  4. Suche Markiesen / Rolladen Steuerung was ist zu Empfehlen
    5.3k
21 Beiträge 3 Kommentatoren 6.1k Aufrufe
  • N Offline
    N Offline
    nsession
    Hier mal alles aus dem Log
    2017-04-26 23:17:18.587 Always, OpenZwave Version 1.4.0 Starting Up
    2017-04-26 23:17:18.589 Info, Setting Up Provided Network Key for Secure Communications
    2017-04-26 23:17:18.589 Warning, Failed - Network Key Not Set
    2017-04-26 23:17:18.590 Info, mgr,     Added driver for controller /dev/ttyAMA0
    2017-04-26 23:17:18.590 Info,   Opening controller /dev/ttyAMA0
    2017-04-26 23:17:18.590 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
    2017-04-26 23:17:18.590 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
    2017-04-26 23:17:18.591 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
    2017-04-26 23:17:18.591 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
    2017-04-26 23:17:18.591 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
    2017-04-26 23:17:18.591 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
    2017-04-26 23:17:18.592 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
    2017-04-26 23:17:18.592 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
    2017-04-26 23:17:18.594 Detail, Unsolicited message received while waiting for ACK.
    2017-04-26 23:17:19.094 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:19.094 Detail, Unsolicited message received while waiting for ACK.
    2017-04-26 23:17:19.595 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:19.595 Warning, WARNING: Out of frame flow! (0x5a).  Sending NAK.
    2017-04-26 23:17:19.597 Detail, Unsolicited message received while waiting for ACK.
    2017-04-26 23:17:19.598 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x39, 0x00, 0x01, 0x95
    2017-04-26 23:17:19.599 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
    2017-04-26 23:17:19.599 Info, contrlr,     Static Controller library, version Z-Wave 3.99
    2017-04-26 23:17:19.599 Detail, Node045,   Expected reply was received
    2017-04-26 23:17:19.599 Detail, Node045,   Message transaction complete
    2017-04-26 23:17:19.599 Detail, contrlr, Removing current message
    2017-04-26 23:17:19.599 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
    2017-04-26 23:17:19.600 Detail, Unsolicited message received while waiting for ACK.
    2017-04-26 23:17:19.600 Detail, contrlr,   Received: 0x01, 0x09, 0x00, 0x0a, 0x05, 0x01, 0x01, 0x02, 0x01, 0x00, 0xfa
    2017-04-26 23:17:19.600 Info, **TODO: handle request for 0x0a** Please report this message.
    2017-04-26 23:17:19.601 Detail, contrlr, CAN received...triggering resend
    2017-04-26 23:17:19.601 Info, contrlr, Sending (Command) message (Attempt 2, Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
    2017-04-26 23:17:19.604 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xc3, 0x44, 0x7f, 0xd3, 0x01, 0xfc
    2017-04-26 23:17:19.604 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc3447fd3\.  Our node ID = 1
    2017-04-26 23:17:19.609 Detail, Node068,   Expected reply was received
    2017-04-26 23:17:19.609 Detail, Node068,   Message transaction complete
    2017-04-26 23:17:19.610 Detail, contrlr, Removing current message
    2017-04-26 23:17:19.610 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
    2017-04-26 23:17:19.612 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x1c, 0xe3
    2017-04-26 23:17:19.613 Detail,
    2017-04-26 23:17:19.613 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
    2017-04-26 23:17:19.613 Info, contrlr,     There is a SUC ID Server (SIS) in this network.
    2017-04-26 23:17:19.613 Info, contrlr,     The PC controller is an inclusion static update controller (SUC) and was the original primary before the SIS was added.
    2017-04-26 23:17:19.613 Detail, Node227,   Expected reply was received
    2017-04-26 23:17:19.613 Detail, Node227,   Message transaction complete
    2017-04-26 23:17:19.614 Detail, contrlr, Removing current message
    2017-04-26 23:17:19.614 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
    2017-04-26 23:17:19.620 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x05, 0x00, 0x01, 0x47, 0x04, 0x00, 0x00, 0x01, 0xfe, 0x83, 0xff, 0x88, 0xcf, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x40, 0x1a, 0x00, 0x59
    2017-04-26 23:17:19.620 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
    2017-04-26 23:17:19.620 Info, contrlr,     Serial API Version:   5.0
    2017-04-26 23:17:19.620 Info, contrlr,     Manufacturer ID:      0x0147
    2017-04-26 23:17:19.620 Info, contrlr,     Product Type:         0x0400
    2017-04-26 23:17:19.620 Info, contrlr,     Product ID:           0x0001
    2017-04-26 23:17:19.621 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
    2017-04-26 23:17:19.621 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
    2017-04-26 23:17:19.621 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
    2017-04-26 23:17:19.621 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
    2017-04-26 23:17:19.621 Detail,   Expected reply was received
    2017-04-26 23:17:19.621 Detail,   Message transaction complete
    2017-04-26 23:17:19.622 Detail, contrlr, Removing current message
    2017-04-26 23:17:19.622 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
    2017-04-26 23:17:19.624 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x01, 0xad
    2017-04-26 23:17:19.625 Detail,
    2017-04-26 23:17:19.625 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 1
    2017-04-26 23:17:19.625 Detail, Node173,   Expected reply was received
    2017-04-26 23:17:19.626 Detail, Node173,   Message transaction complete
    2017-04-26 23:17:19.626 Detail, contrlr, Removing current message
    2017-04-26 23:17:19.626 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
    2017-04-26 23:17:20.177 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:20.178 Detail, contrlr,   Received: 0x01, 0x1c, 0x01, 0x20, 0x03, 0x61, 0x57, 0xd3, 0x6a, 0x34, 0x83, 0x4c, 0xe5, 0x21, 0xb1, 0x4e, 0x04, 0xa8, 0x25, 0x9d, 0x0b, 0x21, 0x2d, 0xa2, 0x71, 0x1f, 0x24, 0x53, 0x98, 0xe4
    2017-04-26 23:17:20.178 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
    2017-04-26 23:17:20.680 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:20.681 Detail, contrlr,   Received: 0x01, 0x1c, 0x01, 0x20, 0x03, 0x61, 0x57, 0xd3, 0x6a, 0x34, 0x83, 0x4c, 0xe5, 0x21, 0xb1, 0x4e, 0x04, 0xa8, 0x25, 0x9d, 0x0b, 0x21, 0x2d, 0xa2, 0x71, 0x1f, 0x24, 0x53, 0x98, 0xe4
    2017-04-26 23:17:20.681 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
    2017-04-26 23:17:21.183 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:21.183 Detail, contrlr,   Received: 0x01, 0x1c, 0x01, 0x20, 0x03, 0x61, 0x57, 0xd3, 0x6a, 0x34, 0x83, 0x4c, 0xe5, 0x21, 0xb1, 0x4e, 0x04, 0xa8, 0x25, 0x9d, 0x0b, 0x21, 0x2d, 0xa2, 0x71, 0x1f, 0x24, 0x53, 0x98, 0xe4
    2017-04-26 23:17:21.183 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
    2017-04-26 23:17:21.685 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
    2017-04-26 23:17:21.686 Detail, contrlr,   Received: 0x01, 0x1c, 0x01, 0x20, 0x03, 0x61, 0x57, 0xd3, 0x6a, 0x34, 0x83, 0x4c, 0xe5, 0x21, 0xb1, 0x4e, 0x04, 0xa8, 0x25, 0x9d, 0x0b, 0x21, 0x2d, 0xa2, 0x71, 0x1f, 0x24, 0x53, 0x98, 0xe4
    2017-04-26 23:17:21.686 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
    2017-04-26 23:28:03.903 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
    2017-04-26 23:28:03.904 Detail, contrlr, Removing current message
    2017-04-26 23:28:03.904 Detail, contrlr, Notification: Notification - TimeOut
    2017-04-26 23:28:03.904 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
    2017-04-26 23:28:03.960 Warning, WARNING: Out of frame flow! (0x25).  Sending NAK.
    2017-04-26 23:28:03.961 Warning, WARNING: Out of frame flow! (0x00).  Sending NAK.
    2017-04-26 23:28:03.963 Warning, WARNING: Out of frame flow! (0x00).  Sending NAK.
    2017-04-26 23:28:03.964 Warning, WARNING: Out of frame flow! (0xff).  Sending NAK.
    2017-04-26 23:28:03.967 Warning, WARNING: Out of frame flow! (0x22).  Sending NAK.
    2017-04-26 23:28:03.969 Warning, WARNING: Out of frame flow! (0x20).  Sending NAK.
    2017-04-26 23:28:05.462 Warning, WARNING: Out of frame flow! (0x22).  Sending NAK.
    2017-04-26 23:28:05.464 Warning, WARNING: Out of frame flow! (0x20).  Sending NAK.
    2017-04-26 23:28:06.962 Warning, WARNING: Out of frame flow! (0x28).  Sending NAK.
    2017-04-26 23:28:06.964 Warning, WARNING: Out of frame flow! (0x20).  Sending NAK.
    2017-04-26 23:28:13.906 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
    2017-04-26 23:28:13.906 Detail, contrlr, Removing current message
    2017-04-26 23:28:13.906 Detail, contrlr, Notification: Notification - TimeOut
    2017-04-26 23:28:13.906 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
    2017-04-26 23:28:14.907 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
    2017-04-26 23:28:14.907 Detail, contrlr, Removing current message
    2017-04-26 23:28:14.907 Detail, contrlr, Notification: Notification - TimeOut
    2017-04-26 23:28:14.908 Detail,
    2017-04-26 23:28:14.908 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
    2017-04-26 23:28:15.908 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
    2017-04-26 23:28:15.909 Detail, contrlr, Removing current message
    2017-04-26 23:28:15.909 Detail, contrlr, Notification: Notification - TimeOut
    ich werde aber nochmal eine installation durchführen.
