  4. [Gelöst] Update meteoalarm Fehler wegen HAM Adapter Plugin
    5.9k
25 Beiträge 3 Kommentatoren 865 Aufrufe 2 Beobachtet
  • draexlerD draexler
    @thomas-braun Hat leider nichts gebracht :-(
    @draexler
    cd /opt/iobroker
    npm ls | grep ERR
    draexlerD 1 Antwort Letzte Antwort
      @draexler
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker update -i
      draexlerD Offline
      draexlerD Offline
      draexler
      @thomas-braun sagte in Update meteoalarm auf 2.1.2:
      @draexler
      iobroker update -i
      Ergebnis:
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.3
      v14.19.3
      6.14.17
      pi
      /home/pi
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           14.19.3-deb-1nodesource1
        Installationskandidat: 14.19.3-deb-1nodesource1
        Versionstabelle:
       *** 14.19.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
        @draexler
        cd /opt/iobroker
        npm ls | grep ERR
        draexlerD Offline
        draexlerD Offline
        draexler
        cd /opt/iobroker
        npm ls | grep ERR
        Ergebnis:
        npm ERR! missing: @nef10/homebridge-midea-air@^1.3.1, required by iobroker.ham@4.0.2
        npm ERR! missing: @nickhudkins/homebridge-midea-air@^1.2.1, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-levoit-air-purifier@^1.1.13, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-levoit-humidifiers@^1.7.1-beta1, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-levoit-humidifiers2@^1.3.1, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-midea@^1.5.5, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-midea-air@^1.4.8, required by iobroker.ham@4.0.2
        npm ERR! missing: homebridge-vesync-client@0.0.3, required by iobroker.ham@4.0.2
        npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@1.0.5
          @draexler
          iobroker update -i
          Ergebnis:
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.19.3
          v14.19.3
          6.14.17
          pi
          /home/pi
          nodejs:
            Versionstabelle:
          @draexler sagte in Update meteoalarm auf 2.1.2:
          iobroker update -i
          wo ist das?
            cd /opt/iobroker
            npm ls | grep ERR
            Ergebnis:
            iobroker.ham
            Der ist wohl nicht richtig installiert. Installier den vielleicht nochmal.
            Oder die ham-Plugins.
              iobroker.ham
              draexlerD Offline
              draexlerD Offline
              draexler
              @thomas-braun So habe jetzt ein bisschen rumprobiert.
              Der HAM Adapter konnte nicht ohne Probleme deinstalliert werden. Lief immer auf Fehler mit dem Hinweis das ich diesen manuell deinstallieren muss.
              Ich habe dann alle Plugins einzeln mit folgenden Befehl gelöscht:
              cd /opt/iobroker/node_modules/iobroker.ham
              npm uninstall homebridge-midea-air --production --loglevel error
              Danach konnte ich den HAM Adapter auch ohne Probleme deinstalliert werden und ich konnte wieder die restlichen Adapter updaten.
              Natürlich brauche ich aber den HAM Adapter.... Also schwups wieder installiert... Aber sobald ich eines der Midea Plugins (für einen Comfee Entfeuchter) installiere habe ich wieder einen NPM Error im Log....
              pi@SmartHomePi:/opt/iobroker $ npm ls | grep ERR
              Irgenwer eine Idee? Kann ich dies irgendwie löschen? Das Plugin läuft nämlich trotz dieses Errors.
                @draexler
                Mach am besten ein Issue dazu auf, ich vermute da müssen die Dependencies angepackt werden.
                Wobei mir nicht ganz klar ist wie das mit den plugins genau funktioniert.
                Sieht für mich aus, als seien da Forks oder sowas von den plugins installiert (gewesen).
                Aber funktioniert der
                https://github.com/TA2k/ioBroker.midea
                nicht?
                  @draexler
                  nicht?
                  draexlerD Offline
                  draexlerD Offline
                  draexler
                  @thomas-braun Issue bei dem Plugin oder beim HAM Adapter?
                  Nö der ioBroker.midea Adapter geht leider für mein Gerät nicht und wird laut GITHub auch nicht mehr dort integriert.
                    draexlerD Offline
                    draexlerD Offline
                    draexler
                    So nach einer Woche würde es mal wieder ein Adapter Update geben... Und wieder das gleiche Thema. Die
                    npm ERR! missing: homebridge-midea-air@^1.4.9, required by iobroker.ham@4.0.2
                    Geschichte macht bei dem Update wieder ein Strich durch die Rechnung. Wie könnte ich das lösen? Wie schon gesagt der ioBroker und alle Adapter inkl. der HAM Adapter mit Plugins läuft ohne Probleme. Kann man die "Missings" irgendwie löschen? Cache etc.
                    Kann ja nicht jedesmal den HAM Adapter löschen wenn ich Updates machen möchte ;-)
                      @draexler sagte in Update meteoalarm auf 2.1.2 EDIT Verursacht HAM Adapter:
                      Wie sieht denn deine Konfiguration beim ham aus?
                      cd /opt/iobroker/
                      npm ls homebridge-levoit-air-purifier
                      npm ls --depth=0 | grep ERR
                      sagt?
