  4. jarvis v3.0.0 - just another remarkable vis
    6.8k
4.5k Beiträge 254 Kommentatoren 3.1m Aufrufe 209 Beobachtet
    DarkDevil
    #2602
    Ich komme hier irgendwie nicht weiter...
    ich möchte gerne mittels Spotify Adapter die Tracklist meiner Playlist in Jarvis anzeigen lassen.
    Es gibt im Adapter unter html eine tracklist.
    Wenn ich diese in Jarvis als html Table anzeige, bekomme ich immer die Meldung "keine Daten vorhanden."
    Der Inhalt des Datenpunkt der Tracklist schaut so aus:
    <table class="spotifyTracksTable"><tr class="spotifyTracksRow spotifyTracksRowActive" onclick="vis.setValue('spotify-premium.0.player.playlist.trackList', 0)"><td class="spotifyTracksColIcon spotifyTracksColIconActive"><img style="width: 16px; height: 16px" class="spotifyTracksIconActive" src="widgets/spotify-premium/img/active_song_speaker_green.png" /></td><td style="color: #1db954; font-weight: bold" class="spotifyTracksColTitle spotifyTracksColTitleActive"><span class="spotifyTracksTitle spotifyTracksTitleActive">Friday (feat. Mufasa & Hypeman) - Dopamine Re-Edit</span><span class="spotifyTracksLinebreak spotifyTracksLinebreakActive"><br /></span><span class="spotifyTracksArtistAlbum spotifyTracksArtistAlbumActive"><span class="spotifyTracksArtist spotifyTracksArtistActive">Riton, Nightcrawlers, Mufasa & Hypeman, Dopamine</span><span class="spotifyTracksSpace spotifyTracksSpaceActive">&nbsp;&bull;&nbsp;</span><span class="spotifyTracksAlbum spotifyTracksAlbumActive">Friday (feat. Mufasa & Hypeman) [Dopamine Re-Edit]</span></span></td><td style="color: #1db954" class="spotifyTracksColDuration spotifyTracksColDurationActive">02:49</td></tr><tr class="spotifyTracksRow" onclick="vis.setValue('spotify-premium.0.player.playlist.trackList', 1)"><td class="spotifyTracksColIcon"><img style="width: 16px; height: 16px" class="spotifyTracksIconInactive" src="widgets/spotify-premium/img/inactive_song_note_white.png" /></td><td class="spotifyTracksColTitle"><span class="spotifyTracksTitle">Your Game (From "Toy Boy" Series)</span><span class="spotifyTracksLinebreak"><br /></span><span class="spotifyTracksArtistAlbum"><span class="spotifyTracksArtist">REYKO</span><span class="spotifyTracksSpace">&nbsp;&bull;&nbsp;</span><span class="spotifyTracksAlbum">Your Game (From "Toy Boy" Series)</span></span></td><td class="spotifyTracksColDuration">02:52</td></tr></table>
    • D DarkDevil
      MCU
      #2603
      @darkdevil
      Du hast PRO?
      Mit StateHTML.
      D 2 Antworten Letzte Antwort
      • M MCU
        @darkdevil
        Du hast PRO?
        Mit StateHTML.
        DarkDevil
        #2604
        @mcu ja habe ich
        • M MCU
          @darkdevil
          Du hast PRO?
          Mit StateHTML.
          DarkDevil
          #2605
          @mcu mal wieder ein herzliches Dankeschön an deine Unterstützung.
          Hast du noch eine Idee, wie in die Breite der Liste komplett ausgefüllt bekomme?
          Bei der Playlist ist rechts noch Platz, ich habe noch andere Listen, bei denen deutlich mehr Platz am rechten Rand ist. (Ich vermute, es wird anhand des Interpreten bzw. des Titels ausgefüllt.)
          Die Horizontale Ausrichtung auf "fülle gesamte Breite" brachte nicht den gewünschten Erfolg.
          • D DarkDevil
            MCU
            #2606
            @darkdevil Geh mal bitte mit der Maus den rechten Randbereich der keine Daten hat und Klick dann rechte Maustaste und "untersuchen" (ganz unten). Es erscheint rechts eine Anzeige. Die bitte hier einstellen als Bild.