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Mal abgesehen davon, dass da einige Fehler auftreten
      macht mich dieser Abschnitt besonders stutzig:
      Hast du noch andere Geräte am Laufen, die zwave unterstützen? USB-Stick am PC oder ähnliches?
      Ich bin nicht ganz sicher, was das bedeutet, aber ich vermute da funken sich zwei Geräte in die Quere.
      • N Offline
        N Offline
        nsession
        Ne ich hab keinerlei ZWAVE Geräte
        nur das Razberry Modul und den Fibaro FGR-222
        Im Netzwerk gibt es sonnst nur HarmonyHub, und MAX!Cube
        Nach der neuinstallation hab ich es einaml geschaft das die Geräte so halb gefunden wurden. und Der Scan als Complet angezeigt wurde.
        Nach drücken auf HardReset war den wieder ende.
        Ich werd mir wohl mal den USB stick zulegen ob das besser klappt.
          AlCalzoneA Offline
          AlCalzone
          @nsession:
          Nach drücken auf HardReset war den wieder ende. `
          Nach Hard Reset dürftest du nur noch die Platine (NODE1) sehen. Alle anderen Geräte musst du dann auch zurücksetzen und neu pairen.
          Sollte man vermeiden, solange alles gut funktioniert. In deinem Fall war es aber denke ich angebracht.
          • N Offline
            N Offline
            nsession
            Ich wollte mal infomieren.
            Hab mir jetzt den USB stick aus Post 2 in diesem Thread bei Amazon gekauft.
            Angesteckt, Port eingestellt, gespeichert Adapter gestartet
            Geräte hinzugefügt und es Funktioniert.
            Ich würde behaupten das Razberrymodul hat nen Schuß.
            • arteckA Offline
              arteckA Offline
              arteck
              sauber
              • N Offline
                N Offline
                nsession
                nun tut es ein bischen aber nicht zufriedenstellend.
                Problem:
                Ich seh jetzt zwar meinen FGR222 in den Objekten aber wenn ich jetzt zum beispiel die Markiese 25% ausfahren will und den Wert über VIS setze oder direkt in den Objekten färt die Markiese kurz an und gleich wieder zu.
                An meinem Schalter der Am FRG222 hängt kann ich die Markiese steuern jedoch nicht über ZWAVE
                auch wirde der wert nihct upgedatet in den Objekten.
                Hier mal ein auszug aus dem Log und ein Screenshot.
                Wer kann mir sagen wo ich jetzt den fehler habe.
                zwave.0	2017-05-10 21:16:29.363	info	Scan completed
                zwave.0	2017-05-10 21:16:29.347	info	Update zwave.0.NODE2
                zwave.0	2017-05-10 21:16:29.346	info	node ready nodeID: 2, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Con
                zwave.0	2017-05-10 21:16:28.979	info	Update zwave.0.NODE1
                zwave.0	2017-05-10 21:16:28.978	info	node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"
                zwave.0	2017-05-10 21:16:28.962	info	controller command feedback: state: "The command has completed successfully", error: "No error", helpmsg: "ControllerCommand - Completed"
                zwave.0	2017-05-10 21:16:28.724	info	controller command feedback: state: "The controller is communicating with the other device to carry out the command", error: "No error", helpmsg: "ControllerCommand - InProgress"
                zwave.0	2017-05-10 21:16:28.709	info	controller command feedback: state: "The command is starting", error: "No error", helpmsg: "ControllerCommand - Starting"
                zwave.0	2017-05-10 21:16:28.704	info	controller command feedback: state: "The command has completed successfully", error: "No error", helpmsg: "ControllerCommand - Completed"
                zwave.0	2017-05-10 21:16:28.659	info	controller command feedback: state: "The controller is communicating with the other device to carry out the command", error: "No error", helpmsg: "ControllerCommand - InProgress"
                zwave.0	2017-05-10 21:16:28.658	info	controller command feedback: state: "The command is starting", error: "No error", helpmsg: "ControllerCommand - Starting"
                zwave.0	2017-05-10 21:16:28.520	info	Update zwave.0.NODE2
                zwave.0	2017-05-10 21:16:28.518	info	Update zwave.0.NODE2
                zwave.0	2017-05-10 21:16:28.502	info	Update zwave.0.NODE1
                zwave.0	2017-05-10 21:16:28.495	info	Update zwave.0.NODE1
                zwave.0	2017-05-10 21:16:28.483	info	driver ready: homeid = 3357898214
                zwave.0	2017-05-10 21:16:28.482	info	scanning homeid=0xc82575e6...
                zwave.0	2017-05-10 21:16:28.267	info	connected: homeid = 1.4.0
                zwave.0	2017-05-10 21:16:27.874	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v6.10.2
                host.ioBroker-zWave	2017-05-10 21:16:25.188	info	instance system.adapter.zwave.0 started with pid 1063
                host.ioBroker-zWave	2017-05-10 21:16:24.739	info	instance system.adapter.zwave.0 terminated with code null ()
                  AlCalzoneA Offline
                  AlCalzone
                  @nsession:
                  auch wirde der wert nihct upgedatet in den Objekten. `
                  Wenn du manuell den Wert setzt (Level_1), wird der State vom Gerät bestätigt (ack=true) oder nicht?
                  Was passiert bei Extremwerten (0, 99), was wenn du auf die Buttons (Bright, Close, …) im Objekt-Tab klickst?
                  Aktivier auch mal in den Adapter-Einstellungen Logdatei schreiben. Dann findest du in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared eine Datei OZW_Log.txt. Deren Inhalt kannst du auch mal posten (bitte nicht viel machen nach dem Adapterstart, außer Wert setzen).
                  • N Offline
                    N Offline
                    nsession
                    Sorry hat etwas länger gedauert.
                    Hier mal das Log.
                    mit den buttons bright close und dim und dec fährt das ding.
                    am anfang konnte ich mal noch den value eingeben aber ich weiß nicht warum es nimmer tut.
                    2017-05-16 19:51:53.950 Always, OpenZwave Version 1.4.0 Starting Up
                    2017-05-16 19:51:53.950 Info, Setting Up Provided Network Key for Secure Communications
                    2017-05-16 19:51:53.951 Info, mgr,     Added driver for controller /dev/ttyACM0
                    2017-05-16 19:51:53.951 Info,   Opening controller /dev/ttyACM0
                    2017-05-16 19:51:53.952 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
                    2017-05-16 19:51:53.953 Info, Serial port /dev/ttyACM0 opened (attempt 1)
                    2017-05-16 19:51:53.954 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
                    2017-05-16 19:51:53.954 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
                    2017-05-16 19:51:53.954 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
                    2017-05-16 19:51:53.954 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
                    2017-05-16 19:51:53.954 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
                    2017-05-16 19:51:53.955 Detail,
                    2017-05-16 19:51:53.955 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
                    2017-05-16 19:51:54.251 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x30, 0x35, 0x00, 0x01, 0x97
                    2017-05-16 19:51:54.251 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
                    2017-05-16 19:51:54.251 Info, contrlr,     Static Controller library, version Z-Wave 4.05
                    2017-05-16 19:51:54.251 Detail, Node045,   Expected reply was received
                    2017-05-16 19:51:54.251 Detail, Node045,   Message transaction complete
                    2017-05-16 19:51:54.251 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.252 Detail,
                    2017-05-16 19:51:54.252 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
                    2017-05-16 19:51:54.254 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xc8, 0x25, 0x75, 0xe6, 0x01, 0xa9
                    2017-05-16 19:51:54.254 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc82575e6\.  Our node ID = 1
                    2017-05-16 19:51:54.255 Detail, Node037,   Expected reply was received
                    2017-05-16 19:51:54.255 Detail, Node037,   Message transaction complete
                    2017-05-16 19:51:54.255 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.255 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
                    2017-05-16 19:51:54.257 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
                    2017-05-16 19:51:54.257 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
                    2017-05-16 19:51:54.257 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
                    2017-05-16 19:51:54.257 Info, contrlr,     The PC controller is a primary controller.
