-23 17:11:01.352  - info: history.0 (504) enabled logging of hm-rega.0.maintenance (Count=8), Alias=false
                2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.ACTUAL_TEMPERATURE (Count=9), Alias=false
                2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.SET_TEMPERATURE (Count=10), Alias=false
                2022-07-23 17:11:01.353  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871169.4.VALVE_STATE (Count=11), Alias=false
                2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.ACTUAL_TEMPERATURE (Count=12), Alias=false
                2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.SET_TEMPERATURE (Count=13), Alias=false
                2022-07-23 17:11:01.354  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871170.4.VALVE_STATE (Count=14), Alias=false
                2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.ACTUAL_TEMPERATURE (Count=15), Alias=false
                2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.SET_TEMPERATURE (Count=16), Alias=false
                2022-07-23 17:11:01.355  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871175.4.VALVE_STATE (Count=17), Alias=false
                2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.ACTUAL_TEMPERATURE (Count=18), Alias=false
                2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.SET_TEMPERATURE (Count=19), Alias=false
                2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ0871224.4.VALVE_STATE (Count=20), Alias=false
                2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.ACTUAL_TEMPERATURE (Count=21), Alias=false
                2022-07-23 17:11:01.356  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.SET_TEMPERATURE (Count=22), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.NEQ1773663.4.VALVE_STATE (Count=23), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.HUMIDITY (Count=24), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0160601.1.TEMPERATURE (Count=25), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.ACTUAL_TEMPERATURE (Count=26), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.SET_TEMPERATURE (Count=27), Alias=false
                2022-07-23 17:11:01.357  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0239290.4.VALVE_STATE (Count=28), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.ACTUAL_TEMPERATURE (Count=29), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.SET_TEMPERATURE (Count=30), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0661458.4.VALVE_STATE (Count=31), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.ACTUAL_TEMPERATURE (Count=32), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.SET_TEMPERATURE (Count=33), Alias=false
                2022-07-23 17:11:01.358  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0668242.4.VALVE_STATE (Count=34), Alias=false
                2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.ACTUAL_TEMPERATURE (Count=35), Alias=false
                2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.SET_TEMPERATURE (Count=36), Alias=false
                2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rpc.0.OEQ0669002.4.VALVE_STATE (Count=37), Alias=false
                2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22568 (Count=38), Alias=false
                2022-07-23 17:11:01.359  - info: history.0 (504) enabled logging of hm-rega.0.22569 (Count=39), Alias=false
                2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.SET_POINT_TEMPERATURE (Count=40), Alias=false
                2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.LEVEL (Count=41), Alias=false
                2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.VALVE_STATE (Count=42), Alias=false
                2022-07-23 17:11:01.360  - info: history.0 (504) enabled logging of hm-rpc.1.00201A49A02B30.1.ACTUAL_TEMPERATURE (Count=43), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of daswetter.0.NextHours.Location_1.Day_1.current.temp_value (Count=44), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_DC_power (Count=45), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_AC_power (Count=46), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_AC_power (Count=47), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Grid (Count=48), Alias=false
                2022-07-23 17:11:01.361  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Grid (Count=49), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Used (Count=50), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used (Count=51), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used (Count=52), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used (Count=53), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used (Count=54), Alias=false
                2022-07-23 17:11:01.362  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_PV (Count=55), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV (Count=56), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV (Count=57), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV (Count=58), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid (Count=59), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid (Count=60), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid (Count=61), Alias=false
                2022-07-23 17:11:01.363  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid (Count=62), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid (Count=63), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid (Count=64), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid (Count=65), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid (Count=66), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark (Count=67), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark (Count=68), Alias=false
                2022-07-23 17:11:01.364  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark (Count=69), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark (Count=70), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV (Count=71), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Autark_Total (Count=72), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Autark_Total (Count=73), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Autark_Total (Count=74), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Autark_Total (Count=75), Alias=false
