  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • F Flohtec76
     iobroker -u
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    #115
    @flohtec76
    Sorry, mein Fehler.
    iobroker update -u
    F 1 Antwort Letzte Antwort
      @flohtec76
      Sorry, mein Fehler.
      iobroker update -u
      Flohtec76
      schrieb am zuletzt editiert von Flohtec76
      #116
      iobroker update -u
      Used repository: stable
      • F Flohtec76
        iobroker update -u
        #117
        @flohtec76
        Passt jetzt alles.
          @flohtec76
          Passt jetzt alles.
          Flohtec76
          #118
          Ich habe immer so eine riesen angst mit der Konsole etwas falsch zu machen!
          Vielen Dank Dir!
          • F Flohtec76
            Vielen Dank Dir!
            #119
            @flohtec76 sagte in Material Design Installation und Widgets:
            Mir geht das immer so wenn ich mit der Maus herumklicke...
            Ja, die Konsole ist mächtig. Deswegen hantiert man da ja z. B. auch nie ohne Schutzkleidung direkt als root herum.
              Flohtec76
              #120
              Beim klicken habe ich keine Angst denn meist kannst Du ja lesen was Du dann tust wennnn du klickst.
              hier ist es etwas löschen oder wie du gesehen hast etwas doppelt machst. Dann kenne ich keinen weg zurück.
              Das Ihr auch die ganzen Kommandos alle im Kopf habt ist für mich magisch.
              Aber ich denke jeder ist da Spezi in seinem Bereich
              • F Flohtec76
                #121
                Es gibt in der Konsole auch keinen Weg zurück. Oder einen 'Mülleimer' für Dateien. Weg ist weg, getan ist getan. (Nur bei ganz 'komischen' Aktionen gibt es schon mal Rückfragen, ob man das wirklich tun will).
                  Flohtec76
                  #122
                  mal eine Frage nebenbei:
                  Wenn ich die SD Karte im Raspberry Kopiere dann habe ich doch so zu sagen eine Sicherung von dem ganzen oder?
                  Ich frage deswegen: sollte das System mal abstürzen ( was schon passiert war ) kann ich das System aus dem Backup neu hochladen.
                  meine Frau kann das nicht aber die kann eine SD Karte wechseln ;-)
                  Klar sind dann vielleicht ein paar Daten nicht auf dem laufenden aber das wäre mir ja dann egal, Hauptsache die Masse funktioniert wieder
                  • F Flohtec76
                    #123
                    Man kann sie Karten clonen. Bin ich aber offen gesagt kein Freund von. Ich würde da immer flugs ein Backup in ein frisch gebackenes System einspielen.
                      Flohtec76
                      #124
                      Da bin ich auch kein Freund von aber lieber ein wenig und nicht ganz so gut weiterhelfen als wenn alles nichts mehr Funktioniert. Als die Frauen hier im Haus den realen Tasten vom Garagentor benutzen mussten war erstmal die Frage "wo war der noch"
                      Ich weiß nicht was damals passiert ist jedoch muss der mal einen Strom aus bekommen haben während eines Updates oder speichern etc. auf jeden Fall ging da gar nichts mehr und ich musste komplett neu aufsetzen
                      ich wollte erst die Haus Steuerung per Siemens aufsetzen denn das kann ich. aber wer soll das bezahlen
                      Naja auf jeden Fall danke ich dir super doll für deine Geduld, Zeit und auch Nerven!
                      Sorry nochmal