                    2017-05-16 19:51:54.257 Detail, Node247,   Expected reply was received
                    2017-05-16 19:51:54.258 Detail, Node247,   Message transaction complete
                    2017-05-16 19:51:54.258 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.258 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
                    2017-05-16 19:51:54.262 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x05, 0x05, 0x01, 0x15, 0x04, 0x00, 0x00, 0x01, 0xfe, 0x83, 0xff, 0x88, 0xcf, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x40, 0x1a, 0x00, 0x0e
                    2017-05-16 19:51:54.262 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
                    2017-05-16 19:51:54.262 Info, contrlr,     Serial API Version:   5.5
                    2017-05-16 19:51:54.262 Info, contrlr,     Manufacturer ID:      0x0115
                    2017-05-16 19:51:54.262 Info, contrlr,     Product Type:         0x0400
                    2017-05-16 19:51:54.263 Info, contrlr,     Product ID:           0x0001
                    2017-05-16 19:51:54.263 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
                    2017-05-16 19:51:54.263 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
                    2017-05-16 19:51:54.263 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
                    2017-05-16 19:51:54.263 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
                    2017-05-16 19:51:54.263 Detail, Node005,   Expected reply was received
                    2017-05-16 19:51:54.263 Detail, Node005,   Message transaction complete
                    2017-05-16 19:51:54.263 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.264 Detail,
                    2017-05-16 19:51:54.264 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
                    2017-05-16 19:51:54.266 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
                    2017-05-16 19:51:54.266 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 0
                    2017-05-16 19:51:54.266 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
                    2017-05-16 19:51:54.266 Detail, Node172,   Expected reply was received
                    2017-05-16 19:51:54.266 Detail, Node172,   Message transaction complete
                    2017-05-16 19:51:54.267 Detail,
                    2017-05-16 19:51:54.267 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.267 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
                    2017-05-16 19:51:54.323 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xbe, 0xab, 0x88, 0xcc, 0x08, 0x54, 0xab, 0x45, 0x63, 0x92, 0x23, 0x8c, 0xdf, 0x42, 0x14, 0x5e, 0x4b, 0x27, 0xa7, 0xc8, 0x49, 0xec, 0xca, 0x5f, 0x77, 0x9b, 0x49, 0x7d, 0x89, 0xf3, 0xe9, 0x83, 0x77
                    2017-05-16 19:51:54.323 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
                    2017-05-16 19:51:54.323 Detail, Node032,   Expected reply was received
                    2017-05-16 19:51:54.323 Detail, Node032,   Message transaction complete
                    2017-05-16 19:51:54.323 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.324 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
                    2017-05-16 19:51:54.422 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc7
                    2017-05-16 19:51:54.422 Info, mgr,     Driver with Home ID of 0xc82575e6 is now ready.
                    2017-05-16 19:51:54.436 Detail, Node002, Queuing (Controller) Delete All Return Routes
                    2017-05-16 19:51:54.436 Detail, Node002, Queuing (Controller) Assign Return Route
                    2017-05-16 19:51:54.437 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
                    2017-05-16 19:51:54.438 Info, contrlr,     Node 001 - Known
                    2017-05-16 19:51:54.438 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
                    2017-05-16 19:51:54.438 Detail, Node001, QueryStage_CacheLoad
                    2017-05-16 19:51:54.438 Info, Node001, Node Identity Codes: 0115:0400:0001
                    2017-05-16 19:51:54.438 Detail, Node001, QueryStage_Associations
                    2017-05-16 19:51:54.438 Detail, Node001, QueryStage_Neighbors
                    2017-05-16 19:51:54.438 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
                    2017-05-16 19:51:54.439 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
                    2017-05-16 19:51:54.439 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
                    2017-05-16 19:51:54.439 Info, contrlr,     Node 002 - Known
                    2017-05-16 19:51:54.439 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
                    2017-05-16 19:51:54.439 Detail, Node002, QueryStage_CacheLoad
                    2017-05-16 19:51:54.439 Info, Node002, Node Identity Codes: 010f:0302:1000
                    2017-05-16 19:51:54.439 Info, Node002, NoOperation::Set - Routing=true
                    2017-05-16 19:51:54.439 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
                    2017-05-16 19:51:54.439 Detail, Node002, Queuing (Query) Query Stage Complete (CacheLoad)
                    2017-05-16 19:51:54.440 Detail,   Expected reply was received
                    2017-05-16 19:51:54.440 Detail,   Message transaction complete
                    2017-05-16 19:51:54.440 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.440 Detail, Node001, Notification: DriverReady
                    2017-05-16 19:51:54.440 Detail, Node001, Notification: NodeAdded
                    2017-05-16 19:51:54.445 Detail, Node001, Notification: NodeProtocolInfo
                    2017-05-16 19:51:54.446 Detail, Node001, Notification: EssentialNodeQueriesComplete
                    2017-05-16 19:51:54.460 Detail, Node001, Notification: ValueAdded
                    2017-05-16 19:51:54.466 Detail, Node001, Notification: NodeNaming
                    2017-05-16 19:51:54.466 Detail, Node002, Notification: NodeAdded
                    2017-05-16 19:51:54.480 Detail, Node002, Notification: NodeProtocolInfo
                    2017-05-16 19:51:54.480 Detail, Node002, Notification: EssentialNodeQueriesComplete
                    2017-05-16 19:51:54.480 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.481 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.482 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.483 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.519 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.520 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.521 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.521 Detail, Node002, Notification: Group
                    2017-05-16 19:51:54.522 Detail, Node002, Notification: Group
                    2017-05-16 19:51:54.522 Detail, Node002, Notification: ValueAdded
                    2017-05-16 19:51:54.522 Detail, Node002, Notification: NodeNaming
                    2017-05-16 19:51:54.523 Detail,
                    2017-05-16 19:51:54.523 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
                    2017-05-16 19:51:54.525 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
                    2017-05-16 19:51:54.525 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
                    2017-05-16 19:51:54.526 Detail, Node015,   Expected reply was received
                    2017-05-16 19:51:54.526 Detail, Node015,   Message transaction complete
                    2017-05-16 19:51:54.526 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.526 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
                    2017-05-16 19:51:54.529 Detail, contrlr, Removing current message
                    2017-05-16 19:51:54.529 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
                    2017-05-16 19:51:54.535 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5c
                    2017-05-16 19:51:54.535 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
                    2017-05-16 19:51:54.536 Info, Node001,     Neighbors of this node are:
                    2017-05-16 19:51:54.536 Info, Node001,     Node 2
                    2017-05-16 19:51:54.536 Detail,   Expected reply was received
                    2017-05-16 19:51:54.536 Detail,   Message transaction complete
                    2017-05-16 19:51:54.536 Detail, Node001, Removing current message
                    2017-05-16 19:51:54.536 Info, Node002, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
                    2017-05-16 19:51:54.545 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:54.546 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:54.562 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x00, 0x00, 0x02, 0xe3
                    2017-05-16 19:51:54.562 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
                    2017-05-16 19:51:54.562 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:51:54.562 Detail,   Expected callbackId was received
                    2017-05-16 19:51:54.563 Detail,   Expected reply was received
                    2017-05-16 19:51:54.563 Detail,   Message transaction complete
                    2017-05-16 19:51:54.563 Detail, Node002, Removing current message
                    2017-05-16 19:51:54.563 Detail, Node002, Notification: Notification - NoOperation
                    2017-05-16 19:51:54.592 Info, Deleting all return routes from node 2
                    2017-05-16 19:51:54.593 Detail, Node002, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x0b, 0xb4
                    2017-05-16 19:51:54.593 Detail, Notification: ControllerCommand - Starting
                    2017-05-16 19:51:54.593 Info, Node002, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x0b, 0xb4
                    2017-05-16 19:51:54.601 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
                    2017-05-16 19:51:54.601 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
                    2017-05-16 19:51:54.601 Detail, Notification: ControllerCommand - InProgress
                    2017-05-16 19:51:54.686 Detail, Node002,   Received: 0x01, 0x05, 0x00, 0x47, 0x0b, 0x00, 0xb6
                    2017-05-16 19:51:54.686 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 2 - SUCCESS
                    2017-05-16 19:51:54.686 Detail,   Expected callbackId was received
                    2017-05-16 19:51:54.686 Detail,   Expected reply was received
                    2017-05-16 19:51:54.687 Detail,   Message transaction complete
                    2017-05-16 19:51:54.687 Detail, Node002, Removing current message
                    2017-05-16 19:51:54.687 Detail, Notification: ControllerCommand - Completed
                    2017-05-16 19:51:54.687 Info, Assigning return route from node 2 to node 1
                    2017-05-16 19:51:54.687 Detail, Node002, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x0c, 0xb0
                    2017-05-16 19:51:54.687 Detail, Notification: ControllerCommand - Starting
                    2017-05-16 19:51:54.699 Detail,
                    2017-05-16 19:51:54.699 Info, Node002, Sending (Command) message (Callback ID=0x0c, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x0c, 0xb0
                    2017-05-16 19:51:54.711 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
                    2017-05-16 19:51:54.711 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
                    2017-05-16 19:51:54.712 Detail, Notification: ControllerCommand - InProgress
                    2017-05-16 19:51:54.952 Detail, Node002,   Received: 0x01, 0x05, 0x00, 0x46, 0x0c, 0x00, 0xb0
                    2017-05-16 19:51:54.953 Detail,
                    2017-05-16 19:51:54.953 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 2 - SUCCESS
                    2017-05-16 19:51:54.953 Detail,   Expected callbackId was received
                    2017-05-16 19:51:54.953 Detail,   Expected reply was received
                    2017-05-16 19:51:54.953 Detail,   Message transaction complete
                    2017-05-16 19:51:54.953 Detail, Node002, Removing current message
                    2017-05-16 19:51:54.953 Detail, Notification: ControllerCommand - Completed
                    2017-05-16 19:51:54.954 Detail, Node001, Query Stage Complete (Neighbors)
                    2017-05-16 19:51:54.954 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
                    2017-05-16 19:51:54.954 Detail, Node001, QueryStage_Session
                    2017-05-16 19:51:54.954 Detail, Node001, QueryStage_Dynamic
                    2017-05-16 19:51:54.954 Detail, Node001, QueryStage_Configuration
                    2017-05-16 19:51:54.954 Detail, Node001, QueryStage_Complete
                    2017-05-16 19:51:54.954 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
                    2017-05-16 19:51:54.954 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=0
                    2017-05-16 19:51:54.955 Detail, Node001, Notification: NodeQueriesComplete
                    2017-05-16 19:51:54.959 Detail, Node002, Query Stage Complete (CacheLoad)
                    2017-05-16 19:51:54.959 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
                    2017-05-16 19:51:54.959 Detail, Node002, QueryStage_Associations
                    2017-05-16 19:51:54.960 Info, Node002, Number of association groups reported for node 2 is 2.