                      Sauber installiert sollte das so aussehen:
                      echad@chet:/opt/iobroker $ npm ls homebridge-levoit-air-purifier
                      iobroker.inst@3.0.0 /opt/iobroker
                      └─┬ iobroker.ham@4.0.2
                        └── homebridge-levoit-air-purifier@1.1.13
                      • draexlerD Offline
                        draexlerD Offline
                        draexler
                        schrieb am zuletzt editiert von draexler
                        Also die Konfiguration sieht so aus:
                        Und hier kommt eine Fehlermeldung....
                        pi@SmartHomePi:~ $ cd /opt/iobroker
                        pi@SmartHomePi:/opt/iobroker $ npm ls homebridge-levoit-air-purifier
                          └── UNMET DEPENDENCY homebridge-levoit-air-purifier@^1.1.13
                        Adapter neuinstalliert und ioBroker Fix ist schon erledigt.
                          @draexler
                          Trag die Module mal ohne das @VERSION ein.
                          Und den Haken bei 'Beim nächsten Start updaten' aktiv setzen.
                            @draexler
                            draexlerD Offline
                            draexlerD Offline
                            draexler
                            @thomas-braun Erledigt. Aber leider immer noch das gleiche Ergebnis. Habe sogar nochmals den HAM Adapter und die Plugins deinstalliert...
                            Kann es irgendeine Berechtigungsgeschichte sein?
                              Kann eigentlich nicht sein, wenn du da ansonsten sauber gearbeitet hast und nicht wild mit root-Rechten um dich geworfen hast.
                              Jag mal ein
                              cd /opt/iobroker
                              npm prune
                              über das System.
                                Jag mal ein
                                cd /opt/iobroker
                                npm prune
                                über das System.
                                draexlerD Offline
                                draexlerD Offline
                                draexler
                                @thomas-braun: Bedeutet anscheinend das ich node größer 16 brauche?
                                pi@SmartHomePi:/opt/iobroker $ npm prune
                                npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                                npm ERR! code ENOTSUP
                                npm ERR! notsup Unsupported engine for homebridge-midea-air@1.5.0: wanted: {"homebridge":">=1.3.0","node":">=16.0.0"} (current: {"node":"14.19.3","npm":"6.14.17"})
                                npm ERR! notsup Not compatible with your version of node/npm: homebridge-midea-air@1.5.0
                                npm ERR! notsup Required: {"homebridge":">=1.3.0","node":">=16.0.0"}
                                npm ERR! notsup Actual:   {"npm":"6.14.17","node":"14.19.3"}
                                npm ERR!     /home/iobroker/.npm/_logs/2022-05-28T06_00_39_042Z-debug.log
                                  @draexler
                                  Ja. In dem Fall würde ich nodejs 16 installieren.
                                  Auch wenn das für den iobroker noch nicht die vorgesehene Version ist.
                                  Anleitung zum Upgrade in meiner Signatur.
                                    @draexler
                                    draexlerD Offline
                                    draexlerD Offline
                                    draexler
                                    @thomas-braun ... mmh, aber irgendwie die Gefahr das was anderes dabei nicht mehr funktioniert.... Oder gibts eine Übersicht welche Adapter mit der 16 noch nicht Funktionieren? ;-)
                                    Habe jetzt mal zu Versuchszwecken mal die homebridge-midea-air@1.4.4 installiert. Die sollte ja noch mit Node 14 laufen .
                                    Aber....
                                    npm ERR! notsup Unsupported engine for homebridge-midea-air@1.4.4: wanted: {"homebridge":">=1.3.0","node":">=16.0.0"} (current: {"node":"14.19.3","npm":"6.14.17"})
                                    npm ERR! notsup Not compatible with your version of node/npm: homebridge-midea-air@1.4.4
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-05-28T06_41_33_771Z-debug.log
                                    Entweder ist die Infos falsch oder der verwendet für die unteren Version automatisch die 16er.
                                      Aber....
                                      @draexler
                                      Ich würde es einfach ausprobieren. Die von mir verwendeten Adapter laufen z.B. alle mit 16.
                                      (Seit heute morgen auch mit nodeJS 18, aber das würde ich zur Zeit noch nicht empfehlen. Die 16 sollte aber eigentlich soweit verwendbar sein.)
                                        @draexler
                                        draexlerD Offline
                                        draexlerD Offline
                                        draexler
                                        @thomas-braun So ich bin jetzt auf die 16 gegangen. Es laufen alle Adapter und bis jetzt noch keine Probleme und auch die HAM Plugins laufen jetzt oder Probleme in der Installation.
                                        NPM wurde auch auf die 8.5.5 hochgezogen. Passt das? Ich meine mich zu erinnern das man dies downgraden soll?? Aber vielleicht täusche ich mich....
                                        Aber auf jeden Fall Danke dir Thomas :-) Super wie einen hier geholfen wird.
