  4. HM-RPC Adapter keine Werte nach Serverneustart
    5.1k
31 Beiträge 7 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • surfer09S Offline
    surfer09S Offline
    surfer09
    ich habe das Problem, wenn ich meinen IO-Broker Server komplett neu starte, dass der HM-RPC Adapter keine Werte von der CCU bekommt.
    Erst wenn ich den Adapter dann noch einmal manuell neu starte (im LOG um 15:44:27), bekommt er wieder Daten.
    Adapterversion: 1.15.12
    hm-rpc.0
    	2022-06-29 15:44:32.345	info	Connected
    hm-rpc.0
    	2022-06-29 15:44:32.320	info	xmlrpc -> 93 devices
    hm-rpc.0
    	2022-06-29 15:44:32.301	info	xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.287	info	xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.274	info	xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:025be6186ff90b9a5f1be3027ff93e0e"]
    hm-rpc.0
    	2022-06-29 15:44:32.273	info	xmlrpc server is trying to listen on 0.0.0.0:2001
    hm-rpc.0
    	2022-06-29 15:44:32.183	info	starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
    hm-rpc.0
    	2022-06-29 15:44:27.949	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    hm-rpc.0
    	2022-06-29 15:44:27.948	info	terminating
    hm-rpc.0
    	2022-06-29 15:44:27.948	info	Disconnected
    hm-rpc.0
    	2022-06-29 15:44:27.943	info	xmlrpc -> 192.168.1.100:2001/ init ["http://192.168.1.25:2001",""]
    hm-rpc.0
    	2022-06-29 15:44:27.942	info	Got terminate signal TERMINATE_YOURSELF
    hm-rpc.0
    	2022-06-29 15:35:35.578	info	Connected
    hm-rpc.0
    	2022-06-29 15:35:35.536	info	xmlrpc -> 93 devices
    hm-rpc.0
    	2022-06-29 15:35:35.515	info	xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.512	info	xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.500	info	xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:a34cc66205223607b79ae1f8af6e7f85"]
    hm-rpc.0
    	2022-06-29 15:35:35.500	info	xmlrpc server is trying to listen on 0.0.0.0:2001
    hm-rpc.0
    	2022-06-29 15:35:35.183	info	starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
    hm-rpc.0
    	2022-06-29 15:35:32.505	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    hm-rpc.0
    	2022-06-29 15:35:32.504	error	hm-rpc.0 already running
    GlasfaserG HomoranH 4 Antworten Letzte Antwort
    • surfer09S surfer09
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      GlasfaserG Offline
      GlasfaserG Offline
      @surfer09
      Das Log danach mit dem erzwungenen Neustart bring so nicht viel , Interessanter ist davor ob es Fehler dazu gibt !?
      Wenn nicht , Adapter in der Logstufe DEBUG setzten und den Server neu starten was dann kommt / warum er nach deiner Ansicht die Daten nicht abholt ..
      surfer09S 1 Antwort Letzte Antwort
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        @surfer09 was verbirgt sich hinter den IPs ...25 und ...100?
        wo genau läuft dein ioBroker drauf?
        • GlasfaserG Glasfaser
          @surfer09
          surfer09S Offline
          surfer09S Offline
          surfer09
          schrieb am zuletzt editiert von surfer09
          @glasfaser
          Direkt nach dem Serverneustart:
          2022-06-29 16:14:34.743 - debug: hm-rpc.0 (8864) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2022-06-29 16:14:34.758 - debug: hm-rpc.0 (8864) Objects client ready ... initialize now
          2022-06-29 16:14:34.759 - debug: hm-rpc.0 (8864) Objects create System PubSub Client
          2022-06-29 16:14:34.759 - debug: hm-rpc.0 (8864) Objects create User PubSub Client
          2022-06-29 16:14:34.774 - debug: hm-rpc.0 (8864) Objects client initialize lua scripts
          2022-06-29 16:14:34.781 - debug: hm-rpc.0 (8864) Objects connected to redis: 127.0.0.1:9001
          2022-06-29 16:14:34.794 - debug: hm-rpc.0 (8864) Redis States: Use Redis connection: 127.0.0.1:9000
          2022-06-29 16:14:34.798 - debug: hm-rpc.0 (8864) States create System PubSub Client
          2022-06-29 16:14:34.799 - debug: hm-rpc.0 (8864) States create User PubSub Client
