  4. Ganze Iobroker Version läuft langsam
    5.8k
286 Beiträge 8 Kommentatoren 31.9k Aufrufe 6 Beobachtet
  • stefu87_CHS stefu87_CH
    @homoran sagte in Ganze Iobroker Version läuft langsam:
    @stefu87_ch bitte nochmal ohne persönliche Daten einstellen
    Meinst du den Log? Wenn ja, da waren schon diverse Buchstaben und Zahlen unkenntlich gemacht.
    #72
    @stefu87_ch
    Aktuelles log bitte.
      stefu87_CHS Offline
      stefu87_CHS Offline
      stefu87_CH
      #73
      2022-07-23 14:21:55.478 - info: shelly.0 (665) [CoAP] Device 192.168.0.45 (shellyht / shellyht-754C24 / SHHT-1#754C24#1) connected! Polltime set to 10 sec.
      2022-07-23 14:24:00.026 - info: host.Iobroker-Visu instance system.adapter.weatherunderground.1 started with pid 1856
      2022-07-23 14:24:00.834 - info: weatherunderground.1 (1856) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.16.0, js-controller: 4.0.23
      2022-07-23 14:24:29.232 - info: weatherunderground.1 (1856) Terminated (NO_ERROR): Without reason
      2022-07-23 14:24:29.745 - info: host.Iobroker-Visu instance system.adapter.weatherunderground.1 terminated with code 0 (NO_ERROR)
      2022-07-23 14:25:51.255 - info: octoprint.0 (1221) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.0.120:80
      2022-07-23 14:26:01.328 - info: octoprint.0 (1221) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
      2022-07-23 14:29:30.453 - info: octoprint.0 (1221) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.0.120:80
      2022-07-23 14:29:41.358 - info: octoprint.0 (1221) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
      2022-07-23 14:30:00.031 - info: host.Iobroker-Visu instance system.adapter.daswetter.1 started with pid 2114
      2022-07-23 14:30:01.071 - info: daswetter.1 (2114) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
      2022-07-23 14:30:04.048 - info: host.Iobroker-Visu instance system.adapter.daswetter.0 started with pid 2129
      2022-07-23 14:30:05.003 - info: daswetter.0 (2129) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
      2022-07-23 14:30:08.679 - info: daswetter.1 (2114) still wrong data structure from server received! repaired...
      2022-07-23 14:30:10.959 - info: daswetter.1 (2114) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-07-23 14:30:11.465 - info: daswetter.1 (2114) cleaned everything up...
      2022-07-23 14:30:11.475 - info: host.Iobroker-Visu instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-23 14:30:12.371 - info: daswetter.0 (2129) still wrong data structure from server received! repaired...
      2022-07-23 14:30:13.711 - info: daswetter.0 (2129) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-07-23 14:30:14.217 - info: daswetter.0 (2129) cleaned everything up...
      2022-07-23 14:30:14.225 - info: host.Iobroker-Visu instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Cores: 1 × 8 = 8 cores
      Threads: 16
      mit Proxmox
      LXC Container mit Iobroker
        @glasfaser sagte in Ganze Iobroker Version läuft langsam:
        ps auxww|grep io
        Gerade das System neu gestartet und Problem ist auch ohne ical noch vorhanden
        message+     149  0.0  0.1  50040  4260 ?        Ss   14:13   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
        iobroker     446  0.0  8.2 1021756 344496 ?      Ssl  14:15   0:55 iobroker.js-controller
        iobroker     487  0.0  4.9 995740 205640 ?       Sl   14:15   0:07 io.admin.0
        iobroker     502  0.0  7.4 1081836 312540 ?      Sl   14:15   0:22 io.javascript.0
        iobroker     517  0.0  1.9 829104 81868 ?        Sl   14:15   0:02 io.telegram.0
        iobroker     532  0.0  1.5 680380 64168 ?        Sl   14:15   0:00 io.whatsapp-cmb.0
        iobroker     547  0.0  1.5 680148 63888 ?        Sl   14:15   0:00 io.whatsapp-cmb.1
        iobroker     562  0.0  1.5 681088 64952 ?        Sl   14:15   0:01 io.scenes.0
