  4. Zigbee Adapter - restart loop detected
    5.8k
66 Beiträge 3 Kommentatoren 7.9k Aufrufe 3 Beobachtet
  • B brokeling
    alles löschen?
    brokeling
    pi@raspi:~ $ sudo apt update
    Holen:1 http://phoscon.de/apt/deconz buster InRelease [2.869 B]
    Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
    OK:3 https://deb.nodesource.com/node_12.x buster InRelease
    Holen:4 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
    OK:5 https://deb.nodesource.com/node_14.x buster InRelease
    Holen:6 http://phoscon.de/apt/deconz buster/main armhf Packages [734 B]
    Holen:7 http://archive.raspberrypi.org/debian buster/main armhf Packages [391 kB]
    Holen:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
    Es wurden 47,6 kB in 7 s geholt (7.063 B/s).
    Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    pi@raspi:~ $ tail -f /opt/iobroker/log/iobroker.current.log
    2022-07-04 23:15:39.626  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.boostactiveendtime" has to be type "number" but received type "string"
    2022-07-04 23:15:39.627  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.endperiod" has to be type "number" but received type "string"
    2022-07-04 23:15:39.629  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.windowopenactiveendtime" has to be type "number" but received type "string"
    2022-07-04 23:15:39.630  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.boostactiveendtime" has to be type "number" but received type "string"
    2022-07-04 23:15:39.631  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.endperiod" has to be type "number" but received type "string"
    2022-07-04 23:15:39.633  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.windowopenactiveendtime" has to be type "number" but received type "string"
    2022-07-04 23:15:39.634  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.boostactiveendtime" has to be type "number" but received type "string"
    2022-07-04 23:15:39.634  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.endperiod" has to be type "number" but received type "string"
    2022-07-04 23:16:08.531  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
    2022-07-04 23:17:08.491  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
    • B brokeling
      @brokeling
      Dann jetzt den Adapter neustarten.
        @brokeling
        brokeling
        läuft schon.
        • B brokeling
          läuft schon.
          @brokeling
          Und?
            @brokeling
            Und?
            brokeling
            kann ich nicht sagen.
            Der zickt nur druchschnittlich einmal rum in 24 h.
            Da muss man jetzt abwarten.
            Ich muss mir den statistics Adapter nochmal anschauen, ob ich den anders konfigurieren kann. Der loggt wohl zu viel, oder?
            Die Adapter werde ich updaten oder rausschmeißen. Paar davon brauche ich garnicht. Doch das Löschen über die Admin Oberfläche hatte ich schon versucht, hat aber nicht geklappt. Blieb stehen. Muss ich nochmal probieren.
            • B brokeling
              @brokeling
              Du sollst den zigbee-Adapter jetzt neustarten.
                @brokeling
                brokeling
                ja ok, aber das ist unauffällig. Was dann?
                • B brokeling
                  @brokeling
                  Zeigen...
                    @brokeling
                    Zeigen...
                    brokeling
                    das hier?
                    2022-07-04 23:30:39.535  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.boostactiveendtime" has to be type "number" but received type "string"
                    2022-07-04 23:30:39.535  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.endperiod" has to be type "number" but received type "string"
                    2022-07-04 23:30:48.901  - warn: zigbee.0 (16002) DeviceAvailability:Failed to ping 0xec1bbdfffeaa8f30 TRADFRI bulb E27 WW 806lm
                    2022-07-04 23:30:49.025  - warn: zigbee.0 (16002) DeviceAvailability:Failed to ping 0xec1bbdfffea186d2 TRADFRI bulb E27 WW 806lm
                    2022-07-04 23:30:49.113  - warn: zigbee.0 (16002) DeviceAvailability:Failed to ping 0xec1bbdfffea17968 TRADFRI bulb E27 WW 806lm
                    2022-07-04 23:30:50.046  - warn: zigbee.0 (16002) DeviceAvailability:Failed to ping 0xec1bbdfffeaa888d TRADFRI bulb E27 WW 806lm
                    2022-07-04 23:31:08.504  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                    2022-07-04 23:32:08.496  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                    2022-07-04 23:34:08.032  - info: sql.0 (918) Do not store value "NULL" for HumAußen because no number
                    2022-07-04 23:34:08.484  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                    • B brokeling
                      das hier?