                2022-07-23 17:11:01.365  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Used_Total (Count=76), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Used_Total (Count=77), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Used_Total (Count=78), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Used_Total (Count=79), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_PV_Total (Count=80), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_PV_Total (Count=81), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_PV_Total (Count=82), Alias=false
                2022-07-23 17:11:01.366  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_PV_Total (Count=83), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Grid_Total (Count=84), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Grid_Total (Count=85), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Grid_Total (Count=86), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Grid_Total (Count=87), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Grid_Total (Count=88), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Grid_Total (Count=89), Alias=false
                2022-07-23 17:11:01.367  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Grid_Total (Count=90), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Grid_Total (Count=91), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Piko_Percent (Count=92), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Plenticore_Percent (Count=93), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro (Count=94), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro (Count=95), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro (Count=96), Alias=false
                2022-07-23 17:11:01.368  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro (Count=97), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_Euro_Total (Count=98), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_Euro_Total (Count=99), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_Euro_Total (Count=100), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_Euro_Total (Count=101), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_From_Battery (Count=102), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_To_Battery (Count=103), Alias=false
                2022-07-23 17:11:01.369  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery (Count=104), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery (Count=105), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery (Count=106), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery (Count=107), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_To_Battery_Total (Count=108), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_To_Battery_Total (Count=109), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_To_Battery_Total (Count=110), Alias=false
                2022-07-23 17:11:01.370  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_To_Battery_Total (Count=111), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery (Count=112), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery (Count=113), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery (Count=114), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery (Count=115), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Battery_Total (Count=116), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Battery_Total (Count=117), Alias=false
                2022-07-23 17:11:01.371  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Battery_Total (Count=118), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Battery_Total (Count=119), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower (Count=120), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower (Count=121), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower (Count=122), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower (Count=123), Alias=false
                2022-07-23 17:11:01.372  - info: history.0 (504) enabled logging of javascript.0.Solar.Daily_From_Overpower_Total (Count=124), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Weekly_From_Overpower_Total (Count=125), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Monthly_From_Overpower_Total (Count=126), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Yearly_From_Overpower_Total (Count=127), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of javascript.0.Solar.Power_Overpower (Count=128), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.SoC (Count=129), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of plenticore.0.devices.local.battery.Charge_P (Count=130), Alias=false
                2022-07-23 17:11:01.373  - info: history.0 (504) enabled logging of jarvis.0.addNotification (Count=131), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.SET_POINT_TEMPERATURE (Count=132), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.LEVEL (Count=133), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of hm-rpc.1.00201D89A26CC9.1.ACTUAL_TEMPERATURE (Count=134), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.kesseltemp.value (Count=135), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.boilertemp.value (Count=136), Alias=false
                2022-07-23 17:11:01.374  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.betrd.fields.aussentemp.value (Count=137), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.kesselsolltemp.value (Count=138), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.aussentemp.value (Count=139), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ebus.0.broadcast.messages.sollw.fields.brauchwassersolltemp.value (Count=140), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.alive (Count=141), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1200.time (Count=142), Alias=false
                2022-07-23 17:11:01.375  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.alive (Count=143), Alias=false
                2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater1750.time (Count=144), Alias=false
                2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.alive (Count=145), Alias=false
                2022-07-23 17:11:01.376  - info: history.0 (504) enabled logging of ping.0.iobroker.Repeater3000.time (Count=146), Alias=false
                2022-07-23 17:11:03.858  - info: host.iobroker instance system.adapter.alexa2.0 started with pid 519
                2022-07-23 17:11:05.114  - info: alexa2.0 (519) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:07.862  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 546
                2022-07-23 17:11:08.321  - info: alexa2.0 (519) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2022-07-23 17:11:08.818  - info: alexa2.0 (519) Unknown Device, but enabling commands, Try it and report back if commands work.
