  4. HM-RPC Adapter keine Werte nach Serverneustart
    5.1k
31 Beiträge 7 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • surfer09S surfer09
    ich habe das Problem, wenn ich meinen IO-Broker Server komplett neu starte, dass der HM-RPC Adapter keine Werte von der CCU bekommt.
    Erst wenn ich den Adapter dann noch einmal manuell neu starte (im LOG um 15:44:27), bekommt er wieder Daten.
    Adapterversion: 1.15.12
    hm-rpc.0
    	2022-06-29 15:44:32.345	info	Connected
    hm-rpc.0
    	2022-06-29 15:44:32.320	info	xmlrpc -> 93 devices
    hm-rpc.0
    	2022-06-29 15:44:32.301	info	xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.287	info	xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.274	info	xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.273	info	xmlrpc server is trying to listen on 0.0.0.0:2001
    hm-rpc.0
    	2022-06-29 15:44:32.183	info	starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
    hm-rpc.0
    	2022-06-29 15:44:27.949	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    hm-rpc.0
    	2022-06-29 15:44:27.948	info	terminating
    hm-rpc.0
    	2022-06-29 15:44:27.948	info	Disconnected
    hm-rpc.0
    	2022-06-29 15:44:27.943	info	xmlrpc -> 192.168.1.100:2001/ init ["http://192.168.1.25:2001",""]
    hm-rpc.0
    	2022-06-29 15:44:27.942	info	Got terminate signal TERMINATE_YOURSELF
    hm-rpc.0
    	2022-06-29 15:35:35.578	info	Connected
    hm-rpc.0
    	2022-06-29 15:35:35.536	info	xmlrpc -> 93 devices
    hm-rpc.0
    	2022-06-29 15:35:35.515	info	xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.512	info	xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.500	info	xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.500	info	xmlrpc server is trying to listen on 0.0.0.0:2001
    hm-rpc.0
    	2022-06-29 15:35:35.183	info	starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
    hm-rpc.0
    	2022-06-29 15:35:32.505	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    hm-rpc.0
    	2022-06-29 15:35:32.504	error	hm-rpc.0 already running
    GlasfaserG Offline
    GlasfaserG Offline
    @surfer09 sagte in HM-RPC Adapter keine Werte nach Serverneustart:
    Diese mal neu gestartet !?
    Welche CCU , aktuelle Firmware usw.
    surfer09S 1 Antwort Letzte Antwort
    • W warp735
      Hab das Problem auch... Aber glaub schon lange. Hab mir angewöhnt hmrega und rpc immer noch mal durchzu starten nach 5min
      surfer09S Offline
      surfer09S Offline
      surfer09
      schrieb am zuletzt editiert von surfer09
      @warp735 sagte in HM-RPC Adapter keine Werte nach Serverneustart:
      Ich hab das Problem auch schon lange. Habe mir aber zuerst nichts dabei gedacht. Da ich meinen Server jetzt aber auch neu installiert habe und der Fehler immer noch besteht, habe ich mir gedacht ich melde es mal.
      • GlasfaserG Glasfaser
        surfer09S Offline
        surfer09S Offline
        surfer09
        @glasfaser sagte in HM-RPC Adapter keine Werte nach Serverneustart:
        @glasfaser CCU3 Firmware 3.63.9
        Nach Serverneustart kommen keine Werte, erst nach manuellem Adapterneustart.
          GlasfaserG Offline
          GlasfaserG Offline
          Ja , das habe ich schon verstanden !
          Die CCU ....
            Die CCU ....
            surfer09S Offline
            surfer09S Offline
            surfer09
            ,@glasfaser Die CCU habe ich nicht neu gestartet, zumindest nicht heute. Seitdem ich das Problem aber habe, habe ich sie schon mal neu gestartet.