                      @brokeling
                      Das sieht so aus:
                      2022-07-04 23:36:45.009  - info: host.chet stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2022-07-04 23:36:45.019  - info: host.chet stopInstance system.adapter.zigbee.0 send kill signal
                      2022-07-04 23:36:45.015  - info: zigbee.0 (451863) Got terminate signal TERMINATE_YOURSELF
                      2022-07-04 23:36:45.029  - info: zigbee.0 (451863) cleaned everything up...
                      2022-07-04 23:36:45.033  - info: zigbee.0 (451863) Zigbee: disabling joining new devices.
                      2022-07-04 23:36:45.530  - info: zigbee.0 (451863) terminating
                      2022-07-04 23:36:45.532  - info: zigbee.0 (451863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-07-04 23:36:46.020  - info: host.chet stopInstance system.adapter.zigbee.0 killing pid 451863
                      2022-07-04 23:36:46.147  - info: host.chet instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-07-04 23:36:48.212  - info: host.chet instance system.adapter.zigbee.0 started with pid 567035
                      2022-07-04 23:36:52.021  - info: zigbee.0 (567035) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.4.0, js-controller: 4.0.23
                      2022-07-04 23:36:52.076  - info: zigbee.0 (567035) internal Backups are disabled
                      2022-07-04 23:36:52.082  - info: zigbee.0 (567035) Starting Zigbee  npm ...
                      2022-07-04 23:36:52.629  - info: zigbee.0 (567035) Installed Version: iobroker.zigbee@1.7.5
                      2022-07-04 23:37:03.580  - info: zigbee.0 (567035) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}}
                      2022-07-04 23:37:03.588  - info: zigbee.0 (567035) Unable to disable LED, unsupported function.
                      2022-07-04 23:37:03.606  - info: zigbee.0 (567035)   --> transmitPower : normal
                      2022-07-04 23:37:03.614  - info: zigbee.0 (567035) Currently no devices.
                      2022-07-04 23:37:03.615  - info: zigbee.0 (567035) Zigbee started
                        @brokeling
                        Das sieht so aus:
                        brokeling
                        bei dir?
                        • B brokeling
                          bei dir?
                          @brokeling
                          Natürlich ist das aus meinem System. Aber so ähnlich sieht das auch bei dir aus.
                            @brokeling
                            brokeling
                            schrieb am zuletzt editiert von brokeling
                            kann ich die logs löschen und dann einen neuen Zigbee Adapter Start aufzeichnen?
                            Was kann ich noch machen?
                            • B brokeling
                              @brokeling
                              Du siehst doch jetzt im tail auch die Meldungen.
                                @brokeling
                                brokeling
                                meinst du die Ursache ist (war) der statistics Adapter?
                                Bis jetzt läuft dieser ja nicht mehr.
                                • B brokeling
                                  @brokeling
                                  Ich weiß es nicht. Ich bekomme ja keine Infos von dir.
                                    @brokeling
                                    brokeling
                                    na ich weiß nicht so recht welche....
                                    was soll ich eingeben?
                                    • B brokeling
                                      @brokeling
                                      MANN...
                                      Das was bei einem NEUSTART des ADAPTERS im LOGFILE NEU ERSCHEINT.
                                        @brokeling
                                        MANN...
                                        brokeling
                                        ...soory, ich dachte das hatten wir alles schon...
                                        hier jetzt aber:
                                        2022-07-05 00:00:39.615  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.boostactiveendtime" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.615  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.endperiod" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.617  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.windowopenactiveendtime" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.634  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.boostactiveendtime" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.635  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.endperiod" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.637  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.windowopenactiveendtime" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.637  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.boostactiveendtime" has to be type "number" but received type "string"
                                        2022-07-05 00:00:39.638  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.endperiod" has to be type "number" but received type "string"
                                        2022-07-05 00:01:00.082  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
                                        2022-07-05 00:01:08.485  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                                        2022-07-05 00:01:30.982  - info: host.raspi "system.adapter.zigbee.0" enabled
                                        2022-07-05 00:01:31.722  - info: host.raspi instance system.adapter.zigbee.0 started with pid 3931
                                        2022-07-05 00:01:36.283  - info: zigbee.0 (3931) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                        2022-07-05 00:01:36.413  - info: zigbee.0 (3931) delete old Backup files. keep only last 10
                                        2022-07-05 00:01:36.416  - info: zigbee.0 (3931) Starting Zigbee  npm ...
