  4. Migration von Docker IOB auf PI4 möglich?
    5.8k
47 Beiträge 4 Kommentatoren 5.9k Aufrufe 2 Beobachtet
  • F Offline
    Fuga
    Ich werde es heute abend noch mal versuchen und dann auf das Log achten. Kann ich das über cli öffnen und dann den Fortschritt verfolgen? Sorry habe da nicht so den Plan. Danke
    • F Fuga
      @fuga
      iobroker logs --watch | uniq
      • F Offline
        Fuga
        Hier mal ein zwischenstand. ich lasse das jetzt mal laufen:
        2022-06-25 19:12:50.164  - info: backitup.0 (5969) [iobroker] backup was activated at 02:40 every 1 day(s)
        2022-06-25 19:14:07.230  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-06-25 19:14:07.274  - info: backitup.0 (5969) Got terminate signal TERMINATE_YOURSELF
        2022-06-25 19:14:07.275  - info: backitup.0 (5969) cleaned everything up...
        2022-06-25 19:14:07.276  - info: backitup.0 (5969) terminating
        2022-06-25 19:14:07.278  - info: backitup.0 (5969) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-06-25 19:14:07.312  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2022-06-25 19:14:07.820  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-06-25 19:14:10.369  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 5985
        2022-06-25 19:14:11.916  - info: backitup.0 (5985) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.12, js-controller: 4.0.23
        2022-06-25 19:14:11.981  - info: backitup.0 (5985) [iobroker] backup was activated at 02:40 every 1 day(s)
        2022-06-25 19:14:30.551  - info: backitup.0 (5985) cleaned everything up...
        2022-06-25 19:14:30.553  - info: host.raspberrypi received SIGTERM
        2022-06-25 19:14:30.552  - info: admin.0 (5894) terminating http server on port 8081
        2022-06-25 19:14:30.555  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-06-25 19:14:30.556  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-06-25 19:14:30.557  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-06-25 19:14:30.576  - info: discovery.0 (5909) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-25 19:14:30.578  - info: backitup.0 (5985) Got terminate signal TERMINATE_YOURSELF
        2022-06-25 19:14:30.579  - info: discovery.0 (5909) Got terminate signal TERMINATE_YOURSELF
        2022-06-25 19:14:30.584  - info: backitup.0 (5985) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-25 19:14:30.585  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
        2022-06-25 19:14:30.587  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
        2022-06-25 19:14:30.576  - info: admin.0 (5894) Got terminate signal TERMINATE_YOURSELF
        2022-06-25 19:14:30.588  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2022-06-25 19:14:30.596  - info: admin.0 (5894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-06-25 19:14:31.119  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-25 19:14:31.138  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-25 19:14:31.149  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-06-25 19:14:31.152  - info: host.raspberrypi All instances are stopped.
        2022-06-25 19:14:31.193  - info: host.raspberrypi terminated
        2022-06-25 19:16:55.061  - info: host.f612e8de0886 iobroker.js-controller version 4.0.23 js-controller starting
        2022-06-25 19:16:55.067  - info: host.f612e8de0886 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-06-25 19:16:55.068  - info: host.f612e8de0886 hostname: f612e8de0886, node: v12.22.12
        2022-06-25 19:16:55.068  - info: host.f612e8de0886 ip addresses: 192.168.1.3 fe80::d17a:9f4c:b584:4595
        2022-06-25 19:16:56.853  - info: host.f612e8de0886 connected to Objects and States
        2022-06-25 19:16:56.934  - info: host.f612e8de0886 added notifications configuration of host
        2022-06-25 19:16:56.941  - info: host.f612e8de0886 Node.js version has changed from 12.20.1 to 12.22.12
        2022-06-25 19:16:57.001  - info: host.f612e8de0886 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2022-06-25 19:16:57.741  - info: host.f612e8de0886 Delete host system.host.raspberrypi
        2022-06-25 19:16:57.917  - info: host.f612e8de0886 71 instances found
        2022-06-25 19:16:57.947  - warn: host.f612e8de0886 does not start any instances on this host
        • F Fuga
          @fuga
          Deine Systemzeit ist auch falsch eingestellt, scheint mir.
          Deine node-Version ist zu niedrig:
          • F Fuga
            @fuga Multihost?
            F 1 Antwort Letzte Antwort
              @fuga Multihost?
