  4. Daikin Adapter ohne Funktion
    6.3k
adapter problemdaikinobjekt nicht erstellt
40 Beiträge 5 Kommentatoren 5.8k Aufrufe 4 Beobachtet
  • A Aidan
    @glasfaser
    ich finde ihn aber nicht in den Instanzen bzw, unter Adaptern
    Raspi ist neu gestartet.
    Eine Schritt Anleitung wäre super.
    GlasfaserG Offline
    GlasfaserG Offline
    @aidan
    bzw, unter Adaptern
    Zeige mal
    iobroker update -i
    iobroker list adapters
    iobroker list instances
    und
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    • GlasfaserG Glasfaser
      @aidan
      bzw, unter Adaptern
      Zeige mal
      iobroker update -i
      und
      Aidan
      schrieb am zuletzt editiert von Aidan
      @glasfaser
      pi@raspberrypi:~ $ iobroker update-i
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      pi@raspberrypi:~ $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.3.8
      system.adapter.alarm                   : alarm          - v3.0.5
      system.adapter.daswetter               : daswetter      - v3.1.2
      system.adapter.discovery               : discovery      - v3.0.3
      system.adapter.email                   : email          - v1.0.10
      system.adapter.heos                    : heos           - v1.9.1
      system.adapter.hm-rega                 : hm-rega        - v3.0.40
      system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
      system.adapter.hmip                    : hmip           - v1.15.4
      system.adapter.ical                    : ical           - v1.12.1
      system.adapter.icons-material-png      : icons-material-png - v0.1.0
      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
      system.adapter.info                    : info           - v1.9.19
      system.adapter.javascript              : javascript     - v5.2.21
      system.adapter.linkeddevices           : linkeddevices  - v1.4.3
      system.adapter.proxy                   : proxy          - v1.2.2
      system.adapter.simple-api              : simple-api     - v2.6.5
      system.adapter.socketio                : socketio       - v4.2.0
      system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
      system.adapter.telegram                : telegram       - v1.12.2
      system.adapter.tvspielfilm             : tvspielfilm    - v2.0.4
      system.adapter.vis                     : vis            - v1.4.15
      system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
      system.adapter.vis-justgage            : vis-justgage   - v1.0.2
      system.adapter.vis-map                 : vis-map        - v1.0.4
      system.adapter.vis-metro               : vis-metro      - v1.2.0
      system.adapter.vis-plumb               : vis-plumb      - v1.0.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.vis-weather             : vis-weather    - v2.5.5
      system.adapter.web                     : web            - v4.3.0
      system.adapter.yr
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
        system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
        system.adapter.proxy.0                  : proxy                 : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      + instance is alive
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      • A Aidan
        @glasfaser
        iobroker [command]
        Commands:
        Options:
        system.adapter.yr
        + instance is alive
        GlasfaserG Offline
        GlasfaserG Offline
        @aidan sagte in Daikin Adapter ohne Funktion:
        iobroker update-i
        iobroker update -i
          iobroker update-i
          iobroker update -i
          Aidan
          @glasfaser
          pi@raspberrypi:~ $ iobroker update -i
          Adapter    "admin"        : 5.3.8    , installed 5.3.8
          Adapter    "alarm"        : 3.1.0    , installed 3.0.5  [Updatable]
          Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
          Adapter    "discovery"    : 3.0.3    , installed 3.0.3
          Adapter    "email"        : 1.0.10   , installed 1.0.10
          Adapter    "heos"         : 1.9.1    , installed 1.9.1
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "hmip"         : 1.17.0   , installed 1.15.4 [Updatable]
          Adapter    "ical"         : 1.12.1   , installed 1.12.1
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "javascript"   : 5.2.21   , installed 5.2.21
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
          Adapter    "proxy"        : 1.2.2    , installed 1.2.2
          Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.12.2   , installed 1.12.2
          Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
          Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
          Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
          Adapter    "yr"           : 5.3.0    , installed 5.1.2  [Updatable]
          • A Aidan
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @aidan
            sehr komisch ..
            poste hier mal dein Problem , bzw. da wird etwas auch von dem gesprochen ...
            https://forum.iobroker.net/topic/55082/test-adapter-daikin-cloud-0-0-1/8?_=1653646583846
            • A Aidan
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @aidan
              Was ergibt noch ... das fehlt oben :
              EDIT :
              Was mich noch mehr Wundert ....
              das der Daikin Adapter auch nicht angezeigt wird in deiner Auflistung .
              A 2 Antworten Letzte Antwort
                @aidan
                EDIT :
                Aidan
                @glasfaser
                pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.20.0
                v12.20.0
                6.14.8
                pi
                /home/pi
                Das ist aber schon sehr speziell^^ das ganze vorgehen. ich bin ja kein informatiker^^
                ich poste mal im anderen Thread meine Probleme..
                Dank dir erstmal, mal sehen was rum kommt
                • A Aidan
                  @glasfaser
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.20.0
                  v12.20.0
                  6.14.8
                  pi
                  /home/pi
                  @aidan
                  Da ist nodeJS falsch (mindestens in veralteter Version) installiert. Und dein System ist nicht aktuell.
                  sudo apt update
                  iobroker stop
                  sudo apt full-upgrade
                  sudo reboot
                  • A Aidan
                    @glasfaser
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.20.0
                    v12.20.0
                    6.14.8
                    pi
                    /home/pi
                    wenn man Alpha Versionen testen will, ist das eben so.
                    • A Aidan
                      @glasfaser
                      hat @glasfaser dir verlinkt.
                      Hast du sie gelesen und befolgt
                        Aidan
                        ich bin dran, den Adapter konnte ich schon sehen.
                        Aktualisiere gerade das System
                          @aidan
                          EDIT :
                          Aidan
                          @glasfaser said in Daikin Adapter ohne Funktion:
                          @aidan
                          EDIT :
                          Es fehlte nur ein Befehl, dann konnte ich den Adapter sehen:
                          iob upload daikin-cloud
