  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
    @firebowl
    Was kommt auf die obigen Befehlszeilen zurück?
    firebowl
    #545
    @thomas-braun Das Ergebnis sieht so aus:
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "bshb"         : 0.1.20   , installed 0.1.20
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.7    , installed 1.0.7
    Adapter    "eusec"        : 0.9.1    , installed 0.9.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
    Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
    Adapter    "hs100"        : 2.0.7    , installed 2.0.7
    Adapter    "hue"          : 3.7.0    , installed 3.7.0
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
    Adapter    "meross"       : 1.10.5   , installed 1.10.5
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "nuki-extended": 2.3.1    , installed 2.6.5
    Adapter    "nut"          : 1.5.1    , installed 1.5.1
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
    x86_64
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v14.19.3
    v16.15.1
    8.11.0
    mike
    OK:1 http://de.archive.ubuntu.com/ubuntu impish InRelease
    OK:2 https://packages.grafana.com/oss/deb stable InRelease
    OK:3 http://de.archive.ubuntu.com/ubuntu impish-updates InRelease
    OK:4 https://repos.influxdata.com/ubuntu bionic InRelease
    OK:5 https://deb.nodesource.com/node_14.x impish InRelease
    OK:6 http://de.archive.ubuntu.com/ubuntu impish-backports InRelease
    OK:7 http://de.archive.ubuntu.com/ubuntu impish-security InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           14.19.3-deb-1nodesource1
      Installationskandidat: 14.19.3-deb-1nodesource1
      Versionstabelle:
     *** 14.19.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x impish/main amd64 Packages
         12.22.5~dfsg-5ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu impish/universe amd64 Packages
    • F firebowl
      x86_64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.19.3
      v16.15.1
      8.11.0
      mike
      nodejs:
        Versionstabelle:
      #546
      @firebowl Dann kann ich dir sagen, dass nodejs falsch installiert ist und die .list-Datei für influxdb hat auch einen falschen Eintrag.
      Dein Ubuntu wird noch 3 Wochen unterstützt. Wechsel auf die derzeitige LTS-Version. 22.04 ist das wohl
      Die wichtigste Frage ist:
      Wie hast du nodejs16 installiert? Welche Anleitung?
      F 1 Antwort Letzte Antwort
        firebowl
        #547
        @thomas-braun aktuell läuft das release upgrade. Ich hätte schwören können, ich hab nodejs16 über die Anleitung für ioBroker installiert. In dieser VM läuft auch sonst nix anderes, die Maschine ist rein der ioBroker mit InfluxDB und Grafana.
        • F firebowl
          #548
          @firebowl sagte in Test Adapter Nuki-extended v2.0.x:
          Welche?
          • F Offline
            firebowl
            #549
            @thomas-braun Kann ich dir nicht mehr genau sagen. Ich vermute es war diese.
            Welche ist denn die "richtige"? Release upgrade ist durch.
            • F firebowl
              #550
              @firebowl
              Och Mann, warum können sich die ganzen 'Falschinstallierer' denn nie daran erinnern wie sie zu den Installationen in /usr/local/bin kommen?
              In meiner Signatur steht drin, wie man es macht.
              Wobei die Anleitung von stabilostick auch zum richtigen Ergebnis führen sollte. Was wird also immer anders gemacht?
                @firebowl
                firebowl
                schrieb am zuletzt editiert von firebowl
                #551
                @thomas-braun Hab versucht es nach deiner Anleitung zu fixen aber ich glaub jetzt ist mehr kaputt als vorher. Die Pfade passen jetzt zwar aber jetzt passen ihm Abhängigkeiten nicht mehr.