              Fuga
              @homoran nein eigentlich nicht.
              @Thomas-Braun heißt erst den alten auf die gleiche Version bringen und dann nochmal?
              • F Fuga
                @fuga
                Ich würden den Docker auf nodejs16 bringen, wenn das läuft davon ein Backup ziehen, dann im Pi einen leeren iobroker installieren, der bringt dann auch gleich node16 mit und dann da das Backup einspielen.
                  @fuga
                  Fuga
                  @thomas-braun okay probiere ich und gebe Rückmeldung. danke
                  • F Fuga
                    @fuga sagte in Migration von Docker IOB auf PI4 möglich?:
                    warum dann zwei unterschiedliche Hostnamen?
                    Außerdem ist die Feage noch offen.
                    @homoran sagte in Migration von Docker IOB auf PI4 möglich?:
                    mit Backitup?
                    bitte immer zeitnah antworten.
                      mit Backitup?
                      Fuga
                      schrieb am zuletzt editiert von Fuga
                      @homoran sorry bin ein wenig langsam ;) ja das Backup habe ich mit Backitup gemacht. Den Hostnamen hatte ich nicht beachtet. Spielt das eine rolle?
                      • F Fuga
                        @fuga Backitup macht ein iobroker host this bevor iobroker gestartet wird, dann wird die noch offene Frage
                        erst recht interessant
                        • F Fuga
                          bitte nicht editieren, das liest nachträglich niemand mehr.
                          ja spielt es. bei nicht identischem Hostnamen i.Vgl. zum Backup startet womöglich die Installation nicht
                            Fuga
                            @homoran okay dann werde ich das anpassen und einen neuen versuch starten. Gibt es probleme wenn 2 gleiche Hostnamen in einem Netztwerk sind? ich will den alten erst runterfahren wenn der neue funktioniert. danke
                            • F Fuga
                              Ja.
                              • F Fuga
                                was genau und wie?
                                ja, beim DNS
                                dann muss der neuen Installation der neue Hostname nochmals bekannt gemacht werden, wobei mich interessiert, warum das nicht geschehen ist
                                  was genau und wie?
                                  ja, beim DNS
                                  Fuga
                                  @homoran said in Migration von Docker IOB auf PI4 möglich?:
                                  was genau und wie?
                                  ich würde den pi4 nochmal neu aufsetzen mit dem gleichen Hostnamen
                                  ja, beim DNS
                                  okay
                                  weil ich drauf nicht geachtet habe. ich habe einfach einen pi4 neu aufgesetzt und das Backup eingespielt
                                  • F Fuga
                                    was genau und wie?
                                    ja, beim DNS
                                    okay
                                    wenn das Backup sauber war, sollte mit backitup das restore dem neuen host zugeordnet werden
                                    @fuga zeig mal iobroker list instances
                                      Fuga
                                      @homoran von dem alten?
                                      • F Fuga
                                        von da wo wir die ganze Zeit dran sind
                                          Fuga
                                          @homoran das ist der Stand, nachdem ich das Backup eingespielt habe:
                                           system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                            system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                            system.adapter.daswetter.1              : daswetter             : raspberrypi                              - disabled
                                            system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                                            system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              - disabled
                                            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                            system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                                            system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                                            system.adapter.geofency.0               : geofency              : raspberrypi                              - disabled, port: 7999
                                            system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                                            system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                                            system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                                            system.adapter.homeconnect.1            : homeconnect           : raspberrypi                              - disabled
                                            system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
                                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                                            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                            system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                                            system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                                            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                                            system.adapter.javascript.1             : javascript            : raspberrypi                              - disabled
                                            system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
                                            system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                                            system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
                                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 0.0.0.0
                                            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                            system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
                                            system.adapter.roomba.0                 : roomba                : raspberrypi                              - disabled
                                            system.adapter.samsung.0                : samsung               : raspberrypi                              - disabled
                                            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.solarwetter.0            : solarwetter           : raspberrypi                              - disabled
                                            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.sunnyportal.0            : sunnyportal           : raspberrypi                              - disabled
                                            system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
                                            system.adapter.synology.1               : synology              : raspberrypi                              - disabled, port: 5001
                                            system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                                            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.virtualpowermeter.0      : virtualpowermeter     : raspberrypi                              - disabled
                                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              - disabled
                                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                                            system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
                                            system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                            system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                                            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
                                            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