                                        2022-07-05 00:01:36.998  - info: zigbee.0 (3931) Installed Version: iobroker.zigbee@1.7.5
                                        2022-07-05 00:01:37.156  - warn: zigbee.0 (3931) Extended PAN ID is reversed (expected=c6b9aa1c004b1200, actual=00124b001caab9c6)
                                        2022-07-05 00:01:37.291  - info: zigbee.0 (3931) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                        2022-07-05 00:01:37.298  - info: zigbee.0 (3931) Unable to disable LED, unsupported function.
                                        2022-07-05 00:01:37.314  - info: zigbee.0 (3931)   --> transmitPower : high
                                        2022-07-05 00:01:37.327  - info: zigbee.0 (3931) Currently 46 devices are joined:
                                        2022-07-05 00:01:37.539  - info: zigbee.0 (3931) 0x00158d0006f783af (addr 64267): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.559  - info: zigbee.0 (3931) 0x00158d0006f24719 (addr 41432): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.562  - info: zigbee.0 (3931) 0x000d6ffffea04475 (addr 44106): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2022-07-05 00:01:37.564  - info: zigbee.0 (3931) 0x00158d0003d092f2 (addr 62419): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                                        2022-07-05 00:01:37.566  - info: zigbee.0 (3931) 0x842e14fffe43865c (addr 27459): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.568  - info: zigbee.0 (3931) 0x00158d0005d11326 (addr 55919): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.569  - info: zigbee.0 (3931) 0x00158d000171ba9f (addr 55416): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                                        2022-07-05 00:01:37.571  - info: zigbee.0 (3931) 0xccccccfffee9a795 (addr 48387): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.572  - info: zigbee.0 (3931) 0x00158d0003d22159 (addr 56651): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                                        2022-07-05 00:01:37.575  - info: zigbee.0 (3931) 0xec1bbdfffeaa8f30 (addr 34651): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.576  - info: zigbee.0 (3931) 0xec1bbdfffea186d2 (addr 23525): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.578  - info: zigbee.0 (3931) 0xccccccfffea9ccd9 (addr 46171): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                        2022-07-05 00:01:37.581  - info: zigbee.0 (3931) 0xec1bbdfffea17968 (addr 59322): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.583  - info: zigbee.0 (3931) 0x00158d00057b0540 (addr 12256): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                        2022-07-05 00:01:37.585  - info: zigbee.0 (3931) 0x00158d000586f719 (addr 46272): JTYJ-GD-01LM/BW - Xiaomi MiJia Honeywell smoke detector (EndDevice)
                                        2022-07-05 00:01:37.586  - info: zigbee.0 (3931) 0x842e14fffef6f646 (addr 39442): HS1SA - HEIMAN Smoke detector (EndDevice)
                                        2022-07-05 00:01:37.588  - info: zigbee.0 (3931) 0x00158d0001d56bd8 (addr 44376): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                                        2022-07-05 00:01:37.590  - info: zigbee.0 (3931) 0x0015bc003100c2ea (addr 53882): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                                        2022-07-05 00:01:37.591  - info: zigbee.0 (3931) 0x00158d00042d639d (addr 13713): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2022-07-05 00:01:37.593  - info: zigbee.0 (3931) 0xccccccfffee86c05 (addr 62590): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                        2022-07-05 00:01:37.594  - info: zigbee.0 (3931) 0x842e14fffe13965d (addr 37271): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2022-07-05 00:01:37.596  - info: zigbee.0 (3931) 0x842e14fffe4028b6 (addr 51203): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.597  - info: zigbee.0 (3931) 0x00158d0005226481 (addr 26815): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-07-05 00:01:37.599  - info: zigbee.0 (3931) 0x00158d0005cf4350 (addr 923): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.600  - info: zigbee.0 (3931) 0x00158d0005435ff6 (addr 27342): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-07-05 00:01:37.602  - info: zigbee.0 (3931) 0x54ef4410000345bd (addr 24768): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                        2022-07-05 00:01:37.604  - info: zigbee.0 (3931) 0x000d6ffffe04ac2a (addr 1520): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