              DarkDevil
              #2607
              Ich hoffe du meintest dies:
              • D DarkDevil
                MCU
                #2608
                @darkdevil Also bei ist es 100 % egal wie breit ich es ziehe. Es scheint mit den Bildern vorne zusammenzuhängen?
                  MCU
                  #2609
                  Beispiel openligadb
                  • M MCU
                    DarkDevil
                    #2610
                    @mcu mhhhh ich habe mir das jetzt nochmal auf meinem Tab angeschaut (auf dem ich die Visualisierung hauptsächlich nutze) hier ist es aber auch so, dass die Ränder den Titeln angepasst werden (sich also mal vergrößern, mal verkleinern).
                    • D DarkDevil
                      MCU
                      #2611
                      @darkdevil In welchem Verzeichnis liegt das?
                      • M MCU
                        DarkDevil
                        #2612
                        @mcu das kann ich dir nicht beantworten, dies steht so im Datenpunkt.
                        • D DarkDevil
                          MCU
                          #2613
                          @darkdevil
                          Du hast ja ein vis.0-Verzeichnis. Schau mal, ob es da liegt.
                          FileZilla im Einsatz?
                          • M MCU
                            @darkdevil
                            DarkDevil
                            #2614
                            @mcu sowohl unter Dateien im Gui von Iobroker, als auch mittels Filezilla finde ich die Datei nicht.
                            Ich habe gerade einmal den ioBroker Server nach der Datei "active_song_speaker_green.png" durchsucht, auch ohne fündig zu werden.
                            • D DarkDevil
                              MCU
                              #2615
                              @darkdevil Woher hast du das?
                              • M MCU
                                DarkDevil
                                #2616
                                @mcu wie gesagt, das ist der Wert des Datenpunktest:
                                spotify-premium.0.html.tracks
                                (aktuell läuft keine Playlist)
                                • D DarkDevil
                                  MCU
                                  #2617
                                  @darkdevil Also hab die Daten gefunden.
                                  /opt/iobroker/node_modules/iobroker.spotify-premium/widgets/spotify-premium/img
                                  Wie soll es aussehen?
                                  Hast du eine Vorstellung wie die Steuerung aussehen soll?
                                  Geht nur um die aktuelle PlayList anzeigen?
                                  Hab es mir mal angeschaut. Es sind Icons die anzeigen, ob ein Song gerade läuft.
                                  Sonst nutzt in jarvis den MediaPlayer?
                                  • M MCU
                                    DarkDevil
                                    #2618
                                    @mcu okay, in dem pfad habe ich die Bilder auch gefunden....
                                    es wäre natürlich toll wenn ein Bild anzeigt welcher Tracks gerade läuft, oder eben das die Bilder ganz weg sein
                                    So schauts halt auch komisch aus:
                                    Ich nutze das Mediaplayer Widget von Jarvis (mit Spotify)
                                      MCU
                                      #2619
                                      @darkdevil
                                      • M MCU
                                        @darkdevil
                                        DarkDevil
                                        #2620
                                        @mcu so schaut es richtig gut aus. Was mir allerdings auffällt:
                                        Du hast bei dir eine Beschriftung der Spalten (Aktiv, Title, Name, Dauer und Album) dies habe ich bei mir nicht, es werden die gleichen Werte angezeigt, allerdings ohne die oberste Spalte.
                                        Hast du auch ein StateHtML Widget angelegt und als Gerät den verweis auf das Gerät mit dem Datenpunkt spotify-premium.0.html.tracks ?
                                        • D DarkDevil
                                          MCU
                                          #2621
                                          @darkdevil Ja es ist ein StateHTML, eine StateList und ein MediaControl.
                                          Das StateHTML und Teile von der StateList sind in einem Zusatzprogramm verarbeitet, so dass man z.B. auch aus der PlayList einen Titel direkt anklicken kann.
                                          Hier das neueste Beispiel:
                                          Mit Selected-Track Verschiebung für längere Playlisten