              @glasfaser
              Direkt nach dem Serverneustart:
              2022-06-29 16:14:34.743 - debug: hm-rpc.0 (8864) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2022-06-29 16:14:34.758 - debug: hm-rpc.0 (8864) Objects client ready ... initialize now
              2022-06-29 16:14:34.759 - debug: hm-rpc.0 (8864) Objects create System PubSub Client
              2022-06-29 16:14:34.759 - debug: hm-rpc.0 (8864) Objects create User PubSub Client
              2022-06-29 16:14:34.774 - debug: hm-rpc.0 (8864) Objects client initialize lua scripts
              2022-06-29 16:14:34.781 - debug: hm-rpc.0 (8864) Objects connected to redis: 127.0.0.1:9001
              2022-06-29 16:14:34.794 - debug: hm-rpc.0 (8864) Redis States: Use Redis connection: 127.0.0.1:9000
              2022-06-29 16:14:34.798 - debug: hm-rpc.0 (8864) States create System PubSub Client
              2022-06-29 16:14:34.799 - debug: hm-rpc.0 (8864) States create User PubSub Client
              2022-06-29 16:14:34.807 - debug: hm-rpc.0 (8864) States connected to redis: 127.0.0.1:9000
              2022-06-29 16:14:34.808 - error: hm-rpc.0 (8864) hm-rpc.0 already running
              2022-06-29 16:14:34.809 - debug: hm-rpc.0 (8864) Plugin sentry destroyed
              2022-06-29 16:14:34.809 - warn: hm-rpc.0 (8864) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              2022-06-29 16:14:36.884 - debug: hm-rpc.0 (9036) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2022-06-29 16:14:36.899 - debug: hm-rpc.0 (9036) Objects client ready ... initialize now
              2022-06-29 16:14:36.899 - debug: hm-rpc.0 (9036) Objects create System PubSub Client
              2022-06-29 16:14:36.900 - debug: hm-rpc.0 (9036) Objects create User PubSub Client
              2022-06-29 16:14:36.914 - debug: hm-rpc.0 (9036) Objects client initialize lua scripts
              2022-06-29 16:14:36.917 - debug: hm-rpc.0 (9036) Objects connected to redis: 127.0.0.1:9001
              2022-06-29 16:14:36.925 - debug: hm-rpc.0 (9036) Redis States: Use Redis connection: 127.0.0.1:9000
              2022-06-29 16:14:36.930 - debug: hm-rpc.0 (9036) States create System PubSub Client
              2022-06-29 16:14:36.930 - debug: hm-rpc.0 (9036) States create User PubSub Client
              2022-06-29 16:14:36.937 - debug: hm-rpc.0 (9036) States connected to redis: 127.0.0.1:9000
              2022-06-29 16:14:36.959 - debug: hm-rpc.0 (9036) Plugin sentry Initialize Plugin (enabled=true)
              2022-06-29 16:14:37.054 - info: hm-rpc.0 (9036) starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
              2022-06-29 16:14:37.080 - debug: hm-rpc.0 (9036) Schedule restart: 30 5 * * *
              2022-06-29 16:14:37.218 - info: hm-rpc.0 (9036) xmlrpc server is trying to listen on 0.0.0.0:2001
              2022-06-29 16:14:37.218 - info: hm-rpc.0 (9036) xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
              2022-06-29 16:14:37.219 - debug: hm-rpc.0 (9036) Connect...