                                        2022-07-05 00:01:37.606  - info: zigbee.0 (3931) 0x00158d0006f798ca (addr 29933): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.610  - info: zigbee.0 (3931) 0x00158d0006f798c4 (addr 11608): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-07-05 00:01:37.611  - info: zigbee.0 (3931) 0x842e14fffe13a855 (addr 701): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2022-07-05 00:01:37.613  - info: zigbee.0 (3931) 0xd0cf5efffefee1d0 (addr 19337): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                        2022-07-05 00:01:37.614  - info: zigbee.0 (3931) 0xec1bbdfffea39be0 (addr 40361): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                        2022-07-05 00:01:37.616  - info: zigbee.0 (3931) 0x00158d0002b35ad2 (addr 21375): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2022-07-05 00:01:37.618  - info: zigbee.0 (3931) 0xec1bbdfffeaa888d (addr 35257): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
                                        2022-07-05 00:01:37.619  - info: zigbee.0 (3931) 0x84fd27fffe6029ba (addr 57452): TS0043 - TuYa Wireless switch with 3 buttons (EndDevice)
                                        2022-07-05 00:01:37.621  - info: zigbee.0 (3931) 0x00158d00047c6488 (addr 19040): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-07-05 00:01:37.623  - info: zigbee.0 (3931) 0x60a423fffe39daad (addr 54526): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
                                        2022-07-05 00:01:37.624  - info: zigbee.0 (3931) 0x00158d0004868072 (addr 55508): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2022-07-05 00:01:37.626  - info: zigbee.0 (3931) 0x680ae2fffe723cf0 (addr 59119): SP 220 - Innr Smart plug (Router)
                                        2022-07-05 00:01:37.627  - info: zigbee.0 (3931) 0x00158d0003d47777 (addr 16788): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                                        2022-07-05 00:01:37.629  - info: zigbee.0 (3931) 0x847127fffed3f100 (addr 17702): PSBZS A1 - Lidl Parkside smart watering timer (EndDevice)
                                        2022-07-05 00:01:37.631  - info: zigbee.0 (3931) 0x842e14fffe5507a8 (addr 41833): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                        2022-07-05 00:01:37.632  - info: zigbee.0 (3931) 0xec1bbdfffeae2d87 (addr 45315): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                        2022-07-05 00:01:37.634  - info: zigbee.0 (3931) 0x2c1165fffe2d49c0 (addr 347): HG08164 - Lidl Silvercrest smart button (EndDevice)
                                        2022-07-05 00:01:37.635  - info: zigbee.0 (3931) 0x2c1165fffe3f28a8 (addr 28076): HG08164 - Lidl Silvercrest smart button (EndDevice)
                                        2022-07-05 00:01:37.637  - info: zigbee.0 (3931) 0x842e14fffe359b01 (addr 11367): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2022-07-05 00:01:37.638  - info: zigbee.0 (3931) Zigbee started
                                        2022-07-05 00:01:37.842  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x2c1165fffe2d49c0"
                                        2022-07-05 00:01:37.843  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x2c1165fffe3f28a8"
                                        2022-07-05 00:01:37.844  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x842e14fffe359b01"
                                        2022-07-05 00:01:56.883  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffeaa8f30 TRADFRI bulb E27 WW 806lm
                                        2022-07-05 00:01:56.994  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffea186d2 TRADFRI bulb E27 WW 806lm
                                        2022-07-05 00:01:57.151  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffea17968 TRADFRI bulb E27 WW 806lm
                                        2022-07-05 00:01:58.163  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffeaa888d TRADFRI bulb E27 WW 806lm
                                        2022-07-05 00:02:00.082  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
                                        2022-07-05 00:02:08.531  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                                        2022-07-05 00:03:00.083  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
                                        2022-07-05 00:03:08.494  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
                                        • B brokeling
                                          hier jetzt aber:
                                          @brokeling
                                          Ich würde nodeJS auf die empfohlene Version 16 bringen.
                                          Das log ist jetzt um 0Uhr rotiert worden, das ist also jetzt wieder handlich.
                                          iobroker logs --watch
                                          dürfte jetzt funktionieren.
                                          Hast du noch weitere Adapter auf dem log level debug stehen? Setzt die alle auf INFO oder WARN.