                    2017-05-16 19:51:54.960 Info, Node002, Get MultiChannelAssociation for group 1 of node 2
                    2017-05-16 19:51:54.960 Detail, Node002, Queuing (Send) MultiChannelAssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x0d, 0x42
                    2017-05-16 19:51:54.960 Detail, Node002, Queuing (Query) Query Stage Complete (Associations)
                    2017-05-16 19:51:54.961 Info, Node002, Sending (Send) message (Callback ID=0x0d, Expected Reply=0x04) - MultiChannelAssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x0d, 0x42
                    2017-05-16 19:51:54.969 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:54.969 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:54.987 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x0d, 0x00, 0x00, 0x03, 0xe5
                    2017-05-16 19:51:54.987 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
                    2017-05-16 19:51:54.988 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:51:54.988 Detail,   Expected callbackId was received
                    2017-05-16 19:51:54.997 Detail, Node002,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x02, 0x05, 0x8e, 0x03, 0x01, 0x07, 0x00, 0x7c
                    2017-05-16 19:51:54.997 Info, Node002, Response RTT 36 Average Response RTT 36
                    2017-05-16 19:51:54.997 Info, Node002, Received Multi Instance Association report from node 2, group 1
                    2017-05-16 19:51:54.998 Info, Node002,   The group contains:
                    2017-05-16 19:51:54.998 Info, Node002, Get MultiChannelAssociation for group 2 of node 2
                    2017-05-16 19:51:54.998 Detail, Node002, Queuing (Send) MultiChannelAssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x0e, 0x42
                    2017-05-16 19:51:54.998 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:54.998 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:54.998 Detail, Node002, Removing current message
                    2017-05-16 19:51:54.998 Detail, Node002, Notification: Group
                    2017-05-16 19:51:54.999 Detail,
                    2017-05-16 19:51:54.999 Info, Node002, Sending (Send) message (Callback ID=0x0e, Expected Reply=0x04) - MultiChannelAssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x0e, 0x42
                    2017-05-16 19:51:55.008 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.009 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.025 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x0e, 0x00, 0x00, 0x02, 0xe7
                    2017-05-16 19:51:55.025 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
                    2017-05-16 19:51:55.025 Info, Node002, Request RTT 27 Average Request RTT 26
                    2017-05-16 19:51:55.025 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.036 Detail, Node002,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x02, 0x05, 0x8e, 0x03, 0x02, 0x07, 0x00, 0x7f
                    2017-05-16 19:51:55.036 Info, Node002, Response RTT 38 Average Response RTT 37
                    2017-05-16 19:51:55.037 Info, Node002, Received Multi Instance Association report from node 2, group 2
                    2017-05-16 19:51:55.037 Info, Node002,   The group contains:
                    2017-05-16 19:51:55.037 Info, Node002, Querying associations for node 2 is complete.
                    2017-05-16 19:51:55.037 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.037 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.037 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.038 Detail, Node002, Notification: Group
                    2017-05-16 19:51:55.038 Detail, Node002, Query Stage Complete (Associations)
                    2017-05-16 19:51:55.038 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
                    2017-05-16 19:51:55.038 Detail, Node002, QueryStage_Neighbors
                    2017-05-16 19:51:55.038 Detail, Requesting routing info (neighbor list) for Node 2
                    2017-05-16 19:51:55.038 Detail, Node002, Queuing (Command) Get Routing Info (Node=2): 0x01, 0x07, 0x00, 0x80, 0x02, 0x00, 0x00, 0x03, 0x79
                    2017-05-16 19:51:55.039 Detail, Node002, Queuing (Query) Query Stage Complete (Neighbors)
                    2017-05-16 19:51:55.039 Info, Node002, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=2): 0x01, 0x07, 0x00, 0x80, 0x02, 0x00, 0x00, 0x03, 0x79
                    2017-05-16 19:51:55.044 Detail, Node002,   Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f
                    2017-05-16 19:51:55.044 Info, Node002, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
                    2017-05-16 19:51:55.044 Info, Node002,     Neighbors of this node are:
                    2017-05-16 19:51:55.045 Info, Node002,     Node 1
                    2017-05-16 19:51:55.045 Detail,   Expected reply was received
                    2017-05-16 19:51:55.045 Detail,   Message transaction complete
                    2017-05-16 19:51:55.045 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.045 Detail, Node002, Query Stage Complete (Neighbors)
                    2017-05-16 19:51:55.045 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
                    2017-05-16 19:51:55.045 Detail, Node002, QueryStage_Session
                    2017-05-16 19:51:55.045 Detail, Node002, Queuing (Query) PowerlevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x73, 0x02, 0x25, 0x0f, 0xbe
                    2017-05-16 19:51:55.046 Detail, Node002, Queuing (Query) ProtectionCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x75, 0x02, 0x25, 0x10, 0xa7
                    2017-05-16 19:51:55.046 Detail, Node002, Queuing (Query) Query Stage Complete (Session)
                    2017-05-16 19:51:55.046 Info, Node002, Sending (Query) message (Callback ID=0x0f, Expected Reply=0x04) - PowerlevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x73, 0x02, 0x25, 0x0f, 0xbe
                    2017-05-16 19:51:55.054 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.055 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.071 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x0f, 0x00, 0x00, 0x02, 0xe6
                    2017-05-16 19:51:55.071 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x0f received (expected 0x0f)
                    2017-05-16 19:51:55.072 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:51:55.072 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.083 Detail, Node002,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x73, 0x03, 0x00, 0x00, 0x87
                    2017-05-16 19:51:55.083 Info, Node002, Response RTT 36 Average Response RTT 36
                    2017-05-16 19:51:55.083 Info, Node002, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
                    2017-05-16 19:51:55.083 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.083 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.084 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.084 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.084 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.088 Detail,
                    2017-05-16 19:51:55.088 Info, Node002, Sending (Query) message (Callback ID=0x10, Expected Reply=0x04) - ProtectionCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x75, 0x02, 0x25, 0x10, 0xa7
                    2017-05-16 19:51:55.097 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.097 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.114 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x10, 0x00, 0x00, 0x02, 0xf9
                    2017-05-16 19:51:55.114 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x10 received (expected 0x10)
                    2017-05-16 19:51:55.115 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:51:55.115 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.124 Detail, Node002,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x75, 0x03, 0x00, 0x00, 0x81
                    2017-05-16 19:51:55.125 Detail,
                    2017-05-16 19:51:55.125 Info, Node002, Response RTT 36 Average Response RTT 36
                    2017-05-16 19:51:55.125 Info, Node002, Received a Protection report: Unprotected
                    2017-05-16 19:51:55.125 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.125 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.125 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.125 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.125 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.126 Detail, Node002, Query Stage Complete (Session)
                    2017-05-16 19:51:55.126 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
                    2017-05-16 19:51:55.126 Detail, Node002, QueryStage_Dynamic
                    2017-05-16 19:51:55.126 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x11, 0xf6
                    2017-05-16 19:51:55.126 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x12, 0xf6
                    2017-05-16 19:51:55.126 Detail, Node002, Queuing (Send) SensorMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x31, 0x04, 0x25, 0x13, 0xe6
                    2017-05-16 19:51:55.127 Detail, Node002, Queuing (Send) MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x14, 0xe5
                    2017-05-16 19:51:55.127 Detail, Node002, Queuing (Send) MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x10, 0x25, 0x15, 0xf4
                    2017-05-16 19:51:55.127 Detail, Node002, Queuing (Query) Query Stage Complete (Dynamic)
                    2017-05-16 19:51:55.127 Info, Node002, Sending (Send) message (Callback ID=0x11, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x11, 0xf6
                    2017-05-16 19:51:55.136 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.136 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.152 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x11, 0x00, 0x00, 0x02, 0xf8
                    2017-05-16 19:51:55.153 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x11 received (expected 0x11)
                    2017-05-16 19:51:55.153 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:51:55.153 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.163 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x25, 0x03, 0xfe, 0x2b
                    2017-05-16 19:51:55.163 Info, Node002, Response RTT 35 Average Response RTT 35
                    2017-05-16 19:51:55.163 Info, Node002, Received SwitchBinary report from node 2: level=On
                    2017-05-16 19:51:55.163 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.163 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.163 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.164 Detail,
                    2017-05-16 19:51:55.164 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.164 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.164 Info, Node002, Sending (Send) message (Callback ID=0x12, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x12, 0xf6
                    2017-05-16 19:51:55.173 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.173 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.191 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x12, 0x00, 0x00, 0x02, 0xfb
                    2017-05-16 19:51:55.191 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x12 received (expected 0x12)
                    2017-05-16 19:51:55.191 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:51:55.191 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.201 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x49, 0x9f
                    2017-05-16 19:51:55.201 Info, Node002, Response RTT 37 Average Response RTT 36
                    2017-05-16 19:51:55.202 Info, Node002, Received SwitchMultiLevel report: level=73
                    2017-05-16 19:51:55.202 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.202 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.202 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.202 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.202 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.202 Info, Node002, Sending (Send) message (Callback ID=0x13, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x31, 0x04, 0x25, 0x13, 0xe6
                    2017-05-16 19:51:55.211 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.212 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.229 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x13, 0x00, 0x00, 0x03, 0xfb
                    2017-05-16 19:51:55.229 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x13)
                    2017-05-16 19:51:55.229 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:51:55.229 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.240 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:51:55.241 Detail,
                    2017-05-16 19:51:55.241 Info, Node002, Response RTT 38 Average Response RTT 37
                    2017-05-16 19:51:55.241 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:51:55.241 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.241 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.241 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.241 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.242 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.242 Info, Node002, Sending (Send) message (Callback ID=0x14, Expected Reply=0x04) - MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x14, 0xe5