                2022-07-23 17:11:08.818  - info: alexa2.0 (519) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2022-07-23 17:11:08.819  - info: alexa2.0 (519)     Device-type:A3EVMLQTU6WL1W (ARTHUR_TARGET,SUPPORTS_LOCALE_SWITCH,FLASH_BRIEFING,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SOUND_SETTINGS,VOLUME_SETTING,MICROPHONE,CHANGE_NAME,SHARKNADO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,EARCONS,BT_PAIRING_FLOW_V2,ASCENDING_ALARM_VOLUME,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,PAIR_BT_SINK,DIALOG_INTERFACE_VERSION,TIMERS_AND_ALARMS,SUPPORTS_LOCALE,SPEECH_RECOGNIZER_USS,ACTIVE_AFTER_FRO,REMINDERS)
                2022-07-23 17:11:09.337  - info: hm-rega.0 (546) starting. Version 3.0.40 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:09.476  - info: hm-rega.0 (546) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                2022-07-23 17:11:09.541  - info: hm-rega.0 (546) ReGaHSS 192.168.86.50 up
                2022-07-23 17:11:10.216  - warn: hm-rega.0 (546) time difference local-ccu 55s
                2022-07-23 17:11:11.868  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 561
                2022-07-23 17:11:13.109  - info: hm-rega.0 (546) request state values
                2022-07-23 17:11:13.714  - info: hm-rpc.0 (561) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:13.887  - info: hm-rpc.0 (561) xmlrpc server is trying to listen on 192.168.86.35:2001
                2022-07-23 17:11:13.888  - info: hm-rpc.0 (561) xmlrpc client is trying to connect to 192.168.86.50:2001/ with ["http://192.168.86.35:2001","iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
                2022-07-23 17:11:13.939  - info: hm-rpc.0 (561) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
                2022-07-23 17:11:13.958  - info: hm-rpc.0 (561) xmlrpc <- listDevices ["iobroker:hm-rpc.0:51f4679f58faa9997c53c2e24bcfe14e"]
                2022-07-23 17:11:14.036  - info: hm-rpc.0 (561) xmlrpc -> 179 devices
                2022-07-23 17:11:14.096  - info: hm-rpc.0 (561) Connected
                2022-07-23 17:11:14.646  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ1773663.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
                2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:14.647  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:14.648  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.OEQ0669002.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
                2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:14.649  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:14.937  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:14.938  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:14.939  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.230  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.327  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.328  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0871224.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
                2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:15.878  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 576
                2022-07-23 17:11:15.957  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: STICKY_UNREACH Meldung: hm-rpc.0.NEQ0401353.0.STICKY_UNREACH wurde auf <true> gesetzt. Das Homematic Gerät ist wieder uneingeschränkt erreichbar.
                2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.958  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:15.959  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:15.960  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Homematic-Servicemeldungen: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:16.329  - info: javascript.0 (434) script.js.common.Homematic_Meldungen: Anzahl Homematic-Servicemeldungen: 5
                2022-07-23 17:11:16.330  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:16.429  - info: hm-rega.0 (546) Updated all datapoints
                2022-07-23 17:11:16.524  - info: javascript.0 (434) script.js.common.Jarvis: Phillip Heizung  ist nicht erreichbar<br>Keller Aufgang Heizung  ist nicht erreichbar<br>Weihnachtsbeleuchtung  ist nicht erreichbar<br>Phillip Heizung  hat eine schlechte Batterie<br>Keller Aufgang Heizung  hat eine schlechte Batterie<br>
                2022-07-23 17:11:16.698  - info: hm-rega.0 (546) added/updated 1 objects
                2022-07-23 17:11:16.729  - info: hm-rega.0 (546) got 42 variables
                2022-07-23 17:11:17.509  - info: hm-rega.0 (546) added/updated 42 variables
                2022-07-23 17:11:17.510  - info: hm-rega.0 (546) deleted 0 variables
                2022-07-23 17:11:17.538  - info: hm-rega.0 (546) got 48 programs