                [sudo] password for mike:
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.19.3
                v14.19.3
                6.14.17
                mike
                /home/mike
                OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                OK:2 https://deb.nodesource.com/node_14.x impish InRelease
                OK:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                OK:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                nodejs:
                  Versionstabelle:
                     12.22.9~dfsg-1ubuntu3 500
                        500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                npm ERR! missing: @angular/common@14.0.3, required by iobroker.inst@3.0.0
                npm ERR! missing: @angular/core@14.0.3, required by iobroker.inst@3.0.0
                npm ERR! missing: zone.js@0.11.6, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.device-watcher@git+ssh://git@github.com/ciddi89/ioBroker.device-watcher.git#da0035195e1c35025429da30187e7443fe503bed, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.switchbot-hub@git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e, required by iobroker.inst@3.0.0
                npm ERR! extraneous: @angular/common@14.0.3 /opt/iobroker/node_modules/@angular/common
                npm ERR! extraneous: @angular/core@14.0.3 /opt/iobroker/node_modules/@angular/core
                npm ERR! extraneous: zone.js@0.11.6 /opt/iobroker/node_modules/zone.js
                npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.device-watcher@git+ssh://git@github.com/ciddi89/ioBroker.device-watcher.git#da0035195e1c35025429da30187e7443fe503bed
                npm ERR! missing: @types/iobroker@4.0.4, required by @iobroker/adapter-core@2.6.0
                npm ERR! missing: @types/node@12.20.55, required by iobroker.javascript@5.7.0
                npm ERR! missing: @types/node@12.20.55, required by @types/iobroker@4.0.3
                npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                npm ERR! missing: body-parser@1.20.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                npm ERR! missing: express@4.18.1, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                npm ERR! missing: ip@2.0.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                npm ERR! missing: bytes@3.1.2, required by body-parser@1.20.0
                npm ERR! missing: depd@2.0.0, required by body-parser@1.20.0
                npm ERR! missing: destroy@1.2.0, required by body-parser@1.20.0
                npm ERR! missing: http-errors@2.0.0, required by body-parser@1.20.0
                npm ERR! missing: on-finished@2.4.1, required by body-parser@1.20.0
                npm ERR! missing: qs@6.10.3, required by body-parser@1.20.0
                npm ERR! missing: raw-body@2.5.1, required by body-parser@1.20.0
                npm ERR! missing: depd@2.0.0, required by http-errors@2.0.0
                npm ERR! missing: inherits@2.0.4, required by http-errors@2.0.0
                npm ERR! missing: setprototypeof@1.2.0, required by http-errors@2.0.0
                npm ERR! missing: statuses@2.0.1, required by http-errors@2.0.0
                npm ERR! missing: toidentifier@1.0.1, required by http-errors@2.0.0
                npm ERR! missing: bytes@3.1.2, required by raw-body@2.5.1
                npm ERR! missing: http-errors@2.0.0, required by raw-body@2.5.1
                npm ERR! missing: accepts@1.3.8, required by express@4.18.1
                npm ERR! missing: body-parser@1.20.0, required by express@4.18.1
                npm ERR! missing: content-disposition@0.5.4, required by express@4.18.1
                npm ERR! missing: cookie@0.5.0, required by express@4.18.1
                npm ERR! missing: depd@2.0.0, required by express@4.18.1
                npm ERR! missing: finalhandler@1.2.0, required by express@4.18.1
                npm ERR! missing: http-errors@2.0.0, required by express@4.18.1
                npm ERR! missing: on-finished@2.4.1, required by express@4.18.1
                npm ERR! missing: qs@6.10.3, required by express@4.18.1
                npm ERR! missing: safe-buffer@5.2.1, required by express@4.18.1
                npm ERR! missing: send@0.18.0, required by express@4.18.1
                npm ERR! missing: serve-static@1.15.0, required by express@4.18.1
                npm ERR! missing: setprototypeof@1.2.0, required by express@4.18.1
                npm ERR! missing: statuses@2.0.1, required by express@4.18.1
                npm ERR! missing: negotiator@0.6.3, required by accepts@1.3.8
                npm ERR! missing: safe-buffer@5.2.1, required by content-disposition@0.5.4
                npm ERR! missing: on-finished@2.4.1, required by finalhandler@1.2.0
                npm ERR! missing: statuses@2.0.1, required by finalhandler@1.2.0
                npm ERR! missing: depd@2.0.0, required by send@0.18.0
                npm ERR! missing: destroy@1.2.0, required by send@0.18.0
                npm ERR! missing: http-errors@2.0.0, required by send@0.18.0
                npm ERR! missing: ms@2.1.3, required by send@0.18.0
                npm ERR! missing: on-finished@2.4.1, required by send@0.18.0
                npm ERR! missing: statuses@2.0.1, required by send@0.18.0
                npm ERR! missing: send@0.18.0, required by serve-static@1.15.0
                npm ERR! missing: axios@0.21.4, required by iobroker.switchbot-hub@git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e
                mike@iobroker:/opt/iobroker$
                Korrektur, war mein Fehler. Jetzt sieht es so aus:
                mike@iobroker:~$ iobroker update -i
                uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                cd /opt/iobroker
                npm ls | grep 'ERR|github'
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.15.1
                v16.15.1
                8.11.0
                mike
                /home/mike
                OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                nodejs:
                  Installiert:           16.15.1-deb-1nodesource1
                  Installationskandidat: 16.15.1-deb-1nodesource1
                  Versionstabelle:
                 *** 16.15.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                        500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                • F firebowl
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.3
                  v14.19.3
                  6.14.17
                  mike
                  /home/mike
                  nodejs:
                    Versionstabelle:
                  cd /opt/iobroker
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.15.1
                  v16.15.1
                  8.11.0
                  mike
                  /home/mike
                  nodejs:
                    Versionstabelle:
                  #552
                  @firebowl
                  Immer noch Chaos...