        iobroker     577  0.0  1.5 678204 63556 ?        Sl   14:15   0:02 io.history.0
        iobroker     601  0.0  1.7 753432 73828 ?        Sl   14:15   0:02 io.influxdb.1
        iobroker     645  0.0  1.4 676424 59916 ?        Sl   14:15   0:01 io.ping.0
        iobroker     665  0.0  2.4 695996 101128 ?       Sl   14:15   0:07 io.shelly.0
        iobroker     676  0.0  1.6 953008 68668 ?        Sl   14:15   0:02 io.alexa2.0
        iobroker     698  0.0  2.1 697148 88816 ?        Sl   14:15   0:03 io.shelly.1
        iobroker     723  0.0  2.0 688080 83956 ?        Sl   14:16   0:06 io.unifi.0
        iobroker     791  0.0  1.7 682920 72496 ?        Sl   14:16   0:01 io.backitup.0
        iobroker     806  0.0  1.6 887808 68220 ?        Sl   14:16   0:00 io.cloud.0
        iobroker     836  0.0  1.3 656856 57304 ?        Sl   14:16   0:00 io.discovery.0
        iobroker     851  0.0  1.4 658292 61632 ?        Sl   14:16   0:01 io.fullybrowser.0
        iobroker     866  0.0  1.6 753980 67368 ?        Sl   14:16   0:01 io.info.0
        iobroker    1221  0.0  1.4 677588 62208 ?        Sl   14:16   0:00 io.octoprint.0
        iobroker    1236  0.0  1.4 676672 60460 ?        Sl   14:16   0:00 io.snmp.0
        iobroker    1251  0.0  1.4 676176 60608 ?        Sl   14:16   0:00 io.trashschedule.0
        iobroker    1266  0.0  1.3 656712 56848 ?        Sl   14:16   0:00 io.vis-inventwo.0
        iobroker    1296  0.0  2.2 978116 96124 ?        Sl   14:16   0:02 io.web-speedy.0
        iobroker    1311  0.0  1.9 697968 82052 ?        Sl   14:17   0:01 io.web.0
        iobroker    1329  0.0  1.4 674828 59008 ?        Sl   14:17   0:00 io.mytime.0
        iobroker    1348  0.0  1.5 678836 63656 ?        Sl   14:17   0:01 io.proxmox.0
        iobroker    1373  0.0  1.9 769076 82664 ?        Sl   14:17   0:01 io.roomba.0
        iobroker    1407  0.0  1.3 657376 57048 ?        Sl   14:17   0:00 io.alexa-timer-vis.0
        iobroker    1457  0.0  1.4 659328 59680 ?        Sl   14:17   0:00 io.countdown.0
        iobroker    1474  0.0  2.1 775072 89420 ?        Sl   14:17   0:01 io.iot.0
        iobroker    1504  0.0  1.5 818672 63700 ?        Sl   14:17   0:00 io.parser.0
        iobroker    1519  0.0  1.5 675908 65044 ?        Sl   14:17   0:00 io.logparser.0
        iobroker    1534  0.0  1.6 684800 68076 ?        Sl   14:17   0:00 io.eventlist.0
        iobroker    1549  0.0  1.3 674868 58668 ?        Sl   14:17   0:00 io.time-switch.0
        iobroker    1564  0.0  1.7 954764 74008 ?        Sl   14:17   0:01 io.vw-connect.0
        iobroker    1579  0.0  1.5 950964 66400 ?        Sl   14:18   0:01 io.life360.0
        iobroker    1594  0.0  1.4 809788 61644 ?        Sl   14:18   0:01 io.ws.0
        admin       1664  0.0  0.0  11472  1040 pts/1    S+   14:18   0:00 grep --color=auto io
        GlasfaserG Offline
        GlasfaserG Offline
        #74
        @stefu87_ch sagte in Ganze Iobroker Version läuft langsam:
        Davon habe ich nichts geschrieben ..... einen Neustart .
        Ich wollte den Aktuellen Stand sehen .
          #75
          daswetter
          Auch mal ausknipsen. Der nippelt ja auch ständig ab.
          stefu87_CHS GlasfaserG 2 Antworten Letzte Antwort
            daswetter
            stefu87_CHS Offline
            stefu87_CHS Offline
            stefu87_CH
            #76
            @thomas-braun sagte in Ganze Iobroker Version läuft langsam:
            daswetter
            Ist gestoppt aber immer noch alles sehr träge
            Threads: 16
            mit Proxmox
              daswetter
              GlasfaserG Offline
              GlasfaserG Offline
              #77
              Ich vermute eher ...
              da du am Anfang ein Mischverhältniss mit Beta hattest / hast und es eventuelle Abhängigkeiten zum neuen Admin 6 in den aktuellen Adaptern programmiert wurden .
              hast du diesen Effekt .