                2022-07-23 17:11:17.550  - info: hm-rpc.1 (576) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:17.692  - info: hm-rpc.1 (576) xmlrpc server is trying to listen on 192.168.86.35:2010
                2022-07-23 17:11:17.693  - info: hm-rpc.1 (576) xmlrpc client is trying to connect to 192.168.86.50:2010/ with ["http://192.168.86.35:2010","iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
                2022-07-23 17:11:17.727  - info: hm-rpc.1 (576) Connected
                2022-07-23 17:11:17.738  - info: hm-rpc.1 (576) xmlrpc <- listDevices ["iobroker:hm-rpc.1:ef79136c1d2ef92154b3f6604ef29adf"]
                2022-07-23 17:11:17.812  - info: hm-rpc.1 (576) xmlrpc -> 0 devices
                2022-07-23 17:11:18.291  - info: hm-rpc.1 (576) xmlrpc <- newDevices 212
                2022-07-23 17:11:18.366  - info: hm-rpc.1 (576) new HMIP devices/channels after filter: 0
                2022-07-23 17:11:18.422  - info: hm-rega.0 (546) added/updated 48 programs
                2022-07-23 17:11:18.423  - info: hm-rega.0 (546) deleted 0 programs
                2022-07-23 17:11:19.856  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 591
                2022-07-23 17:11:21.206  - info: hm-rpc.2 (591) starting. Version 1.15.12 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc server is trying to listen on 192.168.86.35:8701
                2022-07-23 17:11:21.351  - info: hm-rpc.2 (591) binrpc client is trying to connect to 192.168.86.50:8701/ with ["xmlrpc_bin://192.168.86.35:8701","iobroker:hm-rpc.2:2a319a3ec7ec9ea22f86865c577e678a"]
                2022-07-23 17:11:21.426  - info: hm-rpc.2 (591) binrpc -> listDevices 36
                2022-07-23 17:11:21.477  - info: hm-rpc.2 (591) new CUxD devices/channels after filter: 0
                2022-07-23 17:11:21.479  - info: hm-rpc.2 (591) Connected
                2022-07-23 17:11:23.126  - info: alexa2.0 (519) Subscribing to states...
                2022-07-23 17:11:23.990  - info: host.iobroker instance system.adapter.hue.0 started with pid 619
                2022-07-23 17:11:25.440  - info: hue.0 (619) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.hue, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:25.634  - info: hue.0 (619) skip switch: Daylight.configured
                2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunriseoffset
                2022-07-23 17:11:25.635  - info: hue.0 (619) skip switch: Daylight.sunsetoffset
                2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemode
                2022-07-23 17:11:25.638  - info: hue.0 (619) skip switch: Küche wall switch module 1.devicemodevalues
                2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemode
                2022-07-23 17:11:25.640  - info: hue.0 (619) skip switch: Hue wall switch module 1.devicemodevalues
                2022-07-23 17:11:25.641  - info: hue.0 (619) created/updated 4 sensor channels
                2022-07-23 17:11:25.769  - info: hue.0 (619) created/updated 11 light channels
                2022-07-23 17:11:25.773  - info: hue.0 (619) created/updated 6 groups channels
                2022-07-23 17:11:25.776  - info: hue.0 (619) created/updated 25 scenes
                2022-07-23 17:11:25.776  - info: hue.0 (619) creating/updating bridge device
                2022-07-23 17:11:27.861  - info: host.iobroker instance system.adapter.modbus.0 started with pid 634
                2022-07-23 17:11:29.078  - info: modbus.0 (634) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:29.343  - info: modbus.0 (634) Connected to slave 192.168.86.153
                2022-07-23 17:11:31.880  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 649
                2022-07-23 17:11:33.369  - info: fritzbox.0 (649) starting. Version 0.5.0 (non-npm: ruhr70/ioBroker.fritzbox) in /opt/iobroker/node_modules/iobroker.fritzbox, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:33.394  - info: fritzbox.0 (649) try to connect: 192.168.86.1
                2022-07-23 17:11:33.395  - info: fritzbox.0 (649) Trying to connect to TR-064: 192.168.86.1:49000
                2022-07-23 17:11:33.419  - info: fritzbox.0 (649) adapter connected to fritzbox: 192.168.86.1
                2022-07-23 17:11:34.488  - info: fritzbox.0 (649) Successfully connected to TR-064
                2022-07-23 17:11:34.599  - warn: fritzbox.0 (649) TR-064: Error reading files from dir /tam: Error: ENOENT: no such file or directory, scandir 'tam'
                2022-07-23 17:11:35.861  - info: host.iobroker instance system.adapter.ping.0 started with pid 677
                2022-07-23 17:11:37.074  - info: ping.0 (677) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:37.183  - warn: ping.0 (677) Object ping.0.iobroker.Repeater3000. is invalid: obj.type has to exist
                2022-07-23 17:11:37.183  - warn: ping.0 (677) This object will not be created in future versions. Please report this to the developer.