                  Die Releasenames müssen passen. Jetzt haste da jammy, impish, bullseye und was weiß ich noch drin. Das ist falsch! Das muss alles gleich lauten! Und zwar auf das verwendete Release.
                    @firebowl
                    Immer noch Chaos...
                    firebowl
                    #553
                    @thomas-braun Danke für den Hinweis aber leider bekomme ich die Einträge nicht weg:
                    mike@iobroker:~$ sudo apt update
                    Meine sources.list sieht meiner Meinung nach ok aus:
                      GNU nano 6.2                                      /etc/apt/sources.list *
                    ## team. Also, please note that software in universe WILL NOT receive any
                    ## review or updates from the Ubuntu security team.
                    deb http://de.archive.ubuntu.com/ubuntu jammy universe
                    deb http://de.archive.ubuntu.com/ubuntu jammy-updates universe
                    ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
                    ## team, and may not be under a free licence. Please satisfy yourself as to
                    ## your rights to use the software. Also, please note that software in
                    ## multiverse WILL NOT receive any review or updates from the Ubuntu
                    ## security team.
                    deb http://de.archive.ubuntu.com/ubuntu jammy multiverse
                    deb http://de.archive.ubuntu.com/ubuntu jammy-updates multiverse
                    ## N.B. software from this repository may not have been tested as
                    ## extensively as that contained in the main release, although it includes
                    ## newer versions of some applications which may provide useful features.
                    ## Also, please note that software in backports WILL NOT receive any review
                    ## or updates from the Ubuntu security team.
                    deb http://de.archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
                    deb http://de.archive.ubuntu.com/ubuntu jammy-security main restricted
                    deb http://de.archive.ubuntu.com/ubuntu jammy-security universe
                    deb http://de.archive.ubuntu.com/ubuntu jammy-security multiverse
                    • F firebowl
                      ## security team.
                      #554
                      @firebowl
                      Die weiteren Dateien liegen in /etc/apt/sources.list.d/
                      Die müssen alle auf jammy umgestellt werden.
                      Sollte aber nur die nodesource.list betreffen
                        @firebowl
                        firebowl
                        #555
                        @thomas-braun Argh, die hatte ich übersehen, danke dir.
                        cd /opt/iobroker
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.15.1
                        v16.15.1
                        8.11.0
                        mike
                        /home/mike
                        OK:2 https://deb.nodesource.com/node_14.x jammy InRelease
                        OK:6 https://deb.nodesource.com/node_16.x jammy InRelease
                        nodejs:
                          Versionstabelle:
                                500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                                500 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages
                        • F firebowl
                          cd /opt/iobroker
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          mike
                          /home/mike
                          nodejs:
                            Versionstabelle:
                          #556
                          @firebowl
                          Und dein Problem ist jetzt behoben?
                            @firebowl
                            firebowl
                            #557
                            @thomas-braun Sieht so aus, lag scheinbar an der veralteten NPM, wie Du gesagt hast. :)
                            Vielen Dank für die Unterstützung!
                            • ? Offline
                              #558
                              Bei mir steht gelegentlich. "verbunden mit Gerät oder Dienst" das dies rot oder gelb ist. Also das scheint nicht grün zu sein. Wenn ich den Adapter dann aber neu starte, geht wieder alle. Kann ich eine Routine einbauen, die das automatisch macht? Habt ihr diese Anomalie auch?
                                @legro
                                Horst BöttcherH Offline
                                Horst Böttcher
                                #559
                                @thomas-braun wenn ich auf die katze gehe habe ich kein vom npm installieren
                                ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                                • Horst BöttcherH Horst Böttcher
                                  #560
                                  @horst-böttcher
                                  Ich schon. Screenshot?
                                  Horst BöttcherH 1 Antwort Letzte Antwort
                                    @horst-böttcher
                                    Horst Böttcher
                                    #561
                                      #562
                                      @horst-böttcher
                                      iobroker update -i
                                      zeigen.
                                        @horst-böttcher
                                        iobroker update -i
                                        zeigen.
                                        Horst Böttcher
                                        #563
                                        pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                        Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                                        Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                        Adapter    "chromecast"   : 2.3.1    , installed 3.0.1
                                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                        Adapter    "devices"      : 1.0.12   , installed 1.0.12
                                        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                        Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                                        Adapter    "history"      : 1.11.1   , installed 1.11.1
                                        Adapter    "hmip"         : 1.17.0   , installed 1.17.0
                                        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                        Adapter    "node-red"     : 3.3.1    , installed 3.3.0  [Updatable]
                                        Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                                        Adapter    "openweathermap": 0.2.4   , installed 0.2.4
                                        Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
                                        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                        Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                        Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                                        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                        Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                          #564
                                          @horst-böttcher
                                          Hast du im Admin noch auf 'alte Oberfläche' gestellt?