                    2017-05-16 19:51:55.251 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.251 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.269 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x14, 0x00, 0x00, 0x03, 0xfc
                    2017-05-16 19:51:55.269 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x14 received (expected 0x14)
                    2017-05-16 19:51:55.269 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:51:55.269 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.281 Detail, Node002,   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x02, 0x0a, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb7
                    2017-05-16 19:51:55.282 Detail,
                    2017-05-16 19:51:55.282 Info, Node002, Response RTT 39 Average Response RTT 38
                    2017-05-16 19:51:55.282 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.282 Info, Node002, Received Meter report from node 2: Energy=0.01kWh
                    2017-05-16 19:51:55.282 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.282 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.282 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.282 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.283 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.285 Detail,
                    2017-05-16 19:51:55.285 Info, Node002, Sending (Send) message (Callback ID=0x15, Expected Reply=0x04) - MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x10, 0x25, 0x15, 0xf4
                    2017-05-16 19:51:55.294 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:51:55.294 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:51:55.311 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x15, 0x00, 0x00, 0x02, 0xfc
                    2017-05-16 19:51:55.311 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x15 received (expected 0x15)
                    2017-05-16 19:51:55.311 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:51:55.311 Detail,   Expected callbackId was received
                    2017-05-16 19:51:55.322 Detail, Node002,   Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x02, 0x08, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xdc
                    2017-05-16 19:51:55.322 Info, Node002, Response RTT 36 Average Response RTT 37
                    2017-05-16 19:51:55.323 Detail, Node002, Refreshed Value: old value=false, new value=false, type=bool
                    2017-05-16 19:51:55.323 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:51:55.323 Info, Node002, Received Meter report from node 2: Power=0.0W
                    2017-05-16 19:51:55.323 Detail, Node002, Initial read of value
                    2017-05-16 19:51:55.323 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:51:55.323 Detail, Node002,   Message transaction complete
                    2017-05-16 19:51:55.323 Detail, Node002, Removing current message
                    2017-05-16 19:51:55.323 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:51:55.326 Detail, Node002, Query Stage Complete (Dynamic)
                    2017-05-16 19:51:55.326 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
                    2017-05-16 19:51:55.326 Detail, Node002, QueryStage_Configuration
                    2017-05-16 19:51:55.327 Detail, Node002, QueryStage_Complete
                    2017-05-16 19:51:55.327 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
                    2017-05-16 19:51:55.327 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
                    2017-05-16 19:51:55.327 Info,          Node query processing complete.
                    2017-05-16 19:51:55.327 Detail, Node002, Notification: NodeQueriesComplete
                    2017-05-16 19:51:55.328 Detail, contrlr, Notification: AllNodesQueried
                    2017-05-16 19:52:09.653 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Open - 1 - 1 - true
                    2017-05-16 19:52:09.653 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:52:09.654 Info, Node002,   Direction:          Up
                    2017-05-16 19:52:09.654 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:52:09.654 Info, Node002,   Start Level:        0
                    2017-05-16 19:52:09.654 Info, Node002,   Duration:           255
                    2017-05-16 19:52:09.654 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x38, 0x00, 0xff, 0x25, 0x16, 0x31
                    2017-05-16 19:52:09.655 Info, Node002, Sending (Send) message (Callback ID=0x16, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x38, 0x00, 0xff, 0x25, 0x16, 0x31
                    2017-05-16 19:52:09.663 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:52:09.664 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:52:09.681 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x16, 0x00, 0x00, 0x02, 0xff
                    2017-05-16 19:52:09.681 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x16 received (expected 0x16)
                    2017-05-16 19:52:09.681 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:52:09.682 Detail,   Expected callbackId was received
                    2017-05-16 19:52:09.682 Detail,   Expected reply was received
                    2017-05-16 19:52:09.682 Detail,   Message transaction complete
                    2017-05-16 19:52:09.682 Detail, Node002, Removing current message
                    2017-05-16 19:52:10.805 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0x56, 0xbf
                    2017-05-16 19:52:10.806 Detail,
                    2017-05-16 19:52:10.806 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=213.4W
                    2017-05-16 19:52:10.806 Detail, Node002, Refreshed Value: old value=0.0, new value=213.4, type=decimal
                    2017-05-16 19:52:10.806 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:10.807 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:52:22.970 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:52:22.971 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:52:22.971 Info, Node002,   Direction:          Down
                    2017-05-16 19:52:22.971 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:52:22.971 Info, Node002,   Start Level:        0
                    2017-05-16 19:52:22.971 Info, Node002,   Duration:           255
                    2017-05-16 19:52:22.971 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x17, 0x70
                    2017-05-16 19:52:22.972 Detail,
                    2017-05-16 19:52:22.972 Info, Node002, Sending (Send) message (Callback ID=0x17, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x17, 0x70
                    2017-05-16 19:52:22.981 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:52:22.981 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:52:22.999 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x17, 0x00, 0x00, 0x03, 0xff
                    2017-05-16 19:52:22.999 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x17 received (expected 0x17)
                    2017-05-16 19:52:22.999 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:52:22.999 Detail,   Expected callbackId was received
                    2017-05-16 19:52:22.999 Detail,   Expected reply was received
                    2017-05-16 19:52:22.999 Detail,   Message transaction complete
                    2017-05-16 19:52:23.000 Detail,
                    2017-05-16 19:52:23.000 Detail, Node002, Removing current message
                    2017-05-16 19:52:23.055 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x63, 0xb5
                    2017-05-16 19:52:23.055 Info, Node002, Received SwitchMultiLevel report: level=99
                    2017-05-16 19:52:23.056 Detail, Node002, Refreshed Value: old value=73, new value=99, type=byte
                    2017-05-16 19:52:23.056 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:23.056 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:52:23.074 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0x74, 0x9d
                    2017-05-16 19:52:23.075 Detail,
                    2017-05-16 19:52:23.075 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=216.4W
                    2017-05-16 19:52:23.075 Detail, Node002, Refreshed Value: old value=213.4, new value=216.4, type=decimal
                    2017-05-16 19:52:23.075 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:23.075 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:52:37.315 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x03, 0x6e, 0x8c
                    2017-05-16 19:52:37.316 Detail,
                    2017-05-16 19:52:37.316 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=87.8W
                    2017-05-16 19:52:37.316 Detail, Node002, Refreshed Value: old value=216.4, new value=87.8, type=decimal
                    2017-05-16 19:52:37.316 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:37.316 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:52:39.033 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x4b, 0x9d
                    2017-05-16 19:52:39.034 Info, Node002, Received SwitchMultiLevel report: level=75
                    2017-05-16 19:52:39.034 Detail, Node002, Refreshed Value: old value=99, new value=75, type=byte
                    2017-05-16 19:52:39.034 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:39.034 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:52:39.053 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:52:39.053 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:52:39.053 Detail, Node002, Refreshed Value: old value=87.8, new value=0.0, type=decimal
                    2017-05-16 19:52:39.054 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:52:39.054 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:53:15.704 Info, Node002, Value::Set - COMMAND_CLASS_CONFIGURATION - Forced Roller Shutter calibration - 29 - 1 - Start calibration process
                    2017-05-16 19:53:15.705 Info, Node002, Configuration::Set - Parameter=29, Value=1 Size=1
                    2017-05-16 19:53:15.705 Detail, Node002, Queuing (Send) ConfigurationCmd_Set (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x70, 0x04, 0x1d, 0x01, 0x01, 0x25, 0x18, 0xb3
                    2017-05-16 19:53:15.705 Info, Node002, Sending (Send) message (Callback ID=0x18, Expected Reply=0x13) - ConfigurationCmd_Set (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x70, 0x04, 0x1d, 0x01, 0x01, 0x25, 0x18, 0xb3
                    2017-05-16 19:53:15.714 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:53:15.715 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:53:15.732 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x18, 0x00, 0x00, 0x02, 0xf1
                    2017-05-16 19:53:15.732 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x18 received (expected 0x18)
                    2017-05-16 19:53:15.732 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:53:15.732 Detail,   Expected callbackId was received
                    2017-05-16 19:53:15.733 Detail,   Expected reply was received
                    2017-05-16 19:53:15.733 Detail,   Message transaction complete
                    2017-05-16 19:53:15.733 Detail, Node002, Removing current message
                    2017-05-16 19:53:16.784 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0x75, 0x9c
                    2017-05-16 19:53:16.784 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=216.5W
                    2017-05-16 19:53:16.784 Detail, Node002, Refreshed Value: old value=0.0, new value=216.5, type=decimal
                    2017-05-16 19:53:16.784 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:53:16.785 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:54:11.816 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x01, 0x26, 0xc6
                    2017-05-16 19:54:11.817 Detail,
                    2017-05-16 19:54:11.817 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=29.4W
                    2017-05-16 19:54:11.817 Detail, Node002, Refreshed Value: old value=216.5, new value=29.4, type=decimal
                    2017-05-16 19:54:11.817 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:54:11.818 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:54:12.835 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0xb2, 0x5b
                    2017-05-16 19:54:12.836 Detail,
                    2017-05-16 19:54:12.836 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=222.6W
                    2017-05-16 19:54:12.836 Detail, Node002, Refreshed Value: old value=29.4, new value=222.6, type=decimal
                    2017-05-16 19:54:12.836 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:54:12.837 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:55:10.938 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x02, 0x52, 0xb1
                    2017-05-16 19:55:10.939 Detail,
                    2017-05-16 19:55:10.939 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=59.4W
                    2017-05-16 19:55:10.939 Detail, Node002, Refreshed Value: old value=222.6, new value=59.4, type=decimal
                    2017-05-16 19:55:10.939 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:55:10.940 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:55:11.958 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0xb4, 0x5d
                    2017-05-16 19:55:11.959 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=222.8W