                2022-07-23 17:11:37.184  - error: ping.0 (677) Cannot update channel : ping.0.iobroker.Repeater3000 Error: Error: The id "ping.0.iobroker.Repeater3000." is invalid. Ids are not allowed to end in "."
                2022-07-23 17:11:39.863  - info: host.iobroker instance system.adapter.backitup.0 started with pid 695
                2022-07-23 17:11:41.163  - info: backitup.0 (695) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:41.222  - info: backitup.0 (695) [iobroker] backup was activated at 02:00 every 3 day(s)
                2022-07-23 17:11:41.260  - info: backitup.0 (695) [ccu] backup was activated at 01:30 every 7 day(s)
                2022-07-23 17:11:43.860  - info: host.iobroker instance system.adapter.ebus.0 started with pid 710
                2022-07-23 17:11:45.187  - info: ebus.0 (710) starting. Version 3.0.2 (non-npm: rg-engineering/ioBroker.ebus) in /opt/iobroker/node_modules/iobroker.ebus, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:47.860  - info: host.iobroker instance system.adapter.info.0 started with pid 725
                2022-07-23 17:11:49.855  - info: info.0 (725) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:49.916  - info: info.0 (725) Reading/updating systemdata.
                2022-07-23 17:11:50.375  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                2022-07-23 17:11:50.399  - info: info.0 (725) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                2022-07-23 17:11:50.444  - info: info.0 (725) Reading CPU data every 3 seconds.
                2022-07-23 17:11:50.510  - info: info.0 (725) cpu Temp res = {"main":46,"cores":[47,47,48,49],"max":49,"socket":[],"chipset":null}
                2022-07-23 17:11:50.528  - info: info.0 (725) Reading CPU temp data every 3 seconds.
                2022-07-23 17:11:50.546  - info: info.0 (725) Reading CPU current speed every 3 seconds.
                2022-07-23 17:11:50.579  - info: info.0 (725) Reading memory data every 3 seconds.
                2022-07-23 17:11:50.668  - info: info.0 (725) Reading battery data every 8 seconds.
                2022-07-23 17:11:51.085  - info: info.0 (725) Reading user data every 8 seconds.
                2022-07-23 17:11:51.159  - info: info.0 (725) Reading process data every 8 seconds.
                2022-07-23 17:11:51.660  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev4.size" has to be type "string" but received type "number"
                2022-07-23 17:11:51.663  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                2022-07-23 17:11:51.664  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev1.size" has to be type "string" but received type "number"
                2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev2.size" has to be type "string" but received type "number"
                2022-07-23 17:11:51.666  - info: info.0 (725) State value to set for "info.0.sysinfo.disks.diskLayout.dev3.size" has to be type "string" but received type "number"
                2022-07-23 17:11:51.691  - info: info.0 (725) Reading disk data every 8 seconds.
                2022-07-23 17:11:51.862  - info: host.iobroker instance system.adapter.iot.0 started with pid 1109
                2022-07-23 17:11:52.318  - info: info.0 (725) Reading network data every 3 seconds.