              Beispiel :
              Adapter    "javascript"   : 5.7.0    , installed 5.8.9
              Vorschlag ... neu aufsetzen!
              Thomas BraunT stefu87_CHS 2 Antworten Letzte Antwort
              • GlasfaserG Glasfaser
                Beispiel :
                #78
                @glasfaser
                Auf Systemen wie diesem:
                root@Iobroker-Visu:
                weißt du eh nie genau, was da alles umgekippt wurde.
                  Beispiel :
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  #79
                  Beispiel :
                  Wenn ich das tun würde, und das Backup zurück spiele, hab ich den das Problem nicht weiterhin?
                  Threads: 16
                  mit Proxmox
                    @glasfaser
                    root@Iobroker-Visu:
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #80
                    Ja , auch deswegen und ich vermute ...
                    das kam nach seiner Umstellung auf Nodejs 16
                    nodejs:
                      Installed: 16.16.0-1nodesource1
                      Candidate: 16.16.0-1nodesource1
                      Version table:
                     *** 16.16.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                         8.10.0~dfsg-2ubuntu0.4 500
                            500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                         8.10.0~dfsg-2ubuntu0.2 500
                            500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                         8.10.0~dfsg-2 500
                            500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                    root@Iobroker-Visu:/opt/iobroker# ^C
                      Beispiel :
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #81
                      Du hast doch Proxmox... teste doch ist doch schnelle gemacht !
                      Den alten ( Container ) kannst du doch erstmal lassen .
                        stefu87_CHS Offline
                        stefu87_CHS Offline
                        stefu87_CH
                        schrieb am zuletzt editiert von stefu87_CH
                        #82
                        @glasfaser
                        Werde es mal testen und dann meld ich mich wieder wie das ergebnis ist.
                        Threads: 16
                        mit Proxmox
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #83
                          @stefu87_ch
                          Wann hast du auf Nodejs 16 umgestellt ... hast du danach Probleme gehabt !?
                            @stefu87_ch
                            stefu87_CHS Offline
                            stefu87_CHS Offline
                            stefu87_CH
                            #84
                            @stefu87_ch
                            Das weiss ich nicht mehr so genau, aber könnte gut sein, das es da angefangen hat
                            Threads: 16
                            mit Proxmox
                              @stefu87_ch
                              stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              #85
                              Trotz einer neuen Installation mit einem Backup von Iobroker hat leider nichts gebracht.
                              So wie das aussieht hab ich bald keine andere Lösung mehr, als alles von 0 anzufangen.
                              Threads: 16
                              mit Proxmox
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #86
                                Schalte den javascript Adapter mal aus und starte deine Kiste neu.
                                Wie verhält sich dann ioBroker ( Admin Instanz ) !?
                                  stefu87_CHS Offline
                                  stefu87_CHS Offline
                                  stefu87_CH
                                  #87
                                  läuft weiterhin in in Timeout hinein
                                  Threads: 16
                                  mit Proxmox
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #88
                                    Dann alles aus an Adaptern ... natürlich nicht den ADMIN !
                                    und einen Neustart
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #89
                                      aber die Grundeinrichtung ( ioBroker Neu ) mit den Standart-Adapter verlief erstmal gut ohne Timeout und erst nach dem Backupeinspielen !?
                                        stefu87_CHS Offline
                                        stefu87_CHS Offline
                                        stefu87_CH
                                        #90
                                        Ja da läuft es reibungslos
                                        Threads: 16
                                        mit Proxmox
                                          und einen Neustart
                                          stefu87_CHS Offline
                                          stefu87_CHS Offline
                                          stefu87_CH
                                          #91
                                          und einen Neustart
                                          Jetzt ist nur der ADMIN aktiv und wenn ich z.B auf Objects klicke, dann hat er weiterhin ein Timeout, bzw. lange Ladezeiten ( zwischen 15-20 sek. )
                                          Threads: 16
                                          mit Proxmox