                    2017-05-16 19:55:11.959 Detail, Node002, Refreshed Value: old value=59.4, new value=222.8, type=decimal
                    2017-05-16 19:55:11.959 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:55:11.959 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:56:08.005 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:56:08.005 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:56:08.006 Detail, Node002, Refreshed Value: old value=222.8, new value=0.0, type=decimal
                    2017-05-16 19:56:08.006 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:56:08.006 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:56:09.284 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0xbd, 0x54
                    2017-05-16 19:56:09.285 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=223.7W
                    2017-05-16 19:56:09.285 Detail, Node002, Refreshed Value: old value=0.0, new value=223.7, type=decimal
                    2017-05-16 19:56:09.285 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:56:09.285 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:56:51.077 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x06, 0xf3, 0x14
                    2017-05-16 19:56:51.077 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=177.9W
                    2017-05-16 19:56:51.078 Detail, Node002, Refreshed Value: old value=223.7, new value=177.9, type=decimal
                    2017-05-16 19:56:51.078 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:56:51.078 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:56:53.025 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:56:53.025 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:56:53.026 Detail, Node002, Refreshed Value: old value=75, new value=26, type=byte
                    2017-05-16 19:56:53.026 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:56:53.026 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:56:53.044 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:56:53.045 Detail,
                    2017-05-16 19:56:53.045 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:56:53.045 Detail, Node002, Refreshed Value: old value=177.9, new value=0.0, type=decimal
                    2017-05-16 19:56:53.045 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:56:53.046 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:40.106 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:57:40.107 Info, Node002, SwitchMultilevel::Set - Setting to level 0
                    2017-05-16 19:57:40.107 Info, Node002,   Duration: Default
                    2017-05-16 19:57:40.107 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x19, 0x05
                    2017-05-16 19:57:40.107 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1a, 0xfe
                    2017-05-16 19:57:40.107 Info, Node002, Sending (Send) message (Callback ID=0x19, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x19, 0x05
                    2017-05-16 19:57:40.117 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:40.117 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:40.133 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x19, 0x00, 0x00, 0x02, 0xf0
                    2017-05-16 19:57:40.133 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x19 received (expected 0x19)
                    2017-05-16 19:57:40.133 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:57:40.134 Detail,   Expected callbackId was received
                    2017-05-16 19:57:40.134 Detail,   Expected reply was received
                    2017-05-16 19:57:40.134 Detail,   Message transaction complete
                    2017-05-16 19:57:40.134 Detail, Node002, Removing current message
                    2017-05-16 19:57:40.134 Info, Node002, Sending (Send) message (Callback ID=0x1a, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1a, 0xfe
                    2017-05-16 19:57:40.142 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:40.143 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:40.159 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1a, 0x00, 0x00, 0x02, 0xf3
                    2017-05-16 19:57:40.159 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1a received (expected 0x1a)
                    2017-05-16 19:57:40.159 Info, Node002, Request RTT 24 Average Request RTT 24
                    2017-05-16 19:57:40.159 Detail,   Expected callbackId was received
                    2017-05-16 19:57:40.169 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:40.170 Info, Node002, Response RTT 35 Average Response RTT 36
                    2017-05-16 19:57:40.170 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:40.170 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:40.170 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:40.170 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:57:40.170 Detail, Node002,   Message transaction complete
                    2017-05-16 19:57:40.170 Detail, Node002, Removing current message
                    2017-05-16 19:57:40.170 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:41.064 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:57:41.064 Info, Node002, SwitchMultilevel::Set - Setting to level 26
                    2017-05-16 19:57:41.064 Info, Node002,   Duration: Default
                    2017-05-16 19:57:41.064 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x1a, 0xff, 0x25, 0x1b, 0x1d
                    2017-05-16 19:57:41.064 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1c, 0xf8
                    2017-05-16 19:57:41.065 Detail,
                    2017-05-16 19:57:41.065 Info, Node002, Sending (Send) message (Callback ID=0x1b, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x1a, 0xff, 0x25, 0x1b, 0x1d
                    2017-05-16 19:57:41.073 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:41.074 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:41.091 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1b, 0x00, 0x00, 0x02, 0xf2
                    2017-05-16 19:57:41.091 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1b received (expected 0x1b)
                    2017-05-16 19:57:41.091 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:57:41.091 Detail,   Expected callbackId was received
                    2017-05-16 19:57:41.092 Detail,   Expected reply was received
                    2017-05-16 19:57:41.092 Detail,   Message transaction complete
                    2017-05-16 19:57:41.092 Detail, Node002, Removing current message
                    2017-05-16 19:57:41.092 Info, Node002, Sending (Send) message (Callback ID=0x1c, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1c, 0xf8
                    2017-05-16 19:57:41.100 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:41.100 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:41.118 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1c, 0x00, 0x00, 0x03, 0xf4
                    2017-05-16 19:57:41.118 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1c received (expected 0x1c)
                    2017-05-16 19:57:41.118 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:57:41.118 Detail,   Expected callbackId was received
                    2017-05-16 19:57:41.128 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:41.128 Info, Node002, Response RTT 35 Average Response RTT 35
                    2017-05-16 19:57:41.128 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:41.128 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:41.128 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:41.128 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:57:41.129 Detail, Node002,   Message transaction complete
                    2017-05-16 19:57:41.129 Detail, Node002, Removing current message
                    2017-05-16 19:57:41.129 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:42.186 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:42.186 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:42.187 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:42.187 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:42.187 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:42.205 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:57:42.206 Detail,
                    2017-05-16 19:57:42.206 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:57:42.206 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:57:42.206 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:42.206 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:47.168 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:57:47.168 Info, Node002, SwitchMultilevel::Set - Setting to level 0
                    2017-05-16 19:57:47.168 Info, Node002,   Duration: Default
                    2017-05-16 19:57:47.168 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x1d, 0x01
                    2017-05-16 19:57:47.168 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1e, 0xfa
                    2017-05-16 19:57:47.169 Detail,
                    2017-05-16 19:57:47.169 Info, Node002, Sending (Send) message (Callback ID=0x1d, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x1d, 0x01
                    2017-05-16 19:57:47.178 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:47.178 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:47.195 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1d, 0x00, 0x00, 0x02, 0xf4
                    2017-05-16 19:57:47.196 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1d received (expected 0x1d)
                    2017-05-16 19:57:47.196 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:57:47.196 Detail,   Expected callbackId was received
                    2017-05-16 19:57:47.196 Detail,   Expected reply was received
                    2017-05-16 19:57:47.196 Detail,   Message transaction complete
                    2017-05-16 19:57:47.196 Detail, Node002, Removing current message
                    2017-05-16 19:57:47.197 Detail,
                    2017-05-16 19:57:47.197 Info, Node002, Sending (Send) message (Callback ID=0x1e, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x1e, 0xfa
                    2017-05-16 19:57:47.205 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:47.206 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:47.222 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1e, 0x00, 0x00, 0x02, 0xf7
                    2017-05-16 19:57:47.222 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1e received (expected 0x1e)
                    2017-05-16 19:57:47.223 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:57:47.223 Detail,   Expected callbackId was received
                    2017-05-16 19:57:47.232 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:47.233 Detail,
                    2017-05-16 19:57:47.233 Info, Node002, Response RTT 35 Average Response RTT 35
                    2017-05-16 19:57:47.233 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:47.233 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:47.233 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:47.234 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:57:47.234 Detail, Node002,   Message transaction complete
                    2017-05-16 19:57:47.234 Detail, Node002, Removing current message
                    2017-05-16 19:57:47.234 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:47.305 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:57:47.306 Info, Node002, SwitchMultilevel::Set - Setting to level 0
                    2017-05-16 19:57:47.306 Info, Node002,   Duration: Default
                    2017-05-16 19:57:47.306 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x1f, 0x03
                    2017-05-16 19:57:47.306 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x20, 0xc4
                    2017-05-16 19:57:47.307 Info, Node002, Sending (Send) message (Callback ID=0x1f, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x1f, 0x03
                    2017-05-16 19:57:47.315 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:47.316 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:47.333 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x1f, 0x00, 0x00, 0x02, 0xf6
                    2017-05-16 19:57:47.333 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x1f received (expected 0x1f)
                    2017-05-16 19:57:47.333 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:57:47.334 Detail,   Expected callbackId was received
                    2017-05-16 19:57:47.334 Detail,   Expected reply was received
                    2017-05-16 19:57:47.334 Detail,   Message transaction complete
                    2017-05-16 19:57:47.334 Detail, Node002, Removing current message
                    2017-05-16 19:57:47.335 Info, Node002, Sending (Send) message (Callback ID=0x20, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x20, 0xc4
                    2017-05-16 19:57:47.343 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:47.343 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:47.360 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x20, 0x00, 0x00, 0x02, 0xc9
                    2017-05-16 19:57:47.360 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x20 received (expected 0x20)
                    2017-05-16 19:57:47.360 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:57:47.360 Detail,   Expected callbackId was received