              2022-06-29 16:14:37.219 - debug: hm-rpc.0 (9036) xmlrpc -> 192.168.1.100:2001/ init ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
              2022-06-29 16:14:37.222 - debug: hm-rpc.0 (9036) start connecting interval
              2022-06-29 16:14:37.231 - info: hm-rpc.0 (9036) xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
              2022-06-29 16:14:37.235 - info: hm-rpc.0 (9036) xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
              2022-06-29 16:14:37.236 - debug: hm-rpc.0 (9036) No suitable Lua script, fallback to keys!: function(doc) {
              if (doc._id.match(/^hm-rpc\.[0-9]+\.\*?[A-Za-z0-9_-]+(\.[0-9]+)?$/)) {
              emit(doc._id, {ADDRESS:(doc.native?doc.native.ADDRESS:''),VERSION:(doc.native?doc.native.VERSION:'')});
              2022-06-29 16:14:37.256 - info: hm-rpc.0 (9036) xmlrpc -> 93 devices
              2022-06-29 16:14:37.279 - info: hm-rpc.0 (9036) Connected
              2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) clear connecting interval
              2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) start ping interval
              2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) xml multicall : IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291,LEQ1003243:0,STICKY_UNREACH,true
              2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291","LEQ1003243:0","STICKY_UNREACH",true]
              2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) hm-rpc.0.LEQ1003243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
              2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xml multicall : IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291,OEQ0015243:0,STICKY_UNREACH,true
              2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291","OEQ0015243:0","STICKY_UNREACH",true]
              2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) hm-rpc.0.OEQ0015243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
              Auf die Klingeltaster gedrückt (Tasterschnittstelle) "no matching device??"
              hm-rpc.0
              	2022-06-29 16:20:02.817	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.INSTALL_TEST:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:20:02.817	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","INSTALL_TEST",true]
              hm-rpc.0
              	2022-06-29 16:20:02.817	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,INSTALL_TEST,true
              hm-rpc.0
              	2022-06-29 16:20:02.814	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.PRESS:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:20:02.814	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:20:02.814	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,PRESS,true
              hm-rpc.0
              	2022-06-29 16:20:01.066	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.INSTALL_TEST:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:20:01.066	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","INSTALL_TEST",true]
              hm-rpc.0
              	2022-06-29 16:20:01.066	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,INSTALL_TEST,true
              hm-rpc.0
              	2022-06-29 16:20:01.064	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.PRESS:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:20:01.064	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:20:01.064	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,PRESS,true
              hm-rpc.0
              	2022-06-29 16:19:59.315	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.INSTALL_TEST:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:19:59.315	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","INSTALL_TEST",true]
              hm-rpc.0
              	2022-06-29 16:19:59.315	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,INSTALL_TEST,true
              hm-rpc.0
              	2022-06-29 16:19:59.313	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.PRESS:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:19:59.313	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:19:59.313	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,PRESS,true
              hm-rpc.0
              	2022-06-29 16:19:57.816	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.INSTALL_TEST:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:19:57.816	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","INSTALL_TEST",true]
              hm-rpc.0
              	2022-06-29 16:19:57.816	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,INSTALL_TEST,true
              hm-rpc.0
              	2022-06-29 16:19:57.815	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.PRESS:true discarded, no matching device
              hm-rpc.0
              	2022-06-29 16:19:57.815	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:19:57.815	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,PRESS,true
              Auf Klingeltastergedrückt, nach manuellem Adapterneustart (Klingel funktioniert):
              hm-rpc.0
              	2022-06-29 16:23:46.343	debug	hm-rpc.0.LEQ0796944.3.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
              hm-rpc.0
              	2022-06-29 16:23:46.342	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:3","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:23:46.342	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:3,PRESS,true
              hm-rpc.0
              	2022-06-29 16:23:42.317	debug	hm-rpc.0.LEQ0796944.3.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
              hm-rpc.0
              	2022-06-29 16:23:42.317	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:3","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:23:42.317	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:3,PRESS,true
              hm-rpc.0
              	2022-06-29 16:23:40.571	debug	hm-rpc.0.LEQ0796944.1.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
              hm-rpc.0
              	2022-06-29 16:23:40.571	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:1","PRESS",true]
              hm-rpc.0
              	2022-06-29 16:23:40.571	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:1,PRESS,true
              GlasfaserG Offline
              GlasfaserG Offline
              Ok ... du startest es auch nach einer Zeit Neu !?
              Teste mal ,
              Instanz ausschalten .... Server neu starten ... alles hochfahren lassen und dann erst später die Instanz einschalten , was ist dann !?
