  4. Zigebee adapter nach re-install nicht da
    5.8k
15 Beiträge 4 Kommentatoren 898 Aufrufe 4 Beobachtet
  • Fred FreundF Fred Freund
    @haus-automatisierung beim mir trat leider das sonst schon nicht ein :-)
    zigbee.0
    	2022-06-17 10:43:55.130	error	Error herdsman start
    zigbee.0
    	2022-06-17 10:43:55.129	error	Failed to start Zigbee
    zigbee.0
    	2022-06-17 10:43:55.127	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    habe das selbe Problem wie mit der zweiten Instanz vorher
    arteckA Offline
    arteckA Offline
    arteck
    @fred-freund zeigmal die Einstellungen..auf welcher Maschiene läuft der iobroker ?
    Fred FreundF 1 Antwort Letzte Antwort
    • arteckA arteck
      Fred FreundF Offline
      Fred Freund
      schrieb am zuletzt editiert von Fred Freund
      zigbee.0
      	2022-06-17 10:59:42.652	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
      zigbee.0
      	2022-06-17 10:59:11.965	error	Error herdsman start
      zigbee.0
      	2022-06-17 10:59:11.965	error	Failed to start Zigbee
      zigbee.0
      	2022-06-17 10:59:11.963	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2022-06-17 10:59:11.703	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      	2022-06-17 10:59:11.662	info	Starting Zigbee npm ...
      zigbee.0
      	2022-06-17 10:59:11.660	info	Try to reconnect. 1 attempts left
      zigbee.0
      	2022-06-17 10:59:01.656	error	Error herdsman start
      zigbee.0
      	2022-06-17 10:59:01.656	error	Failed to start Zigbee
      zigbee.0
      	2022-06-17 10:59:01.655	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      	2022-06-17 10:59:01.472	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      	2022-06-17 10:59:01.471	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      	2022-06-17 10:59:01.471	error	Please update configuration to prevent further issues.
      zigbee.0
      	2022-06-17 10:59:01.470	error	- Channel List: configured=26, adapter=26
      zigbee.0
      	2022-06-17 10:59:01.469	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0
      	2022-06-17 10:59:01.469	error	- Extended PAN ID: configured=baefcdfabeadcead, adapter=00124b0026b7a94c
      zigbee.0
      	2022-06-17 10:59:01.468	error	- PAN ID: configured=1238, adapter=1238
      zigbee.0
      	2022-06-17 10:59:01.467	error	Configuration is not consistent with adapter state/backup!
      werde mal meinen ti 26x2r1 probieren
      many Thx for your support,
      Vielen Dank!
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        arteckA Offline
        arteckA Offline
        arteck
        @fred-freund sagte in Zigebee adapter nach re-install nicht da:
        das stimmt nicht..
        • arteckA arteck
          das stimmt nicht..
          Fred Freund
          @arteck ???
          hab jetzt den ti und der geht mit gelicher Einstellung...
          was stimmt da nicht?
          usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00cd164c0712ec11ba4c21c7bd930c07-if00-port0
          usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100NSU-if00
          usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100NSU-if03
          moeglicherweise den Sonoff neu flashen?
          Vielen Dank!
            @arteck ???
            arteckA Offline
            arteckA Offline
            arteck
            @fred-freund na klar geht der weil die Konfig jetzt neu geschrieben worden ist und die alte gelöscht. nach dem Coordinator tausch.
            das regelt der adapter intern
            • arteckA arteck
              Fred Freund
              @arteck tut mir leid kann dir absolut nicht folgen...wie kann ich den Fehler beim anderen ausbessern?
              bzw wo sehe ich was richtig waere?
              ich hoffe wenn ich die nv...database der zigbee wieder aktiviere das die dann alle gehen...komisch war das ich nicht pairen konnte..
              leider immer noch das gleiche...
              zumindest startet er interview...vorher war 0
              Vielen Dank!
              arteckA JLegJ 2 Antworten Letzte Antwort
                arteckA Offline
                arteckA Offline
                arteck
                ich dir langsam auch nicht.. sry
                wechsel hier wechsel da starte das nicht dann löschen dann .. neu .. dann tauschen.
                  JLegJ Offline
                  JLegJ Offline
                  JLeg
                  er meinte wohl, du solltest evtl. die Fehlermeldungen genauer lesen, und z.B. bei sowas
                  die konfigurierte PAN-ID der Zigbee-Instanz der des Adapters einfach mal angleichen...
                  • JLegJ JLeg
                    Fred Freund
                    @jleg angleichen an was? an die Adapter id?
                    ich gebs mit zigbee bald auf...
                    Vielen Dank!
                    • arteckA arteck
                      Fred Freund
                      @arteck ich will nur das das ding paired..hatte alles schon am laufen ..nur dann ging nix mehr...und dann hab ich
                      diese Probleme
                      musste den pi mit zigbee an die Lampe auf 5cm ran...sonst paired der nicht und seit kurzem ueberhaupt nicht mehr.
                      hab dann 2531 auf 26x2r1 umgestellt auch nicht...dann noch sonoff gekauft...
                      Vielen Dank!