                    2017-05-16 19:57:47.418 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:47.418 Info, Node002, Response RTT 83 Average Response RTT 59
                    2017-05-16 19:57:47.418 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:47.418 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:47.419 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:47.419 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:57:47.419 Detail, Node002,   Message transaction complete
                    2017-05-16 19:57:47.419 Detail, Node002, Removing current message
                    2017-05-16 19:57:47.419 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:48.309 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:57:48.309 Info, Node002, SwitchMultilevel::Set - Setting to level 26
                    2017-05-16 19:57:48.309 Info, Node002,   Duration: Default
                    2017-05-16 19:57:48.310 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x1a, 0xff, 0x25, 0x21, 0x27
                    2017-05-16 19:57:48.310 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x22, 0xc6
                    2017-05-16 19:57:48.310 Info, Node002, Sending (Send) message (Callback ID=0x21, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x1a, 0xff, 0x25, 0x21, 0x27
                    2017-05-16 19:57:48.319 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:48.319 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:48.336 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x21, 0x00, 0x00, 0x02, 0xc8
                    2017-05-16 19:57:48.336 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x21 received (expected 0x21)
                    2017-05-16 19:57:48.336 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:57:48.337 Detail,   Expected callbackId was received
                    2017-05-16 19:57:48.337 Detail,   Expected reply was received
                    2017-05-16 19:57:48.337 Detail,   Message transaction complete
                    2017-05-16 19:57:48.337 Detail, Node002, Removing current message
                    2017-05-16 19:57:48.337 Info, Node002, Sending (Send) message (Callback ID=0x22, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x22, 0xc6
                    2017-05-16 19:57:48.346 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:48.347 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:48.364 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x22, 0x00, 0x00, 0x02, 0xcb
                    2017-05-16 19:57:48.364 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x22 received (expected 0x22)
                    2017-05-16 19:57:48.364 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:57:48.364 Detail,   Expected callbackId was received
                    2017-05-16 19:57:48.373 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:48.373 Info, Node002, Response RTT 35 Average Response RTT 47
                    2017-05-16 19:57:48.374 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:48.374 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:48.374 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:48.374 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:57:48.374 Detail, Node002,   Message transaction complete
                    2017-05-16 19:57:48.374 Detail, Node002, Removing current message
                    2017-05-16 19:57:48.375 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:49.251 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:49.252 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:49.252 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:49.252 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:49.252 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:49.271 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:57:49.272 Detail,
                    2017-05-16 19:57:49.272 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:57:49.272 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:57:49.273 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:49.273 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:51.710 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:57:51.711 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:57:51.711 Info, Node002,   Direction:          Down
                    2017-05-16 19:57:51.711 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:57:51.711 Info, Node002,   Start Level:        0
                    2017-05-16 19:57:51.711 Info, Node002,   Duration:           255
                    2017-05-16 19:57:51.711 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x23, 0x44
                    2017-05-16 19:57:51.712 Detail,
                    2017-05-16 19:57:51.712 Info, Node002, Sending (Send) message (Callback ID=0x23, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x23, 0x44
                    2017-05-16 19:57:51.721 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:57:51.721 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:57:51.738 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x23, 0x00, 0x00, 0x03, 0xcb
                    2017-05-16 19:57:51.739 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x23 received (expected 0x23)
                    2017-05-16 19:57:51.739 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:57:51.739 Detail,   Expected callbackId was received
                    2017-05-16 19:57:51.739 Detail,   Expected reply was received
                    2017-05-16 19:57:51.739 Detail,   Message transaction complete
                    2017-05-16 19:57:51.740 Detail, Node002, Removing current message
                    2017-05-16 19:57:53.788 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:57:53.788 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:57:53.789 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:57:53.789 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:53.789 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:57:53.806 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:57:53.807 Detail,
                    2017-05-16 19:57:53.807 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:57:53.807 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:57:53.807 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:57:53.808 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:08.418 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:08.419 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:08.419 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:08.419 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:08.419 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:08.419 Info, Node002,   Duration:           255
                    2017-05-16 19:58:08.420 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x24, 0x43
                    2017-05-16 19:58:08.420 Info, Node002, Sending (Send) message (Callback ID=0x24, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x24, 0x43
                    2017-05-16 19:58:08.431 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:08.433 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:08.447 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x24, 0x00, 0x00, 0x03, 0xcc
                    2017-05-16 19:58:08.447 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x24 received (expected 0x24)
                    2017-05-16 19:58:08.447 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:08.448 Detail,   Expected callbackId was received
                    2017-05-16 19:58:08.448 Detail,   Expected reply was received
                    2017-05-16 19:58:08.448 Detail,   Message transaction complete
                    2017-05-16 19:58:08.448 Detail, Node002, Removing current message
                    2017-05-16 19:58:10.492 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:58:10.493 Detail,
                    2017-05-16 19:58:10.493 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:58:10.493 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:58:10.493 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:10.494 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:10.512 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:58:10.513 Detail,
                    2017-05-16 19:58:10.513 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:58:10.513 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:58:10.514 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:10.514 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:13.172 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:13.172 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:13.173 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:13.173 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:13.173 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:13.173 Info, Node002,   Duration:           255
                    2017-05-16 19:58:13.173 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x25, 0x42
                    2017-05-16 19:58:13.174 Info, Node002, Sending (Send) message (Callback ID=0x25, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x25, 0x42
                    2017-05-16 19:58:13.183 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:13.183 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:13.200 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x25, 0x00, 0x00, 0x02, 0xcc
                    2017-05-16 19:58:13.201 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x25 received (expected 0x25)
                    2017-05-16 19:58:13.201 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:13.201 Detail,   Expected callbackId was received
                    2017-05-16 19:58:13.201 Detail,   Expected reply was received
                    2017-05-16 19:58:13.201 Detail,   Message transaction complete
                    2017-05-16 19:58:13.202 Detail, Node002, Removing current message
                    2017-05-16 19:58:14.611 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:14.611 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:14.611 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:14.612 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:14.612 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:14.612 Info, Node002,   Duration:           255
                    2017-05-16 19:58:14.612 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x26, 0x41
                    2017-05-16 19:58:14.613 Info, Node002, Sending (Send) message (Callback ID=0x26, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x26, 0x41
                    2017-05-16 19:58:14.622 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:14.622 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:14.639 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x26, 0x00, 0x00, 0x03, 0xce
                    2017-05-16 19:58:14.639 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x26 received (expected 0x26)
                    2017-05-16 19:58:14.639 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:14.639 Detail,   Expected callbackId was received
                    2017-05-16 19:58:14.640 Detail,   Expected reply was received
                    2017-05-16 19:58:14.640 Detail,   Message transaction complete
                    2017-05-16 19:58:14.640 Detail, Node002, Removing current message
                    2017-05-16 19:58:16.416 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:16.417 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:16.417 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:16.417 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:16.417 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:16.417 Info, Node002,   Duration:           255
                    2017-05-16 19:58:16.417 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x27, 0x40
                    2017-05-16 19:58:16.418 Detail,
                    2017-05-16 19:58:16.418 Info, Node002, Sending (Send) message (Callback ID=0x27, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x27, 0x40
                    2017-05-16 19:58:16.428 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:16.430 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:16.444 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x27, 0x00, 0x00, 0x02, 0xce
                    2017-05-16 19:58:16.445 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x27 received (expected 0x27)
                    2017-05-16 19:58:16.445 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:16.445 Detail,   Expected callbackId was received
                    2017-05-16 19:58:16.445 Detail,   Expected reply was received
                    2017-05-16 19:58:16.445 Detail,   Message transaction complete
                    2017-05-16 19:58:16.446 Detail, Node002, Removing current message
                    2017-05-16 19:58:18.506 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x1a, 0xcc
                    2017-05-16 19:58:18.507 Detail,
                    2017-05-16 19:58:18.507 Info, Node002, Received SwitchMultiLevel report: level=26
                    2017-05-16 19:58:18.507 Detail, Node002, Refreshed Value: old value=26, new value=26, type=byte
                    2017-05-16 19:58:18.507 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:18.508 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:18.526 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:58:18.527 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:58:18.527 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:58:18.527 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:18.527 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:24.469 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:24.469 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:24.469 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:24.470 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:24.470 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:24.470 Info, Node002,   Duration:           255