                2022-07-23 17:11:53.362  - info: iot.0 (1109) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.iot, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:53.400  - info: iot.0 (1109) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                2022-07-23 17:11:53.698  - info: iot.0 (1109) Connection changed: connect
                2022-07-23 17:11:57.012  - info: vis.0 (1230) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:11:57.181  - info: vis.0 (1230) vis license is OK.
                2022-07-23 17:11:57.982  - info: vis.0 (1230) Terminated (NO_ERROR): Without reason
                2022-07-23 17:11:58.572  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                2022-07-23 17:11:59.856  - info: host.iobroker instance system.adapter.web.0 started with pid 1377
                2022-07-23 17:12:01.178  - info: web.0 (1377) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:01.332  - info: web.0 (1377) socket.io server listening on port 8081
                2022-07-23 17:12:01.335  - info: web.0 (1377) http server listening on port 8081
                2022-07-23 17:12:04.949  - info: vis-google-fonts.0 (1444) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:05.540  - info: vis-google-fonts.0 (1444) Terminated (NO_ERROR): Without reason
                2022-07-23 17:12:06.133  - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
                2022-07-23 17:12:07.867  - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * *
                2022-07-23 17:12:07.889  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 1573
                2022-07-23 17:12:09.198  - info: daswetter.0 (1573) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:11.797  - info: host.iobroker instance system.adapter.systeminfo.0 started with pid 1679
                2022-07-23 17:12:13.193  - info: systeminfo.0 (1679) starting. Version 0.3.0 (non-npm: frankjoke/ioBroker.systeminfo) in /opt/iobroker/node_modules/iobroker.systeminfo, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:14.173  - info: systeminfo.0 (1679) Startup Systeminfo Adapter systeminfo.0: {  startup: '',  items: [    {      name: 'Piko.[Type/Value]',      type: 'web',      source: 'http://192.168.86.157/measurements.xml',      regexp: "Device.Measurements.Measurement[?(@.Type=='AC_Power' || @.Type=='DC_Voltage' || @.Type=='DC_Current')]",      conv: 'xml',      role: 'number',      write: '',      sched: '*/10 * * * * *'    }  ],  lang: 'de',  latitude: 51.9793,  longitude: 7.7942}
                2022-07-23 17:12:14.309  - info: systeminfo.0 (1679) Adapter systeminfo.0 started and found 1/3 items/states to process.
                2022-07-23 17:12:15.864  - info: host.iobroker instance system.adapter.bring.0 started with pid 1787
                2022-07-23 17:12:17.300  - info: bring.0 (1787) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:17.791  - info: bring.0 (1787) [LOGIN] Successfully logged in as stephan
                2022-07-23 17:12:19.040  - info: daswetter.0 (1573) still wrong data structure from server received! repaired...
                2022-07-23 17:12:19.872  - info: host.iobroker instance system.adapter.plenticore.0 started with pid 1863
                2022-07-23 17:12:21.457  - info: plenticore.0 (1863) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:21.478  - info: plenticore.0 (1863) [START] Starting adapter plenticore v2.2.0r237
                2022-07-23 17:12:21.529  - info: plenticore.0 (1863) Configured Wp of panel(s) is 0
                2022-07-23 17:12:21.530  - info: plenticore.0 (1863) [INFO] Configured polling interval: 20000
                2022-07-23 17:12:21.801  - info: web.0 (1377) ==> Connected system.user.admin from ::ffff:192.168.86.118
                2022-07-23 17:12:21.894  - info: plenticore.0 (1863) Not enabling forecast data.
                2022-07-23 17:12:21.895  - info: plenticore.0 (1863) Not enabling MinSoC forecast data.
                2022-07-23 17:12:22.606  - info: daswetter.0 (1573) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2022-07-23 17:12:23.115  - info: daswetter.0 (1573) cleaned everything up...
                2022-07-23 17:12:23.191  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-07-23 17:12:23.916  - info: host.iobroker instance system.adapter.jarvis.0 started with pid 2066
                2022-07-23 17:12:25.208  - info: jarvis.0 (2066) starting. Version 3.0.12-beta.3 (non-npm: Zefau/ioBroker.jarvis#bacd7221d9990610ee6c684e0ec6fddd397cde79) in /opt/iobroker/node_modules/iobroker.jarvis, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:25.258  - info: jarvis.0 (2066) Found Backups for layout.
