  4. Sonoff Zigbee Stick im Adapter nicht erkannt
    6.3k
23 Beiträge 4 Kommentatoren 3.1k Aufrufe 4 Beobachtet
  • V vqe17235
    hab ich getan, scheint aber leider nicht geholfen zu haben:
    2022-05-16 18:10:09.746  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-05-16 18:10:12.243  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2603
    2022-05-16 18:10:14.647  - debug: zigbee.0 (2603) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-05-16 18:10:14.696  - debug: zigbee.0 (2603) Objects client ready ... initialize now
    2022-05-16 18:10:14.699  - debug: zigbee.0 (2603) Objects create System PubSub Client
    2022-05-16 18:10:14.700  - debug: zigbee.0 (2603) Objects create User PubSub Client
    2022-05-16 18:10:14.758  - debug: zigbee.0 (2603) Objects client initialize lua scripts
    2022-05-16 18:10:14.765  - debug: zigbee.0 (2603) Objects connected to redis: 127.0.0.1:9001
    2022-05-16 18:10:14.798  - debug: zigbee.0 (2603) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-05-16 18:10:14.817  - debug: zigbee.0 (2603) States create System PubSub Client
    2022-05-16 18:10:14.818  - debug: zigbee.0 (2603) States create User PubSub Client
    2022-05-16 18:10:14.848  - debug: zigbee.0 (2603) States connected to redis: 127.0.0.1:9000
    2022-05-16 18:10:14.960  - debug: zigbee.0 (2603) Plugin sentry Initialize Plugin (enabled=true)
    2022-05-16 18:10:15.342  - info: zigbee.0 (2603) starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
    2022-05-16 18:10:15.385  - debug: zigbee.0 (2603) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[88,242,222,188,90,137,132,21]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24523334e35fec1192ca385f25bfaa52-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
    2022-05-16 18:10:15.443  - info: zigbee.0 (2603) Starting Zigbee  npm ...
    2022-05-16 18:10:15.444  - debug: zigbee.0 (2603) Starting zigbee-herdsman...
    2022-05-16 18:10:15.951  - debug: zigbee.0 (2603) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_05_16-18_10_15.tar.gz success
    2022-05-16 18:10:15.960  - info: zigbee.0 (2603) Installed Version: iobroker.zigbee@1.6.18
    2022-05-16 18:10:36.144  - error: zigbee.0 (2603) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2022-05-16 18:10:36.145  - error: zigbee.0 (2603) Failed to start Zigbee
    2022-05-16 18:10:36.145  - error: zigbee.0 (2603) Error herdsman start
    2022-05-16 18:10:46.148  - info: zigbee.0 (2603) Try to reconnect. 1 attempts left
    2022-05-16 18:10:46.153  - info: zigbee.0 (2603) Starting Zigbee  npm ...
    2022-05-16 18:10:46.155  - debug: zigbee.0 (2603) Starting zigbee-herdsman...
    2022-05-16 18:10:46.209  - info: zigbee.0 (2603) Installed Version: iobroker.zigbee@1.6.18
    2022-05-16 18:10:46.468  - error: zigbee.0 (2603) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2022-05-16 18:10:46.470  - error: zigbee.0 (2603) Failed to start Zigbee
    2022-05-16 18:10:46.471  - error: zigbee.0 (2603) Error herdsman start
    @vqe17235 sagte in Sonoff Zigbee Stick im Adapter nicht erkannt:
    Ist oft ein Problem mit der Firmware des Sticks.
    Welche ist da drauf?
    V 1 Antwort Letzte Antwort
      V Offline
      V Offline
      vqe17235
      die firmware habe ich bisher nicht angefasst. kann ich die am raspberry auslesen?
      Müsste ich da so eine firmware installieren?
      https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0
      • V vqe17235
        Bei einem 'ordentlichen' Start des Sticks/Adapters wird die ausgeworfen.
        Schaut dann so aus:
        2022-05-16 18:32:39.467  - info: zigbee.0 (37350) starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.1.0, js-controller: 4.0.23
        2022-05-16 18:32:39.579  - info: zigbee.0 (37350) Starting Zigbee  npm ...
        2022-05-16 18:32:40.168  - info: zigbee.0 (37350) Installed Version: iobroker.zigbee@1.6.18
        2022-05-16 18:32:51.303  - info: zigbee.0 (37350) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}}
        2022-05-16 18:32:51.311  - info: zigbee.0 (37350) Unable to disable LED, unsupported function.
        2022-05-16 18:32:51.327  - info: zigbee.0 (37350)   --> transmitPower : normal
        2022-05-16 18:32:51.335  - info: zigbee.0 (37350) Currently no devices.