          2022-06-29 16:14:34.807 - debug: hm-rpc.0 (8864) States connected to redis: 127.0.0.1:9000
          2022-06-29 16:14:34.808 - error: hm-rpc.0 (8864) hm-rpc.0 already running
          2022-06-29 16:14:34.809 - debug: hm-rpc.0 (8864) Plugin sentry destroyed
          2022-06-29 16:14:34.809 - warn: hm-rpc.0 (8864) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2022-06-29 16:14:36.884 - debug: hm-rpc.0 (9036) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2022-06-29 16:14:36.899 - debug: hm-rpc.0 (9036) Objects client ready ... initialize now
          2022-06-29 16:14:36.899 - debug: hm-rpc.0 (9036) Objects create System PubSub Client
          2022-06-29 16:14:36.900 - debug: hm-rpc.0 (9036) Objects create User PubSub Client
          2022-06-29 16:14:36.914 - debug: hm-rpc.0 (9036) Objects client initialize lua scripts
          2022-06-29 16:14:36.917 - debug: hm-rpc.0 (9036) Objects connected to redis: 127.0.0.1:9001
          2022-06-29 16:14:36.925 - debug: hm-rpc.0 (9036) Redis States: Use Redis connection: 127.0.0.1:9000
          2022-06-29 16:14:36.930 - debug: hm-rpc.0 (9036) States create System PubSub Client
          2022-06-29 16:14:36.930 - debug: hm-rpc.0 (9036) States create User PubSub Client
          2022-06-29 16:14:36.937 - debug: hm-rpc.0 (9036) States connected to redis: 127.0.0.1:9000
          2022-06-29 16:14:36.959 - debug: hm-rpc.0 (9036) Plugin sentry Initialize Plugin (enabled=true)
          2022-06-29 16:14:37.054 - info: hm-rpc.0 (9036) starting. Version 1.15.12 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v16.15.1, js-controller: 4.0.23
          2022-06-29 16:14:37.080 - debug: hm-rpc.0 (9036) Schedule restart: 30 5 * * *
          2022-06-29 16:14:37.218 - info: hm-rpc.0 (9036) xmlrpc server is trying to listen on 0.0.0.0:2001
          2022-06-29 16:14:37.218 - info: hm-rpc.0 (9036) xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
          2022-06-29 16:14:37.219 - debug: hm-rpc.0 (9036) Connect...
          2022-06-29 16:14:37.219 - debug: hm-rpc.0 (9036) xmlrpc -> 192.168.1.100:2001/ init ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
          2022-06-29 16:14:37.222 - debug: hm-rpc.0 (9036) start connecting interval
          2022-06-29 16:14:37.231 - info: hm-rpc.0 (9036) xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
          2022-06-29 16:14:37.235 - info: hm-rpc.0 (9036) xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291"]
          2022-06-29 16:14:37.236 - debug: hm-rpc.0 (9036) No suitable Lua script, fallback to keys!: function(doc) {
          if (doc._id.match(/^hm-rpc\.[0-9]+\.\*?[A-Za-z0-9_-]+(\.[0-9]+)?$/)) {
          emit(doc._id, {ADDRESS:(doc.native?doc.native.ADDRESS:''),VERSION:(doc.native?doc.native.VERSION:'')});
          2022-06-29 16:14:37.256 - info: hm-rpc.0 (9036) xmlrpc -> 93 devices
          2022-06-29 16:14:37.279 - info: hm-rpc.0 (9036) Connected
          2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) clear connecting interval
          2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) start ping interval
          2022-06-29 16:14:37.279 - debug: hm-rpc.0 (9036) xml multicall : IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291,LEQ1003243:0,STICKY_UNREACH,true
          2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291","LEQ1003243:0","STICKY_UNREACH",true]
          2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) hm-rpc.0.LEQ1003243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
          2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xml multicall : IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291,OEQ0015243:0,STICKY_UNREACH,true
          2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:cb10e00673d97b9f3b28ccb982a1f291","OEQ0015243:0","STICKY_UNREACH",true]
          2022-06-29 16:14:37.280 - debug: hm-rpc.0 (9036) hm-rpc.0.OEQ0015243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
          Auf die Klingeltaster gedrückt (Tasterschnittstelle) "no matching device??"