                2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for styles.
                2022-07-23 17:12:25.260  - info: jarvis.0 (2066) Found Backups for settings.
                2022-07-23 17:12:25.261  - info: jarvis.0 (2066) Found Backups for widgets.
                2022-07-23 17:12:25.284  - info: jarvis.0 (2066) Found Backups for devices.
                2022-07-23 17:12:27.798  - info: host.iobroker instance system.adapter.yahka.0 started with pid 2140
                2022-07-23 17:12:29.202  - info: yahka.0 (2140) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.16.0, js-controller: 4.0.23
                2022-07-23 17:12:29.224  - info: yahka.0 (2140) adapter ready, checking config
                2022-07-23 17:12:29.232  - info: yahka.0 (2140) adding Wohnzimmer Heizung with UUID: 2521183a-dec7-421a-a763-c10f4be10961
                2022-07-23 17:12:29.237  - info: yahka.0 (2140) publishing bridge iobroker on 0.0.0.0 using ciao
                GlasfaserG Offline
                GlasfaserG Offline
                @stephan1827 sagte in admin interface leer:
                Der Admin läuft doch ... und jetzt
                stephan1827S 1 Antwort Letzte Antwort
                  Ändern, mit dem jetzigen Setup läufst du Gefahr da Schleifen anzulegen.
                  stephan1827S Offline
                  stephan1827
                  @thomas-braun sagte in admin interface leer:
                  rectory is not allowed to be a central ioBroker directory! 2022-07-23 17:10:52.007 - error: javascript.0 (434) Directory /opt/iobroker/backups/scripte is not allowed to mirror files!
                  Was soll ich hier ändern? Ich habe schon versucht das wieder auf port 8081 zu stellen aber dann geht garnichts mehr. Außerdem hat es so ja auch mal gelaufen.
                  • stephan1827S stephan1827
                    @stephan1827
                    Hat mit dem admin interface nix zu tun, aber du solltest nach /home/iobroker spiegeln und nicht in den /opt/iobroker-Zweig.
                    Aber wie gesagt, eigentlich OT.
                      Dinge ändern sich und müssen angepasst werden.
                      • GlasfaserG Glasfaser
                        stephan1827
                        @glasfaser Noch jemand eine Idee? Ich habe node und js controller neu installiert aber auch das hat nichts gebracht.
                          @stephan1827
                          Und was steht im Log?
                          • stephan1827S Offline
                            stephan1827
                            @stephan1827
                            Die logs habe ich weiter oben gepostet, ich denke der entscheidende Eintrag ist
                            oot@iobroker:/opt/iobroker# node node_modules/iobroker.admin/main.js --logs
                            2022-07-23 16:08:54.937  - error: admin.0 (30576) admin.0 invalid process id scenario 30454 vs. own ID 30576. Stopping
                            2022-07-23 16:08:54.939  - info: admin.0 (30576) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                              @stephan1827
                              @stephan1827
                              Was JETZT im Log steht, nicht gestern um 16 Uhr.
                              Und NICHT alle root herumeiern!
                                @stephan1827
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Dazu gibt es noch das , deshalb habe ich dich oben gefragt :
                                @glasfaser sagte in admin interface leer:
                                Wie sieht es dort mit dem Docker - Netzwerk aus ... alles Identisch mit den Einstellungen zuvor !?
                                https://forum.iobroker.net/topic/36859/gelöst-keine-admin-oberfläche-nach-neuinstallation/26
                                  stephan1827
                                  @glasfaser Habs mittlerweile durch neu installation des Dockers und einer Kombination aus diversen Backups wieder am Laufen. Keine Ahnung was die Ursache war. Einstellungen sind alle so wie vorher.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Ich Tippe immer noch auf ein Netzwerkproblem / Einstellungssache .
