  4. Test Adapter Z-Wave 2 v2.5.x
testzwave2
20 Beiträge 3 Kommentatoren 2.1k Aufrufe 6 Beobachtet
    taba_luga
    @Thomas-Braun nach den ganzen Problemen beim Node16/NPM8 Update, scheine ich diese nun in den Griff bekommen zu haben. Leider startet jetzt der ZWAVE2 Adapter wieder nicht.
    In dem Protokoll steht:
    host.iobroker-prod
    2022-06-29 22:46:45.609	info	Restart adapter system.adapter.zwave2.0 because enabled
    host.iobroker-prod
    2022-06-29 22:46:45.608	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker-prod
    2022-06-29 22:46:45.608	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    host.iobroker-prod
    2022-06-29 22:46:45.608	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    host.iobroker-prod
    2022-06-29 22:46:45.608	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
    host.iobroker-prod
    2022-06-29 22:46:45.607	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iobroker-prod
    2022-06-29 22:46:45.607	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.iobroker-prod
    2022-06-29 22:46:45.607	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.iobroker-prod
    2022-06-29 22:46:45.607	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.iobroker-prod
    2022-06-29 22:46:45.607	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    host.iobroker-prod
    2022-06-29 22:46:45.606	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    host.iobroker-prod
    2022-06-29 22:46:45.606	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
    host.iobroker-prod
    2022-06-29 22:46:45.605	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
    • T taba_luga
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      host.iobroker-prod
      @taba_luga
      Wie bist du da jetzt unterwegs?
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker update -i
        @taba_luga
        iobroker update -i
        taba_luga
        schrieb am zuletzt editiert von taba_luga
        @thomas-braun sagte in Test Adapter Z-Wave 2 v2.5.x:
        Jetzt schaut es bei mir so aus:
        alex@iobroker-prod:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.15.1
        v16.15.1
        8.11.0
        alex
        /home/alex
        [sudo] Passwort für alex:
        OK:1 http://ftp.de.debian.org/debian bullseye InRelease
        OK:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
        OK:3 http://security.debian.org/debian-security bullseye-security InRelease
        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           16.15.1-deb-1nodesource1
          Installationskandidat: 16.15.1-deb-1nodesource1
          Versionstabelle:
         *** 16.15.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
             12.22.12~dfsg-1~deb11u1 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
        alex@iobroker-prod:~$ iobroker update -i
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "heatingcontrol": 2.8.6   , installed 2.8.6
        Adapter    "history"      : 1.11.1   , installed 1.11.1
        Adapter    "hs100"        : 2.0.7    , installed 2.0.7
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.4   , installed 1.11.4
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "lg-thinq"     : 0.0.7    , installed 0.0.7
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
        Adapter    "milight"      : 0.3.6    , installed 0.3.6
        Adapter    "node-red"     : 3.3.1    , installed 3.2.0  [Updatable]
        Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
        Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "wifilight"    : 1.1.3    , installed 1.1.3
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
        • T taba_luga
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.15.1
          v16.15.1
          8.11.0
          alex
          /home/alex
          nodejs:
            Versionstabelle:
          taba_luga
          @taba_luga sagte in Test Adapter Z-Wave 2 v2.5.x:
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.15.1
          v16.15.1
          8.11.0
          alex
          /home/alex
          nodejs:
            Versionstabelle:
          Hallo zusammen, kann mir hier jemand bei meinem Problem eventuell helfen? Ich komme hier alleine leider nicht weiter.
          Danke euch.
          • T taba_luga
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.15.1
            v16.15.1
            8.11.0
            alex
            /home/alex
            nodejs:
              Versionstabelle:
            Danke euch.
            @taba_luga
            Die Basis ist i. O.
            Zum Problem selber kann ich nix sagen. Vielleicht postest du den Neustart des Adapters mal?
              @taba_luga
              Die Basis ist i. O.
              taba_luga
              @thomas-braun Ich verstehe es nicht. Ich habe den Adapter/die Instanz über die Iobroker Oberfläche bei den Instanzen diverse male gestoppt und neu gestartet. Er wollte einfach nicht starten... Die Meldung bei der Instanz war immer, dass sie nicht mit dem Host verbunden ist und kein Lebenszeichen hat. Mit dem Gerät oder Dienst (ZWaveStick) war sie immer verbunden.
              Ich habe den Adapter jetzt über die Konsole manuell gestoppt und neu gestartet. Jetzt läuft er wieder. :-)
              Danke euch und ein schönes Wochende!
              • T taba_luga
                @taba_luga
                Die Konsole ist halt 'mächtiger'.
                  taba_luga
                  @AlCalzone allerdings funktioniert die Anzeige der Logs leider nicht:
                  Das Fenster bleibt immer leer. Wenn ich das Log File herunterlade, dann sehe ich allerdings die Log Einträge in der *.log Datei.
                  2022-07-01T10:04:36.270Z SERIAL « 0x01100004000d0a3202213204db0000000010                              (18 bytes)
                  2022-07-01T10:04:37.243Z SERIAL « 0x010b0004000d0526036363fe23                                        (13 bytes)
                  2022-07-01T10:04:37.247Z CNTRLR   [Node 013] [~] [Multilevel Switch] targetValue: 90 => 99          [Endpoint 0]
                  2022-07-01T10:04:37.252Z CNTRLR   [Node 013] [~] [Multilevel Switch] duration: "unknown" => "unknow [Endpoint 0]
                                                    n"
                  2022-07-01T10:04:37.254Z CNTRLR   [Node 013] [~] [Multilevel Switch] currentValue: 90 => 99         [Endpoint 0]
                  2022-07-01T10:04:37.256Z SERIAL » [ACK]        (0x06)
                  2022-07-01T10:04:37.259Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
                                                    └─[MultilevelSwitchCCReport]
                                                        current value: 99
                                                        target value:  99
                                                        duration:      unknown
                  2022-07-01T10:04:39.803Z SERIAL « 0x01100004000d0a32022132000000000000cf                              (18 bytes)
                  • T taba_luga
                                                      n"
                                                          current value: 99
                                                          target value:  99
                                                          duration:      unknown
                    @taba_luga
                    Hast du da vielleicht die alte Oberfläche noch aktiv?
                      @taba_luga
                      taba_luga
                      @thomas-braun wie meinst du? Welche alte Oberfläche?
                      • T taba_luga
                        @taba_luga
                        Kann man in den Einstellungen zum 'admin' aktiv schalten.
                        Es gibt aber mittlerweile Adapter, die mit dieser Einstellung nicht mehr kompatibel sind.
                          @taba_luga
                          taba_luga
                          nein, benutze alte Benutzeroberfläche ist in den Admin Adapter Einstellungen deaktiviert.
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            Issue ist bekannt, das ist ein bug im CSS des Adapters.