                    2017-05-16 19:58:24.470 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x28, 0x4f
                    2017-05-16 19:58:24.471 Info, Node002, Sending (Send) message (Callback ID=0x28, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x28, 0x4f
                    2017-05-16 19:58:24.480 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:24.480 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:24.497 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x28, 0x00, 0x00, 0x03, 0xc0
                    2017-05-16 19:58:24.498 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x28 received (expected 0x28)
                    2017-05-16 19:58:24.498 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:24.498 Detail,   Expected callbackId was received
                    2017-05-16 19:58:24.498 Detail,   Expected reply was received
                    2017-05-16 19:58:24.498 Detail,   Message transaction complete
                    2017-05-16 19:58:24.498 Detail, Node002, Removing current message
                    2017-05-16 19:58:25.649 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0xad, 0x44
                    2017-05-16 19:58:25.650 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=222.1W
                    2017-05-16 19:58:25.650 Detail, Node002, Refreshed Value: old value=0.0, new value=222.1, type=decimal
                    2017-05-16 19:58:25.650 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:25.650 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:27.045 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:27.045 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:27.045 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:27.045 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:27.045 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:27.045 Info, Node002,   Duration:           255
                    2017-05-16 19:58:27.046 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x29, 0x4e
                    2017-05-16 19:58:27.046 Info, Node002, Sending (Send) message (Callback ID=0x29, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x29, 0x4e
                    2017-05-16 19:58:27.055 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:27.056 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:27.073 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x29, 0x00, 0x00, 0x02, 0xc0
                    2017-05-16 19:58:27.073 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x29 received (expected 0x29)
                    2017-05-16 19:58:27.074 Info, Node002, Request RTT 26 Average Request RTT 25
                    2017-05-16 19:58:27.074 Detail,   Expected callbackId was received
                    2017-05-16 19:58:27.074 Detail,   Expected reply was received
                    2017-05-16 19:58:27.074 Detail,   Message transaction complete
                    2017-05-16 19:58:27.074 Detail, Node002, Removing current message
                    2017-05-16 19:58:28.947 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dec - 8 - 1 - true
                    2017-05-16 19:58:28.948 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:28.948 Info, Node002,   Direction:          Dec
                    2017-05-16 19:58:28.948 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:28.948 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:28.948 Info, Node002,   Duration:           255
                    2017-05-16 19:58:28.948 Info, Node002,   Step Size:          1
                    2017-05-16 19:58:28.948 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0d, 0x00, 0x13, 0x02, 0x06, 0x26, 0x04, 0xe8, 0x00, 0xff, 0x01, 0x25, 0x2a, 0xde
                    2017-05-16 19:58:28.949 Detail,
                    2017-05-16 19:58:28.949 Info, Node002, Sending (Send) message (Callback ID=0x2a, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0d, 0x00, 0x13, 0x02, 0x06, 0x26, 0x04, 0xe8, 0x00, 0xff, 0x01, 0x25, 0x2a, 0xde
                    2017-05-16 19:58:28.959 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:28.959 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:28.976 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x2a, 0x00, 0x00, 0x02, 0xc3
                    2017-05-16 19:58:28.976 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x2a received (expected 0x2a)
                    2017-05-16 19:58:28.977 Info, Node002, Request RTT 27 Average Request RTT 26
                    2017-05-16 19:58:28.977 Detail,   Expected callbackId was received
                    2017-05-16 19:58:28.977 Detail,   Expected reply was received
                    2017-05-16 19:58:28.977 Detail,   Message transaction complete
                    2017-05-16 19:58:28.977 Detail, Node002, Removing current message
                    2017-05-16 19:58:40.500 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
                    2017-05-16 19:58:40.500 Info, Node002, SwitchMultilevel::StartLevelChange - Starting a level change
                    2017-05-16 19:58:40.501 Info, Node002,   Direction:          Down
                    2017-05-16 19:58:40.501 Info, Node002,   Ignore Start Level: True
                    2017-05-16 19:58:40.501 Info, Node002,   Start Level:        0
                    2017-05-16 19:58:40.501 Info, Node002,   Duration:           255
                    2017-05-16 19:58:40.501 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x2b, 0x4c
                    2017-05-16 19:58:40.502 Info, Node002, Sending (Send) message (Callback ID=0x2b, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=2): 0x01, 0x0c, 0x00, 0x13, 0x02, 0x05, 0x26, 0x04, 0x78, 0x00, 0xff, 0x25, 0x2b, 0x4c
                    2017-05-16 19:58:40.510 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:40.511 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:40.528 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x2b, 0x00, 0x00, 0x03, 0xc3
                    2017-05-16 19:58:40.528 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x2b received (expected 0x2b)
                    2017-05-16 19:58:40.529 Info, Node002, Request RTT 26 Average Request RTT 26
                    2017-05-16 19:58:40.529 Detail,   Expected callbackId was received
                    2017-05-16 19:58:40.529 Detail,   Expected reply was received
                    2017-05-16 19:58:40.529 Detail,   Message transaction complete
                    2017-05-16 19:58:40.529 Detail, Node002, Removing current message
                    2017-05-16 19:58:40.937 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:58:40.938 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:58:40.938 Detail, Node002, Refreshed Value: old value=222.1, new value=0.0, type=decimal
                    2017-05-16 19:58:40.938 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:40.938 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:42.295 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x00, 0xd6
                    2017-05-16 19:58:42.296 Info, Node002, Received SwitchMultiLevel report: level=0
                    2017-05-16 19:58:42.296 Detail, Node002, Refreshed Value: old value=26, new value=0, type=byte
                    2017-05-16 19:58:42.296 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:42.296 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:42.315 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:58:42.316 Detail,
                    2017-05-16 19:58:42.316 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:58:42.316 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:58:42.316 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:42.317 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:42.342 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
                    2017-05-16 19:58:42.342 Info, Node002, SwitchMultilevel::Set - Setting to level 0
                    2017-05-16 19:58:42.343 Info, Node002,   Duration: Default
                    2017-05-16 19:58:42.343 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x2c, 0x30
                    2017-05-16 19:58:42.343 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xc9
                    2017-05-16 19:58:42.344 Info, Node002, Sending (Send) message (Callback ID=0x2c, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0x00, 0xff, 0x25, 0x2c, 0x30
                    2017-05-16 19:58:42.352 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:42.352 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:42.370 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x02, 0xc5
                    2017-05-16 19:58:42.370 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
                    2017-05-16 19:58:42.370 Info, Node002, Request RTT 26 Average Request RTT 26
                    2017-05-16 19:58:42.370 Detail,   Expected callbackId was received
                    2017-05-16 19:58:42.370 Detail,   Expected reply was received
                    2017-05-16 19:58:42.370 Detail,   Message transaction complete
                    2017-05-16 19:58:42.371 Detail,
                    2017-05-16 19:58:42.371 Detail, Node002, Removing current message
                    2017-05-16 19:58:42.371 Info, Node002, Sending (Send) message (Callback ID=0x2d, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xc9
                    2017-05-16 19:58:42.380 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                    2017-05-16 19:58:42.380 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
                    2017-05-16 19:58:42.396 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x03, 0xc5
                    2017-05-16 19:58:42.397 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
                    2017-05-16 19:58:42.397 Info, Node002, Request RTT 25 Average Request RTT 25
                    2017-05-16 19:58:42.397 Detail,   Expected callbackId was received
                    2017-05-16 19:58:42.407 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x00, 0xd6
                    2017-05-16 19:58:42.407 Info, Node002, Response RTT 35 Average Response RTT 41
                    2017-05-16 19:58:42.407 Info, Node002, Received SwitchMultiLevel report: level=0
                    2017-05-16 19:58:42.407 Detail, Node002, Refreshed Value: old value=0, new value=0, type=byte
                    2017-05-16 19:58:42.407 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:42.407 Detail, Node002,   Expected reply and command class was received
                    2017-05-16 19:58:42.408 Detail, Node002,   Message transaction complete
                    2017-05-16 19:58:42.408 Detail, Node002, Removing current message
                    2017-05-16 19:58:42.408 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:44.425 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x00, 0xd6
                    2017-05-16 19:58:44.425 Info, Node002, Received SwitchMultiLevel report: level=0
                    2017-05-16 19:58:44.425 Detail, Node002, Refreshed Value: old value=0, new value=0, type=byte
                    2017-05-16 19:58:44.425 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:44.426 Detail, Node002, Notification: ValueChanged
                    2017-05-16 19:58:44.444 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe1
                    2017-05-16 19:58:44.444 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=0.0W
                    2017-05-16 19:58:44.445 Detail, Node002, Refreshed Value: old value=0.0, new value=0.0, type=decimal
                    2017-05-16 19:58:44.445 Detail, Node002, Changes to this value are not verified
                    2017-05-16 19:58:44.445 Detail, Node002, Notification: ValueChanged
                    • AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      Ich sehe ab und zu, dass der Rolladen auf 26 bzw. 0 gestellt wird und dies vom Gerät auch bestätigt wurde.
                      Ansonsten nichts auffälliges :|
                      • N Offline
                        N Offline
                        nsession
                        Die Markiese tut nur nicht was sie soll.
                        Wenn ich über das Vis den Value wert ändere oder aber in den Objekten selbst fährt die MArkiese einmal an und stopt direkt wieder und der wert ändert sich um 1
                        beispiel:
                        Objekt Level steht bei 25
                        ich schreibe 0 rein und bestätige mit dem häkchen
                        markiese klackt und stopt wieder wert in den Objekten dann auf 24
                        Open und Close funktionieren.
                          AlCalzoneA Offline
                          AlCalzone
                          Klapp mal den CONFIGURATION-Ordner auf und mach nen Screenshot. Nicht dass da eine Geräteeinstellung dazwischen funkt.
                          • N Offline
                            N Offline
                            nsession
                            Hallo hier mal der Screenshot.
                              AlCalzoneA Offline
                              AlCalzone
                              Ich sehe nichts auffälliges, tut mir leid. Vielleicht kann ja der Hersteller weiterhelfen.