        2022-05-16 18:32:51.336  - info: zigbee.0 (37350) Zigbee started
        Hier steht der Stick inkl. Flash-Anleitung dabei:
        https://www.zigbee2mqtt.io/guide/adapters/#recommended
        • V Offline
          V Offline
          vqe17235
          Ich habe die Firmware hier installiert:
          Z-Stack_3.x.0
          Der Stick wird jetzt so erkannt:
          pi@raspberrypi:~ $ ls -la /dev/serial/by-id
          insgesamt 0
          drwxr-xr-x 2 root root 60 17. Mai 16:12 .
          drwxr-xr-x 4 root root 80 17. Mai 16:12 ..
          lrwxrwxrwx 1 root root 13 17. Mai 16:12 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24523334e35fec1192ca385f25bfaa52-if00-port0 -> ../../ttyUSB0
          Und eingestellt ist der so:
          Das Log sagt folgendes:
          2022-05-17 16:20:35.935  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-05-17 16:20:38.402  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1960
          2022-05-17 16:20:40.790  - debug: zigbee.0 (1960) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2022-05-17 16:20:40.847  - debug: zigbee.0 (1960) Objects client ready ... initialize now
          2022-05-17 16:20:40.850  - debug: zigbee.0 (1960) Objects create System PubSub Client
          2022-05-17 16:20:40.852  - debug: zigbee.0 (1960) Objects create User PubSub Client
          2022-05-17 16:20:40.911  - debug: zigbee.0 (1960) Objects client initialize lua scripts
          2022-05-17 16:20:40.918  - debug: zigbee.0 (1960) Objects connected to redis: 127.0.0.1:9001
          2022-05-17 16:20:40.953  - debug: zigbee.0 (1960) Redis States: Use Redis connection: 127.0.0.1:9000
          2022-05-17 16:20:40.971  - debug: zigbee.0 (1960) States create System PubSub Client
          2022-05-17 16:20:40.972  - debug: zigbee.0 (1960) States create User PubSub Client
          2022-05-17 16:20:41.012  - debug: zigbee.0 (1960) States connected to redis: 127.0.0.1:9000
          2022-05-17 16:20:41.123  - debug: zigbee.0 (1960) Plugin sentry Initialize Plugin (enabled=true)
          2022-05-17 16:20:41.492  - info: zigbee.0 (1960) starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
          2022-05-17 16:20:41.534  - debug: zigbee.0 (1960) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[88,242,222,188,90,137,132,21]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24523334e35fec1192ca385f25bfaa52-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
          2022-05-17 16:20:41.591  - info: zigbee.0 (1960) Starting Zigbee  npm ...
          2022-05-17 16:20:41.592  - debug: zigbee.0 (1960) Starting zigbee-herdsman...
          2022-05-17 16:20:42.096  - debug: zigbee.0 (1960) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_05_17-16_20_41.tar.gz success
          2022-05-17 16:20:42.105  - info: zigbee.0 (1960) Installed Version: iobroker.zigbee@1.6.18
          2022-05-17 16:21:02.289  - error: zigbee.0 (1960) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          2022-05-17 16:21:02.290  - error: zigbee.0 (1960) Failed to start Zigbee
          2022-05-17 16:21:02.290  - error: zigbee.0 (1960) Error herdsman start
          2022-05-17 16:21:12.293  - info: zigbee.0 (1960) Try to reconnect. 1 attempts left
          2022-05-17 16:21:12.295  - info: zigbee.0 (1960) Starting Zigbee  npm ...
          2022-05-17 16:21:12.296  - debug: zigbee.0 (1960) Starting zigbee-herdsman...
          2022-05-17 16:21:12.319  - info: zigbee.0 (1960) Installed Version: iobroker.zigbee@1.6.18
          2022-05-17 16:21:12.564  - error: zigbee.0 (1960) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          2022-05-17 16:21:12.565  - error: zigbee.0 (1960) Failed to start Zigbee
          2022-05-17 16:21:12.566  - error: zigbee.0 (1960) Error herdsman start
          Das Flashen wurde mit einer erfolgreichen Meldung beendet. Kann man das sonst noch irgendwie kontrollieren?
          NWHN 1 Antwort Letzte Antwort
          • V vqe17235
            Z-Stack_3.x.0
            insgesamt 0
            NWHN Offline
            NWHN Offline
            NWH
            @vqe17235 @Thomas-Braun
            Ich möchte den Sonoff auf meinem Nas Synology zum laufen bringen.
            IOB läuft im docker am Nas.
            Wenn ich das alles mache kommt bei mir immer die Fehlermeldung
            Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
            Was kann ich machen damit der Stick läuft.
            Mit dem Pfad betreibe ich einen Conbee USB2 Stick
            /dev/ttyACM0
            Da läuft es auf anhieb.
            Kann mir wer helfen das der Sonnoff auch läuft?
            AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
            • NWHN NWH
              /dev/ttyACM0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @nwh sagte in Sonoff Zigbee Stick im Adapter nicht erkannt:
              Poste bitte mal alle Meldungen ab Startversuch des Adapters. Ich gehe davon aus das es weiter vorne noch weitere Meldungen gibt.
              A.
