  4. erledigt! sonoff Adapter legt keine Objekte an
    6.3k
14 Beiträge 2 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    schrieb am zuletzt editiert von ChrisNett
    Systemdata Bitte Ausfüllen
    Hardwaresystem: I5/Proxmox.
    Arbeitsspeicher: 8GB
    Festplattenart: ssd
    Betriebssystem: Ubuntu
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    moin, ich habe einen wemos mit tasmota der im sonoff Adapter kein objekte anlegen will
    hier der log vom ioBroker
    980081	2022-07-07 07:36:31.425	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:36:31","ANALOG":{"Range":8}}
    sonoff.0
    980081	2022-07-07 07:36:31.413	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:36:31","Uptime":"0T01:09:21","UptimeSec":4161,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:05"}}
    sonoff.0
    980081	2022-07-07 07:36:25.942	debug	Client [Bodenfeuchte_vorne] pingreq
    sonoff.0
    980081	2022-07-07 07:36:21.413	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:36:21","ANALOG":{"Range":8}}
    sonoff.0
    980081	2022-07-07 07:36:21.400	debug	[Bodenfeuchte_vorne] Received: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:36:21","Uptime":"0T01:09:11","UptimeSec":4151,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:05"}}
    der von tasmota
    06:38:01.405 MQT: BodenfeuchteVorne/STATE = {"Time":"2022-07-07T06:38:01","Uptime":"0T01:10:51","UptimeSec":4251,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"MqttCount":3,"Wifi":{"AP":1,"SSId":"MundA-HomeNet-W","BSSId":"B0:F2:08:6B:1A:4E","Channel":1,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:05"}}
    06:38:01.419 MQT: BodenfeuchteVorne/SENSOR = {"Time":"2022-07-07T06:38:01","ANALOG":{"Range":10}}
    und meine eintselungen
    in der Objekten habe ich nur das
    ich habe den objektbaum für diesen esp auch schon mal gelöscht mehr als die beiden Objekte kommt aber nicht
    was habe ich falsch gemacht? sonst klappt das immer wunderbar.
    danke
    Christian
    • ChrisNettC ChrisNett
      Festplattenart: ssd
      NPM-Version: 6.x.x
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      der von tasmota
      danke
      Christian
      arteckA Offline
      arteckA Offline
      arteck
      @christian-sandkaulen bitte erstaml das system aktualisieren
      node 10 ist seeeeeeeeeehr alt
      ChrisNettC 1 Antwort Letzte Antwort
      • arteckA arteck
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        @arteck
        sorry habe wohl nicht alles eingetragen...
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          @christian-sandkaulen und jetzt zeigmal die Objekte des sonoffs adapter ..aber alle und nicht nur so ein schnipsel
          von sonoff.0 aus
          • arteckA arteck
            von sonoff.0 aus
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            @arteck
            so ?
              @arteck
              so ?
              arteckA Offline
              arteckA Offline
              arteck
              nimm die mal raus
              • arteckA arteck
                nimm die mal raus
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                @arteck
                leider nix
                  @arteck
                  leider nix
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  Ich habe alle drei hacken wieder gesetzt sonst bekomme ich nicht alle daten ... zum beispiel vom auslekopf des smartmeters
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @christian-sandkaulen hast du alles richtig eingetragen im Tasmota?
                    • arteckA arteck
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      @arteck
                      so habe ich alle eingestellt
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        mach im topic
                        %prefix%/%topic%/
                        der user und psw stimmen auch ?
                          ChrisNettC Offline
                          ChrisNett
                          @arteck
                          danke scheinbar war es das muss an der neuen 12.02 Tasmota version liegen den bei den andern wemos mache ich das immer so!
                          klapp!
                            @arteck
                            klapp!
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @christian-sandkaulen hmm.. werden die auch aktualisiert ??? die anderen meine ich .. da der topic dafür zuständig ist wie die Daten kommen
                            ih würde an deiner stelle die alle wieder zurück auf den oben genannten topic setzten
                            • arteckA arteck
                              ChrisNettC Offline
                              ChrisNettC Offline
                              ChrisNett
                              @arteck sagte in sonoff Adapter legt keine Objekte an:
                              danke das mache ich dann zur Sicherheit!