                Teste mal ,
                surfer09S Offline
                surfer09S Offline
                surfer09
                @glasfaser Ja genau. Ich lasse den Adapter morgens einmal neu starten - einfach prophylaktisch.
                Dein Tipp Adapter stoppen, Server neustarten, kurz abwarten, Adapter starten - funktioniert! Die Klingel funktioniert sofort.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @surfer09
                  Jetzt wäre die Große Frage , was blockt die Verbindung ohne eine Fehlermeldung im Log !?
                    @surfer09
                    @glasfaser Netzwerk noch nicht bereit??
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Das kann nur @surfer09 beantworten , bzw. hast du andere Adapter die auf das Netzwerk zugreifen !?
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @surfer09
                        Hast du noch mehr auf deinem Server ... PI-Hole oder so ......!?
                          @surfer09
                          surfer09S Offline
                          surfer09S Offline
                          surfer09
                          @glasfaser Also auf dem Server läuft der ioBroker, Logitech Media Server, Deconz, Avast Virenscanner, Cobian Backup. Der Server ist eine virtuelle Maschine auf einem ESXi.
                          Diese Adapter habe ich installiert:
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            hm-rpc.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Und warum startest du den kompletten Server neu , oder meinst du die VM wird neu gestartet !?
                              surfer09S Offline
                              surfer09S Offline
                              surfer09
                              @glasfaser Wenn ich vom IO Broker Server spreche, meine ich die VM, nicht den ESXi.
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @surfer09
                                Kann ich ja nicht richen .... deshab hab ich ja schon oben gefragt was noch drauf ist
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  OK ... und dann mit :
                                  Windows 10 64bit
                                  warum kein Linux !?
                                  Ich vermute es liegt dann an Windows , wie schon @Homoran schreibt
                                  @homoran sagte in HM-RPC Adapter keine Werte nach Serverneustart:
                                  surfer09S 2 Antworten Letzte Antwort
                                  • R Offline
                                    Ritter
                                    habe auch das gleiche Problem schon länger. Iobroker läuft auf einem NUC mit Windows 64 bit und Raspberrymatic. Nach Windows Neustart keine Werte z.B. Homematic Wetterstation, eine Lampe über VIS kann ich aber steuern. Das Problem trat bei mir nach dem update des neuen JS Controllers auf.
                                      Windows 10 64bit
                                      warum kein Linux !?
                                      surfer09S Offline
                                      surfer09S Offline
                                      surfer09
                                      @glasfaser Ich bin kein Linux-Kenner, Windows habe ich da besser unter Kontrolle.
                                      Der Adapter funktionierte ja aber mal ohne Probleme unter Windows 10 64Bit.
                                      Scheinbar ist das Problem ja auch kein Einzelfall.
                                      Ich könnte den iobroker-Dienst ja mal verzögert starten lassen, um das Problem mit der noch nicht bestehenden Netzwerkverbindung auszuschließen.
                                        Windows 10 64bit
                                        warum kein Linux !?
                                        surfer09S Offline
                                        surfer09S Offline
                                        surfer09
                                        @glasfaser Also Netzwerk ist es auch nicht. Ich habe gerade den IO-Broker Dienst mal später starten lassen nach hochfahren. Es besteht das gleiche Problem.
                                        • W Offline
                                          W Offline
                                          warp735
                                          Bei mir ist ioBroker in einem Docker Container der auf einem Unraid Server läuft. CCU ist Raspberrymatic auf nem Raspi (soll auch auf Unraid umziehen, bekomm aber das Problem mit der ETH Platine nicht gelöst)
                                          Wenn die Raspberrymatic neu gestartet wird, passt alles. Wird der ioBroker Container neugestartet hab ich danach keine Verbindung. Leuchtet aber alles grün. Ist mir erst aufgefallen, als irgendwelche Lampen nicht mehr gingen. Seitdem starte ich wie gesagt immer nochmal durch.