              NWHN 2 Antworten Letzte Antwort
              • NWHN NWH
                /dev/ttyACM0
                Das dürfte der Wahrheit entsprechen. Die Sticks werden i. d. R. nach /dev/ttyUSB0 gehängt. Aur 'richtigen' Systemen kann man das mit
                ls -l /dev/serial/by-id
                sehen. Schaut bei mir so aus:
                [grothesk@manjaro ~]$ ls -l /dev/serial/by-id/
                insgesamt 0
                lrwxrwxrwx 1 root root 13 29. Apr 15:27 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                Aber auf dem synology/docker-Krempel funktioniert das wohl so nicht. Muss dir wer anders helfen.
                • AsgothianA Asgothian
                  A.
                  NWHN Offline
                  NWHN Offline
                  NWH
                  @asgothian
                  Bitte sehr
                  zigbee.0
                  2022-05-28 21:22:03.420	error	Error herdsman start
                  zigbee.0
                  2022-05-28 21:22:03.420	error	Failed to start Zigbee
                  zigbee.0
                  2022-05-28 21:22:03.419	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                  zigbee.0
                  2022-05-28 21:21:53.414	error	Error herdsman start
                  zigbee.0
                  2022-05-28 21:21:53.414	error	Failed to start Zigbee
                  zigbee.0
                  2022-05-28 21:21:53.414	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                  • NWHN NWH
                    @asgothian
                    Bitte sehr
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    @nwh
                    Der Start des Adapters ist länger. Schaut so oder ähnlich aus:
                    2022-05-28 21:25:35.780  - info: host.chet instance system.adapter.zigbee.0 started with pid 15887
                    2022-05-28 21:25:39.429  - info: zigbee.0 (15887) starting. Version 1.7.1 (non-npm: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.2.0, js-controller: 4.0.23
                    2022-05-28 21:25:39.494  - info: zigbee.0 (15887) internal Backups are disabled
                    2022-05-28 21:25:39.500  - info: zigbee.0 (15887) Starting Zigbee  npm ...
                    2022-05-28 21:25:40.050  - info: zigbee.0 (15887) Installed Version: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1
                    2022-05-28 21:25:51.022  - info: zigbee.0 (15887) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}}
                    2022-05-28 21:25:51.035  - info: zigbee.0 (15887) Unable to disable LED, unsupported function.
                    2022-05-28 21:25:51.059  - info: zigbee.0 (15887)   --> transmitPower : normal
                    2022-05-28 21:25:51.070  - info: zigbee.0 (15887) Currently no devices.
                    2022-05-28 21:25:51.072  - info: zigbee.0 (15887) Zigbee started
                      @nwh
                      NWHN Offline
                      NWHN Offline
                      NWH
                      @thomas-braun Wo sehe ich das? Im Protokollfenster oder?
                      • NWHN NWH
                        @nwh
                        Ich schau dazu in einem Terminal direkt ins log.
                        iobroker logs --watch | uniq
                        • NWHN NWH
                          @nwh
                          Ich weiß nicht ob das beim Docker auch funktioniert, aber mach ein weiteres Terminal auf und dann mit
                          dmesg -wT
                          schauen was passiert wenn der Stick ausgesteckt wird und nach einer Minute wieder eingestöpselt wird.
                            @nwh
                            dmesg -wT
                            NWHN Offline
                            NWHN Offline
                            NWH
                            Das geht nicht im Terminal vom docker bzw. kenne ich mich dabei zu wenig aus.
                            Aber das habe ich jetzt aus den Protokoll.
                            zigbee.0
                            2022-05-28 21:33:22.470	info	Installed Version: iobroker.zigbee@1.6.18
                            zigbee.0
                            2022-05-28 21:33:22.464	error	Error herdsman start
                            zigbee.0
                            2022-05-28 21:33:22.463	error	Failed to start Zigbee
                            zigbee.0
                            2022-05-28 21:33:22.463	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'"
                            zigbee.0
                            2022-05-28 21:33:22.462	debug	zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
                            zigbee.0
                            2022-05-28 21:33:22.462	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6748,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[15],"extenedPanID":[255,221,221,221,221,221,221,170]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
                            zigbee.0
                            2022-05-28 21:33:22.461	debug	zigbee-herdsman:adapter:zStack:znp:error Failed to determine if path is valid: 'Error: ENOENT: no such file or directory, lstat '/dev/ttyACM0''
                            zigbee.0
                            2022-05-28 21:33:22.460	debug	Starting zigbee-herdsman...
                            zigbee.0
                            2022-05-28 21:33:22.459	info	Starting Zigbee npm ...
                            zigbee.0
                            2022-05-28 21:33:22.459	info	Try to reconnect. 1 attempts left
                              A.
                              NWHN Offline
                              NWHN Offline
                              NWH
                              @asgothian Kann es sein, dass es daran liegt, dass ich mit der gleichen Instanz, allerdings habe ich den Stick gewechselt.
                              Andere Frage, ich habe jetzt alles gelöscht (Instanz und Objekte), aber wenn ich wieder eine "zigbee" Instanz installiere und wieder den Conbee2 nehme sind alle angelernten Geräte wieder da. Allerdings steht bei jedem Gerät undefined. Ich kann diese auch nicht umbenennen. Zuvor ging das !
                              Muss was in im Ordner "Iobroker_Data" gelöscht werden?