          hm-rpc.0
          	2022-06-29 16:20:02.817	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.INSTALL_TEST:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:20:02.817	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","INSTALL_TEST",true]
          hm-rpc.0
          	2022-06-29 16:20:02.817	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,INSTALL_TEST,true
          hm-rpc.0
          	2022-06-29 16:20:02.814	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.PRESS:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:20:02.814	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:20:02.814	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,PRESS,true
          hm-rpc.0
          	2022-06-29 16:20:01.066	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.INSTALL_TEST:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:20:01.066	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","INSTALL_TEST",true]
          hm-rpc.0
          	2022-06-29 16:20:01.066	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,INSTALL_TEST,true
          hm-rpc.0
          	2022-06-29 16:20:01.064	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.PRESS:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:20:01.064	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:20:01.064	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,PRESS,true
          hm-rpc.0
          	2022-06-29 16:19:59.315	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.INSTALL_TEST:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:19:59.315	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","INSTALL_TEST",true]
          hm-rpc.0
          	2022-06-29 16:19:59.315	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,INSTALL_TEST,true
          hm-rpc.0
          	2022-06-29 16:19:59.313	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.1.PRESS:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:19:59.313	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:1","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:19:59.313	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:1,PRESS,true
          hm-rpc.0
          	2022-06-29 16:19:57.816	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.INSTALL_TEST:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:19:57.816	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","INSTALL_TEST",true]
          hm-rpc.0
          	2022-06-29 16:19:57.816	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,INSTALL_TEST,true
          hm-rpc.0
          	2022-06-29 16:19:57.815	debug	xmlrpc <- event: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f.LEQ0796944.3.PRESS:true discarded, no matching device
          hm-rpc.0
          	2022-06-29 16:19:57.815	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f","LEQ0796944:3","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:19:57.815	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:7a7b719583ee87966fd906b30e4f1f8f,LEQ0796944:3,PRESS,true
          Auf Klingeltastergedrückt, nach manuellem Adapterneustart (Klingel funktioniert):
          hm-rpc.0
          	2022-06-29 16:23:46.343	debug	hm-rpc.0.LEQ0796944.3.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
          hm-rpc.0
          	2022-06-29 16:23:46.342	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:3","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:23:46.342	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:3,PRESS,true
          hm-rpc.0
          	2022-06-29 16:23:42.317	debug	hm-rpc.0.LEQ0796944.3.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
          hm-rpc.0
          	2022-06-29 16:23:42.317	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:3","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:23:42.317	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:3,PRESS,true
          hm-rpc.0
          	2022-06-29 16:23:40.571	debug	hm-rpc.0.LEQ0796944.1.PRESS ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
          hm-rpc.0
          	2022-06-29 16:23:40.571	debug	xmlrpc <- event ["IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353","LEQ0796944:1","PRESS",true]
          hm-rpc.0
          	2022-06-29 16:23:40.571	debug	xml multicall <event>: IOBroker-Server:hm-rpc.0:defd888ef20521f7492a1f78f4819353,LEQ0796944:1,PRESS,true
            surfer09S Offline
            surfer09S Offline
            surfer09
            @homoran IOBroker Server: 192.168.1.25, CCU: 192.168.1.100. Die CCU hat die Firmware 3.63.9.
              @surfer09 sagte: IOBroker Server: 192.168.1.25
              Dann wähle diese IP-Adresse mal als "Adapter Adresse" aus.
                surfer09S Offline
                surfer09S Offline
                surfer09
                @paul53 Das habe ich gerade gemacht, danach Server Neustart, immer noch das gleiche Problem.
                • W Offline
                  W Offline
                  warp735
                  Hab das Problem auch... Aber glaub schon lange. Hab mir angewöhnt hmrega und rpc immer noch mal durchzu starten nach 5min
                  GlasfaserG surfer09S 2 Antworten Letzte Antwort
                  • W warp735
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @warp735 sagte in HM-RPC Adapter keine Werte nach Serverneustart:
                    Auch die gleiche Hardware ... Docker / Adapter Callback ... usw. !?
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      hm-rpc.0
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @surfer09 sagte in HM-RPC Adapter keine Werte nach Serverneustart:
                      Diese mal neu gestartet !?
                      Welche CCU , aktuelle Firmware usw.
                      • W warp735
                        surfer09S Offline
                        surfer09S Offline
                        surfer09
                        Ich hab das Problem auch schon lange. Habe mir aber zuerst nichts dabei gedacht. Da ich meinen Server jetzt aber auch neu installiert habe und der Fehler immer noch besteht, habe ich mir gedacht ich melde es mal.
                          surfer09S Offline
                          surfer09S Offline
                          surfer09
                          @glasfaser sagte in HM-RPC Adapter keine Werte nach Serverneustart:
                          @glasfaser CCU3 Firmware 3.63.9
                          Nach Serverneustart kommen keine Werte, erst nach manuellem Adapterneustart.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Ja , das habe ich schon verstanden !
                            Die CCU ....
                              Die CCU ....
                              surfer09S Offline
                              surfer09S Offline
                              surfer09
                              ,@glasfaser Die CCU habe ich nicht neu gestartet, zumindest nicht heute. Seitdem ich das Problem aber habe, habe ich sie schon mal neu gestartet.
                                @glasfaser
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                hm-rpc.0
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Ok ... du startest es auch nach einer Zeit Neu !?
                                Teste mal ,
                                Instanz ausschalten .... Server neu starten ... alles hochfahren lassen und dann erst später die Instanz einschalten , was ist dann !?
                                  Teste mal ,
                                  surfer09S Offline
                                  surfer09S Offline
                                  surfer09
                                  @glasfaser Ja genau. Ich lasse den Adapter morgens einmal neu starten - einfach prophylaktisch.
                                  Dein Tipp Adapter stoppen, Server neustarten, kurz abwarten, Adapter starten - funktioniert! Die Klingel funktioniert sofort.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @surfer09
                                    Jetzt wäre die Große Frage , was blockt die Verbindung ohne eine Fehlermeldung im Log !?
                                      @surfer09
                                      @glasfaser Netzwerk noch nicht bereit??
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Das kann nur @surfer09 beantworten , bzw. hast du andere Adapter die auf das Netzwerk zugreifen !?
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @surfer09
                                          Hast du noch mehr auf deinem Server ... PI-Hole oder so ......!?
